Page 17 of 21
Re: Netatmo authentication changes Oct 2022
Posted: Monday 24 March 2025 12:07
by cadkey
You can follow my post above to check your access_token and access to the Netatmo server.
Posted: Monday 24 March 2025 15:29
by DomoFlits
jcb2 wrote: Monday 24 March 2025 12:01 always one other error : "No access granted, forcing login again (Refresh tokens): invalid_client"
You have another error than most of us here have. We have:
Invalid/no data received (refresh tokens)... HTTP/2 403
You should check your client ID, Client secret and tick the scope(s) you own in Domoticz.
Posted: Monday 24 March 2025 16:36
by chrominator
Log with new PR #6281:
Capture d'écran 2025-03-24 163250.png (20.9 KiB) Viewed 12472 times
... Waiting for 45 mn.... Keep you posted.
Posted: Monday 24 March 2025 16:43
by phil35
@jpaul : I am this owner of netatmo_manage_tokens.php , and it works like a a charm. I tested every day with the other script netatmo-floodlight Public , by these days ;-) ,
The archictecture is:
sonoff button -> domoticz via zigbee -> a script handles (one click, double click and long click) and uses the access_token, stored and managed by netatmo_manage_tokens.php to perform the action on the camera.
[https://www.domadoo.fr/fr/peripheriques ... ee-30.html]
What is the build number 16583? and where to find it?
on the domoticz download page there is only stable 2024.7.16140 or beta 2024.7.16586
Thank you.
Phil
Posted: Monday 24 March 2025 16:56
by chrominator
chrominator wrote: Monday 24 March 2025 16:36 Log with new PR #6281:
No time to wait.
Added some debug lines to the source:
Capture d'écran 2025-03-24 164811.png (56.89 KiB) Viewed 12467 times
compile and restart:
Got a good reply from the Netatmo server then, it worked directly, no relation with my changes in the source.
Capture d'écran 2025-03-24 164029.png (52.24 KiB) Viewed 12467 times
Still working randomly, I'm saved probably until the next restart.
Posted: Monday 24 March 2025 17:57
by jcb2
With last beta, after one renew of ID and password and one restart I have always one error :
2025-03-24 17:52:28.197 Status: Domoticz V2025.1 (build 16586) (c)2012-2025 GizMoCuz
2025-03-24 17:52:37.668 Error: Météo: Invalid/no data received (refresh tokens)... HTTP/2 403
When I try to use the button connexion into hardware I have this error :
Posted: Monday 24 March 2025 19:20
by jpaul
Hello @phil35,
phil35 wrote: Monday 24 March 2025 16:43 I am this owner of netatmo_manage_tokens.php , and it works like a a charm.
I know your module netatmo_manage_tokens.php works. But I had to create a new App on dev.netmatmo website. With my historical App, used by Domoticz for a while, I'm unable to refresh the token with netatmo_manage_tokens.php (even when Netmatmo plugin is disabled in Domoticz).
That's why I suspect Netatmo of banning or blacklisting some Apps when they generate with too many errors.
Posted: Monday 24 March 2025 19:32
by jpaul
Hi dev team,
Could it be an issue with the HTTPClient lib ?
I added debug in httpclient/HTTPClient.cpp , this line
curl_easy_setopt(curl, CURLOPT_VERBOSE, 1L);
in HTTPClient::POSTBinary and HTTPClient::GETBinary methods,
and it seems the headers are not exactly the same between Domotiz and netatmo_manage_tokens.php
Posted: Monday 24 March 2025 20:26
by homeJLB
jcb2 wrote: Monday 24 March 2025 12:01 Hello,
One new PR is available into new beta about issue of Netatmo.
For me this is always not good. I have wait 20 minutes but always one other error : "No access granted, forcing login again (Refresh tokens): invalid_client"
I have check and check again, make a new app but nothing ...
With this Error You are having a issue with your ClientID or ClientSecret, maybe you have a space in front or in back.
