Page 153 of 184
Change colour of an icon dynamically
Posted: Saturday 25 November 2017 23:41
by l0gic
Guys,
I'm moving on with my screens but I want to change the colour of an icon in a block depending on conditions (e.g. temperature)
I'm not expert in js / css but I'll have a go
If I have an icon, say fa-bolt I can permanently change the colour using css and defining .fa-bolt {color:rgba(10,20,30,0.5);
but I don't understand how I can then change the colour to something different depending on a value.
As the css code defines the icon .fa-bolt I can't reference it if I make a change to the name.
Can I change the colour in the js code somehow, perhaps
blocks[123]['icon'] = 'fa fa-bolt' color:rgba(10,20,30,0.5); <- doesn't work but you get the idea
Any ideas?
Kevin
Posted: Sunday 26 November 2017 11:50
by tigo72
I know this issue has been raised before--in april or so--but on the latest beta it still seems to prevail, at least in my case:
The Nefit Boiler pressure block gives me "On" instead of "1.6 Bar" or something similar.
I know for sure the IDX is right. The output file:
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"CustomImage" : 0,
"Data" : "1.6 Bar",
"Description" : "",
"Favorite" : 0,
"HardwareID" : 23,
"HardwareName" : "Nefit Easy",
"HardwareType" : "Nefit Easy HTTP server over LAN interface",
"HardwareTypeVal" : 68,
"HaveTimeout" : false,
"ID" : "00000101",
"LastUpdate" : "2017-11-26 11:30:00",
"Name" : "Waterdruk Boiler",
"Notifications" : "false",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Pressure" : 1.6000000000000001,
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : "-",
"SubType" : "Pressure",
"Timers" : "false",
"Type" : "General",
"TypeImg" : "gauge",
"Unit" : 1,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "1851"
Can someone help me out?
BTW: I love Dashtics, great great work!
Best
Tigo
Posted: Sunday 26 November 2017 14:08
by aiolos
I pushed a possible fix, if Rob merges it, you can test it.
Posted: Sunday 26 November 2017 19:34
by tigo72
thank you aiolos!
Posted: Sunday 26 November 2017 21:11
by robgeerts
Merged into beta!
Posted: Sunday 26 November 2017 22:27
by tigo72
And working!~Thank you so much Rob
Re: Change colour of an icon dynamically
Posted: Monday 27 November 2017 14:43
by Ingmar
l0gic wrote: Saturday 25 November 2017 23:41
Guys,
Any ideas?
Kevin
I use the following code for changing the background of a opened door block, it gives the block a certain div class depending on the value. Then in the CSS you can define the div class styles. Maybe with a bit of playing around you can get it to work for your case? Got the info from the Wiki:
http://www.domoticz.com/wiki/Dashticz_V ... Cdevice.29.
function getStatus_145(idx,value,device){
if(parseFloat(device['Data'])>23){
$('div.block_145').addClass('warning');
else {
$('div.block_145').removeClass('warning');
function getStatus_286(idx,value,device){
if(parseFloat(device['Data'])>4){
$('div.block_286').addClass('warningblue');
else {
$('div.block_145').removeClass('warningblue');
And in the CSS:
.warning {
background: rgba(199,44,44,0.3) !important;
background-clip: padding-box;
.warningblue {
background: rgba(45,119,204,0.3) !important;
Posted: Monday 27 November 2017 16:44
by Jempe
I have a problem with temperature/humidity sensor. It's not possible to clic on the block to see the graph. Before the last update to stable(~3 week
https://github.com/robgeerts/dashticz_v ... 2441361715), it's was possible to clik on the block 23 (not 23_1) and show the temp graph. The graph working good in domoticz... The switch option doesn't work...
Information from domoticz;
53 Rflink 5618 0 Corridor Temp + Humidity WTGR800 21.3 C, 35 %
23 Rflink 2DE1 0 Températue Salon Temp + Humidity WTGR800 21.1 C, 32 %
52 Rflink 52C9 0 Extérieur Temp + Humidity WTGR800 1.2 C, 60 %
The 23 is an oregon, the other are cheap one from china but work good.
