Page 171 of 184
Posted: Saturday 14 July 2018 15:51
by JuanUil
Hi Folks,
I have tried everything over and over again.
Installed stable version - no favourites
Installed beta - no favourites
when I insert
columns[1] = {}
columns[1]['blocks'] = ['341']
columns[1]['width'] = 5;
then I get a switch on the screen.
here is my config
var config = {}
config['language'] = 'nl_NL';
config['domoticz_ip'] = 'http://192.168.2.18:8080';
config['auto_positioning'] = 0;
config['use_favorites'] = 0;
config['loginEnabled'] = 0;
var publictransport = {}
publictransport.ovinfobus = { show_via: false, station: 'son-en-breugel/bushalte-penseelkever', provider: '9292-bus', icon: 'bus', width:5, results: 6 }
var tvguide = {}
tvguide.dutch = { key:'dutch', icon: 'fa-television', width:7, channels: [1,3,4,31,46,92], maxitems: 5 }
var _STREAMPLAYER_TRACKS = [
{"track":1,"name":"Q-music","file":"http://icecast-qmusic.cdp.triple-it.nl/Qmusic_nl_live_96.mp3"},
{"track":2,"name":"538 Hitzone","file":"http://vip-icecast.538.lw.triple-it.nl/WEB11_MP3"},
{"track":3,"name":"Slam! NonStop","file":"http://stream.radiocorp.nl/web10_mp3"},
{"track":4,"name":"100%NL","file":"http://stream.100p.nl/100pctnl.mp3"},
var buttons = {}
buttons.nunl = {key: 'nunl', width:12, icon: 'fa-newspaper-o', title: 'Nu.nl', newwindow:true, url: 'http://www.nu.nl'}
buttons.nos = {key: 'nos', width:12, icon: 'fa-newspaper-o', title: 'Nos', url: 'http://www.nos.nl'}
var blocks = {}
blocks['blocktitle_1'] = {}
blocks['blocktitle_1']['key'] = 'blocktitle_1';
blocks['blocktitle_1']['title'] = 'Example';
var columns = {}
columns['bar'] = {}
/*columns[1] = {}
columns[1]['blocks'] = ['currentweather_big','weather']
columns[2] = {}
columns[2]['blocks'] = ['blocktitle_1',tvguide.dutch,publictransport.ovinfobus]
columns[2]['width'] = 5;
columns[3] = {}
columns[3]['blocks'] = ['sunrise','streamplayer',buttons.nunl,buttons.nos]
columns[3]['width'] = 2;
columns[1] = {}
var columns_standby = {}
columns_standby[1] = {}
columns_standby[1]['blocks'] = ['clock','weather']
var screens = {}
screens[1] = {}
screens[1]['background'] = 'bg2.jpg';
also set autopositioning from 1 to 0 and also use favourites from 1 to 0 also no luck
Any help is highly appreciated!!
Jan
Posted: Sunday 15 July 2018 0:24
by HansieNL
JuanUil wrote: Saturday 14 July 2018 15:51
Hi Folks,
when I insert
- Spoiler: show
columns[1] = {}
here is my config
- Spoiler: show
var config = {}
var tvguide = {}
var buttons = {}
var blocks = {}
var columns = {}
columns['bar'] = {}
/*columns[1] = {}
columns[2] = {}
columns[3] = {}
columns[1] = {}
var screens = {}
screens[1] = {}
Jan
You have to add your switches as blocks ( blocks[IDX] = {} ) if set favorites to 0.
How to do that is described in the wiki
https://www.domoticz.com/wiki/Dashticz_V2_-_Positioning
var blocks = {}
blocks[123] = {} //Sensor 1
blocks[234] = {} //Example 2
Then you can add your switch/sensor where you want it.
columns[1] = {}
columns[1]['blocks'] = [123,234]
Posted: Sunday 15 July 2018 12:03
by JuanUil
Oh oké,
thanx for your reply, I thought that the favourites were added automatically.
I will start working it out with an example!
Thanx again.
