Geofence for Domoticz
thecosmicgate
Domoticz version: newest
Re: Blockly export
Post by thecosmicgate »
gjaa wrote:I stopped with Domofence
I use now https://www.domoticz.com/wiki/Presence_detection
This script checks the presence off the ip-addresses of the phones in the home network
Gerard
But then you need WiFi enabled , I used both ;) en geo and WiFi so the presence should be detected better
Sent from my SM-G935F using Tapatalk
It's nice to be important, but it's more important to be nice
Scooter ;)
thecosmicgate
Re: Geofence for Domoticz
Still the requist : multiple servers ;) at moment i'am running a stable and beta = test environment and wanted to send the presence to both servers
Scooter ;)
Misterik
Post by Misterik »
Appesteijn wrote: Thursday 25 January 2018 7:57 I currently don't have much spare time to work on this. I'll post here when I have an update.
Hopefully you find some time soon, because it is very annoying Android 8 is not working.
RPI-3 : RFLink + Zigbee2MQTT + Shelly + MySensors + Milight
mic71
Post by mic71 »
The app works a couple of times about 3 or 4 times and after the app don't work anymore untill i press the button in the middle it works again for a couple of times. I have android 8 on samsung galaxy s8+. Please solve!
Thanks.
Regards,
Mic
marcpos
Post by marcpos »
Hi Appesteijn, I hope you can find a moment of your time to take a look at the new Android 8 API. Thanks in advance!! :roll:
mic71
Post by mic71 »
Its a nice solution. I have use ping in domoticz but it is to slow for opening roller shutter its take some time to detect my phone and than i must wait untill the shutter is openend :cry: Maybe has Appestein time for solve it :P
Appesteijn
Post by Appesteijn »
I have an improved version almost ready, but don't have Android 8.0 so it will be difficult to test for me. I will post a beta link here once it is ready.
smithoofd
Domoticz version: 3.8153
Post by smithoofd »
Hi Appesteijn, happy to help you testing. I have Andriod 8.0, let me know if I can help.
Appesteijn
I have just posted some beta builds in the Play Store. As I don't have an phone with Android 8+ (yet) it is difficult for me to test if everything correctly works.
Android 8 has some pretty big changes in Geofencing, Notifications and apps that run in the background (This is exactly everything my app does...).
If you want to help test you can join the Beta test here: https://play.google.com/apps/testing/co ... .domofence
Please be aware that sometimes these versions can be broken (of course I try to avoid this)
manutremo
Post by manutremo »
Appesteijn, many thanks for taking the time to work on these updates. I just installed the last beta in my Oreo and will test it tomorrow on my way to work. For the moment it seems to be working correctly. I'll report back asap!
mic71
Post by mic71 »
Thank you ferry much for your work Appesteijn, but it wont work for me with galaxy s8+ kind regards Mic
Verstuurd vanaf mijn SM-G955F met Tapatalk
marcpos
Post by marcpos »
Great, thanks for the new (beta) version!!
But it looks like it only sends the home/On signal. The leaving/Off singnal won't work.
And the notification only works once (when editting the settings and adding the Geofence).
manutremo
Post by manutremo »
Many thanks for this great piece of software. In my case:
In my Asus with Oreo, the last beta seems to work well... great!
In my wife's phone, Samsung on Android 4.4.2, the app hangs when setting the geofencing, although it then seems to work... But only sends the signal when leaving the fence, but not when entering again.
Open for more testing if needed :-)
Appesteijn
I just released a new version (2.9.9) it should work correctly on all Android versions. If not please let me know.
mic71
Post by mic71 »
Its not working i have tried many times but it wont work on android 8.0.0
manutremo
Post by manutremo »
Thanks for the hard work and I'm sorry to report this but while working great on Android 8, last version is not yet working on my wife's Android 4.4.2. Made more tests with other geofencing apps (e.g. EgiGeoZone) and they work correctly both when entering ans leaving the geofence. It would be great however to get Domofence running since other apps are significantly heavier.
Appesteijn
Thx for you feedback, I'm looking for a solution for those two devices.
andreo
Domoticz version: 2024.3
Post by andreo »
Hello Appesteijn,
Tested on a Huawei Mate 9 (oreo) and its not working.
Latest version of Domoticz and more running on Docker|Raspberry Pi 4-B 8GB Bookworm|RF-Link|Klik Aan Klik Uit|Nefit easy|ESPeasy|P1 power meter|S0PCM-5 through Ser2Net|Alecto WS5500|FrtizBox|Satel Integra|Solis
Greetz Andre.
marcpos
Post by marcpos »
Unfortunately same problem over here with the Galaxy S8 with Oreo. During/leaving the initial setup, it gives a onetime notification but after that, no switches are made when entering or leaving the geofence (and no notifications). :(
Thanks for you support!
Appesteijn
manutremo wrote: Sunday 15 April 2018 16:37 Thanks for the hard work and I'm sorry to report this but while working great on Android 8, last version is not yet working on my wife's Android 4.4.2. Made more tests with other geofencing apps (e.g. EgiGeoZone) and they work correctly both when entering ans leaving the geofence. It would be great however to get Domofence running since other apps are significantly heavier.
I put a version in Beta that should fix Android 4.4
