Page 17 of 56
Re: Python plugin: Presence detection from wireless router
Posted: Monday 03 September 2018 22:31
by EscApe
@sapnho:
That statement will just be repeated on every poll. Have a look at the debug log while the plugin is starting. That should provide more helpful info.
Posted: Monday 03 September 2018 22:46
by sapnho
Ok, will check tomorrow. Thanks.
Posted: Tuesday 04 September 2018 5:18
by sapnho
Following another restart of Domoticz (with iDetect deactivated) everything seems to work fine again. No error messages during the night. Thanks.
Now, I just need to find out how to install ssh public key authentication instead of the password because the password is indeed open in the logfiles. I haven't quite understood the instructions other than putting the public key on the wifi device. But since I have three of those and a separate controller (Unifi Cloud Key), I am not sure how that would work. Any pointers?
Posted: Tuesday 04 September 2018 8:46
by sapnho
@EscApe: Received this error message once this morning. No worries everything works fine, but I know you are always keen to get a report of error messages...
2018-09-04 07:44:13.675 Error: (iDetect) SSH subprocess failed with error (255):b''
Posted: Tuesday 04 September 2018 11:13
by PatrickM
The plugin works great for me, after making some modifications. I run a router with openwrt/lede based firmware with grep supplied by busybox. Patterns like
don't work properly, only matching lines starting with eth. Changing to
fixes that and should work on any version of grep. I would submit a PR but I also changed all indenting to my personal preference
Posted: Tuesday 04 September 2018 19:39
by EscApe
@mvzut:
I sill hope you didn't hold your breath .... for 21 hours
@sapnho:
Nice to hear that it works... i have added a little something to monitor response times and potential timeout situations (and upped the hard timeout a little)
No longer displaying passwords in the debug log
@PatrickM:
Thanks for letting me know! Fixed in this version
Just pushed a new version
**version 0.6.2**
- Added: You can now use different passwords for routers by configuring them as username@routerip (otherwise global username on the configuration page will be used).
- Added: Displaying the time a ssh command takes when in debug mode.
- Enhanced: Password is no longer displayed in the debug log.
- Fixed: Grep command for some openwrt routers.
Posted: Tuesday 04 September 2018 20:57
by sapnho
Very nice. That removed the occasional error message altogether. Thanks!
Posted: Wednesday 05 September 2018 13:37
by mvzut
Cool, great improvements!
Unfortunately it still doesn't solve my problem completely: The Linksys router with Tomato firmware still gives a 255 error, regardless of which timeouts I choose, unless I put it in #forcegeneric mode. Any idea what this could be? Seems something might be going wrong in the part which determines which methods are supported by the router. This part of the code is probably not used when you force the method? I can post (or PM) a piece of my log using debug mode if that helps.
Posted: Wednesday 05 September 2018 14:38
by EscApe
@mvzut
Without a debug log i can't tell what's going on... There should no longer be a password in the log, so it should be safe to share.
Posted: Wednesday 05 September 2018 14:42
by sapnho
EscApe wrote: Wednesday 05 September 2018 14:38
Oh, the password is still in there.. (0.62)
2018-09-05 14:41:15.405 (iDetect) Fetching data from router using: ['sshpass', '-p', 'thisiswhereyoucanseethepassword', 'ssh', '-o', 'StrictHostKeyChecking=no', '-o', 'ConnectTimeout=2', '
[email protected]', "export PATH=/usr/sbin:/usr/bin:/usr/local/sbin:/usr/local/bin:/sbin:/bin:$PATH;wlanconfig ath0 list | grep '^..:..:..:..:..:.. ' | cut -d' ' -f1;wlanconfig ath2 list | grep '^..:..:..:..:..:.. ' | cut -d' ' -f1;wlanconfig eth0 list | grep '^..:..:..:..:..:.. ' | cut -d' ' -f1;exit"]
Posted: Wednesday 05 September 2018 15:05
by EscApe
Oops... that’s a different piece of logging I didn’t take into account. Will see if I can remove those passwords in a future version. Can you share or pm me the debug log from where the plug starts until the first poll?
