Page 19 of 21
Re: Python plugin: Modbus RTU / ASCII / TCP/IP
Posted: Wednesday 05 July 2023 19:05
by simat
marcin81233 wrote: Sunday 11 June 2023 12:33
simat wrote: Sunday 07 May 2023 9:57 Is your inverter Modbus RTU or Modbus TCP ?
Someone suggested that the Deye Inverter is the same as Sol-Ark ?
Either way the Modbus RTU/ASCI/TCP plugin mentioned in this thread should do the trick without modification, you just need to know the modbus slave ID, register address and data type for starters.
I'm a novice in such matters. Could you write what I should enter in the appropriate fields in domoticz from this frame?
Looking at your easy to read pdf, try 053 in the register box, and the modbus ID and rate in the ID:PollingRate box.
Posted: Wednesday 05 July 2023 19:06
by simat
PieterS wrote: Tuesday 04 July 2023 21:38
Alain wrote: Saturday 08 April 2023 8:59 Yes, 2021.1 was the last working version. I had the above issues too and although I looked into it to try and find out why this was happening, I just decided to run a 2021.1 version of Domoticz. In my case this is possible because I run this plugin on a dedicated remote server. It doesn't influence the running of any other plugins of which you want the latest versions.
I investigate the posibility of buying a kWh-meter with Modbus. Especialy a Eastron SDM 630 V2. Goal is to read how much energy is loaded into my EV. But reading this thread it seems not that easy with Domoticz.
@Alain:
Can you explain how you configure it to run the plugin on a remote server?
How do you export the results of the measurements to Domoticz?
I am very interested. Thanks in advance.
https://www.domoticz.com/wiki/Setting_up_Device_sharing
Posted: Wednesday 05 July 2023 19:40
by PieterS
@Simat: Thanks for the hint.
I am familiar with the Master/Slave principle. I used it before. Master on the Syno in a virtual machine (Docker) and the slave on a Pi. I did not think of this solution, but it might work! :o
Studied your link to the Wiki. But there is one restriction in there:
You have, for example, 3 machines or controllers or RaspberryPis with Domoticz. All software should be at the latest version and all main and remotes must be running the same version.
I read Alain used an older version for running the Python-script because the latest version of Domoticz is running scripts simultaniously. But I will try it. With different versions.. Maybe it does the job. Thanks!
Posted: Wednesday 05 July 2023 20:50
by PieterS
Hi Domoberry,
Lots of information and as I read about what data the DDS024MR exposes, it should be sufficient for me. But I didn't found a shop in the Netherlands where I can buy one. I will not buy such a kWh-meter in cheap countries for my own safety.
Do you think your version is working on the Eastron SDM630 V2 or any other meter with a Modbus-interface?
Read your link https://github.com/domoticz/domoticz/issues/5671 and maybe the suggestion of simat to use a master/slave workaround will do the job for me.
Thanks for your help anyway.
Posted: Wednesday 05 July 2023 22:57
by Domoberry
Hi PieterS,
My plugin will not work out-of-the-box with the SDM630. However, since my plugin was forked from the SDM630, it should be possible by updating some parameters. However, Mr. Murphy typically exists in these cases.
You would need to compare both plugins; they have the same structure. A quick scan on the key differences: different default Modbus slave address, different parity, different register addresses for the various parameters. Updating the latter two requires some value changes in the plugin itself. Next to that, there are obviously several textual references to 'DDS024MR'. Perhaps it is easier to revive the SDM630 plugin.
Alternatively, the plugin from DomoticX is likely to work, but you will only be able to retrieve one value without any changes to the plugin.
Posted: Thursday 06 July 2023 9:40
by simat
What about using something like ESPEasy to post straight into Domoticz
and btw, the plugin I published had been updated to handle the parallel running of multiple scripts in the later versions of Domoticz to avoid comms problems. Although if you only have one Modbus device you'll have no problems as there won't be multiple calls.