Jan
Posted: Sunday 15 July 2018 23:34
by poudenes
Hi All,
Can someone help me. Volt is ok. Volt as text and value below. But Gas vandaag, Totaal Gas, And the rest are not switched also not the title is showing
// P1 INFO
blocks[23] = {width: 4, icon: 'fa-bolt', show_lastupdate: false, hide_data: true, switch: true, title: 'Watt' };
blocks[24] = {width: 4, icon: 'fa-bolt', show_lastupdate: false, hide_data: true, switch: true, title: 'Volt' };
blocks[25] = {width: 4, icon: 'fa-fire', show_lastupdate: false, hide_data: true, switch: true, title: 'Gas' };
Posted: Friday 20 July 2018 17:21
by poudenes
nobody?
Posted: Friday 20 July 2018 17:45
by EdwinK
No, sorry. I had the same problem, and somehow it's now gone. Strange.
Posted: Sunday 22 July 2018 18:44
by mvveelen
I managed to get one of my webcams integrated in Dashticz:
buttons.camera1 = {width:12, isimage:true, refreshimage:2000, image: 'http://192.168.0.17:88/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=user&pwd=passwd'}
But the other one has a URL like:
http://192.168.0.101/webcapture.jpg?command=snap&channel=0
and I can't seem to get this one integrated in my Dashticz. Maybe someone can help me out? It's an Escam QD500
Another question:
I have some door/window sensors in my house, but on the Dashticz screen all sensors are displayed as DOOR-sensors. I would like to be able to change some of them into WINDOWS-sensors. Is this possible? If so, how?
Posted: Wednesday 25 July 2018 20:31
by Ectholian
Beware of an upcoming change in the new domoticz versions. The LevelNames returned by domoticz will be base64-encoded instead of plain text. That means it will stop working in dashticz. I quickfixed it (try base64-decode and after that use the current split('|') ) but a nicer way would be to check the domoticz version and do/don't base64decode on that.
More info:
https://github.com/domoticz/domoticz/issues/2454
Posted: Wednesday 25 July 2018 20:34
by Ectholian
mvveelen wrote: Sunday 22 July 2018 18:44
https://www.ispyconnect.com/man.aspx?n=eScam
That cam does not have a jpeg stream, only rtsp and that won't work if i am not mistaken.
Posted: Wednesday 25 July 2018 21:10
by EdwinK
RTSP won't work on Domoticz/Dashticz, unfortunately.
Posted: Wednesday 25 July 2018 21:30
by mvveelen
Ah, too bad.... thanks though.
Posted: Saturday 28 July 2018 22:20
by RiLaSol
Is there a manual for Dashticz?
For example were can I find were the TV channels that are coded in the CONFIG.js file are?
Posted: Saturday 28 July 2018 23:36
by HansieNL
Posted: Friday 10 August 2018 17:03
by TapNL
My Pi crashed the other day. I had all settings backed up. That worked out quite well.
I was not yet running on the latests version of Dashticz, not sure on which one.
I use an Android tablet to display the dashboard. Works like a charm.
In the past I was able to refresh the page by pulling the screen down. That does not work anymore. I checked other websites and it works there, so I am guessing that something changed in an update of Dashticz. Anyone any clue how I can fix this?
Posted: Friday 10 August 2018 19:19
by Herman-H
First of all i will thanks Rob Geerts for this nice piece of software and the community for the samples and tips etc.
I'm a noob with this kind of programs so it was a lot of reading and testing.
But now i have two questions:
1: When i change somthing in the settings menu and will save it it doesn't work.
2: I have 'currentweather_big','weather' in my CONFIG.js but i don't see it again.
I have a key of Weather Underground.
What do i wrong? Any help will appreciate.
