pollefinario
Latest Beta resolved my issues!
JuanUil
- Domoticz version: 4.11083
updated to latest beta but problems stay
javed222pi
- Domoticz version: 3.4834
I’m try to insert an CO2 (air quality) graph, in my dashticz dashboard, but I cant …
How I must to do? I must to edit graphs.js ? but how??
Please help
Please help
Aussi
Does any one have a clue why I get these "undefined" statements ?
I tried to add the garbage module to my dashticz screen. I have it setup that automaticly my favorites are added to the dashticz dashboard.
But then when I add the garbage module and want to save it I get an pop up to add the following code which obviously doesnt work.
Also tried it with the feature automatically add favorites to dashticz off and I get a lot less undefined statements but still too much to get it working.
/* BLOCKS CONFIGURATION */
var blocks = {}
/* COLUMNS CONFIGURATION */
var columns = {}
columns[undefined] = {};
columns[undefined]['blocks'] = ['logo', 'miniclock', 'settings'];
columns[1] = {};
columns[1]['blocks'] = ['undefined', 'garbage', 'undefined'];
columns[2] = {};
columns[2]['blocks'] = ['undefined', 'undefined', 'undefined'];
columns[3] = {};
columns[3]['blocks'] = ['undefined', 'undefined', 'undefined'];-
Stephan83
javed222pi wrote: Sunday 01 April 2018 0:53 Hi all,
Please help
I can get the basiscs of the graph with this code:
//Luchtkwaliteit
blocks[255] = {} //CO2
blocks[255]['width'] = 4;
blocks['graph_255'] = {} //CO2
blocks['graph_255']['width'] = 12;Code: Select all
result
0
co2 "398"
d "2018-04-02 18:15"
1
co2 "399"
d "2018-04-02 18:20"
2
co2 "398"
d "2018-04-02 18:25"
3
co2 "399"
d "2018-04-02 18:30"
4
co2 "398"
d "2018-04-02 18:35"
5
co2 "398"
d "2018-04-02 18:40"
6
co2 "399"
d "2018-04-02 18:45"
7
co2 "414"
d "2018-04-02 18:50"
8
co2 "486"
d "2018-04-02 18:55"
9
co2 "481"
d "2018-04-02 19:00"
10
co2 "480"
d "2018-04-02 19:05"And how can I get the graph in total?
HW:Raspberry Pi 3 B, Pi B,Nano w, Aeon Labs Aeotec Gen 5 Z-Wave USB,P1,RFLink,Fibaro dimmers,Fibaro RGBW, Fibaro wallplug,Harmony Companion,GPIO switches, EUROtronic Spirit
SF:Raspbian Stretch,Domoticz 4.97,HaBridge 5.2.1,Dashticz V2.0
javed222pi
Hi Stephan83!
I have exactly the same problem
The sensor data are correct, but the graph shows no information.
David44
Hello to all.
I started with domoticz since few weeks now and I discovered Dashticz. I tried to make it work by using examples given on differents page.
But i still have a problem to get my sensors present on Dashticz.
I tried raspberry feedback as CPU usage or memery. I've added them to Domoticz as favorites. I've modified IDX inside config.js and nothing appear on Datshticz.
If someone can help it would be much appreciate
JesusArmy
For info I have moved from last Dashticz v2 stable to last beta and it worked right away!JesusArmy wrote: Tuesday 27 March 2018 17:40 Hello, I have installed last stable version (running on Windows 7), have added "auto_positioning" and "use_favorites" but I still not get any switch on Dashticz dashboard.
The rest is "ok", I get sunset and sunrise time from Domoticz on the default right column, and can modify buttons, etc...
I am forgeting something on Dashticz or Domoticz side in order to get my favorites showing up here? Do I have to add a "favorite switch" area in a column?Code: Select all
var config = {} config['domoticz_ip'] = 'http://192.168.11.40:9080'; config['app_title'] = 'Dashticz'; config['domoticz_refresh'] = '5'; config['dashticz_refresh'] = '60'; config['auto_positioning'] = 1; config['use_favorites'] = 1; config['user_name'] = 'Login'; config['pass_word'] = 'Password'; config['loginEnabled'] = 0;
Have last stable of domotic and last stable of Dashticz.
