Page 18 of 114
Posted: Sunday 17 December 2017 10:54
by jeroenvanpelt
georgesattali wrote:Hello,
I have a question about Google Home and Dz, please : is it possible to have it speaking ?
That is to send recorded sound files from the raspberry to the Google Home ?
GD
If you mean notification type plays, you cannot initiate that from Domoticz.
I have seen google-home-notifier, but you could also try a cli script that allows you to start a sound cast to the Google Home, as if you were chromecasting (chromecast-cli).
Sent from my Pixel 2 XL using Tapatalk
Posted: Sunday 17 December 2017 11:20
by HarryHase
Hi, is there actual a problem on controlicz.com?
i can connect from outsite via http and https but contolicz sayed
Controlicz is unable to connect - please check your config
Posted: Sunday 17 December 2017 12:39
by alanlsmith
jeroenvanpelt wrote: Sunday 17 December 2017 10:54
You can use a switch in Domoticz to trigger a node-red flow which can in turn speak a notification based on the switch state via a Google Home.
Posted: Sunday 17 December 2017 15:19
by HarryHase
It comes back working ... spooky ..
Posted: Sunday 17 December 2017 15:26
by sandervanpelt
Hi Madgeni,
I just registered. Can you please add me to your beta program?
My email is my forum username @gmail.com
Thanks,
Sander
Posted: Sunday 17 December 2017 22:17
by vboulaye
Hello Madgeni,
I registered on the controlicz website and would like to try the google home beta integration if possible.
My email is also my forum username at gmail.
Thanks,
Vincent
Posted: Monday 18 December 2017 8:41
by Vens
Hi Madgeni,
Can you add me to the beta program as well, my email address is arj**ven******@ gmail.com. And how can I add controlicz to google assistant?
Thnx!
Posted: Monday 18 December 2017 15:37
by Noka
Hi Madgeni!
Controlicz test say it unable to connect but it work for almost everythings except xiaomi smart plug. I don't understand why. Everythings are right on your side?
Posted: Monday 18 December 2017 16:25
by Madgeni
yes, the test is broken - going to remove it whilst i debug.
What's wrong with the xiaomi plugs? Not discovered at all?
Posted: Monday 18 December 2017 17:37
by Noka
It discovered but when I command it by google it work but not every time.. it's strange. I need to repeat several times the command.
Posted: Monday 18 December 2017 17:38
by Madgeni
ok that is strange!
Posted: Monday 18 December 2017 17:56
by Noka
Yep, and I don't know why. I search some technics, rename it etc.. on the google side it work but not in domoticz.
Posted: Monday 18 December 2017 18:35
by fergalom
perhaps someone can help
S7 with 6.01 - home and assistant installed
Joined the controllicz beta
the controllicz "app" is not showing up on assistant when I ask it to "talk to controllicz" "talk to homecontrollicz" or "turn on my lights"
Any pointers? kinda driving me nuts now
Posted: Monday 18 December 2017 18:36
by jeroenvanpelt
fergalom wrote:perhaps someone can help
Have you signed up for the beta test?
Posted: Monday 18 December 2017 18:37
by fergalom
thanks yes, signed up and enabled on the google actions page
Posted: Monday 18 December 2017 18:39
by jeroenvanpelt
fergalom wrote:thanks yes, signed up and enabled on the google actions page
Hmm, same Gmail account I assume?
Posted: Monday 18 December 2017 18:48
by tohn
Discovered that Google home can broadcast messages.
Would this function work with this integration to domoticz?
Posted: Monday 18 December 2017 20:15
by Madgeni
fergalom wrote: Monday 18 December 2017 18:37
so it's not showing up under settings>Home Control?
Posted: Monday 18 December 2017 22:29
by demon1977
Hi Madgeni, I just registered on Controlicz, my email demon****@gmail.com
Can you add me?
Thanks a lot!
Posted: Monday 18 December 2017 22:33
by fergalom
Madgeni wrote:fergalom wrote: Monday 18 December 2017 18:37
Yes same gmail account
No "home control" option listed under settings in assistant
Sent from my SM-G930F using Tapatalk
