Python Plugin: Shelly MQTT
- gizmocuz
Re: Python Plugin: Shelly MQTT
@microchip1974
I have send you an email.
Anyone having issues with the MQTT Auto Discovery hardware feel free to join our Slack channels:
https://join.slack.com/t/domoticz/share ... G2dBSOTRwg
Derik
- Domoticz version: BETA
Love you Rob....gizmocuz wrote: Sunday 06 February 2022 18:45 @microchip1974
Hope you get shelly working...
If you need a hardware device to test.
I buy 1 for you..
Let me know please
- Domoticz version: 2026.3
There is no zigbee2mqtt integration, there is a MQTT Autodiscover integration that Z2M also happen to support. That and also the fact that Zwavejs2mqtt supports this gave some momentum.
But everyone is free to start a C++ integration. Rob is not the only person that starts an integration.
Also you would need the hardware to test.
But you are free to ask
Derik
I now wat you mean....waltervl wrote: Sunday 06 February 2022 22:07 There is no zigbee2mqtt integration, there is a MQTT Autodiscover integration that Z2M also happen to support. That and also the fact that Zwavejs2mqtt supports this gave some momentum.
But you are free to ask![]()
If you could.. i buy you a shelly
darrepac
Hello
I have shellies and plugin working since a while flawlessly.
Yet, I realized something odd with my Shelly EM:
While the voltage device is updated everything few seconds (at each mqtt update), the watt consumption is only updated every 10 or more seconds (while through MQTT Explorer I see that both are updated in the same time).
What is the reason behind and can we change that?
EDIT:
Looking at the plugin.py, domoticz voltage device value (and on/off values) is updated at every mqtt message while power/energy values are updated at minimum every 10seconds:
EDIT:
Why? I don't knowif( updated > 10 ):
Robinjoo94
- Domoticz version: 2022.1
I have the Shelly MQTT running rather flawlesly for over a year, or maybe 2 already, now.
I just updated to Domoticz 2022.1 stable build, and that is when the problems started.
Is see the following error in the Domoticz.log after which Domoticz service goes to "active (exited)":
Anyone faced the same and has a solution?
Error: Domoticz(pid:22631, tid:22647('Shelly MQTT')) received fatal signal 11 (Segmentation fault)- waltervl
There is an issue on running Python plugins on Bullseye but you seem to run Buster so that would not be an issue.
Does it stop directly or after a while?
What is in the Domoticz log before the crash?
darrepac
I found why, here is the answer if someone else need it: https://github.com/enesbcs/Shelly_MQTT/pull/87darrepac wrote: Friday 04 March 2022 11:48 Hello
EDIT:
Looking at the plugin.py, domoticz voltage device value (and on/off values) is updated at every mqtt message while power/energy values are updated at minimum every 10seconds:Why? I don't knowif( updated > 10 ):
Robinjoo94
It stops after a while, where the "while" is rather unpredictable (1 minute to >24 hours).waltervl wrote: Sunday 06 March 2022 17:40 There is an issue on running Python plugins on Bullseye but you seem to run Buster so that would not be an issue.
The log shows "Disconnected from MQTT Server" for the occurences I was not directly looking at last time. Other than that there is nothing interesting in the log, just my (non-Shelly) devices updating:
- Spoiler: show
- Spoiler: show
darrepac
I had also lot of plugin problem with latest stable. I updated to latest Beta because something has been changed about python, and everything is working much better now
Is MQTT broker (eg mosquitto) running on the same server or a different one?
As it seems that the disconnecting issue could trigger the crash (it should not).
Perhaps another issue in your environment that is triggering this? Wifi issues, Network issues, Memory issues?
@darrepac Plugin issues were on Bullseye environment not on Buster.
darrepac
I just share my experience...waltervl wrote: Monday 07 March 2022 16:33 @darrepac Plugin issues were on Bullseye environment not on Buster.
Robinjoo94
Yes, running on the same Raspberry Pi.waltervl wrote: Monday 07 March 2022 16:33 Is MQTT broker (eg mosquitto) running on the same server or a different one?
