Page 152 of 184
Posted: Monday 20 November 2017 16:52
by gielie
aiolos wrote: Monday 20 November 2017 16:07
gielie wrote: Monday 20 November 2017 15:24 After some time i started to all over with this very nice project and i still have some problems with my temp sensors, i can't get them to switch title/value.
This is the code i use;
blocks['303_1'] = {} //badkamer temp
blocks['303_1']['title'] = 'Badkamer'
blocks['303_1']['switch'] = true
blocks['303_1']['width'] = 3
but the title and value doesn't switch, why?
Hmm, I tried it too, and indeed, it doesn't switch. I looked in the code and it turns out it is swapped twice, so not at all...
I'll make a pull request to fix it.
Edit: And Rob already merged it, check out latest beta
And as usual it is fixed with the speed of light, thanks again for this great application.
One slight problem, i can't adjust the width, it stays on 4
Solved, for some reason i had to add 303 together with the '303_1' to get the width adjusted.
Posted: Tuesday 21 November 2017 18:46
by sailmich
I use the newest beta. The weather weekdays are always in english and weatherunderground country code DL for Germany isn't working anylonger. When I choose DL I got nothing. I checked it with French/Italy and Netherlands, there you got forecast but always in english.
I use my personal weather station, with that I got forecast but again in english.
Posted: Tuesday 21 November 2017 19:23
by EdwinK
Isn't Germany not DE instead of DL?
Posted: Tuesday 21 November 2017 20:37
by sailmich
Not at wunderground, there it is DL.
Posted: Tuesday 21 November 2017 22:05
by trennel
I've playing around a little bit with dashticz. It seems that dashticz loses connection as soon as I call the ['spotify'] block. Whenever I remove this my light blocks start showing and the rest of the data comes through properly. Also the 'playlist' link doesn't do anything whenever spotify is loaded.
Anway, good work! I'm doing my best to make myself an awesome dashboard aswell :)
Posted: Tuesday 21 November 2017 22:14
by CaesarPL
O! You arÄ™ right! I had the same issue with Spotify two days ago. It used to work very good previously
Posted: Tuesday 21 November 2017 22:27
by dagger38
When i acces dashticz on my gsm (mobile phone) with the correct ip from my home , i see all my dashboard except the switches and blinds?
Why would that happen?
When working with domoticz via the gsm it works perfectly (without the beautifull screens of dashticz )
Strange ???
Posted: Tuesday 21 November 2017 22:28
by trennel
Perhaps something went wrong with last update? Also the sliders for adjusting brightness (philips hue) aren't work very smooth.
installed domoticz with dashtics on raspberry 3, accessing with surface tablet 3 through local ip. Does anyone else have this issue?
Posted: Tuesday 21 November 2017 22:40
by robgeerts
Mobile view has to be adjusted so it looks well.
It's best to remove Spotify, I'm recoding this plugin but doesnt work well yet.
@trennel, do you have a RGB-selector on your page?
Posted: Wednesday 22 November 2017 9:43
by aiolos
sailmich wrote: Tuesday 21 November 2017 18:46 I use the newest beta. The weather weekdays are always in english and weatherunderground country code DL for Germany isn't working anylonger. When I choose DL I got nothing. I checked it with French/Italy and Netherlands, there you got forecast but always in english.
In beta the weather now uses the language set through
config['calendarlanguage'] = 'nl_NL';
Then the forecast is given in that language (with the right punctuation). If you want to change the display of the date, change
config['shortdate'] = 'D MMM';
to something else (see format at momentjs.com)
Why the country code is not working anymore is weird, that is just using
config['wu_country'] = '..';
as before.