CONFIG.js
- Spoiler: show
- var config = {}
config['language'] = 'nl_NL'; //or: en_US, de_DE, fr_FR, hu_HU, it_IT, pt_PT, sv_SV
config['domoticz_ip'] = 'My-IP';
config['wu_api'] = 'My_Key';
config['wu_city'] = 'Hengelo';
config['wu_name'] = 0;
config['wu_country'] = 'NL';
config['standby_after'] = 10;
/* REMOVE THIS LINE, INCLUDING THIS TEXT IF YOU WANT TO USE THE CODE BELOW, ALS REMOVE THE LAST LINE OF THIS FILE ( the asterisk * with the slash)
publictransport.ovinfobus = { show_via: false, station: 'hengelo/bushalte-bruninkshoek', show_lastupdate:true, provider: '9292-bus', icon: 'bus', width:6, results: 6 }
publictransport.ovinfotrain= { station: 'station-hengelo', show_lastupdate:true, provider: '9292-train', icon: 'train', width:6, results: 6 };
var buttons = {}
buttons.nos = {key: 'nos', width:12, icon: 'fa-newspaper-o', title: 'Nos',url: 'http://nos.nl'}
buttons.tweakers = {key: 'tweakers', width:12, icon: 'fa-newspaper-o', title: 'Tweakers', newwindow:true, url: 'http://tweakers.net'}
buttons.buienradar = {width:12, isimage:true, refreshimage:60000, image: 'http://api.buienradar.nl/image/1.0/Rada ... =285&h=256', newwindow:true, url: 'https://gadgets.buienradar.nl/gadget/zo ... &overname=$
//************************************************** 'blocktitle_1' **********************************************************************
//Lampen kamer
blocks[66] = {} //Woonkamer Duo lampen
blocks[66]['width'] = 6;
blocks[67] = {} //Woonkamer L & R naast TV
blocks[67]['width'] = 6;
blocks[345] = {} //Woonkamer staande schemerlamp
blocks[345]['width'] = 6;
blocks[346] = {} //Woonkamer staande schemerlamp lezen
blocks[346]['width'] = 6;
blocks[779] = {} //WC-Raam
blocks[779]['width'] = 6;
//************************************************** 'blocktitle_2' ************************************************************************
blocks[2170] = {} //Temperatuur slaapkamer
blocks[2170]['width'] = 6;
blocks[3268] = {} //Temperatuur zolder
blocks[3268]['width'] = 6;
var blocks = {}
//Block Titles
blocks['blocktitle_1']['title'] = 'Schakelaars';
blocks['blocktitle_2'] = {}
blocks['blocktitle_2']['key'] = 'blocktitle_2';
blocks['blocktitle_2']['title'] = 'Temperatuur';
blocks['blocktitle_3'] = {}
blocks['blocktitle_3']['key'] = 'blocktitle_3';
blocks['blocktitle_3']['type'] = 'blocktitle';
blocks['blocktitle_3']['title'] = 'Bus en Trein';
blocks['blocktitle_4'] = {}
blocks['blocktitle_4']['key'] = 'blocktitle_4';
blocks['blocktitle_4']['type'] = 'blocktitle';
blocks['blocktitle_4']['title'] = 'Info en Weer';
columns = {}
columns['bar'] = {}
columns[1] = {}
columns[1]['blocks'] = ['blocktitle_1',66,67,345,346,779,'blocktitle_2',2170,3268]
columns[1]['width'] = 4;
columns[2] = {}
columns[2]['blocks'] = ['blocktitle_3','currentweather_big','weather',publictransport.ovinfobus,publictransport.ovinfotrain]
columns[2]['width'] = 4;
columns[3] = {}
columns[3]['blocks'] = ['blocktitle_4','clock','sunrise',buttons.nunl,buttons.nos,buttons.tweakers,buttons.buienradar]
columns[3]['width'] = 4;
//************************************************** 'Standby' ************************************************************************
var screens = {}
screens[1] = {}
custom.css
- Spoiler: show
CUSTOM CSS FILE
Posted: Friday 10 August 2018 19:43
by HansieNL
1. Settings are only saved when running php.
2. Have you tried config['auto_positioning'] = 0; ?
Posted: Friday 10 August 2018 20:25
by Herman-H
i don't use php so point 1 is clear.
for point 2 i tried auto positioning. same 'currentweather_big','weather not visible.
When i use the data from the original CONFIG_DEFAULT.js of github and my wu key i have the same result.
And that do i don't understand.
Posted: Friday 10 August 2018 22:10
by HansieNL
@Herman-H: can you try to enlarge the width for the column containing weather block to 5?
Posted: Friday 10 August 2018 22:49
by Herman-H
@ HansieNL, the same, no weather or currentweather_big. Is there a relation between the key of WU and showing this items?
Posted: Friday 10 August 2018 23:01
by HansieNL
@Herman-H: If the key is not right the item only shows 4 small blocks without info.