Posted: Thursday 06 July 2023 12:03
by PieterS
simat wrote: Thursday 06 July 2023 9:40 What about using something like ESPEasy to post straight into Domoticz
Thanks for your additional info! I will have one Modbus device. But what if I use a three fase kWh-meter like the Eastron SDM630 instead of your single fase?
I will keep the way of ESPEasy in mind. Ik use that method for reading my gasmeter and PV. But they read just S0-pulses in my case.
Posted: Thursday 06 July 2023 12:04
by PieterS
Domoberry wrote: Wednesday 05 July 2023 22:57 Hi PieterS,
Thanks for adding more info. I will think about it.
Posted: Tuesday 11 July 2023 19:25
by marcin81233
Po dodaniu 4 czujnika zaczyna zgłaszać błędy.
Posted: Friday 14 July 2023 11:44
by Aziona
I use the plugin with and Eastron SDM220 kwh meter. The value of the total active energy is 52520.4765625 Kwh but it shows as "0, 52520.4765625". How can I remove the "0, " from the value? I tried all data types but nothing seems to work.
RTU/9600/1/8/N
Register number 74
Data Type FLOAT 32-bit
It might be the ByteSize but changing that does not work.
Posted: Sunday 23 July 2023 23:30
by PieterS
simat wrote: Monday 24 April 2023 21:11 Updated and tested plugin now available on
https://github.com/simat-git/SDM120-Modbus
Works with Domoticz 2023.1, now just takes a few minutes to initially allocate each instance to its own timeslot, will also recover from bus disconnection and re-time itself. The previous plugin would error until manual intervention / reset.
@simat:
I bought a SDM630-Modbus V2 together with a USB to RS485 Adapter - CH340 and installed your SDM120-Modbus software on a Raspberry Pi 4 - 4GB. The OS: Raspbian GNU/Linux 11 (bullseye), Python 3.9.2.
On the Py I installed Domoticz Version: 2023.2 (build 15459)
In Hardware I selected the
Modbus Port: /dev/ttyUSB0
Baud rate: 9600
Device ID: 1
Reading Interval min: 1
Debug: True
This is part of the log:
 2023-07-23 22:51:32.326 Status: SDM120-Modbus Simat: Entering work loop.
2023-07-23 22:51:32.326 Status: SDM120-Modbus Simat: Started.
2023-07-23 22:51:32.499 Status: SDM120-Modbus Simat: Initialized version 2, author 'simat-git'
2023-07-23 22:58:42.394 SDM120-Modbus Simat: Total kwh: 52.264 kWh
2023-07-23 22:58:42.395 SDM120-Modbus Simat: Voltage: 228.340 V
2023-07-23 22:58:42.395 SDM120-Modbus Simat: Import power: 0.000 W
2023-07-23 22:58:42.395 SDM120-Modbus Simat: Export power: 0.000 W
2023-07-23 22:59:42.412 SDM120-Modbus Simat: SDM120M Modbus Data
2023-07-23 22:59:42.412 SDM120-Modbus Simat: Total system power: 0.000 W
2023-07-23 22:59:42.412 SDM120-Modbus Simat: Import Wh: 0.000 kWh
2023-07-23 22:59:42.412 SDM120-Modbus Simat: Export Wh: 52.264 kWh
2023-07-23 22:59:42.412 SDM120-Modbus Simat: Total kwh: 52.264 kWh
2023-07-23 22:59:42.412 SDM120-Modbus Simat: Voltage: 228.530 V
The results are hopefull because a part the output of the meter to Domoticz is the same as on the display of the meter. And no errors at all!
When I start loading the EV the information is updated in Domoticz. But it is only a small part of all the results the meter is calculating.
The SDM630 is a 3-fase meter and now I only get the total value and the Voltage of L1.. Should be nice to get all info from the meter.
Can you explain how to edit the file(s) to get all output from the SDM630 to Domoticz?
Thanks in advance. Best regards,
Pieter
Posted: Monday 24 July 2023 17:20
by PieterS
As I own a SDM630 Modbus 3Fase-meter I wanted to extend the SDM120-plugin from @simat with some values. A lot of trial and error... But there is some progress.. 8-)
  2023-07-24 17:19:32.487 SDM630: Worker thread started.