Posted: Monday 24 March 2025 20:33
by homeJLB
jpaul wrote: Monday 24 March 2025 19:32 Hi dev team,
As a user off Domoticz myself I invested time in the New-API from Netatmo
The authentication and the HTTPClient library I have less experience with but I'm willing to test and find a solution.
kind regards
Posted: Monday 24 March 2025 21:03
by homeJLB
chrominator wrote: Monday 24 March 2025 16:56
No time to wait.
If you enable Debug on Domoticz then you can see the httpUrl and httpData without any changes
Debug(DEBUG_HARDWARE, "Netatmo URL %s with %s", httpUrl.c_str(), httpData.c_str());
for enabeling Debug on a Domoticz.service for example;
      ExecStart=/domoticz/domoticz -www 8080 -sslwww 443 -log "/var/log/domoticz-1.log" -loglevel all -debuglevel normal,hardware
#      ExecStart=/domoticz/domoticz -www 8080 -sslwww 443 -log "/var/log/domoticz-1.log" -loglevel all
with the # you can easily change between the normal and debug. (comment out the unused line)
kind regards
Posted: Tuesday 25 March 2025 11:46
by jcb2
OK I have found one error into my config : I have now cleared the field redirect URI. OK I have the page for accepting the scope.
Now I have these errors :
2025-03-25 11:42:57.920 Error: Météo: Error connecting to Server (refresh tokens): HTTP/1.1 28 Timeout was reached
2025-03-25 11:42:57.920 Status: Météo: Login 0
2025-03-25 11:43:00.279 Status: [web:8080] Incoming connection from: 127.0.0.1
2025-03-25 11:43:27.927 Status: Météo: Use refresh token from database...
2025-03-25 11:43:27.933 Status: Météo: Requesting refreshed tokens
2025-03-25 11:43:28.190 Error: Météo: Invalid/no data received (refresh tokens)... HTTP/2 403
2025-03-25 11:43:28.191 Status: Météo: Retry LOGIN within 45 min.
2025-03-25 11:43:28.192 Status: Météo: Login 0
Posted: Tuesday 25 March 2025 13:03
by waltervl
The wiki https://wiki.domoticz.com/Netatmo has been updated to show hopefully the correct way of adding/modifying the software.
This implementation of adding Netatmo in Domoticz is very different from any other plugin/gateway.
Posted: Tuesday 25 March 2025 21:21
by jcb2
After many try I have one connexion.
But no update of my devices. I have deleted all devices and hope one automatic new creation (with params for allow new device) but nothing !
One idea ?
Thanks,
Jean-Charles
Log :
2025-03-25 21:14:01.982 Status: Météo: Use refresh token from database...
2025-03-25 21:14:01.982 Status: Météo: Requesting refreshed tokens
2025-03-25 21:14:02.423 Status: Météo: We refresh our token ...
2025-03-25 21:14:02.423 Status: Météo: Login 1
2025-03-25 21:14:02.639 Status: Météo: Station Data parsed Buanderie
2025-03-25 21:14:02.640 Status: Météo: Station Data parsed Météo abri
2025-03-25 21:14:02.640 Status: Météo: Weather 1
2025-03-25 21:14:02.640 Status: Météo: Get HomesData Details
2025-03-25 21:14:02.902 Status: Météo: Home id METEO updated.
2025-03-25 21:14:02.902 Status: Météo: Home id Buanderie et cave updated.
2025-03-25 21:14:02.902 Status: Météo: Home id Abri et serre updated.
2025-03-25 21:14:02.902 Status: Météo: Home Status Details, size (number of homes) is 3
2025-03-25 21:14:03.829 Status: Météo: Parse Persons
2025-03-25 21:14:03.829 Status: Météo: HomeStatus parsed
2025-03-25 21:14:04.106 Status: Météo: Scenarios Data Recieved
2025-03-25 21:14:04.284 Status: Météo: Parse Persons
2025-03-25 21:14:04.285 Status: Météo: HomeStatus parsed
2025-03-25 21:14:04.513 Status: Météo: Scenarios Data Recieved
2025-03-25 21:14:04.514 Status: Météo: Status 1
Posted: Tuesday 25 March 2025 21:51
by homeJLB
jcb2 wrote: Tuesday 25 March 2025 21:21 Hello,
One idea ?
