dtgbot - Domoticz TeleGram BOT
nosehook
Re: dtgbot - Domoticz TeleGram BOT
Post by nosehook »
I am not that familiar with Linux, so I do not know how I am afraid...
I tried sudo apt-get remove libssl1.0.0_1.0.1t-1+deb8u8_armhf.deb
resulting in:
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package libssl1.0.0_1.0.1t-1+deb8u8_armhf.deb
E: Couldn't find any package by glob 'libssl1.0.0_1.0.1t-1+deb8u8_armhf.deb'
E: Couldn't find any package by regex 'libssl1.0.0_1.0.1t-1+deb8u8_armhf.deb'
Pi3 Domoticz | RFXcom 433E | KAKU/COCO |Harmony Hub | Samsung TV | HS100 | HS110| HUE | Tradfri | Tado| Xiaomi |sensors | scripts| Pi3 Node Red | Pi2 SDS_011 + MH-Z19B | PiAware (zero) | Pi2 breadboard with Node red and Domoticz
pesa1234
Domoticz version: 2020.1
Post by pesa1234 »
Hi, thanks for the dgtbot service, very good.
I have an issue with the selector label name:
Here my log... How can I solve this issue?
dtgbot: Start DTGMENU ... (1) Riscaldamento
2018-12-05 11:38:35 - ==> menu.lua process:Riscaldamento
2018-12-05 11:38:35 - -< getSelectorStatusLabel found: T2ZmfEF1dG98Rm9yY2Vk (1) 1 (2) T2ZmfEF1dG98Rm9yY2Vk
2018-12-05 11:38:35 - -< getSelectorStatusLabel not found: 2 (1) 1 (2) T2ZmfE5vcm1hbHxFY29ub215
2018-12-05 11:38:35 -   -< replymarkup:{"keyboard":[["Caldaia - Off"],["Economy_Temp - 20.0°C"],["Normal_Temp - 21.0°C"],["StatoCaldaia - Off"],["Termostato - T2ZmfEF1dG98Rm9yY2Vk"],["Termostato_-_Mode - "],["Termostato_-_Pausa - On"],["menu"]],"selective":true,"resize_keyboard":true}
2018-12-05 11:38:35 - ==< show options in submenu.
Why that strange label T2ZmfEF1dG98Rm9yY2Vk? I use SVT plugin
And also this...
tgbot: Start DTGMENU ... (1) Clima
2018-12-05 11:38:27 - ==> menu.lua process:Clima
2018-12-05 11:38:27 - -< getSelectorStatusLabel not found: 0 (1) 1 (2) T2ZmfEF1dG98RHJ5
2018-12-05 11:38:27 -   -< replymarkup:{"keyboard":[["AC_Mode - "],["AC_Temp - 24.0°C"],["menu"]],"selective":true,"resize_keyboard":true}
2018-12-05 11:38:27 - ==< show options in submenu.
What I make wrong? Thanks
jvdz
Domoticz version: 4.107
Post by jvdz »
This is an issue since the last production version of Domoticz where the Selector switch options are encoded with base64, and you are the first one reporting the issue as I haven't upgrade my production system as yet. :)
I will have a look at this in the coming days an post the fix.
PM me in case you would like to help testing.
Jos
pesa1234
Post by pesa1234 »
At the moment I can't send PM, I don't know why, but, sure I can try help you.
TomDZ
Post by TomDZ »
I seem to be having the same problem as other users on this forum:
/usr/bin/lua: error loading module 'ssl.core' from file '/usr/local/lib/lua/5.2/ssl.so':
        libssl.so.1.0.0: cannot open shared object file: No such file or directory
stack traceback:
        [C]: in ?
        [C]: in function 'require'
        /usr/local/share/lua/5.2/ssl.lua:7: in main chunk
        /usr/local/share/lua/5.2/ssl/https.lua:10: in main chunk
        /home/pi/dtgbot/dtgbot.lua:66: in main chunk
        [C]: in ?
jvdz
Post by jvdz »
Have you added the extra LUA libraries as described in the instructions? :
https://www.domoticz.com/wiki/Remote_Co ... _Libraries
Jos
TomDZ
Post by TomDZ »
Jos,
I did indeed add them. Downloaded them from your first post and installed them to the required directory.
I read the following and wonder if this is the problem:
Libssl.so.1.0.0 obsolete library on Raspbian Stretch, updated November 2017. Since the beginning of November 2017, the libssl.so.1.0.0 library seems to no longer be integrated into the Raspbian Strech repository. Here’s how to install the library. A big thank you to Guillaume for the tip.
See article : https://diyprojects.io/domoticz-install ... DcKIS7TXeV
The installation I didn't do because i get a lot of warnings and errors with files missing when I follow the description given in the article.
Regards,
Tom
pimseb
Post by pimseb »
Anybody got this bot working ?
I have this error in my log file :
/usr/bin/lua5.2: error loading module 'socket.core' from file '/usr/local/lib/lua/5.2/socket/core.so':
        /usr/local/lib/lua/5.2/socket/core.so: wrong ELF class: ELFCLASS64
jvdz
Post by jvdz »
Looks like you need to rebuild those userfiles. Are you not using a raspberry?
