Page 17 of 32
Re: Testers wanted!
Posted: Friday 30 September 2016 11:55
by Madgeni
chimit wrote:Madgeni wrote:
IFTT support will probably be added during/after app support (with OAUTH).
Currently there's no target date known of when that will be finished.
+1 for oauth2 support! Any idea on timescales?
The short answer: No. It depends on whenever I have enough free time available for implementation and testing.
Totally understand - appreciate all your hard work
Re: Testers wanted!
Posted: Sunday 02 October 2016 22:02
by mikejclark
Still just get this in my log:
Error: PROXY: Connect failed, reconnecting: Network is unreachable
Any ideas?
Re: Testers wanted!
Posted: Monday 03 October 2016 19:16
by Minglarn
Same here...
From the log:
- Skärmklipp.PNG (12.25 KiB) Viewed 4141 times
The problem with the dashboard [how to fix]
Posted: Monday 10 October 2016 19:04
by ArturK
The problem with the dashboard.
If I choose a floor plan as the dashboard mode (normal, compact, mobile and floorplan options) in the Domoticz settings, in the upper menu the button "Floorplan" (between Dashboard and Switches) disappears and the link
http://192.168.1.5:8080/#/Dashboard doesn't exist. When I click on "Dashboard", the address is "
http://192.168.1.5:8080/#/Floorplans" not "
http://192.168.1.5:8080/#/Dashboard". I prefer this, because floorplan is my favourite.
In this case, trying to
connect from my.domoticz.com to local domoticz server by pressing the green man icon is impossible. This is because mydomoticz tries to connect with "
https://my.domoticz.com/mydomoticz/dashboard#Floorplans".
In case, when the dashboard in domoticz is different than floorplan, when I click green man icon in mydomoticz, it connects with address "https://my.domoticz.com/my/3...4/#/Dashboard" and all works fine.
Please fix it, thanks.
Re: Testers wanted!
Posted: Monday 10 October 2016 21:29
by waow29
I register on Domiticz.com, filled all field in my Domitcz but my boad stay clear and I have this message in the Log:
PROXY: Connect failed, reconnecting: Connection timed out
And MyDomoticz Instance ID: (none)
Any Idea to help me
Re: Testers wanted!
Posted: Monday 17 October 2016 12:59
by DaWauZ
I have registered and set up but I only see this in de logs:
Online I see this only
- domoticz1.jpg (21.98 KiB) Viewed 4067 times
My dashboard are some switches and a group.
Re: Testers wanted!
Posted: Wednesday 26 October 2016 9:56
by marcellll
- Screenshot_20161026-110105_1.jpg (87.71 KiB) Viewed 3991 times
i have installed domoticz on my raspberry pi. Works all good. After that, i followed the steps from
http://domoticz.com/wiki/MyDomoticz and that also worked.
Unfortunately, i removed the instance from my dashboard, but probably when Domoticz was connected. Now, i can log in but i see only a empty dashboard. I cant find out how to repair / reset this to get mydomoticz get worked again. Can someone tell me how to fix this or where i can find the information to do this?
Many thx, Marcel
Re: Testers wanted!
Posted: Thursday 10 November 2016 11:04
by pybypl
hello.
Yesterday i've updated Domoticz on RPI with ./updaterelease;
finally domoticz instance came up in MyDomoticz.
But when i click on green icon it shows background of my domoticz, then returns to instances list.
- domo2.jpg (138.76 KiB) Viewed 3906 times
- domo1.jpg (28.89 KiB) Viewed 3906 times
Unfortunately i cant see now the log file, maybe in the evening.
OK the message was "browser cache failed" and login dialog wont appear.
When i change it to Firefox everything works fine!!!
THANKS!!!!!!!
Re: Testers wanted!
Posted: Sunday 13 November 2016 11:15
by Toni
Domoticz instance goes offline in the MyDomoticz portal, and does not come back before Domoticz is restarted. In the logs I have:
2016-11-13 07:16:30.112 Error: PROXY: timeout occurred, reconnecting
2016-11-13 07:16:45.115 Error: PROXY: StartThread(): Exception: resolve: Host not found (non-authoritative), try again later
Domoticz is connected to the network via Huawei 4G router B593.
