Page 17 of 37
Re: ELV Max! Heating control system
Posted: Thursday 03 November 2016 9:24
by hasan
LAU installation problem
Hi guys, I follow Wiki step by step and I have problem with LUA installation
pi@raspberrypi:~/domoticz/scripts/lua $ lua maxtest.lua
lua: maxtest.lua:5: module 'basexx' not found:
	no field package.preload['basexx']
	no file '/usr/local/share/lua/5.2/basexx.lua'
	no file '/usr/local/share/lua/5.2/basexx/init.lua'
	no file '/usr/local/lib/lua/5.2/basexx.lua'
	no file '/usr/local/lib/lua/5.2/basexx/init.lua'
	no file '/usr/share/lua/5.2/basexx.lua'
	no file '/usr/share/lua/5.2/basexx/init.lua'
	no file './basexx.lua'
	no file '/usr/local/lib/lua/5.2/basexx.so'
	no file '/usr/lib/arm-linux-gnueabihf/lua/5.2/basexx.so'
	no file '/usr/lib/lua/5.2/basexx.so'
	no file '/usr/local/lib/lua/5.2/loadall.so'
	no file './basexx.so'
stack traceback:
	[C]: in function 'require'
	maxtest.lua:5: in main chunk
	[C]: in ?
if I try
LUA
I received
Lua 5.2.3  Copyright (C) 1994-2013 Lua.org, PUC-Rio
I checked installation and it seems that LUA was installed into /usr
There is no folder for LUA in /usr/lib/; missing folder 5.2 in /usr/local/share/lua/ - only 5.1 is there; missing folder 5.2 in /usr/local/lib/lua/ - only 5.1 is there
I did clean installation of DOMOTICZ on RPI2 from SD image.
Any idea?
Posted: Thursday 03 November 2016 12:18
by blackdog65
hasan wrote:LAU installation problem
Try this
https://www.domoticz.com/forum/viewtopic.php?f=34&t=841&start=280#p101650
if it works for you I'll update the wiki
Sean
Posted: Thursday 03 November 2016 12:48
by hasan
Try this
Sean
There is problem that folder /usr/local/lib/lua/5.2 doesn't exist. If I created folder manually, still same error. It seems that LUA 5.2 was installed into different folder. I found LUA 5.2 installation in /usr/share/lua/5.2.
Also folder for LUA 5.2 is missing in folder /usr/local/share/lua/ there is only 5.1
Posted: Thursday 03 November 2016 13:36
by blackdog65
maybe a complete removal and reinstall of lua?
sudo apt-get --purge remove lua*
then try reinstall as per previous post.
Unless anyone else has a better idea :?
Posted: Thursday 03 November 2016 13:53
by hasan
blackdog65 wrote:maybe a complete removal and reinstall of lua?
Doesn't work :( I'll do some testing with LUA installation during evening...
Posted: Thursday 03 November 2016 16:18
by hasan
I found command for showing where LUA is installed.
pi@raspberrypi:~ $ whereis lua
lua: /usr/bin/lua5.1 /usr/bin/lua5.2 /usr/bin/lua /usr/local/lib/lua /usr/include/lua5.1 /usr/share/lua /usr/share/man/man1/lua.1.gz
pi@raspberrypi:~ $
Could somebody who has working LUA send me output?
Posted: Thursday 03 November 2016 16:42
by Westcott
I get -
lua: /usr/bin/lua5.1 /usr/bin/lua /usr/bin/lua5.2 /usr/local/lib/lua /usr/include/lua5.1 /usr/include/lua5.2 /usr/share/lua /usr/share/man/man1/lua.1.gz
Posted: Thursday 03 November 2016 16:58
by blackdog65
I get
lua: /usr/bin/lua /usr/bin/lua5.1 /usr/bin/lua5.2 /usr/local/lib/lua /usr/include/lua5.1 /usr/include/lua5.2 /usr/share/lua /usr/share/man/man1/lua.1.gz
@Westcott, did you see my earlier post ref your code change suggestion? Any further thoughts mate? Could that section be snipped out as mvzut suggests? If so... where and I'll try it. :D
Sean
Posted: Thursday 03 November 2016 17:47
by Westcott
Hi Sean,
My code change was merely to see what the unknown device names were, and stop them from being processed.
