Page 16 of 19
Re: Domoticz-Google-Assistant (dzga)
Posted: Sunday 27 August 2023 12:23
by jpvaneijk
Hi DewGew,
Sorry, sorry, sorry. Please forget the above.
I had an issue with my reverse proxy and after repairing this I linked my account and al devices were added to my Google home.
Still a few minor issues but thats ok for a sunday. Once again: sorry!
Posted: Thursday 07 September 2023 12:02
by PeJeWe
samourai47 wrote: Sunday 01 November 2020 21:06
somewhere i found this line
Ngrok was unable to start. Error: 'NgrokTunnel' object has no attribute 'replace' is not valid
But ngrock seems to be ok because he give a new url.
in config.yaml i writed
ngrok_tunnel: true
ngrok_auth_token: 1-------------------yrO9el1_d5DS899GvZaspqPf3SZ3
I don't understand
i have the same error.
i have run the following steps without luck:
source Domoticz-Google-Assistant/env/bin/activate
pip3 install pyngrok
deactivate.
and when i whant to resync my devices i get the error: Page not found!: 404 Client Error: Not Found for url:
https://homegraph.googleapis.com/v1/devices:requestSync
Device already in off state?
Posted: Thursday 07 September 2023 16:47
by portafreak
Hi, how can I force dzga to turn off a light even if it's already in off state? I always get a response from google saying that the device is already off. I get the following message in the DZGA log:
Unable to execute action.devices.commands.OnOff for Light48. Already in state
Posted: Monday 11 September 2023 11:51
by Merlijn
Hi DewGew,
I've been trying for a couple of days now but i can't even seem to get
http://localhost:3030/settings running.
It's giving: ERR_CONNECTION_REFUSED.
sudo systemctl status dzga returns with:
● dzgaservice - Domoticz-Google-Assistant Service
Loaded: loaded (/etc/systemd/system/dzgaservice; enabled; vendor preset: ena
Active: active (running) since Mon 2023-09-11 11:21:32 CEST; 966ms ago
Main PID: 26176 (python3)
Tasks: 1 (limit: 2058)
CGroup: /systemslice/dzgaservice
└─26176 /home/pi/Domoticz-Google-Assistant/env/bin/python3 /home/pi/D
sep 11 11:21:32 raspberrypi systemd[1]: Started Domoticz-Google-Assistant Servic
lines 1-9/9 (END)...skipping...
Loaded: loaded (/etc/systemd/system/dzgaservice; enabled; vendor preset: enabled)
└─26176 /home/pi/Domoticz-Google-Assistant/env/bin/python3 /home/pi/Domoticz-Google-Assistant/
sep 11 11:21:32 raspberrypi systemd[1]: Started Domoticz-Google-Assistant Service."
I hope you can point me in the right directions cause at the moment i'm clueless.
Posted: Monday 11 September 2023 21:45
by PeJeWe
PeJeWe wrote: Thursday 07 September 2023 12:02
ngrok_tunnel: true
I don't understand
deactivate.
i stil get the error in the DZGA log: Ngrok was unable to start. Error: 'NgrokTunnel' object has no attribute 'replace' is not valid
when i resync my devices i now have the message : Page not found!: 'client_email'
after a server restart i also dont get a new ngrok adres assignd
Posted: Monday 11 September 2023 21:49
by PeJeWe
Merlijn wrote: Monday 11 September 2023 11:51
Hi DewGew,
could it be tha you have a firewall running UFW perhaps
in that case you can do
sudo ufw disable
sudo ufw allow 3030
sudo ufw enable
this allows you to commuicatie over port 3030
Posted: Tuesday 12 September 2023 17:11
by Merlijn
PeJeWe wrote: Monday 11 September 2023 21:49
Hi DewGew,
sudo ufw disable
sudo ufw allow 3030
sudo ufw enable
I tried the first command but it returns with: 'sudo: ufw: command not found.'
Thanks for the suggestion though!
Posted: Tuesday 12 September 2023 19:23
by PeJeWe
Then you don't have this firewall installed.
Maybe you have another installed.
ore you can use for example 192.168.1.100:3030/settings
change it in youre ip adress
Posted: Wednesday 13 September 2023 7:58
by DewGew
Merlijn wrote: Tuesday 12 September 2023 17:11
Hi DewGew,
sudo ufw disable
sudo ufw allow 3030
sudo ufw enable
Don't use
http://localhost:3030/settings as url. I should be a ipnr like
http://192.168.1.10:3030/settings
Try run manually and see if there is any errors in terminal log:
cd /home/${USER}/
sudo systemctl stop dzga #If service is running
python3 Domoticz-Google-Assistant
Posted: Wednesday 13 September 2023 22:19
by PeJeWe
I have removed dzga and ngrok, and reinstalled it. maybe there are stil some files left over after removing dzga and ngrok.
