Dashticz - Module - Garbage collector Topic is solved
curious
Re: Dashticz - Module - Garbage collector
Post by curious »
Great, thank you Rob and aiolos.
htilburgs
Post by htilburgs »
Maybe I'm the only one using IE11, but I'm keep getting "Loading..." when the Garbage modules loads data.
This only occurs with IE11.
When I remove https://cors-anywhere.herokuapp.com/ from the garbage.js (I'm having CURE, so I remove in function getAfvalstromenData), it works.
function getAfvalstromenData(address, date, random, baseUrl) {
    $('.trash' + random + ' .state').html('');
    $.getJSON(baseUrl + '/rest/adressen/' + address.postcode + '-' + address.housenumber, function (data) {
        $.getJSON(baseUrl + '/rest/adressen/' + data[0].bagId + '/afvalstromen', function (data) {
            data = data
                .filter(function (element) { return element.ophaaldatum !== null; })
                .map(function (element) {
                        date: moment(element.ophaaldatum, 'YYYY-MM-DD'),
                        summary: element.title,
                        garbageType: mapGarbageType(element.title),
            addToContainer(random, data);
Can this be solved? Or maybe a variable to put on true of false (config['use_garbage_cors-url'] = true;)?
Hardware:
aiolos
Domoticz version: stable
Post by aiolos »
It could be that IE handles the url a bit different, which causes aan error. And probably IE doesn't do the security check for which the core stuff is needed, so then it can be removed. This week I don't have the time for it I think, next week at the earliest.
Contributor to Dashticz
More on my Github profile
rbeech
Post by rbeech »
Love the work on this, just working on mounting a tablet on the wall by the front door so I might have lots of questions to come up.
I *always* forget which bin to put out.
Apologies if I've missed it, to add my own calendar as I don't have a service provided one:
a) Can I create me own json file and serve it locally? If so, what format should it be in?
b) If I use a google calendar, what format do I add events to it?
Thanks.
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
You could create an Ical for this.
Just enter the type of bins on the correct date, for example, add a 'whole day'-event on 10-12-2017 with the name: 'Rest'.
With the right config you can show them in the right colors, for example:
config['garbage'] = {
    gft: {kliko: 'green', code: '#375b23', name: 'GFT'},
    pmd: {kliko: 'orange', code: '#db5518', name: 'PMD'},
    rest: {kliko: 'grey', code: '#5e5d5c', name: 'Rest'},
    papier: {kliko: 'blue', code: '#153477', name: 'Papier'},
    kca: {kliko: 'red', code: '#b21807', name: 'Chemisch afval'},
    brown: {kliko: 'brown', code: '#7c3607', name: 'Bruin'},
    black: {kliko: 'black', code: '#000000', name: 'Zwart'},
config['garbage_use_names'] = true;
config['garbage_use_colors'] = true;
Zoekm
Post by Zoekm »
Just recently installed Dashticz and I like it very much, great work! Yesterday was the first time the garbage ("Restafval") pickupdate passed by and I noticed that on the day of pickup of "Restafval", in my case Thursdays ("donderdag"), the block already shows the next pickup days/dates and garbage type, so on Thursday I see the next weeks messages and later. Yesterday, Thursday, they came to pickup "Restafval", but the Dashticz shows "GFT":"Thursday". For me this is confusing, is it possible that the first line displays the garbage type until that day has passed? Is there a configuration setting for this?
afval dashticz.jpg (2.38 KiB) Viewed 2724 times
aiolos
Post by aiolos »
Which garbage company do you use? In a situation where an ical link is used, I can imagine the 'appointment' is in the morning, so later on the day it is gone (however, that somehow can be fixed I think). Or maybe the company that you use removes it on the day it is due. Still an error, but that's harder to fix...
Please give some more information about your config.
Thanks.
Zoekm
Post by Zoekm »
Thanks for looking into this, we have only GFT and Restafval collected, at Thursdays, my garbage configurations:
config['garbage_company'] = 'mijnafvalwijzer';
config['garbage_zipcode'] = 'XXXXXX';
config['garbage_housenumber'] = 'XX';
config['garbage_maxitems'] = '2';
gft: {kliko: 'green', code: '#7DBF59', name: 'GFT'},
rest: {kliko: 'grey', code: '#CDCCCB', name: 'Restafval'},
config['garbage_icon_use_colors'] = true;
Note, on "mijnafvalwizer", 7 December is still the first day listed for collection of garbage.
afval dashticz2.jpg (7.73 KiB) Viewed 2691 times
aiolos
Post by aiolos »
Zoekm wrote: Friday 08 December 2017 13:10 Just recently installed Dashticz and I like it very much, great work! Yesterday was the first time the garbage ("Restafval") pickupdate passed by and I noticed that on the day of pickup of "Restafval", in my case Thursdays ("donderdag"), the block already shows the next pickup days/dates and garbage type, so on Thursday I see the next weeks messages and later. Yesterday, Thursday, they came to pickup "Restafval", but the Dashticz shows "GFT":"Thursday". For me this is confusing, is it possible that the first line displays the garbage type until that day has passed? Is there a configuration setting for this?
I created a PR for this. It should show the garbage collection now also on the day itself. This problem could happen with all kinds of garbage companies. I couldn't do a real test since it is sunday right now, but simulating it a few days ahead, I could reproduce it, and solve it. If Rob merges it, you can see how it works next thursday.
aiolos
Post by aiolos »
htilburgs wrote: Tuesday 05 December 2017 9:24 Maybe I'm the only one using IE11, but I'm keep getting "Loading..." when the Garbage modules loads data.
Is created a PR which adds a new option. If merged, you can use
config['garbage_use_cors_prefix'] = false;
This value is normally true, so the cors-anywhere prefix is used. But if this causes errors, you can now disable it. For now this is only added to the garbage functionality, not (yet) on other places.
robgeerts
Post by robgeerts »
It's merged :)
Zoekm
Post by Zoekm »
aiolos/Rob, Thanks for the upddate! Will check coming Thursday.
Zoekm
Post by Zoekm »
Todays picture looks as I expect it to be, great, thanks for the help!
afval updated.jpg (2.82 KiB) Viewed 2584 times
jdemas
Post by jdemas »
hi Rob,
is it possible to add one other garbage collector
https://www.rd4info.nl/NSI/Burger/Aspx/ ... lv&nr=4&t=
this is the tekst version of the callendar
It is the callendar for south of Limburg.
regards
Jeffrey
aiolos
Post by aiolos »
jdemas wrote: Thursday 14 December 2017 18:45 hi Rob,
regards
Jeffrey
I created a PR for it. On the last days of the year it might not show the next year yet, but I expect that to 'solve' itself from January 1. (This might also happen with other garbage companies).
robgeerts
Post by robgeerts »
Merged!
Also added an option to the settings-popup!
aiolos
Post by aiolos »
Cool, unfortunately there is a small bug in it, I just found out. Almost fixed it, but then it turned out the page is not available between 00:00 and 03:00, due to a refresh of the information...
I'll complete the fix later.
DewGew
Domoticz version: V4.10618
Post by DewGew »
I have added more garbage setting to the setting menu. See my pull request.
JacEngels
Post by JacEngels »
Is it possible to add support for Venlo https://www.venlo.nl/afvalkalender
aiolos
Post by aiolos »
JacEngels wrote: Thursday 21 December 2017 0:53 Is it possible to add support for Venlo https://www.venlo.nl/afvalkalender
I'll have a look and see what I can do.