Jos
pimseb
Post by pimseb »
Hello jos yes I do with rasbian stretch.
I followed the tutorial on domoticz wiki and used the tar.gz files from the first page of this post
jvdz
Post by jvdz »
Understand, but it that precompiled version seems not be compatible with your RaspberryPI. which version are you using?
I am still an older RPI and have no issues with the core.so. I did have some issue with the ssl.so when I upgraded one of the PI's to Stretch as that was causing some crash every now and then so rebuild that from the source found here: https://github.com/brunoos/luasec
Jos
pimseb
Post by pimseb »
My version :
Linux raspberrypi 4.14.90-v7+ #1183 SMP Fri Dec 21 14:03:50 GMT 2018 armv7l GNU/Linux
model name : ARMv7 Processor rev 4 (v7l)
BogoMIPS : 38.40
Raspberry Pi 3 Model B Rev 1.2
jvdz
Post by jvdz »
I don't have a RPI3b so can test with that.... maybe others have tested this?
Maybe @simonrg can tell us which sources he used to compile these libraries, but my guess is these:
https://github.com/diegonehab/luasocket -> socket.* stuff
https://github.com/brunoos/luasec -> /usr/local/lib/lua/5.2/ssl.so
Jos
pimseb
Post by pimseb »
Thank you jvdz. It seems to be very complicated for me. However I'd love to see this bot working...
I've checked https://github.com/brunoos/luasec but the makefile is about lua 5.1 and not 5.2. Isn't it a problem ?
miroslavpetrov
Post by miroslavpetrov »
Hello everyone. I have the following problem to solve:
I use domoticz in my factory to control many things and heating is one of them. I have heating schedule set by timers. However, if the production schedule lags behind, we need to work on Saturday. The problem is my schedule is set from Monday to Friday and I have created a second timer plan in domoticz that includes Saturday. I have created a virtual switch called "Working Saturday" and if it is set to ON, domoticz switches to the second timer plan.
So, why I write in this topic... My idea is to use my telegram bot to ask me every Friday at 16:00 "Are we working tomorrow" and if I answer with "yes" it will turn on the virtual switch.
I have been reading about dtgbot and telegram bot in general but I didin't find a solution to this. Can somebody help?
Automation Hardware:
Domoticz on Raspberry Pi 3 with HomeBridge.
Zigbee2MQTT + Xiaomi sensors
Fibaro HomeCenter 2 + Fibaro Dimmer2 & Double Switch2 + Aeon Multisensor 6 + Remotec ZXT-120
Eastron SDM230
pimseb
Post by pimseb »
Sorry I still can't make dtgwork I can't help you :-(
I was unable to compile the libraries for lua, I don't even know how to do it. If somebody has them compiled for the Rapberry 3B (ready to use, like the 2 rar files on the first page of this post) please send them to me :-)
Marcello1970
Post by Marcello1970 »
I've got the bot working on the RB3.
Edit the sources.list
sudo nano /etc/apt/sources.list
add the next line:
deb http://archive.raspbian.org/raspbian/ jessie main contrib non-free rpi
Save it with CTRL + X , Y
and then:
sudo apt-get update
sudo apt-get install libssl1.0.0
Then the bot works!
Thanks to:
https://diyprojects.io/domoticz-install ... HfCKOhKgdW
pimseb
Post by pimseb »
Marcello1970 : Thank you so much ! It's working here finally
I have now to figure out how to use it. Btw I'm able to talk to my bot directly in private but is it possible to have the command in a channel shared by a group ?
beamzer
Domoticz version: stable
Post by beamzer »
Is there a way to set variables from dtgbot ? I use these to control my alerting options from the PIR sensors (wemos d1 mini through mqtt), so controlling these through telegram would be nice.
      devices = {
         'PIR-1'
   execute = function(domoticz, PIRswitch)
      if (PIRswitch.state == 'On') then				-- if1
	 if (domoticz.variables('SchuurAlert').value == 1) then -- if2
         	domoticz.log('PIR Schuur Alert')
         	domoticz.notify('Domoticz Alert', 'Schuur Motion', domoticz.PRIORITY_EMERGENCY, domoticz.SOUND_DEFAULT,'', domoticz.NSS_PUSHOVER)
         	domoticz.variables('SchuurAlert').set(0)
	elseif (domoticz.variables('SchuurAlert').value == 2) then
        	domoticz.notify('Domoticz Alert', 'Schuur Motion', domoticz.PRIORITY_EMERGENCY, domoticz.SOUND_DEFAULT,'', domoticz.NSS_TELEGRAM)
	end -- if2
      end -- if1
   end -- execute
Domoticz stable on a Raspberry Pi 3
RFXtrx433E - RFLink - Smartmeter (through RasPi-Zero-W) - Hue - BMP180 - DHT22 - Wemos D1 Mini's with PIR
jvdz
Post by jvdz »
You could simply create a bash file in dtgbot/bash and have that set the uservariable. Just have a look at the existing examples and modify one to set the appropriate uservariable via an JSON command.
Jos