Posted: Wednesday 22 November 2017 16:31
by robgeerts
Not yet but you can do that this way:
Add to config.js:
var empty = {}
empty.camera = { empty:true, key: 'mycamera', width:12 }
Add to block-definitions in config.js:
columns[1]['blocks'] = [empty.camera]
Add to custom.js:
$(document).ready(function(){
	setTimeout(function(){
		$('div[data-id="mycamera"]').removeClass('mh');
		$('div[data-id="mycamera"]').html('<img style="max-width:100%;" src="http://webcasthosting.mylivestreams.com/images/webcam-live-webcam-streaming-hosting.jpg" />');
	},1000);
It now displays an image, does your camera output a jpg?
You can use that URL? Or, if it doesnt, try replaceing the image-tag to this:
https://stackoverflow.com/questions/224 ... a-web-page
Posted: Wednesday 22 November 2017 21:14
by trennel
robgeerts wrote: Tuesday 21 November 2017 22:40 Mobile view has to be adjusted so it looks well.
Yes, all my lights have this RGB selecter next to the brightness slider. However the non-smoothness was also the case before the update. Whenever i use the slider it keeps 'focus' for a very short time. Meaning that after small adjustment i have to reclick the slider to adjust it again.
Posted: Wednesday 22 November 2017 21:38
by sailmich
@aiolos
I have an older beta version were DL works. Seems something is different in dashticz. Thanks for the hint with calendar language, now I got German days :D for my personal weather station.
Posted: Thursday 23 November 2017 0:03
by aiolos
sailmich wrote: Wednesday 22 November 2017 21:38 @aiolos
Can you give your wu settings from the config? Then I can try it myself (I don't need your API key ;))
Posted: Thursday 23 November 2017 7:18
by sailmich
aiolos wrote: Thursday 23 November 2017 0:03
I'm wrong, although the older beta doesn't work, it was just working because I have set up my personal weather station key. And if you do so it doesn't matter wich country code you fill in.
My settings for Germany.
config['wu_name'] = 'Hannover';
config['wu_country'] = 'DL';
Posted: Thursday 23 November 2017 11:23
by aiolos
sailmich wrote: Thursday 23 November 2017 7:18 ...
When there are more results for a given location, the block also doesn't show up, so entering the station key works best then (for example "config['wu_city'] = 'zmw:00000.143.10338';").
Posted: Thursday 23 November 2017 11:49
by l0gic
** SOLVED **
morning guys,
I've just started on my Dashticz odyssey and I'm doing OK after a few false starts.
I've hit an issue that has me stumped at the moment relating to dummy devices.
I want to do my 'notifications' by manipulating the icon rather than changing the background or similar.
Using the blocks[532]['icon'] = 'fa-sun-o'; works fine generally and I can then insert code into custom.js to change the icon/colour/etc as the data changes. All great!
However, I have some bespoke items relating to power that do not want to take a new icon and I can't make the change in custom.js either.
I'm guessing this may be down to the nature of the item.
They all currently show a flame (Gas?) as the icon and I can't seem to make any changes.
They are either,
SMA Spot install (WIKI - http://www.domoticz.com/wiki/SMASpot_Mo ... n_Domoticz)
MySensors Power clamp set up
Dummy item which is an output from data above. E.g. House Load (from MySensors) minus the SMA solar to give me a total power requirement.
