Page 159 of 184
Posted: Wednesday 03 January 2018 9:47
by AndreFR
hi All,
I'm experiencing a weird problem, Dashticz was running fine till yesterday afternoon. Steps I did so far:
1) copied the CONFIG.js from Rob, started with only changing the IP address from Domoticz => no result, started to commend out almost everything, still no result
2) removed the Dashticz folder and re-installed it, still no working Dashticz :(
in the browser console I'm getting the following:
jquery.min.js:4 [Deprecation] Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/.
send @ jquery.min.js:4
ajax @ jquery.min.js:4
loadFiles @ main.js?v=1514968064669:34
(anonymous) @ index.html:66
f @ head.js:6
(anonymous) @ head.js:6
o @ head.js:6
jquery.min.js:4 XMLHttpRequest cannot load file:///home/pi/domoticz/www/dashboard/custom/CONFIG.js?_=1514968065255. Cross origin requests are only supported for protocol schemes: http, data, chrome, chrome-extension, https.
Any idea how to solve this?
Posted: Wednesday 03 January 2018 14:54
by kottick
aiolos wrote: Wednesday 03 January 2018 0:49 That's because of the security settings in your browser. I'm not sure if you can disable that (and actually I hope not). This message is to prevent websites to post usernames and password to other sites than the one you think (imagine the site of your bank, where malicious code is injected, which sends your username and password to some people with wrong intentions).
In this case annoying and I'm not sure you can easily get round it.
I don't think thats the problem. In the browser its visible without any problem. In dashticz i get constant the question for password and username, but no webcam stream. Only in popup screen.
Greetz,
Kottick
Posted: Wednesday 03 January 2018 14:58
by AndreFR
@Kottick, I've got this on various browsers... Strange, as it worked before without a problem... will try to dig further in the CONFIG.js file
Posted: Wednesday 03 January 2018 16:27
by kottick
AndreFR wrote: Wednesday 03 January 2018 14:58 @Kottick, I've got this on various browsers... Strange, as it worked before without a problem... will try to dig further in the CONFIG.js file
I think in the javascript ;-)
Re: Dashticz v2.0, custom positioning and multiple screens
Posted: Wednesday 03 January 2018 19:15
by AndreFR
EdwinK wrote: Thursday 13 April 2017 23:02 Just this
jquery.min.js:4 Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/.
(anonymous)	@	main.js?v=108:16
then
@EdwinK; how did you solve this error?
Posted: Wednesday 03 January 2018 21:45
by robgeerts
@Andre, how are you calling your dashticz?
It seems like you are not opening it from a webserver because it tries to get the CONFIG.js from an address starting with: file://
Posted: Wednesday 03 January 2018 21:58
by AndreFR
robgeerts wrote: Wednesday 03 January 2018 21:45 @Andre, how are you calling your dashticz?
@Rob, i use : http://192.168.178.178/dashboard/ Port 80
The thing is that it worked before and since yesterday I get the ‘white ‘ page :|
Posted: Thursday 04 January 2018 9:39
by EdwinK
AndreFR wrote: Wednesday 03 January 2018 19:15
then
Cnt remember, it's almost a year old. I think Rob did a update then.
Posted: Thursday 04 January 2018 10:08
by AndreFR
EdwinK wrote: Thursday 04 January 2018 9:39
then
All, it's working again, I've restarted from scratch with the CONFIG_DEFAULT.js from custom2 folder. I've to recreate it, but at least the defaults are working again...
Posted: Thursday 04 January 2018 11:01
by jake
jake wrote:With the beta's of 2 days before,I had the electricity, solar panel yield and gas blocks showing default titles instead of custom. Today, with a fresh git pull, it solved itself for electricity, but the PVoutput.org splitted block (power and energy) both show the default title 'Solar Panel Yield'.
It was solved before, after mentioning it in this topic
The gas blocks is a different story:
It used to display today's values only.
With the latest beta:
- It creates 2 blocks, both for today and for total (when I use the _1 or _2 I can solve that)
- It gives the totals the custom title
- It gives the today's values the default title 'gas vandaag'
I was able to solve the 'gas vandaag' default title: since the _1 and _2 had to be added to the column definition to make the right choice between today and total usage, I did not add the _1 to the block definition. In the block definition, you also define the custom title. Now it is working fine:
blocks['186_1'] = {}
blocks['186_1']['width'] = 4;
blocks['186_1']['title'] = 'Verwarming' //gasverbruik
blocks['181_1'] = {}
blocks['181_1']['width'] = 4;
blocks['181_1']['title'] = 'Tapwater' //gasverbruik
blocks['181_1']['icon'] = 'fa-shower';
The solar system definition blocks are done correctly:
blocks['39_1'] = {}
blocks['39_1']['width'] = 4;
blocks['39_1']['title'] = 'Opbrengst' // energie vandaag in kWh
blocks['39_2'] = {}
blocks['39_2']['width'] = 4;
blocks['39_2']['title'] = 'Opbrengst' //vermogen in Watt
blocks['39_2']['unit'] = 'Watt;W';
However the dashboard still displays these 2 blocks with identical title 'Solar Panel Yield'
Posted: Thursday 04 January 2018 11:34
by Derik
how do you set them in the columns?
Posted: Thursday 04 January 2018 20:25
by Derik
dear all..
Please some help..
Is there perhaps a simple how to to set the css options.
I was thinking my dash was very good.