I am now fine tuning my layout...
CaesarPL
Those things doesn't match. Favorites and modifying config.js can't work together. Either favorites or your config.js.David44 wrote: Wednesday 04 April 2018 17:10 I've added them to Domoticz as favorites. I've modified IDX inside config.js and nothing appear on Datshticz.
JesusArmy
Hello again,
I cannot find the syntax to use in Dashticz in order to get time and date.
Basically I would like it to display a weather picture dynamicaly, so I would need to tune the img url to add date and time like this:
Any easy way to get the YYYYMMDDHHMM ?
http://www.jma.go.jp/en/gms/imgs_c/0/infrared/1/YYYYMMDDHHMM-00.png-
aiolos
- Domoticz version: stable
You can use the MomentJS library that's available in Dashticz. You can get the current timestamp as follows:JesusArmy wrote: Tuesday 10 April 2018 7:54 Hello again,
Basically I would like it to display a weather picture dynamicaly, so I would need to tune the img url to add date and time like this:Any easy way to get the YYYYMMDDHHMM ?Code: Select all
moment().format('YYYYMMDDHHmmss');
var url = 'http://www.jma.go.jp/en/gms/imgs_c/0/infrared/1/' + moment().format('YYYYMMDDHHmm') + '-00.png';
JesusArmy
Great thanks, I will try ! Now that I know that I can use MomentJS it should help to build the good url.
(I think actually the website upload only one sat image every 10 min so not all values are accurate for "mm", I will need to round up to nearest possible value
JesusArmy
Here is my final working code if anyone is interrested in working on date strings f0r building URLs.
Sorry comments are in French, but basically I had remove 9h to adjust to GMT time, and then 6 minutes to compensate 5 min time of image upload from Sat image provider. And also truncate last char to round up to last 10 min since there is only one image every 10 minutes.
//Pour la carte météo et les news
var m = moment(); //Object temps actuel
m.subtract(9, 'hours'); //Ajustement GMT
m.subtract(6,'minutes'); //Compense 5min de retard image JMA
var picday = m.format('YYYYMMDDHHmm'); //Date au bon format
picday = picday.substring(0,11); //Garde les 11 premiers caracteres pour garder les min a la dizaine
var picurl = 'http://www.jma.go.jp/en/gms/imgs_c/0/infrared/1/' + picday + '0-00.png'; // Build URL img
var buttons = {}
buttons.buienradar = {width:12, isimage:true, image: picurl};-
Venzent
- Domoticz version: 3.8153
Running Domoticz V3.8153 and latest beta of dashticz V2.3.2, but for me also no devices visible.
Clean install, no changes but the ip and port of my domoticz
poudenes
- Domoticz version: 3.8993
Hi All,
Can you hide the Dimmer Sliders for a lamp? I only want them to turn on/off in Dasthicz and want hide the slider?
Cheers,
Peter
Cheers,
Peter
poudenes
nobody?
- HansieNL
@poudenes:
You can try to add to custom.css:
.ui-slider-handle, .ui-slider-horizontal {
display: none;
display: none;
Blah blah blah
poudenes
@HansieNL that did the trick !! Thanks !!
Venzent
I have my Nest thermostat configured in Domoticz, so the temperature and humidty is reported. I would like to show the temperature on the dashboard, but have no clue on how to do it, cannot find an example either. Any directions for me?
- mAiden88
- Domoticz version: 3.7286
Venzent wrote: Tuesday 01 May 2018 14:18 I have my Nest thermostat configured in Domoticz, so the temperature and humidty is reported. I would like to show the temperature on the dashboard, but have no clue on how to do it, cannot find an example either. Any directions for me?
If you mean dashboard of Dashticz? Then you need to find out what IDX number is youre temperature sensor on Domoticz.
Ex:
My temperature sensor idx on domoticz is: 2
in the config.js file you do the following
columns[1] = {}
columns[1]['blocks'] = ['2'']
columns[1]['width'] = 5;
Anyone can build a fast processor. The trick is to build a fast system.