Devices information below:-
SMA Solar Inverter (SMA Spot)
ActTime: 1511433195,
ServerTime: "2017-11-23 10:33:15",
Sunrise: "07:30",
Sunset: "15:57",
result: [
AddjMulti: 1,
AddjMulti2: 1,
AddjValue: 0,
AddjValue2: 0,
BatteryLevel: 100,
CounterToday: "1.092 kWh",
CustomImage: 0,
Data: "19674.482 kWh",
Description: "",
Favorite: 0,
HardwareID: 11,
HardwareName: "SunnyBoy 4000",
HardwareType: "SBFSpot (SMA)",
HardwareTypeVal: 27,
HaveTimeout: false,
LastUpdate: "2017-11-23 10:30:21",
Notifications: "false",
Options: "",
PlanID: "0",
PlanIDs: [
0
Protected: false,
ShowNotifications: true,
SignalLevel: "-",
SubType: "kWh",
SwitchTypeVal: 0,
Timers: "false",
Type: "General",
TypeImg: "current",
Unit: 1,
Usage: "666.0 Watt",
Used: 1,
XOffset: "0",
YOffset: "0",
idx: "418"
status: "OK",
title: "Devices"
MySensors Power Clamp
ActTime: 1511433412,
ServerTime: "2017-11-23 10:36:52",
Sunrise: "07:30",
Sunset: "15:57",
result: [
AddjMulti: 1,
AddjMulti2: 1,
AddjValue: 0,
AddjValue2: 0,
BatteryLevel: 255,
CounterToday: "7.657 kWh",
CustomImage: 0,
Data: "943.262 kWh",
Description: "",
Favorite: 0,
HardwareID: 8,
HardwareName: "MySensors Tranceiver",
HardwareType: "MySensors Gateway USB",
HardwareTypeVal: 41,
HaveTimeout: false,
LastUpdate: "2017-11-23 10:36:40",
Name: "Main Consumer Unit",
Options: "0",
PlanID: "0",
PlanIDs: [
0
Protected: false,
SignalLevel: "-",
SubType: "kWh",
SwitchTypeVal: 0,
Timers: "false",
Type: "General",
TypeImg: "current",
Unit: 1,
Usage: "900.3 Watt",
Used: 1,
XOffset: "0",
YOffset: "0",
idx: "439"
status: "OK",
title: "Devices"
Dummy Item
ActTime: 1511433287,
ServerTime: "2017-11-23 10:34:47",
Sunrise: "07:30",
Sunset: "15:57",
result: [
AddjMulti: 1,
AddjMulti2: 1,
AddjValue: 0,
AddjValue2: 0,
BatteryLevel: 255,
CounterToday: "9.513 kWh",
CustomImage: 0,
Data: "1317.626 kWh",
Description: "",
Favorite: 1,
HardwareID: 15,
HardwareName: "Virtual generic items",
HardwareType: "Dummy (Does nothing, use for virtual switches only)",
HardwareTypeVal: 15,
HaveTimeout: false,
LastUpdate: "2017-11-23 10:34:00",
Name: "House Power Incoming",
Options: "1",
PlanID: "0",
PlanIDs: [
0
Protected: false,
SignalLevel: "-",
SubType: "kWh",
SwitchTypeVal: 4,
Timers: "false",
Type: "General",
TypeImg: "current",
Unit: 1,
Usage: "666.6 Watt",
Used: 1,
XOffset: "0",
YOffset: "0",
idx: "475"
status: "OK",
title: "Devices"
Any idea what I'm doing wrong or am I out of luck?
Reading back through the thread (sooo long, my eyes hurt :D ) it looks like these items may not be coded for and default to the Gas block?
Thoughts and advice most welcome!
Kevin
Edit running gitpull from two days ago.
Posted: Thursday 23 November 2017 12:03
by aiolos
You might need to specify the icons for the blocks with an underscore, for example:
blocks['35_1'] = {'icon': 'fa-sun-o'};
The power devices usually have multiple blocks per idx and I think the icon is only checked per sub-block.
Posted: Thursday 23 November 2017 12:55
by l0gic
aiolos wrote: Thursday 23 November 2017 12:03 You might need to specify the icons for the blocks with an underscore, for example:
Bang on the money - thanks.
I'd tried blocks[35_1] = {'icon': 'fa-sun-o'}; which crashed the screen.
Adding the ' around the 35_1 makes the difference.
So simple....
Excellent!
All the best
Kevin
Posted: Friday 24 November 2017 21:44
by dagger38
dagger38 wrote: Tuesday 21 November 2017 22:27 Hi,
Strange ???
Stil not working on my cell??
i have ccopyed and changed all to the custom_2 folder with use of index2.html , the files are adapted for use over my home ip number , but i still cant's see my swithes and the blinds (or the moon) all of witch are working , if i switch from the 4g internet to wifi on the cellphone??