Thanks,
Jean-Charles
Log :
For answering this you need to enable debug to see which devices are received?
Did you use 16586 ?
Posted: Wednesday 26 March 2025 8:27
by jcb2
Yes it is with version 16586.
But the connection up durring the night and is down this morning.
Very strange. Below I provide the log about this error and hope it is an help.
Thanks,
Jean-Charles
Log this night and morning :
2025-03-26 02:29:31.744 Status: Météo: Use refresh token from database...
2025-03-26 02:29:31.744 Status: Météo: Requesting refreshed tokens
2025-03-26 02:29:31.928 Status: Météo: Retry LOGIN within 45 min.
2025-03-26 02:29:31.928 Status: Météo: Login 0
2025-03-26 03:14:32.306 Status: Météo: Use refresh token from database...
2025-03-26 03:14:32.306 Status: Météo: Requesting refreshed tokens
2025-03-26 03:14:32.505 Status: Météo: Retry LOGIN within 45 min.
2025-03-26 03:14:32.505 Status: Météo: Login 0
2025-03-26 03:59:32.876 Status: Météo: Use refresh token from database...
2025-03-26 03:59:32.876 Status: Météo: Requesting refreshed tokens
2025-03-26 03:59:33.052 Status: Météo: Retry LOGIN within 45 min.
2025-03-26 03:59:33.052 Status: Météo: Login 0
2025-03-26 04:44:33.447 Status: Météo: Use refresh token from database...
2025-03-26 04:44:33.447 Status: Météo: Requesting refreshed tokens
2025-03-26 04:44:33.606 Status: Météo: Retry LOGIN within 45 min.
2025-03-26 04:44:33.607 Status: Météo: Login 0
2025-03-26 05:29:34.000 Status: Météo: Use refresh token from database...
2025-03-26 05:29:34.000 Status: Météo: Requesting refreshed tokens
2025-03-26 05:29:34.174 Status: Météo: Retry LOGIN within 45 min.
2025-03-26 05:29:34.175 Status: Météo: Login 0
2025-03-26 06:14:34.546 Status: Météo: Use refresh token from database...
2025-03-26 06:14:34.546 Status: Météo: Requesting refreshed tokens
2025-03-26 06:14:34.712 Status: Météo: Retry LOGIN within 45 min.
2025-03-26 06:14:34.712 Status: Météo: Login 0
2025-03-26 06:59:35.079 Status: Météo: Use refresh token from database...
2025-03-26 06:59:35.079 Status: Météo: Requesting refreshed tokens
2025-03-26 06:59:35.252 Error: Météo: Invalid/no data received (refresh tokens)... HTTP/2 403
2025-03-26 06:59:35.252 Status: Météo: Retry LOGIN within 45 min.
2025-03-26 06:59:35.252 Status: Météo: Login 0
2025-03-26 07:44:35.614 Status: Météo: Use refresh token from database...
2025-03-26 07:44:35.614 Status: Météo: Requesting refreshed tokens
2025-03-26 07:44:35.786 Error: Météo: Invalid/no data received (refresh tokens)... HTTP/2 403
2025-03-26 07:44:35.786 Status: Météo: Retry LOGIN within 45 min.
2025-03-26 07:44:35.786 Status: Météo: Login 0
2025-03-26 07:46:45.118 Status: Météo: Worker stopped...
