Page 17 of 32
Re: Domoboard a New Dashboard using Domoticz as backend
Posted: Sunday 15 January 2017 23:06
by domoj
Hi again,
well, I did miss the one post on pm2 and the one on systemd. Anyways, I wouldn't say that this question had been asked and answered multiple times.
I just tried both pm2 and systemd. No luck with the pm2 solution but the 'systemd' solution as kindly advised by Snowtiger worked without issue (thanks pepinj).
As I said, I am new to domoticz, and fairly new to everything linux. Long time users to domoticz probably do not realize it, but searching for information on the forum is a daunting task. So, IMHO, Sateetje is right, it would be nice to have a subforum for everything related to basic install and configuration of domoboard (or a wiki ?).
Cheers
JY
Posted: Sunday 15 January 2017 23:29
by Awst6000
No news here. Domoboard works fine for me.
The WAF factor raised skyhigh :-)
Although there are some minor wishes:
- Sorting of the toptiles in the top_tiles sectors [[[1}]]] etc.
- Icons instead of the relatively large text (Open/closed/on/off) in the top_tiles
Posted: Monday 16 January 2017 11:52
by squandor
Awst6000 wrote:No news here. Domoboard works fine for me.
We are working on the sorting, we thought that it was fixed, but apparently something still is messing with it.
What kind of icons gives the same impression as the Open/Closed and On/Off
On/Off could be the icons which are being used with the group section.
But open and closed are specific term so the icon must express this term.
Any ideas? :)
Posted: Monday 16 January 2017 12:37
by domoj
This has be raised before, but I don't think there is a definitive answer: is there a way to start domoboard without having to enter a username and password ? If not, could it be possible in the future ?
Posted: Monday 16 January 2017 12:52
by Awst6000
squandor wrote:What kind of icons gives the same impression as the Open/Closed and On/Off
Maybe using the enlarged icon instead of the text? In red or green, depending on the status, like:
[[top_tiles]]
TV = 1, bolt or lightbulb
http://puu.sh/hPj3v/5e70de7d54.png
Posted: Monday 16 January 2017 13:58
by Awst6000
Intentionally in a new post.
Is it possible to add Philips Jointspace to Domoboard?
If yes, for more than one TV?
Posted: Monday 16 January 2017 14:13
by squandor
Awst6000 wrote:Itentionally in a new post.
i should say anything is possible haha :) but therefore i think its best to create an plugin for it.
Posted: Monday 16 January 2017 15:26
by Awst6000
squandor wrote: i should say anything is possible haha :) but therefore i think its best to create an plugin for it.
I wish I had the knowledge to write plugins...
Posted: Monday 16 January 2017 16:19
by squandor
It's not about knowledge but try and error :lol:
Believe me i've had a lot of error's in my day's and still i would like to extend my programming but that takes time and there are only 24 hours in an day :roll:
Posted: Monday 16 January 2017 22:27
by felix63
How nice it would be to integrate something like http://www.netdata.be/tv/ in domoboard!
Posted: Monday 16 January 2017 23:55
by domoj
don't know if it's legit, but here is a workaround for the need to login at startup. Since I don't want to have a keyboard on the rpi+7 ' touchscreen, I'd rather do without the login page. The workaround is to pre-fill the login form.
Do not change the config file, keep as is:
 [[users]]
    username = password                 # Add users for Domoboard here. In this case login with username "username" and password "password"
then:
cd ~/domoboard/templates
cp login.html old_login.html
sudo nano login.html
add change the lines
<input type="username" name="username" class="form-control" required="yes" placeholder="Username">
and
<input type="password" name="password" class="form-control" id="inputPassword3" placeholder="Password" required="">
into
<input type="username" name="username" class="form-control" required="yes" placeholder="Username" value="username">
and
<input type="password" name="password" class="form-control" id="inputPassword3" placeholder="Password" required="" value="password">
And voila. The login form is pre-filled, and one just has to confirm log in.
Posted: Tuesday 17 January 2017 11:42
by Awst6000
I wrote a template for the Knmi-weatherpages.
Does this template has to be reviewed first?
(This template is probably only useful for Dutch people. Sorry)
Posted: Tuesday 17 January 2017 11:45
by woody4165
Awst6000 wrote:Ik heb een template gemaakt voor de Knmi-actueel pagina's.
Dient deze eerst te worden gereviewed door iemand? Of kan ik deze hier gewoon plaatsen?
English, please!
Posted: Tuesday 17 January 2017 12:19
by woody4165
Is Wundergound working?
I've tried both on master and dev, but with no success.
I've installed the plugin via web page, in general_setting i have
   [[wunderground]]
   api = xxxxxx
   language = EN (or IT)
and in dashboard
  [[wunderground]]
   [[[forecast]]]
   location = "Rome, IT"
   [[[condition]]]
with
wunderground[forecast], wunderground[condition]
in display_components
I don't see any new section in the web page and nothing in the log... very strange
thanks
Posted: Tuesday 17 January 2017 12:22
by patricknooijen
woody4165 wrote:Is Wundergound working?
   [[wunderground]]
   api = xxxxxx
and in dashboard
  [[wunderground]]
   [[[forecast]]]
   [[[condition]]]
with
thanks
had the same problem. Wunderground only worked with the developer repo, not the master.
Posted: Tuesday 17 January 2017 12:39
by woody4165
patricknooijen wrote: had the same problem. Wunderground only worked with the developer repo, not the master.
Thanks @patricknooijen
I've tried also with dev branch, on another ip port, in another folder, but no success...
PS: Actually in the log I can see
192.168.xx.xx - - [17/Jan/2017 12:42:11] "POST /api?custom=wunderground&loc=forecast&country=&action=Rome,IT HTTP/1.1" 200 -
192.168.xx.xx - - [17/Jan/2017 12:42:11] "POST /api?custom=wunderground&loc=condition&country=&action=Rome,IT HTTP/1.1" 200 -
maybe i'm wrong, but it seems that the value passed are in the wrong places.
Posted: Tuesday 17 January 2017 13:35
by patricknooijen
Try this :
  [[wunderground]]
   [[[forecast]]]
   location = Rome, IT
   [[[condition]]]
   location = Rome, IT
Posted: Tuesday 17 January 2017 13:42
by woody4165
Using it without double quotes, now some values have changed positions
192.168.xx.xx - - [17/Jan/2017 13:39:09] "POST /api?custom=wunderground&loc=IT&country=condition&action=Rome HTTP/1.1" 200 -
192.168.xx.xx - - [17/Jan/2017 13:39:09] "POST /api?custom=wunderground&loc=IT&country=forecast&action=Rome HTTP/1.1" 200 -
but seems still wrong, to me.
Posted: Tuesday 17 January 2017 13:53
by patricknooijen
woody4165 wrote:Using it without double quotes, now some values have changed positions
looks ok to me. When i use this it works. I use develop branch. Did you fill in your wunderground api key?
i see you get the wrong order. try the develop branch please.
Posted: Tuesday 17 January 2017 14:16
by woody4165
got it.
I made a git clone, starting with the link in the dev page, but the link is the same as the master (or prob I missed something).
So I downloaded the dev zip and now wundergound is working.
But temp that I have in dashboard are not showed anymore, I will look into it.
Thanks again.