That is what was causing the crashes.
You then have the opportunity to add/edit Domoticz devices.
I'm sure that Mvzut will come up with a 'proper' fix!
Posted: Thursday 03 November 2016 17:52
by mvzut
Westcott wrote:I'm sure that Mvzut will come up with a 'proper' fix!
I'll have a look later tonight, first need to pick up my daughter from gymnastics class, cook dinner and get all the kids in bed.
People around me sometimes wonder where I find the time to work on all this home automation stuff, now wondering myself too... Image
Posted: Thursday 03 November 2016 18:22
by Skippiemanz
We will be patient... At least we will try
Posted: Thursday 03 November 2016 18:39
by blackdog65
Skippiemanz wrote:We will be patient... At least we will try Image
+1 :lol:
Posted: Thursday 03 November 2016 20:05
by mvzut
blackdog65 wrote:Could that section be snipped out as mvzut suggests? If so... where and I'll try it. :D
Yes, in my opinion you should completely remove this part:
        --Temperaturdevices den Status aktualisieren
       if temp ~= 0 and dtype == "Valve" then
           table.insert(commandArray, { ['UpdateDevice'] = otherdevices_idx[name.." (Valve)"]..'|0|'..temp..';'..valve_pos..';0'})
        elseif  temp ~= 0 and dtype == "Thermostat" then
            table.insert(commandArray, { ['UpdateDevice'] = otherdevices_idx[room]..'|0|'..temp})
Actually I have no idea where this part of the code came from, you probably got this from another source? (also judging from the German comment). It was not in my original version of this script, a few pages back. There are more additions compared to my script, such as that it only updates if the system is in Manual mode, but if you want you can leave that in (although I don't have this condition in my own version of the script).
Posted: Thursday 03 November 2016 20:30
by Skippiemanz
But what would youre preffered version of the script be?
Posted: Thursday 03 November 2016 20:35
by blackdog65
Skippiemanz wrote: But what would youre preffered version of the script be?
+1 again lol
I agree, can we compare your script with ours and then I'll change the wiki.
It looks like the lua part of the wiki is a bit dodgy/buggy :roll:
Many thanks mvzut
Posted: Thursday 03 November 2016 23:30
by mvzut
Skippiemanz wrote:But what would youre preffered version of the script be?
This is my currrent script, adapted with some changes to improve handling of systems without wall thermostats:
package.loadlib("core.so", "*")
local Socket = require "socket"
local Basexx = require "basexx"
local MaxIP='192.168.178.46'
local MaxPort = 62910
local useWMT = true --Set to true if there is a wall mounted thermostat in every room
local interval = 5
local DomoticzPort = 8080
local Rooms   = {}
local Devices = {}
local Room_nums = {}
function age(timestring)
  t = {}
  t.year = string.sub(timestring,1,4)
  t.month = string.sub(timestring,6,7)
  t.day = string.sub(timestring,9,10)
  t.hour = string.sub(timestring,12,13)
  t.min = string.sub(timestring,15,16)
  t.sec = string.sub(timestring,18,19)
  return os.difftime(os.time(),os.time(t))
function maxCmd_H(data)
--   print('H='..data)
function maxCmd_M(data)
   i = 0
   j = 0
    while true do    -- find next comma
      i = string.find(data, ",", i+1)
      if not i then break end
     j = i
   s   = data:sub(j+1)
   dec = Basexx.from_base64(s)
   num_rooms = string.byte(dec,3)
   pos=4
   for i=1, num_rooms do
      room_num = string.byte(dec, pos)
      name_len = string.byte(dec, pos+1)
      pos  = pos+2
