peter141080 wrote: Saturday 08 September 2018 11:22
Hey,
I installed Domoticz on a Raspberry Pi 3B +. I installed Dasticz with Github. Then I changed the Config file with the correct IP address and port number. When I go to http://192.168.0.128:8081/dashticz_v2/index.html I get the message:
Dashticz v2 is loading ...
Time-out! Something is wrong please check your CONFIG.js
For more help visit Dashticz v2 wiki
I have already searched the forum but can not really find an answer. What am I missing? I have already placed Authentication on Basic-Auth in settings.
Though I get all sorts of strange things going on. When i remotely change something in the config.js file, it does not change when i go to the server url. Very strange. So i add a block in a column remotely with notepad++ then save it, so to the server url, but it keeps showing the old config... hmmm
I change a blocktitle from cameras to camera, and it keeps showing cameras. What am i doing wrong, it worked like this before?¿
HansieNL wrote:The version of FontAwesome is changed to newer version. You have to change fa to fas. fas fa-bell
For an overview of all fonts: https://fontawesome.com/icons?d=gallery&m=free
Thanks, this did the trick.
However, my yellow 'light 'on'' icons don't work anymore. I assume it has to do with the custom.css file that needs updating as well. I simply can't figure how to update it.
For sure the wiki part needs updating for this section: https://www.domoticz.com/wiki/Dashticz_ ... Lightbulbs
Thanks, that did the trick. However, I think you turned 'far' and 'fas around. I changed it back and now the 'off' light is a dim white off-light bulb and the 'on' light is a bright orange on-light:
I faced a strange situation. My Xiaomi temperature sensors and doorswitches do not shows in dashticz. If I change de idx number to a rf or dlink temperature sensor (dsp-w215), the values show up. Is it possible that Dashticz cannot show the sensors witch come through the xiaomi hub?
I use the last stable version from Domoticz and Dashticz as well.
pkrabben wrote: Wednesday 26 September 2018 15:10
Hi All
I hope everybody is fine.
I did an update today of my Dashticz system but for some reason all the FA icons are not showing anymore all the custom icons are oke did I miss something that I need to change.
Hi All
I have a weird problem whereby, using the latest beta, the font colour in frames.weather switches on refreshiframe. Like many others, I replaced WU with
heggink wrote: Wednesday 03 October 2018 19:58
I'm missing the logic completely, but it works, and that seems to be the trend of today's technical insight.
It does not matter why it works, if it works, be happy, it feels like logic is gone nowadays. :-p
Thuis wrote:I'm missing the logic completely, but it works, and that seems to be the trend of today's technical insight.
Agree 100%. Back in the days I worked off a functional and technical design and then developed. Now I just copy and hack until it works.
P1 meter & solar panel
There is always some logic
To prevent caching of the iframe the current time is added to the url of the iframe when it gets reloaded. The following text is added:
'?t=<time> '
The question mark in the url results in that forecast.io rejects the last parameter. This last parameter normally sets the text color to white...
Hi, I have gottwo question about forecast.io, maybe you can help me. It wokrs great with your solution, but in every 10th second it blinks, and it is very disturbing. Can it switched of? Is it possible to reduce the refreshing time? The second problem is when I try to use it in tablet mode, there is no forecast, only the actual weather and temperature.