Her is the block information from CONFIG.js
blocks['23_1'] = {} //salon oregon
blocks['23_1']['title'] = 'Salon';
blocks['23_2'] = {}
blocks['23_2']['title'] = 'Salon';
blocks['52_1'] = {} //température extérieur
blocks['52_1']['switch'] = true
blocks['52_1']['title'] = 'Extérieur';
blocks['52_2'] = {} //humidité extérieur
blocks['52_2']['title'] = 'Extérieur';
blocks['53_1'] = {} //température corridor
blocks['53_1']['title'] = 'Corridor';
blocks['53_2'] = {} //humidité corridor
blocks['53_2']['title'] = 'Corridor';
Posted: Monday 27 November 2017 19:26
by l0gic
Ingmar wrote: Monday 27 November 2017 14:43
Hi, thanks for looking Ingmar.
Yeah, I started off using that code but I want to move on to just change the colour of the icon rather than the whole background.
I've been playing with it for a few days now without any luck. If the data was on/off rather than a value I can reference the icon using icon.on and icon.off but with a variable it seems to be more difficult.
I can change the icon depending on the value but can't seem to change the colour of a single icon on demand.
I'll keep on plugging at it
Kevin
Posted: Monday 27 November 2017 19:46
by Jempe
l0gic wrote: Monday 27 November 2017 19:26
Kevin
I do it for my temp/humidity sensor;
custom.js;
function getStatus_23(idx,value,device){
if((parseFloat(device['Humidity'])<40) && (parseFloat(device['Humidity'])>30)){
$('div.block_23_2').addClass('orange');
else {
$('div.block_23_2').removeClass('orange');
if(parseFloat(device['Humidity'])<=30){
$('div.block_23_2').addClass('red');
else {
$('div.block_23_2').removeClass('red');
if(parseFloat(device['Humidity'])>60){
$('div.block_23_2').addClass('blue');
else {
$('div.block_23_2').removeClass('blue');
if((parseFloat(device['Temp'])>23) && (parseFloat(device['Temp'])<28)){
$('div.block_23_1').addClass('orange');
else {
$('div.block_23_1').removeClass('orange');
if(parseFloat(device['Temp'])>=28){
$('div.block_23_1').addClass('red');
else {
$('div.block_23_1').removeClass('red');
if(parseFloat(device['Temp'])<18){
$('div.block_23_1').addClass('blue');
else {
$('div.block_23_1').removeClass('blue');
if(parseFloat(device['Temp'])<=15){
$('div.block_23_1').addClass('white');
else {
$('div.block_23_1').removeClass('white');
custom.css;
.orange .wi.wi-humidity:before, .orange .fa-thermometer-half:before {color:gold}
.red .wi.wi-humidity:before, .red .fa-thermometer-half:before {color:red}
.blue .wi.wi-humidity:before, .blue .fa-thermometer-half:before {color:blue}
.white .wi.wi-humidity:before, .white .fa-thermometer-half:before {color:#FFF}
Hope it's help...
Posted: Monday 27 November 2017 23:00
by Jempe
You can show all the possible value from your sensor (in this exemple
parseFloat(device['Humidity'])<=30) )with an json call:
curl -s "domoticz.ip:port/json.htm?type=devices&rid=YourIDXsensor"
Posted: Tuesday 28 November 2017 13:04
by Ingmar
Kevin
You can always decide to go the less flexible way, where you take the same icon but change the color in paint or photoshop and save them as separate files on your system (see wiki). Then you can make it look like only the colour is changing, while actually the whole icon is changing...
Posted: Thursday 30 November 2017 10:20
by Ingmar
Is there a way to change the size of the popup window of the "var buttons"? Is it possible to set the size per individual button?
Gr. Ingmar
Posted: Thursday 30 November 2017 13:40
by robgeerts
Not yet unfortunately
Posted: Thursday 30 November 2017 16:16
by woody4165
Hi all
I think I'm having an issue with my Dashticz config.