I still get the ngrok connection error. ("error: 'ngroktunnel' object has no attribute 'replace' is not valid")
i don't get a new tunnel adress, i still get the first adress that i have got in the beginning.
Google Home has bin working for one time.
when i look at ngrok.com i see that that tunnel is running, it don't gets renewed when i restart te server.
has it something to do with "ngrok start --none --log=stdout" ?
or with pyngrok?
Log
Domoticz@Domoticz:~ $ sudo systemctl stop dzga
Domoticz@Domoticz:~ $ source Domoticz-Google-Assistant/env/bin/activate
(env) Domoticz@Domoticz:~ $ python3 Domoticz-Google-Assistant
Loading configuration...
(Press CTRL+C to stop server)
could you help DewGew?
Posted: Monday 18 September 2023 13:44
by Merlijn
DewGew wrote: Wednesday 13 September 2023 7:58
sudo ufw disable
sudo ufw allow 3030
sudo ufw enable
Don't use
cd /home/${USER}/
This helped! turns out i made a mistake in my ip number in the configuration.
But now i get the following error in the log:
2023-09-18 13:37:39 - ERROR - Error in getting devices and settings
Posted: Tuesday 19 September 2023 8:44
by DewGew
Merlijn wrote: Monday 18 September 2023 13:44
Don't use
cd /home/${USER}/
You have to enable Allow Basic Authentication over plain HTTP in menu
https://www.domoticz.com/wiki/Applicati ... Protection .
Its recomended to add a new user in Domoticz dedicated for DZGA and add devices to this user. See
https://www.domoticz.com/wiki/User_Management.
Posted: Tuesday 19 September 2023 9:11
by Merlijn
I already set up a user for dzga and enabled Allow Basi Authentication over plain HTTP.
The user has admin rights, so that isn't it either.
Do you have any other things i could check?
Posted: Tuesday 19 September 2023 9:16
by Merlijn
Merlijn wrote: Tuesday 19 September 2023 9:11
Turns out i had to update my Domoticz, now devices are visible for dzga!
Posted: Tuesday 19 September 2023 21:50
by Merlijn
DewGew wrote: Tuesday 19 September 2023 8:44
Last thing (for now problably), how do i keep ngrok running? As soon as i stop the putty connection to my raspberry, ngrok stops as well.
Posted: Wednesday 20 September 2023 14:25
by gvandick
Latest versions stable domoticz and dzga I use ngrok free connection with google home works fine.
Sychr domoticz dzga function oke.
Problem is that devices in google home app are showing offline, but voice command works for all devices.
When I change roomnumber in dzga instandly correct devices for that room in google home but showing offline voice command works well.
I change smart-key several times but didn't solved the problem. I added google nest IP as trusted IP in domoticz
What can be the problem.
Posted: Wednesday 20 September 2023 22:20
by Merlijn
gvandick wrote: Wednesday 20 September 2023 14:25
Can you tell me how you set up ngrok?
This might help me with my problem.
Posted: Thursday 21 September 2023 8:23
by gvandick
I asume you installed ngrok on your raspberry.
For configuration
Ngrok instellingen
sudo nano ~/.ngrok2/ngrok.yml
tunnels:
nginx-server:
proto: http
addr: 3030
bind-tls: true
console_ui: false
authtoken: jouw authtoken
region: eu
sudo nano /etc/systemd/system/ngrok-client.service
[Unit]
Description=ngrok client
After=network.target
[Service]
ExecStart=/home/pi/ngrok start --all -config /home/pi/.ngrok2/ngrok.yml
Restart=on-abort
[Install]
WantedBy=multi-user.target
Posted: Thursday 21 September 2023 11:01
by Merlijn
gvandick wrote: Thursday 21 September 2023 8:23
For configuration
Ngrok instellingen
tunnels:
nginx-server:
proto: http
addr: 3030
bind-tls: true
console_ui: false
region: eu
[Unit]
[Service]
Restart=on-abort
[Install]
I'm getting the following error when editing ngrok.yaml:
ERROR: Invalid configuration file saved at "/home/pi/.config/ngrok/ngrok.yml": Error reading configuration file '/home/pi/.config/ngrok/ngrok.yml': YAML parsin g error: yaml: unmarshal errors:
ERROR: line 5: field nginx-server not found in type config.v2yamlConfig
ERROR: line 6: field proto not found in type config.v2yamlConfig
ERROR: line 7: field addr not found in type config.v2yamlConfig
ERROR: line 8: field bind-tls not found in type config.v2yamlConfig
Posted: Friday 22 September 2023 9:40
by Merlijn
Merlijn wrote: Thursday 21 September 2023 11:01
For configuration
Ngrok instellingen
tunnels:
nginx-server:
proto: http
addr: 3030
bind-tls: true
console_ui: false
region: eu
[Unit]
[Service]
Restart=on-abort
[Install]
Managed to keep ngrok running after logging off with: nohup ngrok http 3030 &