I changed 1 ting and mor things are going crazy..
I hope there is some on that can help me with this css.
/*////////////////  Tekst in de buttons en er onder \\\\\\\\\\\\\\\\\\\\\*/
.col-data .title 	{ font-size: 45px; margin-left: 25px; font-weight: 600; color: deepskyblue; font-variant: small-caps;}
//.col-data span 		{ font-size: 25px; margin-right: 25px; font-weight:220; color: dodgerblue;font-variant: small-caps;}
.col-xs-3     { font-size: 15px; margin-right: 25px; font-weight:20; color: dodgerblue;font-variant: small-caps;} // tekst onder button
Example of my problems....
I was thinking the mid rule works fine..
Only when i use the last rule, my text was better.
When i do a xs-4 there are more things to change ..
Like sunrise or the sunset etc etc
Please.
Posted: Friday 05 January 2018 20:37
by renerene
Does the dialogue between Dashticz and Domoticz only run through devices? Or is It also possible to display/adjust domoticz user variables?
If not, I have to re-programm variables to dummy's.....
Posted: Friday 05 January 2018 21:54
by AndreFR
I’v Managed the setup to my satisfaction. I’m facing only a strange thing: when I’m accessing my Dashticz from my phone (4g), then I can only see the ‘non-IDX’ part. Everything else is working, except I can’t see my devices. Any idea to solve this? Btw I see them if I access Domoticz....
Posted: Saturday 06 January 2018 9:56
by sailmich
@all happy new year,
I still need help. I can't move my blinds with arrow up/down. I'm using latest beta. Am I the only one with that issue or am I the only one using blinds?
I have an older beta version that is working with blinds, but can't use it because of other issues.
I investigated some changes in main.js but I don't know if that is the root. When that main.js is the reason, somebody might have a look into it and give me information which part I have to delete and/or change.
working_main.js
(74.93 KiB) Downloaded 78 times
not_working_main.js
(79.33 KiB) Downloaded 66 times
Any help appreciate
Posted: Saturday 06 January 2018 12:21
by renerene
Can someone please help this beginner?
Problem: domoticz devices do not show in dashticz. No communication between them?
See screenshots below: device 68 is missing.
Domoticz version is V3.8798, Dashticz is downloaded and installed last week, V2
In Domoticz a password and username is set;
changing the second line below into "config['domoticz_ip'] = 'http://name:[email protected]:8080';" does not help
UPDATE: the sunrise time in upper right corner only shows up with correct IP address in dashticz confi. So I guess it reads the values from Domoticz, ;there is communication between the two.
But why is device 68 not whowing? (offcourse I have tried with other IDX nummers, same result)
CONFIG.js
var config = {}
config['domoticz_ip'] = 'http://192.168.0.106:8080';
var buttons = {}
buttons.buienradar = {width:12, isimage:true, image: 'http://api.buienradar.nl/image/1.0/RadarMapNL?w=285&h=256', url: 'http://www.weeronline.nl/Europa/Nederland/Son/4058667'}
var blocks = {}
blocks[68] = {}
blocks[68]['title'] = 'example';
var columns = {}
columns[1] = {}
columns[1]['blocks'] = [buttons.buienradar]
columns[1]['width'] = 5;
columns[2] = {}
columns[2]['blocks'] = [68]
columns[2]['width'] = 5;
columns[3] = {}
columns[3]['blocks'] = ['sunrise']
columns[3]['width'] = 2;
Posted: Saturday 06 January 2018 12:55
by Derik
mmm
You mis behind [buttons.buienradar] a ; even al so behind ['sunrise'] you mis a ;
Then your block is not complete.
a block of my:
blocks[697] = {}
blocks[697]['width'] 			= 2;
blocks[697]['title'] 			= 'Laad'; // Kamer laders
blocks[697]['icon'] 			= 'fa-battery-three-quarters';
blocks[697]['switch'] 			= true;
blocks[697]['hide_data'] 		= true;
blocks[697]['show_lastupdate']	= false;
blocks[697]['protected'] 		= false;
And your with in buttons is different with the with of your colomn
So try a blank config.
Then step 1 wokr? then step 2 works step3 etc etc.....
You make more then 1 error..
Make sure you have a clean code or check the code online with w3...
Posted: Saturday 06 January 2018 13:31
by renerene
Yes, i have struggled with the semicolums. There is no explanation on the wiki page.
from the wiki I understand only the first line is mandatory
var blocks = {}
The width of the block is relative to the column width it end up in.
good idea. Can not make it more blank than the current one ;-)
SOLVED: this line HAS TO BE in the config section
config['auto_positioning'] = 0;
Posted: Saturday 06 January 2018 17:06
by nldforce
hello,
i want to view my camera (d-link dcs5009L) on dashticz but i get just a white screen when i click on it. https://ibb.co/gOCgUw
can sombody help me?
the link i rule i got:
buttons.webcam1 = { width:6, isimage:true, refresh:5000, image: 'http://guest:[email protected]/video.c ... lution=VGA', url: 'http://guest:[email protected]/video.c ... lution=VGA'}
when i go to my browser to http://guest:[email protected]/video.c ... lution=VGA the page loads without any problem.
Posted: Saturday 06 January 2018 20:32
by rathmannm
I've looked through the Wiki and searched the forum but couldn't find an answer on a seemingly simple question:
Is it possible to change the font size for the calendar and if so how?
Thanks,
Manuel