Will keep an eye on the logs upcoming days.
ProjektC
- Domoticz version: 4.10717
Hello
I have been using Domoticz for many years
basically with Yeelight lamps in LAN mode and Shelly products.
Have various Shelly sockets, motion sensor, window detector and since short Shelly 1.
Now I thought for my daughter a Shelly button to switch on zb your lamps or colored switch.
I thought the part just turns on and off.
The Shelly Button is integrated in domoticz.
But on and off I guess I can't switch.
Instead once, twice, three times and long press.
But it's not clear to me how I can just turn anything on and off.
Or how I can assign the commands somewhere to a lamp or scene.
So I'm not sure if that works at all.
bye
bye
Robinjoo94
Have a look at: https://www.domoticz.com/wiki/EventsProjektC wrote: Wednesday 09 March 2022 20:00 But it's not clear to me how I can just turn anything on and off.
So I still do not have a clear cause for my issues.Robinjoo94 wrote: Monday 07 March 2022 17:47Yes, running on the same Raspberry Pi.waltervl wrote: Monday 07 March 2022 16:33 Is MQTT broker (eg mosquitto) running on the same server or a different one?
I now have a "watchdog" script running that restarts domoticz whenever went to "active (exited)".
Added a simple script/domoticz device to track the memory consumption, there seems to be some memory leak, but the error happens already when the memory consumption is at 70%, so too early in my oppinion to be caused by memory issues.
I will have to add some more monitoring to get to the root cause.
For memory tracking you can use the build in motherboard sensor gateway https://www.domoticz.com/wiki/Motherboard_sensors
extremeaudio
Everything was working, suddenly when i checked again I get this error
mqtt: disconnected, Invalid Username/Password (rc=5)
I havent made any changes. How can I re enable mqtt again?
log as below
log as below
2022-03-16 20:19:33.143 Error: Shelly MQTT: (Shelly MQTT) Disconnected from MQTT Server: 192.168.1.63:1883
2022-03-16 20:19:33.143 Error: Shelly MQTT: (Shelly MQTT) No transport, write directive to '192.168.1.63' ignored.
2022-03-16 20:19:43.111 Shelly MQTT: (Shelly MQTT) Connected to MQTT Server: 192.168.1.63:1883
2022-03-16 20:19:43.162 Error: Shelly MQTT: (Shelly MQTT) Disconnected from MQTT Server: 192.168.1.63:1883
2022-03-16 20:19:43.162 Error: Shelly MQTT: (Shelly MQTT) No transport, write directive to '192.168.1.63' ignored.
2022-03-16 20:19:45.088 RPi: Temp (Internal Temperature)
2022-03-16 20:19:45.423 InfluxLink: value Temperature,idx=2,name=Internal-Temperature value=57.9
2022-03-16 20:19:49.444 Status: MQTT: MQTT: Connecting to localhost:1883
2022-03-16 20:19:49.646 Error: MQTT: MQTT: Connection failed!, restarting (rc=2)
2022-03-16 20:19:49.646 Error: MQTT: MQTT: disconnected, Invalid Username/Password (rc=5)
2022-03-16 20:19:53.131 Shelly MQTT: (Shelly MQTT) Connected to MQTT Server: 192.168.1.63:1883
2022-03-16 20:19:53.183 Error: Shelly MQTT: (Shelly MQTT) Disconnected from MQTT Server: 192.168.1.63:1883
2022-03-16 20:19:53.183 Error: Shelly MQTT: (Shelly MQTT) No transport, write directive to '192.168.1.63' ignored.
Did you update to latest beta (would conflict your statement that nothing changed..)? As this seems to be an issue now:
https://github.com/domoticz/domoticz/issues/5195
extremeaudio
I had not updated to beta. After reading your post I updated in fact to the latest beta and the problem persists.
Is your MQTT broker running? Can you connect it with MQTT explorer? https://www.domoticz.com/wiki/MQTT#Debugging_MQTT