2023-07-24 17:19:32.670 SDM630: SDM120M Modbus plugin start
2023-07-24 17:19:32.487 Status: SDM630: Entering work loop.
2023-07-24 17:19:32.487 Status: SDM630: Started.
2023-07-24 17:19:32.667 Status: SDM630: Initialized version 2, author 'simat-git'
2023-07-24 17:19:42.667 SDM630: SDM630 Modbus Data
2023-07-24 17:19:42.667 SDM630: Total system power: -1150.726 W
2023-07-24 17:19:42.667 SDM630: Import Wh: 0.000 kWh
2023-07-24 17:19:42.667 SDM630: Export Wh: 56.092 kWh
2023-07-24 17:19:42.667 SDM630: Total kwh: 56.092 kWh
2023-07-24 17:19:42.667 SDM630: Import power: 0.000 W
2023-07-24 17:19:42.667 SDM630: Export power: 0.000 W
2023-07-24 17:19:42.667 SDM630: Voltage L1: 230.010 V
2023-07-24 17:19:42.667 SDM630: Voltage L2: 228.774 V
2023-07-24 17:19:42.667 SDM630: Voltage L3: 229.036 V
2023-07-24 17:19:42.667 SDM630: Current L1: 5.005 A
2023-07-24 17:19:42.667 SDM630: Current L2: 4.985 A
2023-07-24 17:19:42.667 SDM630: Current L3: 4.983 A
I keep you informed.
Posted: Thursday 27 July 2023 12:35
by PieterS
A small update...
As I am a noob with Python language.. I got lost about the command
Devices[2].Update(0,str(Total_kWh))
Environment:
I changed the SDM120-Modbus software
Python 3.9.2.
I prefer in the GUI a device with the type of Managed Counter. Or General, kWh. It should show a bar for every different day. A line graph is less readable...
But not the results I expected.
So I tried 3 different sort of devices from the list in the Wiki: https://www.domoticz.com/wiki/Developin ... vice_Types
But not always input from the plugin to the devic in Domoticz :roll:
The device with IDX 1, SubType kWh, is updated but has no data in graph.
The device with IDX 2, custom sensor, is updated and had data in graph.
The device with IDX 3, Managed Counter, is not updated
This is my script: Original authors still readable ;)
#!/usr/bin/env python
Eastron SDM120-Modbus Smart Meter Single Phase Electrical System. The Python plugin for Domoticz
Original Author: MFxMF and bbossink and remcovanvugt
Better Error handling and event recovery added by simat-git 2023.
Edited by PieterS for Eastron SDM630
Works with Eastron SDM120M / SDM120CT-M, can be easily adapted to any Modbus meter.
Requirements:
    1.python module minimalmodbus -> http://minimalmodbus.readthedocs.io/en/master/
        (pi@raspberrypi:~$ sudo pip3 install minimalmodbus)
    2.Communication module Modbus USB to RS485 converter module
<plugin key="SDM630-Pieter" name="SDM630" version="2" author="simat-git">
    <params>
        <param field="SerialPort" label="Modbus Port" width="200px" required="true" default="/dev/ttyUSB0" />
        <param field="Mode1" label="Baud rate" width="40px" required="true" default="9600"  />
        <param field="Mode2" label="Device ID" width="40px" required="true" default="1" />
        <param field="Mode3" label="Reading Interval min." width="40px" required="true" default="1" />
        <param field="Mode6" label="Debug" width="75px">
            <options>
                <option label="True" value="Debug"/>
                <option label="False" value="Normal"  default="true" />
            </options>
        </param>
    </params>
</plugin>
import minimalmodbus    #v2.0.1
#import serial          #minimalmodbus imports this now.