Into debug mode I have these informations :
Error :
2025-03-26 08:16:46.736 [7fd1ce7fc6c0] Error: Météo: Invalid/no data received (refresh tokens)... HTTP/2 403
Log info :
2025-03-26 08:16:46.568 [7fd1ce7fc6c0] Debug: Météo: Netatmo URL https://api.netatmo.com/oauth2/token? with grant_type=refresh_token&refresh_token=5f4d36d****************&client_id=67e2ee72e3***********&client_secret=CVGzSpWbyw*********************
2025-03-26 08:16:46.730 [7fd1ce7fc6c0] Debug: Météo: Netatmo Invalid ... <!DOCTYPE html PUBLIC '-//W3C//DTD XHTML 1.0 Transitional//EN' 'http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd'>
2025-03-26 08:16:46.730 <html xmlns='http://www.w3.org/1999/xhtml'>
2025-03-26 08:16:46.730 <head>
2025-03-26 08:16:46.730 <meta content='text/html; charset=utf-8' http-equiv='content-type' />
2025-03-26 08:16:46.730 <style type='text/css'>
2025-03-26 08:16:46.730 body {
2025-03-26 08:16:46.730 font-family: Arial;
2025-03-26 08:16:46.730 margin-left: 40px;
2025-03-26 08:16:46.730 }
2025-03-26 08:16:46.730 img {
2025-03-26 08:16:46.730 border: 0 none;
2025-03-26 08:16:46.730 #content {
2025-03-26 08:16:46.730 margin-left: auto;
2025-03-26 08:16:46.730 margin-right: auto
2025-03-26 08:16:46.730 #message h1 {
2025-03-26 08:16:46.730 font-size: 24px;
2025-03-26 08:16:46.730 font-weight: normal;
2025-03-26 08:16:46.730 color: #000000;
2025-03-26 08:16:46.730 margin: 34px 0px 0px 0px
2025-03-26 08:16:46.730 #message h2 {
2025-03-26 08:16:46.730 font-size: 20px;
2025-03-26 08:16:46.730 #message p {
2025-03-26 08:16:46.730 font-size: 16px;
2025-03-26 08:16:46.730 margin: 8px 0px 0px 0px
2025-03-26 08:16:46.730 #message hr {
2025-03-26 08:16:46.730 margin: 15px 0px
2025-03-26 08:16:46.730 #errorref {
2025-03-26 08:16:46.730 font-size: 11px;
2025-03-26 08:16:46.730 color: #737373;
2025-03-26 08:16:46.730 margin-top: 41px
2025-03-26 08:16:46.730 </style>
2025-03-26 08:16:46.730 <title>Service unavailable</title>
2025-03-26 08:16:46.730 </head>
2025-03-26 08:16:46.730 <body>
2025-03-26 08:16:46.730 <div id='content'>
2025-03-26 08:16:46.730 <div id='message'>
2025-03-26 08:16:46.730 <h2>The request is blocked.</h2>
2025-03-26 08:16:46.730 </div>
2025-03-26 08:16:46.730 <div id='errorref'>
2025-03-26 08:16:46.730 <span>20250326T071646Z-185fd8ffd9fqklwzhC1BRUcv2400000004p0000000006t6y </span>
2025-03-26 08:16:46.730 </body>
2025-03-26 08:16:46.730 </html>
2025-03-26 08:16:46.737 [7fd1ce7fc6c0] Debug: Météo: Refresh Token Flag 1 ...
Posted: Wednesday 26 March 2025 20:36
by homeJLB
My test system did also have a block after the 20 min wait.
so I stopped that system and restart today.
 2025-03-25 19:38:10.509  Error: Netatmo: Invalid/no data received (refresh tokens)... HTTP/2 403
2025-03-25 19:38:10.513  Status: Netatmo: Retry LOGIN within 45 min.
2025-03-25 19:38:10.513  Debug: Netatmo: Refresh Token Flag 1 ...
2025-03-25 19:38:10.513  Status: Netatmo: Login 0
2025-03-25 19:38:21.784  Status: Mainworker Stopped...
2025-03-26 20:09:34.060  Status: Netatmo: Status 1
So sometimes the wait is needed and longer or you can make a new App on dev.netatmo.com
Kind regards
Posted: Thursday 27 March 2025 6:16
by ninicob93
i have the same problem. Have you found a solution?
Posted: Thursday 27 March 2025 15:26
by Abidos
As far as I'm concerned, I had exactly the same problem.
After seeing "Retry LOGIN within 45 min." several times, I decided to reauthenticate. With no success. Then I rebooted my RPI: that did the trick! After reboot, it worked.
It's worth giving it a try... ;)
Posted: Thursday 27 March 2025 15:28
by ninicob93
Abidos wrote: Thursday 27 March 2025 15:26 Hi,
Thanks. For my part I found the solution by allowing the addition of equipment. Another NETATMO device was added and everything was in order. Thanks
