Dashticz - Module - Garbage collector Topic is solved
aiolos
Domoticz version: stable
Re: Dashticz - Module - Garbage collector
Post by aiolos »
I added a PR for 'Gemeente Venlo'.
'Restafval' and 'PMD' show up under the 'PMD' type, because in the calendar they are sort of combined.
Contributor to Dashticz
More on my Github profile
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
It's merged!
JacEngels
Post by JacEngels »
aiolos and robgeerts, thank you both for the quick response to my request.
Currently it is not showing data for Venlo! Do I have to wait for the next BETA release?
aiolos
Post by aiolos »
If you update with 'git pull' you should have the new version. You should also use 'venlo' as garbage company, with of course your postal code and house number.
JacEngels
Post by JacEngels »
aiolos wrote: Saturday 23 December 2017 12:51 If you update with 'git pull' you should have the new version. You should also use 'venlo' as garbage company, with of course your postal code and house number.
I thought that :), did that :) but the garbage can is showing with text: 'loading' ;)
nldforce
Post by nldforce »
hello,
i have added this to my config:
config['domoticz_ip'] = 'http://192.168.*.**:8080';
config['garbage_company'] = 'circulus';
config['garbage_icalurl'] = 0;
config['garbage_zipcode'] = '7415vs';
config['garbage_street'] = 'f. van blankenheimstraat';
config['garbage_housenumber'] = '1';
config['garbage_maxitems'] = '12';
columns[2] = {}
columns[2]['blocks'] = ['traffic',tvguide.dutch,calendars.business,calendars.private,'garbage']
columns[2]['width'] = 5;
when i reload my page i am getting the screen loading like this:
https://ibb.co/iuE44w
also updated already buth nothing changes for me.
what am i doing wrong?
robgeerts
Post by robgeerts »
nldforce wrote: Wednesday 27 December 2017 23:00 hello,
Try this:
config['garbage_company'] = 'circulusberkel';
robgeerts
Post by robgeerts »
JacEngels wrote: Saturday 23 December 2017 12:57
What does your config.js look like?
(Only the garbage settings-part)
nldforce
Post by nldforce »
robgeerts wrote: Thursday 28 December 2017 15:18
Try this:
thnx it worked for me.
JacEngels
Post by JacEngels »
robgeerts wrote: Thursday 28 December 2017 15:19
@Rob, my setting for 'garbage'
config['garbage_company'] = 'venlo';
config['garbage_street'] = 'gelrestraat';
config['garbage_zipcode'] = '5951JE';
config['garbage_housenumber'] = '79';
config['garbage'] = {
gft: {kliko: 'green', code: '#7DBF59', name: 'GFT'},
pmd: {kliko: 'orange', code: '#db5518', name: 'PMD'},
rest: {kliko: 'grey', code: '#CDCCCB', name: 'Restafval'},
papier: {kliko: 'blue', code: '#153477', name: 'Papier'},
kca: {kliko: 'red', code: '#b21807', name: 'Chemisch afval'},
brown: {kliko: 'brown', code: '#7c3607', name: 'Bruin'},
black: {kliko: 'black', code: '#000000', name: 'Zwart'},
config['garbage_use_names'] = true;
config['garbage_use_colors'] = true;
config['garbage_icon_use_colors'] = true;
robgeerts
Post by robgeerts »
It's working here with your settings.
Are you sure you are using the latest BETA?
JacEngels
Post by JacEngels »
robgeerts wrote: Friday 29 December 2017 14:04 It's working here with your settings.
Yes. A 'git pull' is telling me I'm 'Already up-to-date.'
update: I did a fresh install (of the 'BETA') and everything is working now !!
mentalTheo
Domoticz version: 3.8798
Post by mentalTheo »
Struggeling to get the 'mijnafvalwijzer' to work.
Loaded latest beta with following CONFIG.js garbage lines:
CONFIG_part.txt
(1.24 KiB) Downloaded 64 times
it keeps returning 'Geen gegevens gevonden':
Output.docx
(180.07 KiB) Downloaded 52 times
Info is available on Mijn afvalwijzer site for my zipcode/housenumber
I guess I am missing one or more settings.
Please guide me in the right direction.
kottick
Post by kottick »
Hello Rob,
Is Duiven also in the possibilities, this the pdf download: https://www.duiven.nl/file/5405/download
Thanks,
Gosse
pkrabben
Domoticz version: 3.5877
Post by pkrabben »
Hi Rob
The garbage collector is not working anymore in Almere
I looked at mijnafvalwzijzer and I see my address (1321LJ, 10)
But I'm not able to get it to work
config['garbage_company'] = 'mijnafvalwijzer';
config['garbage_zipcode'] = '1321LJ';
config['garbage_street'] = '';
config['garbage_housenumber'] = '10';
Do you have any idea or tip to get this up and running again
thanks in advance
Derik
Post by Derik »
mmm my garbage app is stopped with working to..
And i did not make any change in my settings??
Perhaps a 2018 bug?
config['garbage_zipcode']		= 'xxxxxx';
config['garbage_street'] 		= 'parkweg';
config['garbage_housenumber'] 		= '29';
config['garbage_maxitems'] 		= '3';
config['garbage_width'] 		= '6';
config['garbage_hideicon'] 		= 0;
var trashnames = {}
trashnames['Restafval'] 		= 'Grijze';
trashnames['Grofvuil'] 		= 'Groot';
trashnames['Papier'] 			= 'Papier';
trashnames['Gft'] 			= 'GFT-Folie';
trashnames['Tuinafval'] 		= 'Takken';
var trashcolors = {}
trashcolors['Restafval'] 		= 'white';
trashcolors['Grofvuil'] 		= 'grey'
trashcolors['Papier'] 			= 'blue'
trashcolors['Gft'] 			= 'red';
trashcolors['Tuinafval'] 		= '#2ECC40';
aiolos
Post by aiolos »
It looks like 'mijn afvalwijzer' only shows the current year. So wait one day, and it will be working again. I hope... (otherwise, we will fix it) And I think you can assume that on 1 January no garbage is collected ;)
I will have a look at other garbage collection services in the next year.
robgeerts
Post by robgeerts »
Indeed, some calendars are not working correctly with 2018.
Try again tomorrow ;)
aiolos
Post by aiolos »
'Mijn afvalwijzer' is working for me today. If anyone is experiencing problems since the new year, please let us know.
aiolos
Post by aiolos »
kottick wrote: Friday 29 December 2017 22:35 Hello Rob,
Thanks,
Gosse
I'm afraid it's not possible. Since there is only a pdf available, it is hard to get the information from there. I could not find any other source for the information, for example an app. Do you know if such information is available?