      name = dec:sub(pos, pos+name_len-1)
      pos  = pos+name_len
      adr  = Basexx.to_hex(dec:sub(pos, pos+2))
      Rooms[room_num] = name
      pos = pos+3
   num_devs = string.byte(dec, pos)
   for i=1, num_devs do
      dtype = string.byte(dec, pos+1)
      adr   = Basexx.to_hex(dec:sub(pos+2, pos+4))
      snum  = dec:sub(pos+5, pos+14)
      name_len = string.byte(dec, pos+15)
      pos  = pos+16
      pos  = pos+name_len
      Room_nums[adr] = room_num
      Devices[adr] = name
function maxCmd_C(data)
--   print('C='..data)
function maxCmd_L(data)
   pos = 1
   dec = Basexx.from_base64(data)
   L_hex = Basexx.to_hex(dec)
   L_len = string.len(L_hex)
   while (pos < L_len) do
      s = L_hex:sub(pos,(pos+1))
      data_len  = tonumber(s,16) + 1
      hex  = L_hex:sub(pos,pos+(data_len*2))
      adr  = hex:sub(3,8)
      room_num = string.format("%02X", Room_nums[adr])
      room = Rooms[Room_nums[adr]]
      name = Devices[adr]
      if not name then name=adr end
      valve_info = tonumber(hex:sub(13,14),16)
      batt = bit32.extract(valve_info,7,1)
      bst  = bit32.extract(valve_info,3,1)
      mode = bit32.extract(valve_info,0,2)
      if (batt==0) then sbat="OK" else sbat="Low" end
      if (mode==0) then smode="Auto" elseif (mode==1) then smode="Manual"
      elseif (mode==2) then smode="Holiday" elseif (mode==3) then smode="Boost" end
      if (data_len == 13) then	-- WallMountedThermostat (dev_type 3)
        valve_pos = -1
        s = hex:sub(17,18)
        setpoint = tonumber(s,16) / 2
        s = hex:sub(23,26)
        temp = tonumber(s,16) / 10
        dtype = "Thermostat"
      elseif (data_len == 12) then -- HeatingThermostat (dev_type 1 or 2)
        s = hex:sub(15,16)
        valve_pos = tonumber(s,16)
        s = hex:sub(17,18)
        if (mode ~= 2) then
          s = hex:sub(19,22)
          temp = 0
        dtype = "Valve"
      --Following two lines correct temperatures over 25.5 degrees, since e.g. 26 degrees is reported as 0.5 degrees
      --This is due to the fact that temperatures seem to be stored as two Hex characters only (= max 255 in decimal)
      --Pending better solution
      if temp < 5 then temp = temp + 25.5 end
      if setpoint > 50 then setpoint = setpoint - 64 end
      -- Update virtual devices in Domoticz and update MAX! setpoints if necessary
      --print(dtype.."  "..name.."  Setpoint="..setpoint.."  Temp="..temp.."  Valve pos="..valve_pos)
      if dtype == "Valve" then
        table.insert(commandArray, { ['UpdateDevice'] = otherdevices_idx[name]..'|0|'..valve_pos})
	if not useWMT then --Use valve to check thermostat setpoint mismatch
          name = name:sub(1,-5) .. "-Stat"  -- set thermostat name to valve name with "-Stat" instead of "-Rad" suffix
          setpoint_Domoticz = tonumber(otherdevices_svalues[name])
          if setpoint_Domoticz ~= setpoint then
            if age(otherdevices_lastupdate[name]) > interval * 60 then --Domoticz thermostat value must be updated
              table.insert(commandArray, { ['OpenURL'] = 'http://127.0.0.1:"..DomoticzPort.."/json.htm?type=command&param=udevice&idx='..otherdevices_idx[name]..'&nvalue=0&svalue='..setpoint})
              print('Domoticz setpoint ' .. name .. ' updated')
            else --Max! setpoint must be updated
              MaxCmdSend(adr, room_num, "manual", setpoint_Domoticz)
              print('MAX! setpoint ' .. name .. ' updated')
      elseif dtype == "Thermostat" then
      pos = pos + (data_len*2)
function MaxCmdSend(id, room, mode, setpoint)
