Page 16 of 19
Re: Satel Integra (Security System) with ethernet module
Posted: Tuesday 22 October 2019 9:40
by fantom
Which version of domoticz ?
Posted: Tuesday 22 October 2019 10:48
by mmormon
fantom wrote: Tuesday 22 October 2019 9:40 Which version of domoticz ?
ver 4.10717
Posted: Tuesday 22 October 2019 10:56
by fantom
This is very old version.
Please update to the latest beta.
Posted: Wednesday 23 October 2019 8:26
by mmormon
Works properly with beta 11394. Thanks.
Posted: Saturday 26 October 2019 10:36
by fantom
Super :)
Posted: Saturday 25 January 2020 20:07
by Mih2o2pl
Hello, I have the following problem with connecting to the Integra 256 plus control panel.
Domoticz does not set up a connection in 32 bit mode, which means I have available for 128 I / O.
Everything updated to the highest version.
logs:
2020-01-25 15:30:06.539 Status: Satel Integra: connected to 192.168.1.250:7094
2020-01-25 15:30:06.540 Status: EventSystem: reset all events...
2020-01-25 15:30:06.540 Status: Satel Integra: Model Integra 256 Plus
2020-01-25 15:30:06.541 Status: Satel Integra: RTC 2020-01-25 16:33:22
2020-01-25 15:30:06.542 Status: Satel Integra: ETHM-1 ver. 2.07 2019-07-08 (32 bytes mode = false)
2020-01-25 15:30:06.542 Status: Satel Integra: worker started
Domoticz
Version: 4.11652
Posted: Sunday 26 January 2020 12:00
by fantom
Hmm.
I see that Satel change documentation for this 32 bit mode, and I must fix it in domoticz code.
I thinks it is fixed after merge this code : https://github.com/domoticz/domoticz/pull/3869/files
Pls try with the latest beta.
Posted: Tuesday 28 January 2020 8:49
by Mih2o2pl
2020-01-28 07:46:36.068 Status: Domoticz V4.11662 (c)2012-2020 GizMoCuz
2020-01-28 07:46:36.069 Status: Build Hash: 6dcbec606, Date: 2020-01-28 07:13:37
2020-01-28 07:46:36.070 Status: Startup Path: /home/pi/domoticz/
2020-01-28 07:46:36.339 Status: PluginSystem: Started, Python version '3.5.3'.
2020-01-28 07:46:36.339 Status: Satel Integra: Create instance
2020-01-28 07:46:36.352 Status: WebServer(HTTP) started on address: :: with port 5631
2020-01-28 07:46:36.357 Status: WebServer(SSL) started on address: :: with port 443
2020-01-28 07:46:36.360 Status: TCPServer: shared server started...
2020-01-28 07:46:36.393 Status: RxQueue: queue worker started...
2020-01-28 07:46:38.394 Status: Satel Integra: connected to 192.168.1.250:7094
2020-01-28 07:46:38.395 Status: EventSystem: reset all events...
2020-01-28 07:46:38.396 Status: Satel Integra: Model Integra 256 Plus
2020-01-28 07:46:38.396 Status: EventSystem: reset all device statuses...
2020-01-28 07:46:38.397 Status: Satel Integra: RTC 2020-01-28 08:46:44
2020-01-28 07:46:38.398 Status: Satel Integra: ETHM-1 ver. 2.07 2019-07-08 (32 bytes mode = false)
2020-01-28 07:46:38.398 Status: Satel Integra: worker started
Posted: Tuesday 28 January 2020 9:01
by fantom
Then maybe ETHM1 don't support 32 bit mode ?
Maybe only ETHM1 Plus supported it.
Please ask about it Satel support
Posted: Tuesday 28 January 2020 15:47
by Mih2o2pl
I have ethm 1 plus. I checked the laminate a day ago.
Posted: Tuesday 28 January 2020 16:25
by fantom
You need to find out more in the Satel when it is enabled (32 bit mode, info receive from ETHM1 on 0x7C command).
