Page 17 of 114
Posted: Thursday 14 December 2017 21:26
by HarryHase
I need some hints how to mange 2 houses. Is this possible with one acoount?
Posted: Friday 15 December 2017 9:56
by Madgeni
quirk wrote: Thursday 14 December 2017 20:15
Thanks Madgeni for the test button, I've been able to spot error in my Nginx reverse proxy config that prevents Controlicx to access Domoticz!
yay!
Posted: Friday 15 December 2017 15:09
by Elmardus
I'm having some trouble setting up Controlicz.
So far I've opened the Google actions page, pressed 'Start Testing', selected the 'Actions on Google - Version 2'. In the home app under add devices the 'test home controlicz' shows up in the list. It opens a page for approval, but after approving I get the error: "Couldn't update the setting, please check your connection".
What can I do to fix this?
Posted: Friday 15 December 2017 15:52
by lassiko
Hi Madgeni,
I just registered.
Can you please add me in your beta program.
My email starts with: lass***
Thank you!
Sent from my FRD-L09 using Tapatalk
Posted: Friday 15 December 2017 16:42
by ticranou
Hi Madgeni,
I tried to test the connection to my domoticz from my profile on Controlicz.com, but it always fails with the following message: "Controlicz is unable to connect - please check your config" ;-(
Could you please have a look on your side to see what the problem could be ?
Edit: it seems that no user/password is provided during the testing request...
Thanks in advance,
T.
Posted: Friday 15 December 2017 16:58
by Madgeni
Elmardus wrote: Friday 15 December 2017 15:09
Hi - can you check the account you've entered in Controlicz has access to your Domoticz? - i've added a test connection button to the Profile page
Posted: Friday 15 December 2017 16:59
by Madgeni
ticranou wrote: Friday 15 December 2017 16:42
Hi Madgeni,
Thanks in advance,
T.
hahah - i was testing the one API call that doesn't need authentication :/
Working on this now
Posted: Friday 15 December 2017 17:00
by Elmardus
Madgeni wrote: Friday 15 December 2017 16:58
Test is succesful, Controlicz can connect, however I still get the same error in my Google Home app.
Posted: Friday 15 December 2017 17:07
by Madgeni
Elmardus wrote: Friday 15 December 2017 17:00
yep, test is not working as expected! Can you just double check your username/password, Controlicz is getting an authentication error
Posted: Friday 15 December 2017 17:09
by ticranou
Hi Madgeni,
My nginx logs say:
1xx.xxx.xxx.xxx - - [15/Dec/2017:16:51:03 +0100] "OPTIONS /json.htm?type=command¶m=getversion HTTP/2.0" 401 590 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/63.0.3239.84 Safari/537.36"
and
no user/password was provided for basic authentication, client: 1xx.xxx.xxx.xxx, server: xxx.xxx.xxx, request: "OPTIONS /json.htm?type=command¶m=getversion HTTP/2.0", host: "xxx.xxx.xxx:8443"
The first log does not contain any login, contrary to user requests. That's what is surprising me...
Any idea about this behavior ?
T.
Posted: Friday 15 December 2017 17:10
by Madgeni
yep, it's 'normal' i think. Don't blame me, it seems that getversion call is unauthenticated..
Posted: Friday 15 December 2017 17:14
by ticranou
no problem
well... with a colleague, we made a test within his Controlicz account. His connection test also uses the getVersion request, but he has a user specified in the log related to the request. But I don't... ???
Posted: Friday 15 December 2017 17:56
by ebbspot
Madgeni wrote: Wednesday 06 December 2017 8:46
ebbspot wrote: Tuesday 05 December 2017 21:52
ebbspot wrote: Wednesday 29 November 2017 0:42
Hello Madgeni,
Have you read this request?
i would like to use (test) controlicz with my domoticz and google assistant. I am registred on controlicz with email eb*e*@xs4all.nl
Hi there -
Email addresses and domains must be associated with an active Google Account or Google Apps account
Madgeni.
I have changed the email address
ebie**************
[email protected]
Posted: Friday 15 December 2017 19:03
by sly14
Hello Madgeni,
I just registered, can i test beta program Controlicz.
My email sly1***@gmail.com
Thank you!
Posted: Friday 15 December 2017 22:00
by nounours0000
Hello Madgeni,
I just registered, can you please tes beta program controlicz.
My email perr****@gmail.com
Thank you !
Posted: Saturday 16 December 2017 13:45
by jeroenvanpelt
Everything seems to work after all. @Madgeni thanks for all your help so far!
Initially received the "Couldn't update settings. Please check your connection." when linking my account in the Google Home app while it did not link Controlicz. This morning I casually checked my Home app, just to find out it had somehow linked my Controlicz and had synced my devices. Since then I have unlinked Controlicz once and succesfully re-linked it. Devices appear in the Home app; I can control my devices and query the status of my lights and temperature sensors.
There's two things left that I am wondering about:
- The dreaded "Couldn't update settings. Please check your connection." message: It keeps appearing 99% of the times when I link devices to rooms. Funny thing is though: It does link the devices. Even when I hit " Discard" in the app. Any ideas what is going wrong here?
- I added one group in Domoticz to a room plan called Groups. This group does not seem to sync though. It cannot be added to the list of devices for the specific user I use for Controlicz. I noticed that another device did sync with the "sync my devices" command from Google Assistant. I thought groups were also supposed to sync to Home. In Nginx I noticed the command to query for all devices does not include the groups though: /json.htm?type=devices&filter=all&used=true&order=Name
My setup uses Domoticz with Nginx to enable HTTPS.
Posted: Saturday 16 December 2017 18:23
by Madgeni
jeroenvanpelt wrote: Saturday 16 December 2017 13:45
Hi - i'm afraid I can't control any of those "Couldn't update settings" errors, they sit firmly with the Google apps.
re: Groups - they are absolutely part of the /json.htm?type=devices&filter=all&used=true&order=Name call:
"Data" : "On",
"Description" : "",
"Favorite" : 1,
"LastUpdate" : "2017-12-16 15:20:01",
"Name" : "Top Group",
"PlanID" : "3",
"PlanIDs" : [ 3 ],
"Protected" : false,
"Status" : "On",
"Type" : "Group",
"TypeImg" : "group",
"UsedByCamera" : false,
"XOffset" : 0,
"YOffset" : 0,
"idx" : "1"
I can take a look, but if it's in a Room plan, and your Controlicz user has access to it, then Controlicz will find it
Posted: Sunday 17 December 2017 7:12
by jeroenvanpelt
Figured out the case of the missing groups. One needs to enable the tab "Scenes" _and_ add the groups to a room plan for them to be able to sync through Controlicz.
And, guess I'll have to live with the connection error then.
Donation on it's way...
Sent from my Pixel 2 XL using Tapatalk
Posted: Sunday 17 December 2017 10:03
by Madgeni
jeroenvanpelt wrote: Sunday 17 December 2017 7:12
Glad you worked it out - yes, unless i get some sense from Google, it's firmly with them!
Posted: Sunday 17 December 2017 10:49
by georgesattali
I have a question about Google Home and Dz, please : is it possible to have it speaking ?
That is to send recorded sound files from the raspberry to the Google Home ?
GD