   bits  = setpoint * 2
   smode = string.upper(mode)
   if smode == 'MANUAL' then
      bits = 64 + bits
   elseif smode == 'BOOST' then
      bits = 192 + bits
   elseif smode == 'VACATION' then
      bits = 128 + bits
   hex = "000440000000"..id..room..string.format("%x",bits)
   sendStr = Basexx.to_base64(Basexx.from_hex(hex))
   i, status = tcp:send("s:"..sendStr.."\r\n")
   if not i then
      print("MAX TCP send failed - "..status)
      return
local m = os.date('%M')
if (m % interval == 0) and (m ~= 0) then
  tcp = Socket.connect(MaxIP, MaxPort)
  if not tcp then
    print("Socket connect failed for "..MaxIP..':'..MaxPort)
    return
  tcp:settimeout(2)
  while true do
    s, status, partial = tcp:receive()
    if (status) then
      print("TCP receive - "..status)
     break
    local line = (s or partial)
    local cmd  = line:sub(1,1)
    local data = line:sub(3)
    if (cmd == 'H') then
      status = maxCmd_H(data)
      if status == 'Error' then break end
    elseif (cmd == 'M') then
      maxCmd_M(data)
    elseif (cmd == 'C') then
      maxCmd_C(data)
    elseif (cmd == 'L') then
      maxCmd_L(data)
      break
  tcp:close()
A few important notes on the naming scheme:
  • If you have a wall thermostat in every room (set "useWMT" to true), you need to name your Domoticz dummy temperature sensor(s) after your room(s) as defined in MAX!, your dummy percentage sensor(s) after your valve(s), and your dummy thermostat device(s) after your thermostat(s).
  • If you don't use wall thermostats (set "useWMT" to false), you need to name your dummy percentage sensor(s) after your valve(s), your dummy thermostat device(s) after your valve(s) where the "-Rad" suffix is replaced by a "-Stat" suffix, and you DON'T need to have a dummy temperature sensor
The naming of the actual MAX! deivces (done int the MAX! configuration software) should be as suggested in the Wiki, so a "-Rad" suffix for the valve names and a "-Stat" suffix for the thermostat names. This is to let the other LUA script (the one which switches the heater etc.) do its job.
P.S. I also changed the direct LUA update command for the Domoticz thermostats into an http JSON command. This is because updating thermostats from within LUA caused error messages stating that the script was running longer than 10 seconds, for reasons not understood. If you get errors in the log because of this JSON method, please add 127.0.0.* to your list of local networks that don't require authentication (this can be done on the settings page).
Posted: Thursday 03 November 2016 23:36
by blackdog65
I'll try this now. Since the last mod (at 19.36) my stat temperatures have flat-lined.
Posted: Thursday 03 November 2016 23:40
by mvzut
blackdog65 wrote:I'll try this now. Since the last mod (at 19.36) my stat temperatures have flat-lined.
Please use the latest code, I changed something a few minutes after first uploading it. Didn't realize you were that quick to try ;-). Only important if you don't have wall thermostats by the way.
Posted: Thursday 03 November 2016 23:42
by blackdog65
Just tried it... nothing in log as no debug... but all sensor reporting now... YAY! :D
Posted: Thursday 03 November 2016 23:50
by mvzut
blackdog65 wrote:Just tried it... nothing in log as no debug... but all sensor reporting now... YAY! :D
Great to hear! You can always add debugging if you want (there's one print command already in the code that you can un-comment), but I personally like to keep my log clean when everything is working well.
