Dashticz - Module - Calendar
peerkersezuuker
Re: Dashticz - Module - Calendar
Post by peerkersezuuker »
I have the same problem.
I also have afval kalender enabled and that is working perfect with the local php.
jake
Post by jake »
peerkersezuuker wrote:I have the same problem.
How did you get the 'afval kalender' block working again? Mine doesn't work, but it possibly has to do with both ther server shutdown and HVC who changed access to their data some weeks ago. I don't know yet if anybody updated the code for HVC. Before it was stored on Rob's server, so nobody had access to it.
peerkersezuuker
@Jake, We have Cure as our local garbage disposal company.
I changed function getGeneralData in garbage.js, ther you se an url pointing to dashticz.nl.
Change it to you own.
function getGeneralData(service,address, date, random, subservice){
$.getJSON(getPrefixUrl() + 'http://xxxxx.xxxxx.xxx:880/php/afval/?s ... '&zipcode=' + address.zipcode + '&nr=' + address.housenumber + '&t=' + address.housenumberSuffix, function (data) {
data = data
jake
Post by jake »
Thanks, allthough according git pull everything is up to date, I see that I have in /dashboard/vendor/dashticz only the folder ical, while the zip of Rob shows afval and tv as well. I added the additional folders to the dashticz folder and pointed towards that accordingly (192.168.x.x/dashticz/dashboard/vendor/dashticz/afval) but it still doesn't work. I assume this is because of the change in the HVC call that I don't fully understand.
Siewert308SW
Domoticz version: Stable
Post by Siewert308SW »
Is there a max amount of combined calendars in the beta version?
My code below works.
But if i add a third or fourth calendar then only the first two are shown.
var calendars = {}
calendars.fcg = { width:6 ,maxitems: 10, icalurl: 'https://calendar.google.com/calendar/ical/xxxx%40import.calendar.google.com/public/basic.ics' }
calendars.prive = { width:6 ,maxitems: 10, icalurl: 'https://calendar.google.com/calendar/ical/xxxx/basic.ics' }
calendars.feestdagen = { width:6 ,maxitems: 10, icalurl:'https://calendar.google.com/calendar/ical/xxxx%40group.v.calendar.google.com/public/basic.ics' }
//calendars.vakanties = { width:6 ,maxitems: 10, icalurl:'https://calendar.google.com/calendar/ical/xxxx%40import.calendar.google.com/public/basic.ics' }
calendars.combined = {}
calendars.combined.maxitems = 6;
calendars.combined.width = 9
calendars.combined.icon = 'far fa-calendar-alt';
calendars.combined.calendars = [
	{ color:'white',calendar:calendars.vakanties },
	{ color:'green',calendar:calendars.fcg },
	//{ color:'white',calendar:calendars.prive },
	//{ color:'red',calendar:calendars.feestdagen }
calendars.combined.url = 'https://calendar.google.com/calendar';
Setup:
- RPi4 - Domo Stable / Aeotec Z-stick7 / PiHole Unbound Gemini
- RPi4 - PiHole / PiVPN Unbound Gemini
- Synology DS923+ / DS218j
- P1 Gas/Power, SmartGateway watermeter
- Fibaro switches, contacts, plugs, smoke/Co2 ect
- rootfs @ USB HDD
tileiran
Post by tileiran »
Is there any solution how to shown calendars that repeating? I have lots of calendar items that is repeating every 5 weeks. Somedays more then 2 on a day.
Derik
Post by Derik »
Dear...
Update to last beta :oops: :oops:
Is the way to use the new calendar:
{maxitems: 35, 	icalurl: 'https://cors-anywhere.herokuapp.com/https://calendar.google.com/calendar/ical/demxxxxxx
Because in the calendar.js i see the dashticz.nl not any more?
Only when i try this the calendar is not working yet :roll:
EdwinK
Post by EdwinK »
dashticz.nl isn't being used for some time now.
Derik
Post by Derik »
EdwinK wrote: Saturday 05 January 2019 22:54 dashticz.nl isn't being used for some time now.
Yes i read that...
Only where do i need to make a change to use the calendar function again..
I did:
config['default_cors_url']	='https://cors-anywhere.herokuapp.com/';
I did:
 {maxitems: 35, 	icalurl: 'https://cors-anywhere.herokuapp.com/https://calendar.google.com/calendar/ical/xxxxxxxxxx
where do i go wrong?
Or otherwise how do i get the calendar working/
Lokonli
Post by Lokonli »
Derik wrote: Saturday 05 January 2019 22:57
Yes i read that...
I did:
I did:
Do you have it working already?
With the latest beta you can remove config['default_cors_url']. You also can just use the normal calendar url (without the cors-anywhere part in front)
Derik
Post by Derik »
please a simple how to use the/this calendar option..
Lokonli
Post by Lokonli »
Derik wrote: Saturday 19 January 2019 18:55 please a simple how to use the/this calendar option..
First install Dashticz, including Apache and PHP, according the info on the wiki:
Then add the following lines to your CONFIG.js:
var calendars = {}
calendars.me = { maxitems: 10, url: 'https://calendar.google.com/calendar/embed?src=youremail%40gmail.com&ctz=Europe%2FAmsterdam', icalurl: 'https://calendar.google.com/calendar/ical/youremail%40gmail.com/private-yourprivatekey/basic.ics' }
Your calendar must be in ical format. When you click on the agenda the url is opened in a frame. The example above works for a google agenda. You can find the links on the settings page of your agenda on calendar.google.com.
Add the calendar to a column:
var columns = {}
columns[1] = {}
columns[1]['blocks'] =  [
calendars.me
And then it should work :)
Derik
Post by Derik »
Lokonli wrote: Saturday 19 January 2019 19:29
var calendars = {}
var columns = {}
columns[1] = {}
calendars.me
Apache en php?
In the wiki from?
Lokonli
Post by Lokonli »
Derik wrote: Saturday 19 January 2019 19:38
var calendars = {}
var columns = {}
columns[1] = {}
calendars.me
Apache en php?
In the wiki from?
https://www.domoticz.com/wiki/Dashticz_V2
First start with the installation part.
Derik
Post by Derik »
Lokonli wrote: Saturday 19 January 2019 20:05
var calendars = {}
var columns = {}
columns[1] = {}
calendars.me
Apache en php?
In the wiki from?
Still running for long time only the calendar part is missing after the "big" change
Lokonli
Post by Lokonli »
Derik wrote: Saturday 19 January 2019 20:08
Apache en php?
In the wiki from?
If you want to use calendar you have to install apache, PHP and a recent beta version of Dashticz.
Derik
Post by Derik »
Lokonli wrote: Saturday 19 January 2019 20:14
Yes i read something...
Only that's my problem..
Can i this direct install on the same hardware where domoticz is on running...
And then where to start to get the calendar working fine
Lokonli
Post by Lokonli »
Derik wrote: Saturday 19 January 2019 20:25
Yes, you can install it on the same hardware. What kind of system are you using?
Derik
Post by Derik »
Lokonli wrote: Saturday 19 January 2019 20:54
RPi 3 or Xu4 odroid [ testing ]
Derik
Post by Derik »
Derik wrote: Saturday 19 January 2019 21:30
so what are the commands i need to use?
the wiki from domoticz is very great..