Fantom
ps. A few weeks ago on this topic was a similar discussion - https://www.domoticz.com/forum/viewtopi ... 60#p210215
Posted: Thursday 30 January 2020 22:45
by Mih2o2pl
Integra 256 plus to work in 32 bit mode requires https://www.satel.pl/pl/product/664/INT ... i-systemow
Posted: Monday 18 May 2020 19:54
by Irek
I've four external curtain (PIR sensors dedicated to detect movement around my building). I assume that such a sensors acts as ordinary PIRs. After connecting domoticz to my Satel hardware via ETHM-1 plus, I can see this devices, but they do not change status at all or domoticz can not recognize change of its status. I've checked using DLOADX app if I can observe any status change and suprisely I see it. From DLOADX point of view everything works just fine.
I would like to use this PIRs to turn on external lights during the night if movement will be detected, but this is impossible if domoticz can not recognize status change. Below I attach photo of such a sensor. Sensor model: RISCO RK315DT.
Can you somehow help me with my issue?
Irek
Posted: Monday 18 May 2020 21:43
by xury
Do you have other PIR sensors? And their status change is correct?
Are these sensors connected in 2EOL to the mainboard or INT-E?
Or maybe you use it with wireless expander such as ACX-220?
Did you tried turn off Satel Integra hardware in Domoticz and let start rescan your whole system again?
The type of sensor does not matter, only the connection method.
Posted: Monday 18 May 2020 22:10
by domoticzcom1234
Please read the full threat carefully. You probably are misreading some essential information.
Also you question is not specific enough and less people can (and probably will) help you out. :o
What is your PIR setup in your Satel panel? Does your PIR show up as a text device or switch device in Domoticz? Do you want to script it with blocky?
Posted: Tuesday 19 May 2020 0:57
by Irek
I'll try to answer some of your questions, but first I've to explain that I'm not the one who has installed whole alarmed system in my house. I was talking to the fitter (who did this) couple of weeks ago. Whole installation is about two years old and the situation is the same from the begining. The fitter has told me, that he has no idea why domoticz can not "catch" status change of those particular PIRs, because they are connected to Satel hardware (not wireless) the same way as many other PIRs in my house. All other PIRs works just fine. Below I attach print screen with some of my PIRs and the problem ones has idx: 145, 146, 147, 148. All other PIRs and reeds (kontaktrony) installed in window frames and doors works great. To answer the question related to connection method, I'll check it tomoorow, but I assume that it's the same way as many other PIRs in my house.
Posted: Tuesday 19 May 2020 1:17
by Irek
One more information about my plans how I'm going to use it. I've mqtt broker installed on another raspberry PI, and domoticz sends all the messages to this broker. On the same PI with broker I've node-red to provide whole logic in my house. I'm not going to use blocky or lua scripts if I've node-red. I'm able to filter all mqqt messages from domoticz and there is not even one from PIRs with idx menthioned in my previous post. But I can see all messages from every other PIR, switch, temperature and humitity sensor, PM2,5 and PM10 sensor, smart power plugs (z-wave and wifi versions with power consumption info), z-wave buttons, etc. in my house.
I also have an idea for another test but it's very laborious: I can switch off domoticz for few hours and write piece of code on ESP32 to communicate with Satel (using ETHM-1 plus) to find out if I can catch status change of mentionet erlier PIRs. I haven't done it before because I thought that mabe my issue is well known and has been already solved by some one else.
Posted: Tuesday 19 May 2020 10:45
by fantom
Pls show me what happess in domoticz logs, whe You trigger this PIR.
Fantom
Posted: Tuesday 19 May 2020 11:54
by Irek
Hi Fantom,
I've checked logs, and there is nothing form devices with idx: 145-148. All other PIRs works fine. I also know that type of line of all my PIRs is 2EOL/NC - have a look on print screens below. One last thing that bothers me is on image with hardware structure: module INT-E row nr 22. This one is different than the others where module is INT-IORS. I've no idea if it's important but all my external PIRs are connected to this module (row 22).
Posted: Tuesday 19 May 2020 12:43
by fantom
Pls check priv message.
Fantom