import Domoticz         #tested on Python 3.9.2 in Domoticz 2023.2
class BasePlugin:
    def __init__(self):
        self.runInterval = 1
        self.rs485 = ""
        return
    def onStart(self):
        devicecreated = []
        Domoticz.Log("SDM630 Pieter plugin start")
        self.runInterval = int(Parameters["Mode3"]) * 1
        if 2 not in Devices:
            Domoticz.Device(Name="Total kWh Unit2", Unit=2,TypeName="General",Subtype=29,Used=0).Create()  #Subtype Name:kWh, TypeName:kWh, Electric (Instant+Counter)
        Options = { "Custom" : "1;kWh"}
        if 3 not in Devices:
            Domoticz.Device(Name="Total kWh Unit3", Unit=3,TypeName="Custom",Used=0,Options=Options).Create()
        Options = { "Custom" : "1;kVArh"}
        if 4 not in Devices:
            Domoticz.Device(Name="Total kWh Unit4", Unit=4,TypeName="General",Subtype=33,Used=0).Create()
    def onStop(self):
        Domoticz.Log("SDM630 plugin stop")
    def onHeartbeat(self):
        self.runInterval -=1;
        if self.runInterval <= 0:
            Total_System_Power = 0  #  Declare these to keep the debug section at the bottom from complaining. 1
            Import_Wh = 0                                          # Var 2
#            Export_Wh = 0                                          # Var 3
            Total_kWh = 0   #Fix door Pieter: kwh naar kWh    Var 4
            # Get data from SDM630
            try:
                 self.rs485 = minimalmodbus.Instrument(Parameters["SerialPort"], int(Parameters["Mode2"]))
                 #class minimalmodbus.Instrument(port: str, slaveaddress: int, mode: str = 'rtu', close_port_after_each_call: bool = False, debug: bool = False)
                 self.rs485.serial.baudrate = Parameters["Mode1"]
                 self.rs485.serial.bytesize = 8
                 self.rs485.serial.parity = minimalmodbus.serial.PARITY_NONE
                 self.rs485.serial.stopbits = 1
                 self.rs485.serial.timeout = 1
                 self.rs485.serial.exclusive = True # Fix From Forum Member 'lost'
                 self.rs485.debug = False
                 self.rs485.mode = minimalmodbus.MODE_RTU
                 self.rs485.close_port_after_each_call = True
                 Total_kWh = self.rs485.read_float(342, 4, 2)
                 #self.rs485.read_float(register, functioncode, numberOfRegisters)
                 self.rs485.serial.close()  #  Close that door !
            except:
                Domoticz.Heartbeat(1)   # set Heartbeat to 1 second to get us back here for quick retry.
                self.runInterval = 1    # call again in 1 second
                Domoticz.Log("**** SDM120M Connection problem ****");
            else:
                #Update devices
                Devices[3].Update(0,str(Total_kWh))
                Devices[4].Update(0,str(Total_kWh))
                self.runInterval = int(Parameters["Mode3"]) * 6 # Success so call again in 60 seconds.
                Domoticz.Heartbeat(10)  # Sucesss so set Heartbeat to 10 second intervals.
            if Parameters["Mode6"] == 'Debug':
                Domoticz.Log("SDM630 Modbus Data")
                Domoticz.Log('Total kWh: {0:.3f} kWh'.format(Total_kWh))
            #self.runInterval = int(Parameters["Mode3"]) * 6
global _plugin
_plugin = BasePlugin()
def onStart():
    global _plugin
    _plugin.onStart()
def onStop():
    global _plugin
    _plugin.onStop()
def onHeartbeat():
    global _plugin
    _plugin.onHeartbeat()
# Generic helper functions
def DumpConfigToLog():
    for x in Parameters:
        if Parameters[x] != "":
            Domoticz.Debug("'" + x + "':'" + str(Parameters[x]) + "'")
    Domoticz.Debug("Device count: " + str(len(Devices)))
    for x in Devices:
        Domoticz.Debug("Device:           " + str(x) + " - " + str(Devices[x]))
        Domoticz.Debug("Device ID:       '" + str(Devices[x].ID) + "'")
        Domoticz.Debug("Device Name:     '" + Devices[x].Name + "'")
        Domoticz.Debug("Device nValue:    " + str(Devices[x].nValue))
        Domoticz.Debug("Device sValue:   '" + Devices[x].sValue + "'")
        Domoticz.Debug("Device LastLevel: " + str(Devices[x].LastLevel))
    return
In my opinion it has to do with the command
#Update devices
I do not understand what is wrong. :oops: 3 different devicetypes, 1 command should do the job? No errors in the logfile of Domoticz.