Would like to see any responses and/or errors to the command it is sending (according to the line you shared)
Is the password the right password for that router? Passwords must be the same on both routers unless you use key based authentication. Only the usernames can be different if you use a password.
Posted: Wednesday 05 September 2018 15:23
by EscApe
Thanks for the log in pm
Can you login to the failing router (xxx.56) using ssh from the command line, run the command manually and share the results? Just copy me paste to the routers command line.
Haven’t seen the start part of the debug log, but since it is using a command line it probably initialized just fine. Passwords or ssh connection should not be the problem. Otherwise it would not initialize properly and forcegeneric would also fail. Maybe the router has a different syntax for wlanconfig. What is the model and firmware of the router?
Posted: Wednesday 05 September 2018 15:34
by sapnho
All wifi access points are Unifi AP Pro, same firmware. Funny thing, they all work with iDetect. Will send you the login with PM.
Posted: Wednesday 05 September 2018 20:50
by hjzwiers
Running a AC86u as main router and AC68u in AImesh mode.
with #forcegeneric it sees all phones, but with quite a detection delay
So I tried the newest version and added both the IP of the main and mesh router. This is the log:
2018-09-05 20:40:48.391 Status: (iDetect) Initialized version 0.6.2, author 'ESCape'
2018-09-05 20:40:48.593 Status: (iDetect) Using chipset specific (wl) command on router 192.168.1.1 for interfaces ['eth5', 'eth6']
2018-09-05 20:40:48.971 Status: (iDetect) Using chipset specific (wl) command on router 192.168.1.236 for interfaces ['eth1', 'eth2']
iDetect now only sees the phones connected to the main router, but not the ones on the mesh router.
I will revert to using #forcegeneric, just did this to do the test
Posted: Wednesday 05 September 2018 21:25
by EscApe
@hjzwiers
Thanks for your feedback! To bad it's not working (yet).
So the plugin was able to retrieve the router capabilities. The ssh connection works. For some reason it is not getting the association ('presence') info from the router, but without a debug log i cannot tell whats happening. Maybe the routers behave differently in a mesh setup. I cannot try this because i only have one router.
Forcegeneric will also work if only one of the routers is queried, so that doesn't tell us anything about the multi router support.
by EscApe
@hjzwiers
Posted: Wednesday 05 September 2018 21:32
by EscApe
@sapnho:
From the logs you send me i can tell all three routers are queried and responding with mac addresses. For some reason the wlanconfig command does not exit with an error code when querying a eth* interface, but only ath* interfaces seem te be right. It only displays an error but does exit with code 0 (no error). That's why eth* are still detected at startup and queries at every poll. I don't think the error message will interfere with the detection though.
In the log i see no reason for the detection to fail. It shows mac addresses from all three mesh members. Has it magically started working??
Posted: Wednesday 05 September 2018 21:38
by sapnho
Yes, 0.62 works fine and detects all phones quickly. No complaints from my side.
Great stuff! Thanks!
Posted: Wednesday 05 September 2018 21:40
by EscApe
Help wanted
Dear forum members and plugin users. There seem to be some issues with the detection on mesh/multiple routers. I can not troubleshoot these myself, since i don't own such a setup. If anyone with sufficient linux cli, networking and preferably python knowledge (who does use multiple routers) wants to help me troubleshoot this, then please let me know. Either on the forum or pm.
If anyone knows how to determine the right wireless interfaces on a router that uses the wlanconfig (atheros chipset?) command, then that info would also be appreciated. Just trying every interface is not the solution, because it will not throw an exit code when it fails. Is it safe to assume the interfaces are always called ath* ????
Posted: Wednesday 05 September 2018 21:54
by mvzut
EscApe wrote:@mvzut
I sent you a PM with the log. Hope you find some hints in there about what might be the problem with the Linksys/Tomato router.
Thank for all your support!
