Page 18 of 37
Re: Nefit Easy™
Posted: Sunday 13 March 2016 17:51
by SweetPants
access-key is with double 's'
Re: Nefit Easy™
Posted: Sunday 13 March 2016 19:29
by Peacock
The mistype error didnt seem to be the problem
Re: Nefit Easy™
Posted: Sunday 13 March 2016 19:33
by pepijn
You need NodeJS 4 or up so if your node -v says 0.10 it will not work.
Re: Nefit Easy™
Posted: Sunday 13 March 2016 19:57
by Peacock
Any idea how I can install these on a ARM5 version. (have installed the v5.3.0 but doesnt seem to work), get the following: NAS> node -v
-ash: node: not found
Re: Nefit Easy™
Posted: Tuesday 15 March 2016 21:37
by knights
@pepijn: any progress in the gass usage meter/chart ?
Re: Nefit Easy™
Posted: Friday 18 March 2016 8:11
by Blaah
After Two nights of very little sleep i finale managed to connect my nefit easy to Domoticz using pepijn's flow in node red. Thans very much and compliments for the great work.
Main problem was the scattering of instructions all over 18 pages of this post
. It definitely does not do justice to your work. When I have more time, my contribution will be a comprehensive instruction within one message. To be continued..
Re: Nefit Easy™
Posted: Saturday 19 March 2016 9:13
by gizmocuz
Would be nice if you could make a wiki page for it
Re: Nefit Easy™
Posted: Saturday 19 March 2016 10:18
by Marcel
HI, since I have the nefit Domoticz integration running I sometimes loose the connection to my easy thermostat both from the Nefit app and from Domoticz. This happens every 2-3 weeks (now 3 times) Restarting the easy thermostat (taking it off the wall for a couple of seconds solves the issue. It looks like either the server denies the connection or the easy thermostat looses its connection.
Anyone else have the same experience?
Re: Nefit Easy™
Posted: Saturday 19 March 2016 10:47
by gizmocuz
Are you using the easy server with the native domoticz implementation ?
Re: Nefit Easy™
Posted: Saturday 19 March 2016 10:54
by Marcel
Yes, running the easy-server script and native implementation.
Version: 3.4978
Build Hash: b5fe63d
Compile Date: 2016-03-17 08:33:15
Re: Nefit Easy™
Posted: Saturday 19 March 2016 11:03
by m4rc3ls
I am experiencing same issue as Marcel: Running easy-server on separate RPI2. Nefit Easy thermostat seems to be hanging every 1 to 2 days, also no longer accessible through native app. Have to restart it by removing it from wall, then everything works fine again.
Re: Nefit Easy™
Posted: Saturday 19 March 2016 11:48
by gizmocuz
I dont experience these issues, maybe your internet connection went down ?
Running here for a long time
i do not use the native app of nefit
Re: Nefit Easy™
Posted: Saturday 19 March 2016 11:53
by pepijn
No issues here, I run (my) Node red solution but also the native Domoticz integration. We also use the Nefit app
Re: Nefit Easy™
Posted: Saturday 19 March 2016 13:50
by m4rc3ls
Worked fine here too for a while, but since about a month the thermostat is not accepting requests (timeout) every few days. It functions by hand, but is inaccessible though Internet (native app) and local network (it's not Internet connection related). I checked but the device does keep saying it is connected to WiFi and Internet, just can not access it. Only solution is to, like I said, restart the thermostate by taking it off dock.
Because of this issue I have removed the software today unfortunately.
I am getting the feeling the thermostat blocks incoming requests at a certain point. Perhaps a new firmware version? (or old one
Re: Nefit Easy™
Posted: Saturday 19 March 2016 15:00
by Holland
@Marcel.
I had the same problem. One of the more recent version solved the time-out issue. Please make sure you have the most recent version of the Nefit http server daemon. I have version 2.1.0, which is the latest version
https://github.com/robertklep/nefit-eas ... ckage.json
Re: Nefit Easy™
Posted: Saturday 19 March 2016 15:04
by Holland
@Blaah, sorry to say but you could have saved yourself a lot of time by using the native Nefit implementation of Domoticz.
You do need to install the nefit-easy-http-server daemon, which you can find overhere ;
https://github.com/robertklep/nefit-easy-http-server
Re: Nefit Easy™
Posted: Saturday 19 March 2016 15:11
by SweetPants
No issues here, using both Domoticz (native) integration and Nefit App without any issues. Had some problems in the beginning and contacted Nefit about loosing connection too, but this was caused by bad mounting of the thermostat on the groundplate. They also had some backend (scaling) problems, but since last two months, it works great.
Re: Nefit Easy™
Posted: Saturday 19 March 2016 20:16
by dorenberg
Just tried to install the nefit http server and starting to use the native support, but this completely messed up my plugwise setup. Had to reinstall a previous image and a database restoration. I will keep the node-red version for now.
Re: Nefit Easy™
Posted: Saturday 19 March 2016 20:22
by Doler
For those who use the Clock Mode switch to control their Nefit and want dedicated icons for the switch I created this custom icon set:
- clockmode_On.jpg (17.73 KiB) Viewed 3353 times
- clockmode_Off.jpg (16.9 KiB) Viewed 3353 times
Here is the zip-file you can use to import in Domoticz.
Re: Nefit Easy™
Posted: Saturday 19 March 2016 21:15
by Marcel
@Holland,
Thanks for your reply. I am running 2.1.0 and latest Beta release. Somehow it looks like Nefit is blocking me occasionally because also their iOS app cannot connect to the thermostat. Internet in my house is very stable and Thermostat seems to have WIFI connection to the outside world. I also found that it occurs (more) after setting the temp from Domoticz. Maybe there is something in there that cause it to decline the connection afterwords. It is very hard to debug as it is not occurring very frequently. Because more users have the issue I am led to believe that it is something we do different....