 2023-07-27 12:27:00.495 SDM630: Worker thread started.
2023-07-27 12:27:00.682 SDM630: SDM630 Pieter plugin start
2023-07-27 12:27:00.495 Status: SDM630: Entering work loop.
2023-07-27 12:27:00.495 Status: SDM630: Started.
2023-07-27 12:27:00.680 Status: SDM630: Initialized version 3, author 'PieterS'
2023-07-27 12:27:10.168 SDM630: SDM630 Modbus Data
2023-07-27 12:27:10.168 SDM630: Total kWh: 81.025 kWh
2023-07-27 12:28:10.160 SDM630: SDM630 Modbus Data
2023-07-27 12:28:10.160 SDM630: Total kWh: 81.083 kWh
2023-07-27 12:29:10.156 SDM630: SDM630 Modbus Data
2023-07-27 12:29:10.156 SDM630: Total kWh: 81.142 kWh
2023-07-27 12:30:10.149 SDM630: SDM630 Modbus Data
2023-07-27 12:30:10.149 SDM630: Total kWh: 81.201 kWh
2023-07-27 12:31:10.145 SDM630: SDM630 Modbus Data
2023-07-27 12:31:10.145 SDM630: Total kWh: 81.258 kWh
Any help appreciated. Did not find info on the wiki about the syntax how update a device.. :oops:
Thnx in advance!
Posted: Monday 14 August 2023 11:44
by simat
@Pieter, did you get your SDM630 working ?
Posted: Tuesday 15 August 2023 9:04
by PieterS
simat wrote: Monday 14 August 2023 11:44 @Pieter, did you get your SDM630 working ?
Some devices yes. But strugling with how to get the right graphics for energy. I want bars, no lines. No idea how to create a virtual device RFXMeter with RFXMeter counter. :?
But that's for next weekend.
Posted: Tuesday 15 August 2023 9:32
PieterS wrote: Tuesday 15 August 2023 9:04
Check https://www.domoticz.com/wiki/Dummy_for ... es#Counter
But better to use Electricity (instant and counter) https://www.domoticz.com/wiki/Dummy_for ... counter.29
Watts (usage) are reported in lines, Wh or kWh (used or generated energy) are reported in bars. No way to change this.
Posted: Tuesday 15 August 2023 9:33
by simat
In my plugin, its the line
Devices[2].Update(0,str(Total_System_Power)+";"+str(Import_Wh*1000))
That puts 2 values to display, the kWh and the current Watts load.
Total_kWh = self.rs485.read_float(342, 4, 2) is only going to pull out the kWh reading and not the current load. Sorry i didn't have time to read the whole post, is that what you where after ?
Posted: Tuesday 15 August 2023 9:44
by simat
Like this ?
Its type 243 - Domoticz.Device(Name="Import Wh", Unit=2,Type=243,Subtype=29,Used=0).Create()
Posted: Friday 18 August 2023 15:19
by PieterS
[/quote]
[/quote]
@waltervl: thanks for hint.
I checked and created a new virtual device you suggested (Instant and Counter). But that has no indicator of measurement in the top. Did I do something wrong?
Second case:
I want to send data by MQTT to that virtual device. It arrives, but it does not seem to represented..
This is the info that passes by in MQTT Explorer:
{"command":"udevice","idx":76,"nvalue":0,"svalue":"152.36"}
This is in Domoticz..
Running Domoticz Build 15459..
Any idea what's wrong?
Posted: Friday 18 August 2023 15:56
It needs 2 sValues: POWER;ENERGY
POWER = current power (Watt)
ENERGY = total (lifetime) cumulative energy counter in Watt-hours (Wh).
{"command":"udevice","idx":76,"nvalue":0,"svalue":"152;12345678"}
