Page 175 of 184
Posted: Friday 05 October 2018 9:18
by mozo78
heggink wrote: Friday 05 October 2018 9:06
The refreshiframe parameter determines the refresh rate. Just increase. Not sure why you don't get a forecast tho...
Thank you, decreased the refreshiframe to 100000, and it is not blinking now.
The tablet view is very confusing because the owm block is very ugly, the tempereature values are to big in that mode . Thats why I tried the forecast.io.
Posted: Wednesday 10 October 2018 10:36
by GrOOt
I can't use Sonos on dashticz, it's ok when I used Domoticz (switch selector with play/pause/volume up & down)
no links of Sonos in main.js, normal ?
grep -r "Logitech Media" *
js/main.js: case 'Logitech Media Server':
pi@raspberrypi:~/domoticz/www/dash $ grep -r "Sonos" *
custom/CONFIG.js:// {"track":1,"name":"Sonos","file":"
http://xx:5005/salon/play"}, (--> my test with VAR)
custom/CONFIG.js:blocks[18] = {} //Sonos
Posted: Thursday 11 October 2018 9:19
by GrOOt
something is wrong ?
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"CustomImage" : 101,
"Data" : "Set Level: 20 %",
"Description" : "",
"DimmerType" : "none",
"Favorite" : 1,
"HardwareID" : 4,
"HardwareName" : "Dummy",
"HardwareType" : "Dummy (Does nothing, use for virtual switches only)",
"HardwareTypeVal" : 15,
"HaveDimmer" : true,
"HaveGroupCmd" : true,
"HaveTimeout" : false,
"ID" : "00014062",
"Image" : "Sonos",
"IsSubDevice" : false,
"LastUpdate" : "2018-10-09 22:25:38",
"Level" : 20,
"LevelActions" : "fGh0dHA6Ly8xOTIuMTY4LjEuNTI6NTAwNS9zYWxvbi9wbGF5fGh0dHA6Ly8xOTIuMTY4LjEuNTI6NTAwNS9zYWxvbi9wYXVzZXxodHRwOi8vMTkyLjE2OC4xLjUyOjUwMDUvc2Fsb24vcGxheWxpc3QvU29ub3N8aHR0cDovLzE5Mi4xNjguMS41Mjo1MDA1L3NhbG9uL3ZvbHVtZS8rNXxodHRwOi8vMTkyLjE2OC4xLjUyOjUwMDUvc2Fsb24vdm9sdW1lLy01",
"LevelInt" : 20,
"LevelNames" : "T2ZmfFBsYXl8UGF1c2V8UGxheWxpc3R8VXB8RG93bg==",
"LevelOffHidden" : true,
"MaxDimLevel" : 100,
"Name" : "Sonos",
"Notifications" : "false",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Protected" : false,
"SelectorStyle" : 0,
"ShowNotifications" : true,
"SignalLevel" : "-",
"Status" : "Set Level: 20 %",
"StrParam1" : "",
"StrParam2" : "",
"SubType" : "Selector Switch",
"SwitchType" : "Selector",
"SwitchTypeVal" : 18,
"Timers" : "false",
"Type" : "Light/Switch",
"TypeImg" : "Light",
"Unit" : 1,
"Used" : 1,
"UsedByCamera" : false,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "18"
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 12,
"Data" : "",
"Description" : "",
"Favorite" : 1,
"HardwareID" : 4,
"HaveDimmer" : false,
"ID" : "65",
"Image" : "Media",
"LastUpdate" : "2018-10-09 22:23:10",
"Level" : 0,
"LevelInt" : 0,
"MaxDimLevel" : 0,
"Name" : "Sonos Salon",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Status" : "On",
"StrParam1" : "aHR0cDovLzE5Mi4xNjguMS41Mjo1MDA1L3NhbG9uL3BsYXk=",
"StrParam2" : "aHR0cDovLzE5Mi4xNjguMS41Mjo1MDA1L3NhbG9uL3BhdXNl",
"SubType" : "X10",
"SwitchType" : "Media Player",
"SwitchTypeVal" : 17,
"Timers" : "false",
"Type" : "Lighting 1",
"TypeImg" : "Media",
"Unit" : 1,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "19"
Posted: Thursday 11 October 2018 18:26
by Lokonli
Dashticz should display the switch selector. Domoticz recently switched to a new way of encoding the selector values. Support for this has been added to Dashticz beta some time ago. Are you running the beta version of Dashticz?
