Dashticz - Module - Garbage collector Topic is solved
robgeerts
Domoticz version: 3.7067
Re: Dashticz - Module - Garbage collector
Post by robgeerts »
Good NEWS!
In latest Beta, the Rova-calendar should work, try these settings in config.js:
config['garbage_company'] = 'rova';
config['garbage_icalurl'] = '';
config['garbage_zipcode'] = '7731ZT';
config['garbage_street'] = '';
config['garbage_housenumber'] = '84';
config['garbage_maxitems'] = 5;
EdwinK
Post by EdwinK »
Yeah... there is a new beta :)
marxkemp
Post by marxkemp »
robgeerts wrote: Wednesday 08 November 2017 9:40 Good NEWS!
I did a fresh beta clone into another folder
git clone https://github.com/robgeerts/dashticz_v2 --branch beta dashboard
The above config gives me a garbage block with "Loading"
New beta not released yet?
robgeerts
Post by robgeerts »
Weird, could you check console if it gives any error?
Or search in the network-tab to an url wich contains the string 'rova', click it and show me what you see ;)
marxkemp
Post by marxkemp »
I did another git pull, it updated garbage js and its working with my own zipcode. thank you
Gerald
Post by Gerald »
@Rob: You are truly a master sir!
It works like a charm!
pvm
Domoticz version: 4.10538
Post by pvm »
Is it possible to mention the short names in the opening post like for 'Afval App' in the config you have to use 'deafvalapp'
pvm
Post by pvm »
I've found an issue with housenumbers with an additional letter, can you integrate the change below?
Code has been tested for Afval App and working correctly
I've fixed this by:
Adding an extra config parameter in config.js
config['garbage_housenumberadd'] = 'a';
Reading this new parameter in the top of garbage.js with (naming kept similar)
var homenumberadd = settings['garbage_housenumberadd'];
And adding this parameter to the services who can use this (like afvalapp in this example), in the old code the parameter was not filled
'&toevoeging=' + homenumberadd, function(data){
robgeerts
Post by robgeerts »
Added in latest beta, could you test this?
If you get a blank page, please reply in the Bug report-topic.
pvm
Post by pvm »
Hi Rob, tested latest beta, thnx, working fine
robgeerts
Post by robgeerts »
Nice :)
PeJeWe
Domoticz version: Latest
Post by PeJeWe »
I can't get it running the "HVC Groep" afval programma.
my settings in the CONFIG.js
config['garbage_company'] = 'HVC groep';
config['garbage_icalurl'] = 'http://inzamelkalender.hvcgroep.nl/maand';
config['garbage_zipcode'] = 'my zipcode';
config['garbage_street'] = 'my street';
config['garbage_housenumber'] = '17';
//Afval programma
var trashcan = {}
trashcan.hvc = { maxitems: 10, trashapp: 'hvc groep', width:12, zipcode:'******', housenumber:'17' }
var trashnames = {}
trashnames['Rest'] = 'Grijze bak';
trashnames['Gft'] = 'Groene bak';
trashnames['Pmd'] = 'Plastic';
trashnames['Papier'] = 'Blauwe bak';
var trashcolors = {}
trashcolors['Rest'] = 'Grey';
trashcolors['Gft'] = 'Green';
trashcolors['Pmd'] = 'Orange';
trashcolors['Papier'] = 'Blue';
when i push the button i get the "Domoticz offline" message
do i have to install something in domoticz?
I have done a git pull "beta" without succes.
robgeerts
Post by robgeerts »
When you push the button? Wich button?
Could you PM me your zipcode?
aiolos
Domoticz version: stable
Post by aiolos »
for hvc you can just use config['garbage_company'] = 'hvc';
With zipcode and housenumber you should get the calendar. The ical url is not necessary.
Contributor to Dashticz
More on my Github profile
aiolos
Post by aiolos »
A PR for changes in the garbage collection module has been created, so this will be merged soon. There are some changes related to the colouring and naming.
The following config options are new (and trashnames/trashcolors config is gone)
config['garbage'] = {
    gft: {kliko: 'green', code: '#375b23', name: 'GFT'},
    pmd: {kliko: 'orange', code: '#db5518', name: 'PMD'},
    rest: {kliko: 'grey', code: '#5e5d5c', name: 'Restafval'},
    papier: {kliko: 'blue', code: '#153477', name: 'Papier'},
    kca: {kliko: 'red', code: '#b21807', name: 'Chemisch afval'},
    brown: {kliko: 'brown', code: '#7c3607', name: 'Bruin'},
    black: {kliko: 'black', code: '#000000', name: 'Zwart'},
config['garbage_use_names'] = true;
config['garbage_use_colors'] = true;
Within this config you can change the kliko color and color code of the lines in the block (color code only used if you enable the 'garbage_use_colors' config option). The name property is used if the 'garbage_use_names' option is enabled, otherwise the information from your garbage company will be used.
All various garbage company handling has slightly changed (but the outcome should not be different).
All garbage collection information that was fetched through an ical calender is now loaded directly through javascript (without the need of a php script, which was loaded externally).
A new option for google calendars is also added. The google calendar API can be used with a calendar id and api key (for creating an api key, see https://docs.simplecalendar.io/google-api-key/)
The new config options for google calendars:
config['garbage_company'] = 'googlecalendar';
config['google_api_key'] = 'YourOwnApiKey';
config['garbage_calendar_id'] = '[email protected]';
If anyone experiences any weird behaviour after the update, let me know. (preferably with information like your garbage config settings)
EdwinK
Post by EdwinK »
Nice. Of course this means changing stuff again
aiolos
Post by aiolos »
Yeah, unfortunately. Especially if you have specific colouring. The garbage_company and address settings haven't changed, so for most people it should just work.
EdwinK
Post by EdwinK »
Trying to figure things out is not that bad. Already preparing :)
robgeerts
Post by robgeerts »
Merged and tested!
@aiolos, sent you a few beers via PayPal!
EdwinK
Post by EdwinK »
Thanks. Was just getting ready to go to bed, when I noticed the update. So, quickly pulled it, and running ;)
