Controlicz - Domoticz to Google Home/Assistant integration Topic is solved
Alexa, Google Home and Siri
Madgeni
Re: Controlicz - Domoticz to Google Home/Assistant integration
Post by Madgeni »
ok, that isn't a Controlicz issue - I had the same right at the start
try this?
https://www.techwalls.com/home-control- ... -home-app/
fergalom
Post by fergalom »
try this?
That was it, thanks!! Bloody hell that was well hidden if you dont have a google home device
Madgeni
Post by Madgeni »
Yep, it's a pain! Still, once you've enabled Controlicz, Home Control stays in your menu
nounours0000
Post by nounours0000 »
Hi Madgeni,
I just registered, can you please tes beta program controlicz.
My email perr****@gmail.com
Thank you !
holybob
Post by holybob »
Please can you add me to the beta program. My Google account is Gavin@se***.com
lrachet
Post by lrachet »
Hi Madgeni, Could you please add me too - my e-mail: lrachet****@gmail.com
Thank you !
DewGew
Domoticz version: V4.10618
Post by DewGew »
I can't link my account in home control. it says " couldn´t update setting. check your connection".
Any ideas?
Madgeni
Post by Madgeni »
DewGew wrote: Wednesday 20 December 2017 13:30 I can't link my account in home control. it says " couldn´t update setting. check your connection".
Any ideas?
Hi there
if you go into your Profile on Controlicz, you'll find the new improved 'test connection' button - this will verify that Controlicz has access to your Domoticz instance? If this fails, check you can access your Domoticz via HTTPS from an external source, and that the uid/pwd you've specified work.
Madgeni
Post by Madgeni »
ticranou wrote: Friday 15 December 2017 17:14 no problem ;-)
well... with a colleague, we made a test within his Controlicz account. His connection test also uses the getVersion request, but he has a user specified in the log related to the request. But I don't... ???
Hi there -
i've re-written the test functionality, should be robust now - care to try again?
DewGew
Post by DewGew »
Madgeni wrote: Wednesday 20 December 2017 13:48
Any ideas?
Hi there
The test is ok. I have connection. json call works also in my browser. Seems to be something on google. I manage to link yesterday and I had some problems then i unlinked it today and now I can't link it back.
EDIT: Never mind. it linked back now for some reason :?
Last edited by DewGew on Wednesday 20 December 2017 14:05, edited 1 time in total.
Madgeni
Post by Madgeni »
urgh - stupid Google, and their stupid app. I've not found a clean way of fixing this, all I can suggest is clearing app cache, force stopping and keep trying - sorry!
DewGew
Post by DewGew »
Madgeni wrote: Wednesday 20 December 2017 14:04 urgh - stupid Google, and their stupid app. I've not found a clean way of fixing this, all I can suggest is clearing app cache, force stopping and keep trying - sorry!
Madgeni
Post by Madgeni »
good and bad i guess!
nairolFlo
Post by nairolFlo »
Hi Madgeni,
I just registered to Controlicz.
Could you please add me in your beta program.
My email is flo***********@gmail.com
Thanks in advance,
waow29
Post by waow29 »
Hi Madgeni,
I register on Controlicz the 05/12/17, my email is [email protected]
Could you add me please?
bldewit
Domoticz version: Stable
Post by bldewit »
Hi Madgeni,
It's working better and better for me. There is however one thing: if I want my shutteres closed, I have to say "open shutters" and vice versa. On and Off works fine by the way, where On equals Close I can of course add dummy buttons to reverse this, but that would not be my preferred option. Do you know of a solution to reverse these commands within Google (or domoticz perhaps)?
Thx!
Running on rPi 3b (main) and rPi 2b (somfy), both RFLink
IthoRemote, Xiaomi Gateway, KAKU
wimfabries
Post by wimfabries »
Hi Madgeni,
Great work. Can you add me for google-beta, my adress is wim***@cas****.**
Wim
miremi
Post by miremi »
Hi Madgeni
Can you add my account e.mi*******[email protected]
Thank you!
Ubuntu 16.04.3, Core i5 8GB RAM 120GB SSD, RFlink, ESPeasy, Z-Stick Gen5, 8 FIbaro, 17 Neo Coolcam
deennoo
Post by deennoo »
Hello Madgeni.
Can see, controlicz on m'y Home contrôle.
Have you remove m'y account ?
[email protected]
http://domo-attitude.fr
Madgeni
Post by Madgeni »
bldewit wrote: Thursday 21 December 2017 0:05 Hi Madgeni,
Thx!
hah - that is annoying. Not sure I can do much to it, because if i inverted it, then no doubt, it would be the other way for someone else!