Posted: Friday 12 October 2018 9:42
by GrOOt
no i'm running the stable version. you suggest to install the beta version ?
Posted: Friday 12 October 2018 10:07
by heggink
Yes. Stable doesn't have it.
Posted: Friday 12 October 2018 10:53
by GrOOt
Ok thank you
Posted: Saturday 20 October 2018 11:04
by DarkG
When I add those lines, I get an error when I open the webpage. What could be fault?
blocks['10'] = {}
blocks['10']['width'] = 4;
blocks['8'] = {}
blocks['8']['width'] = 4;
blocks['9'] = {}
blocks['9']['width'] = 4;
blocks['55'] = {}
blocks['55']['width'] = 4;
columns[5] = {}
columns[5]['blocks'] = ['10'.'8','9','55']
columns[5]['width'] = 5;
Posted: Saturday 20 October 2018 11:22
by HansieNL
Dot should be comma I think and you don't have to use an apostrophe if you only have digits: columns[5]['blocks'] = [10,8,9,55]
Posted: Saturday 20 October 2018 11:27
by DarkG
omg, I looked 100 times over and over. Thank you
Posted: Tuesday 23 October 2018 22:34
by JimmyH1969
I'm trying to make a button change color on a specific value (or even better, when in between values). I added the classes in the custom.css ofcourse. It's a temperature device and i want it to change color when in between specific values
This works:
function getStatus_2(idx,value,device){
if(parseFloat(device['Data'])<21){
$('div.block_2').addClass('yellow');
This does not:
if(parseFloat(device['Data'])>23){
$('div.block_2').addClass('red');
This does not:
if(parseFloat(device['Data'])>=17&&<=19){
$('div.block_2').addClass('lightblue');
Any ideas? I'm probably doing something wrong but can't seem to find it. Tnx in advance!
Posted: Tuesday 23 October 2018 23:20
by HansieNL
Posted: Tuesday 23 October 2018 23:32
by Lokonli
JimmyH1969 wrote: Tuesday 23 October 2018 22:34
This does not:
For this part try:
if(parseFloat(device['Data'])>=17 && parseFloat(device['Data'])<=19){
Posted: Wednesday 24 October 2018 15:20
by JimmyH1969
Thanks to all for pointing me in the right direction. I solved it like this:
if(parseFloat(device['Data'])>22){
$('div.block_2').removeClass('darkblue').removeClass('lightblue').removeClass('yellow').removeClass('orange').addClass('red');
else if(parseFloat(device['Data'])>21){
$('div.block_2').removeClass('darkblue').removeClass('lightblue').removeClass('yellow').removeClass('red').addClass('orange');
else if(parseFloat(device['Data'])>20){
$('div.block_2').removeClass('darkblue').removeClass('lightblue').removeClass('orange').removeClass('red').addClass('yellow');
else if(parseFloat(device['Data'])>19){
$('div.block_2').removeClass('darkblue').removeClass('yellow').removeClass('orange').removeClass('red').addClass('lightblue');
else if(parseFloat(device['Data'])>15){
$('div.block_2').removeClass('lightblue').removeClass('yellow').removeClass('orange').removeClass('red').addClass('darkblue');
Posted: Wednesday 24 October 2018 16:04
by houtumj
Is
www.dashticz.nl down???
Garbage not working anymore
Posted: Wednesday 24 October 2018 17:52
by HansieNL
Posted: Thursday 25 October 2018 9:48
by gielie
After the changes concerning dashticz.nl i cant get the garbage/ical working again but that's another problem, my dashticz is also super super slow.
is anybody having the same problem.
Posted: Thursday 25 October 2018 9:50
by poudenes
gielie wrote: Thursday 25 October 2018 9:48
http://www.domoticz.com/forum/viewtopic ... 87#p195387
Posted: Friday 26 October 2018 11:19
by edge
I managed to got the scripts working again. But somehow the fontawesome icons aren't working.
fas fa-calendar-alt
fa-calendar-alt
fas.fa-calendar-al
All without luck
Posted: Friday 26 October 2018 11:32
by poudenes
edge wrote: Friday 26 October 2018 11:19
fas fa-calendar-alt
fa-calendar-alt
fas.fa-calendar-al
All without luck
check
https://fontawesome.com/icons?d=gallery
some names are changed. I corrected mine and have icons back