This exception seems to come from CProxyManager::StartThread(), perhaps the StartThread is not rescheduled if it fails?
EDIT: I think I got it fixed:
https://github.com/domoticz/domoticz/pull/978
Re: Testers wanted!
Posted: Wednesday 16 November 2016 9:15
by pybypl
Got the same error as user above.
For me connection was lost "forever" when I've changed the password in settings via domoproxy.
Connection was lost, domoticz was freezed. After restart i cant connect - host not found.
I'll provide logs soon.
Re: Testers wanted!
Posted: Wednesday 23 November 2016 6:46
by michaldobrotka
Hi Everyone,
is the service down?
Just wondering, nobody is talking about it and I cant connect it for few days.
Re: Testers wanted!
Posted: Thursday 24 November 2016 13:14
by pybypl
Hello. My instance was working fine after making new account few days ago.
Till now - MyDomoticz was offline (maybe yesterday)? since then i have no instance od the control panel.
Will my domoticz be stable in the future or its only for educational purpsoes and it will disappear soon?
Re: The problem with the dashboard [how to fix]
Posted: Thursday 24 November 2016 15:51
by chimit
Could you post this here?
https://github.com/domoticz/mydomoticz/issues
Re: Testers wanted!
Posted: Thursday 24 November 2016 15:56
by chimit
Toni wrote:Domoticz instance goes offline in the MyDomoticz portal, and does not come back before Domoticz is restarted. In the logs I have:
Probably this is a network or DNS configuration issue on your end. That StartThread() is not rescheduled is on purpose. We don't want to reconnect if there´s no network to avoid error messages every 15 seconds.
Re: Testers wanted!
Posted: Thursday 24 November 2016 16:01
by chimit
Yeah, MyDomoticz has been offline for a bit.
It´s back now on a fresh host and available for the people who run a recent beta.
Unfortunately I don´t have time to respond immediately in case an issue arises. So there´s no SLA kind of warranties of this service.
Thanks to all the people who have helped testing so far.
°° Rene
Re: Testers wanted!
Posted: Friday 25 November 2016 8:23
by Toni
No, this had to be fixed (and was fixed by that pull request). Without this, any short network outage will cause Domoticz to not reconnect to MyDomoticz. For example, if you pull the ethernet cable for a short while, the MyDomoticz connection didn't come back until Domoticz was restarted. Imagine having Domoticz in some remote place, when having a short network outage in the 3G or 4G network...
Re: Testers wanted!
Posted: Friday 25 November 2016 8:27
by chimit
The problem was that all of a sudden the Domoticz's started reconnecting enlessly without any delay in between, causing a ddos on MyDomoticz.
I cannot "prove" that this was because of your patch. But it generated the same log line and it did start after applying your patch.
I promise will try to look into it more, when I get the time.
Re: Testers wanted!
Posted: Friday 25 November 2016 11:13
by Toni
Ouch, sorry if I caused that... It should probably have some retry delay.
Anyway, without my patch all you need is to disconnect the network for a short while -> MyDomoticz connection never comes back. It's very easy to reproduce this for example with the Windows version, just by placing a breakpoint on that line of code, and then pulling the network cable for a while.
Re: Testers wanted!
Posted: Friday 25 November 2016 11:36
by chimit
Toni wrote:Ouch, sorry if I caused that... It should probably have some retry delay.
The funny thing is. The Reconnect() function does have a time-out. So we're not 100% sure, but we wanted to better be safe than sorry.
Like I said, I will look into it again and put your code back as neccesary.
Re: Testers wanted!
Posted: Friday 25 November 2016 12:27
by chimit
chimit wrote:Toni wrote:Ouch, sorry if I caused that... It should probably have some retry delay.
Toni, I put your idea of catching resolver errors back in it, just in a bit of another form.
The suspected bug was probably of another cause. But your patch made it trigger.
The ContinueConnect() function gets invoked by an async_wait command. I suspect that the timer gets cancelled under some circumstances, which basically turns the timeout into 0.
Would you be so kind to check out my "iteratorbug" pull request and see if you see something wrong with it?
Also the resolver iterator was not correctly increased.
== Rene
