Page 16 of 25
Re: Android app
Posted: Sunday 02 November 2014 21:27
by Derik
On a enigma box perhaps?
Re: Android app
Posted: Sunday 02 November 2014 22:34
by sebas
There's a special Android version coming for TV's. Will be released tomorrow. Google has send out developer units of a standalone box that has Android TV running on it.
More info on Android TV:
http://www.android.com/tv/
Re: Android app
Posted: Monday 03 November 2014 14:41
by Brutus
He Sebas,
You did more then just fixed some issues
I can now see my camera to
My wishlist would be:
- To see the Dashboard icons instead of all the switches.
- When you scroll down and look at some switches and a refresh is comming the screen scrolls back to the top.
- Notifications in the app so you don't need any other apps. (When doorbell is pressed you get a popup from your camera).
Greetings Brutus.
Re: Android app
Posted: Monday 03 November 2014 16:51
by Mart
@Brutus and @Sebas. Thank you very much for help and updating; the app works fine!
Re: Android app
Posted: Monday 03 November 2014 17:53
by sebas
Brutus wrote:He Sebas,
Greetings Brutus.
Surprise
Notifications would require work on the Domoticz side as well so I need to see if the dev team has time to implement it. Dashboard should be doable and that refresh thing as well.
Mart wrote:@Brutus and @Sebas. Thank you very much for help and updating; the app works fine!
You're welcome
Good to hear it works.
Does someone know how I get that security panel to work? I entered a security code and set the delay to 0. It doesn't show anywhere event after I logout of Domoticz.
Re: Android app
Posted: Tuesday 04 November 2014 10:13
by ThinkPad
vmb wrote:@thinkpad Same situation here. When I connect through vpn (synology) I filled in Dromotica at field external and internal adress the internal adress of my Pi. Is works like a charm...
I filled in my internal IP and port at both internal and external, and now it works
@sebas, thanks for adding support for protected switches so quickly!!
However, i can't view the status of a protected switch (or i didn't look good, for now it looks like it just displays a grey lock icon). Is it possible to still leave the switches protected, but display the status (maybe display a blue lock when active, or a grey logo when inactive) ?
Re: Android app
Posted: Tuesday 04 November 2014 14:19
by vmb
ThinkPad wrote:vmb wrote:@thinkpad Same situation here. When I connect through vpn (synology) I filled in Dromotica at field external and internal adress the internal adress of my Pi. Is works like a charm...
Great, nice to hear. My first contribution to this forum...
Re: Android app
Posted: Tuesday 04 November 2014 16:19
by Sappien
When will the widgets get a update? A custom short tag would we very handy! They are now a bit useless
Re: Android app
Posted: Wednesday 05 November 2014 10:54
by Schim57300
Sappien wrote:When will the widgets get a update? A custom short tag would we very handy! They are now a bit useless
Good morning,
I agree with that point.. A short label would be usefull to manage the widgets.
I am using Dromotica since yesterday with my Domoticz server installed on my Synology. It is a nice app, congrats for the job.
I have sent an e-mail to the developper to inform him about a bug with the "Form authentication"
I had to set my server to "Basic Auth" in order to solve my issue. I was able to list the devices and the scenes but no command could be sent.
Regarding a wish list... Would it be possible to add a STOP button for blinds ?
Schim'
Re: Android app
Posted: Wednesday 05 November 2014 13:24
by sebas
Schim57300 wrote:Sappien wrote:When will the widgets get a update? A custom short tag would we very handy! They are now a bit useless
Good morning,
Schim'
Hi, developer here
Received your email. Those connection issues are the final touches I'm adding. This happens in some cases and will be solved soon.
Stop button for blinds has been requested before. I have added it to the (long) list of features that I would like to include.
Re: Android app
Posted: Wednesday 05 November 2014 18:34
by bizziebis
Tags would be great indeed. I now created them with a widget 'simple text'. Otherwise it's indeed almost useless. Or you must have a photographic memory
Re: Android app
Posted: Thursday 06 November 2014 9:02
by jannl
Is there a way to get Dromotica working through a vpn? I think the problem now is the check of the home wifi ssid.
Re: Android app
Posted: Thursday 06 November 2014 10:25
by sebas
jan_nl wrote:Is there a way to get Dromotica working through a vpn? I think the problem now is the check of the home wifi ssid.
Yes, there is. Copy your local settings to the remote settings.
Re: Android app
Posted: Thursday 06 November 2014 10:32
by jannl
Thx, that works. Should have thought of that myself.
Now the dashboard would be a nice feature tot have.
Re: Android app
Posted: Thursday 06 November 2014 11:15
by Schim57300
Hi Sebastian,
Thanks for your answer on Google Play ^^
I have updated Dromotica on my smartphone. I have switched my Dromoticz server from "Basic Auth" to "Connection Form" and started Dromotica.
List of devices : ok
List of scenes : ok
List of Temp Sensor : ok
Opening one blind : ok
Getting my Temp sensor state : ok
Well done amd thank you very much !
I only miss a stop button which is available on Domoticz web interface
Yesterday I tried the widget. It works... It only remains to add a short tag but thanks to bizziebis, we have a way to bypass the problem
Schim'
Re: Android app
Posted: Thursday 06 November 2014 12:31
by maluko
hi sebas
i have a problem with the last update, when i scroll down on switchs the dromototica goes down ( application turn off).
Scenes- ok
utilities- ok
temperature- ok
Weather - ok
cameras- ok
i think that is about switches are longer (more switchs) then the other tabs.
thanks
Re: Android app
Posted: Thursday 06 November 2014 12:55
by sebas
Schim57300 wrote:Hi Sebastian,
List of scenes : ok
Schim'
Are you using the venetian blinds? For me those are the only one's with a stop button in the web interface. I haven't added support for them yet but will do soon.
maluko wrote:hi sebas
Scenes- ok
utilities- ok
temperature- ok
Weather - ok
cameras- ok
thanks
Do you have protected switches? If that's the case I fixed that this morning, that update should be available in the store about now.
Re: Android app
Posted: Thursday 06 November 2014 13:13
by Schim57300
I m using SOMFY blinds :
I can send an "Open" command and then send a "stop" command via Domoticz
Domoticz type of Switch : Blinds
Protocol : RTS
Does that answers you ?
Re: Android app
Posted: Thursday 06 November 2014 13:48
by sebas
Protocol : RTS
Yes, and it adds some confusion
The stop command apparently works with normal blinds.
This is how the blinds switch is shown in Domoticz for me:
And this is the Venetian blinds:
I expected to only have the stop command with the venetian blinds and I haven't implemented them yet. As the stop button works with blinds I can add that to the switch in Dromotica without a problem.
P.S. your second image doesn't show (403 error).
Re: Android app
Posted: Thursday 06 November 2014 14:56
by maluko
Scenes- ok
utilities- ok
temperature- ok
Weather - ok
cameras- ok
thanks
Do you have protected switches? If that's the case I fixed that this morning, that update should be available in the store about now.[/quote]
Thanks sebas, i did the update now and works fine.