After a few minutes that I open a browser with Dashticz I get no more access to standard Domoticz frontpage as well as Dashticz.
Browser wheel continue to spin on the Dashticz page.
I found that I wrongly set 3 cameras refreshimage to 1500 and changing this to 10000 seems to solve the issue of not showing anymore the webpage.
But I still get the wheel spinning all the time
My configs related to refresh are:
var frames = {}
frames.weather = {refreshiframe:10000,height:230,frameurl:"//forecast.io/embed/#lat=xx.xxxxx&lon=yy.yyyy&name=xxx&color=#00aaff&font=Helvetica&fontcolor=#ffffff&units=si&text-color=#fff",width:24}
var maps = {}
maps.rome = { height:250, refreshimage:60000, width:6, latitude: xx.xxxx, longitude: xx.xxxx, zoom:13 }
//Buttons or images to open webpages in an iframe, like a news website or weather forecast
var buttons = {}
buttons.buienradar = {height:220, width:6, isimage:true, refreshimage:600000, image: 'http://www.meteo60.fr/satellites/animation-satellite-ir-france.gif', url: 'https://www.3bmeteo.com/meteo/acilia'}
buttons.buienradar2 = {height:120, width:6, isimage:true, refreshimage:600000, image: 'http://www.centrometeo.com/sat/it-vis-animation.gif', url: 'https://www.3bmeteo.com/meteo/acilia'}
buttons.webc = {height:250, width:6, isimage:true, refreshimage:10000, image: 'http://192.168.xxx.xxx:xxxx/camsnapshot.jpg?idx=x&count=x?t=xxx', title: 'Webcam', url: 'http://192.168.xxx.xxx/zm/index.php? view=montage&group=x'}
buttons.webc1 = {height:250, width:6, isimage:true, refreshimage:10000, image: 'http://192.168.xxx.xxx:xxxx/camsnapshot.jpg?idx=y&count=y?t=xxx', title: 'Webcam', url: 'http://192.168.xxx.xxx/zm/index.php? view=montage&group=x'}
buttons.webc2 = {height:250, width:6, isimage:true, refreshimage:10000, image: 'http://192.168.xxx.xxx:xxxx/camsnapshot.jpg?idx=z&count=z?t=xxx', title: 'Webcam', url: 'http://192.168.xxx.xxx/zm/index.php? view=montage&group=x'}
Is this too much refresh, as number of item and/or refresh time?
Posted: Thursday 30 November 2017 16:29
by htilburgs
woody4165 wrote: Thursday 30 November 2017 16:16
Hi all
var frames = {}
var maps = {}
var buttons = {}
The problem is indeed in the camera's. Standard I've a Dashboard active.
For testing purposes I've an identical configuration in Dashtest. In the test I've to exclude the camera's because I've the same issue as you descripe.
For your weather I see you use an iframe. An iframe can cause issue too with sluggish performance.
Posted: Thursday 30 November 2017 16:53
by woody4165
Thanks for the suggestion for iframe.
Now I've set all weather stuff, iframe and image, to 1800000
For now i'ts ok, if I have other issue I will try to exclude it.
Posted: Friday 01 December 2017 8:39
by woody4165
Trying to solve my issue, I was watching to the Development Tools in Chrome and in particular to the Network tab.
I saw a lot of request like this:
http://192.168.xxx.xxx:8080/json.htm?type=devices&filter=all&used=true&order=Name&jsoncallback=jQueryxxx_xxx&_=xxx
that give as result all the devices.
What is the reason to get all the device continously while I don't have all the devices shown and I have auto_positioning and use_favorites disabled (0)?
Posted: Friday 01 December 2017 9:36
by robgeerts
It is used to update the states of each device.
I can get the result per device but that results in a request per device
So that would be a lot more.. Or does somebody now I can use a request like this?
http://192.168.xxx.xxx:8080/json.htm?ty ... 234,5,2,11 etc?
Posted: Friday 01 December 2017 9:47
by woody4165
I got it, thanks
I don't think that the request with multiple idx will, work, no it doesn't, at least in that way.
