Locked
ddahya
Re: New Dashboard Design
Post by ddahya »
just noticed in that my setpoint devices are not showing up at two devices in the Dashboard
Setpoint Device 2.JPG (21.78 KiB) Viewed 2809 times
Setpoint Device 1.JPG (21.2 KiB) Viewed 2809 times
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
ddahya wrote:just noticed in that my setpoint devices are not showing up at two devices in the Dashboard
Aren't they also positioned in the left column?
Could you send me a complete screenshot?
And, if possible, the complete (all devices) json-output from domoticz, via PM?
EdwinK
Post by EdwinK »
robgeerts wrote:
EdKo66 wrote: Just the two bottom (wind and barometer) should go up a little more.
Could you test if this is working, add to creative.css:
.states > div {
	height:75px;
#switches > div {
	height:85px;
(or download latest version)
Works :)
robgeerts
Post by robgeerts »
@ALL:
Do define wich switches/states you want to show, I'm thinking of the following solution, if there's a file called POSITION.JS execute this, if not, parse everything the way it is currently. The contents could be something like:
//defining wich blocks to show
var blocks = {}
blocks[23] = {}
blocks[23]['title'] = 'Dinner table'; //remove line if you want use title as defined in domoticz
blocks[23]['width'] = 2; //1 to 12, remove this line if you want to use the default (4)
blocks[35] = {}
blocks[35]['title'] = 'Living room'; //remove line if you want use title as defined in domoticz
blocks[35]['width'] = 2; //1 to 12, remove this line if you want to use the default (4)
blocks[76] = {}
blocks[76]['title'] = 'Stairs'; //remove line if you want use title as defined in domoticz
blocks[76]['width'] = 2; //1 to 12, remove this line if you want to use the default (4)
//defining number of columns, their contents en widths
//width can be a number 1 to 12, but total widths of all columns should always be 12
var columns = {}
columns[1] = {}
columns[1]['blocks'] = {23,35,76}
columns[1]['width'] = 5;
columns[2] = {}
columns[2]['blocks'] = {'weather',1,67,128,'buttons'}
columns[2]['width'] = 5;
columns[3] = {}
columns[3]['blocks'] = {'clock','sunrise','currentweather'}
columns[3]['width'] = 2;
In this case, everybody can arrange their dashboard according to their needs!
ddahya
Post by ddahya »
Just sent you all the details via PM
Dynamic
Post by Dynamic »
robgeerts wrote:@ALL:
var blocks = {}
blocks[23] = {}
blocks[35] = {}
blocks[76] = {}
var columns = {}
columns[1] = {}
columns[2] = {}
columns[3] = {}
I think it's a good approach. If you need a beta-tester, count me in!
EdwinK
Post by EdwinK »
I would like that very much.
robgeerts
Post by robgeerts »
Already started with this and it's looking good! :)
SwordFish
Domoticz version: V4.11375
Post by SwordFish »
var blocks = {}
blocks[23] = {}
blocks[35] = {}
blocks[76] = {}
var columns = {}
columns[1] = {}
columns[2] = {}
columns[3] = {}
Verry nice
robgeerts
Post by robgeerts »
PROGRESS, THESE DIFFERENT LAYOUTS ARE ONLY DONE BY CHANGING STUFF IN CONFIG:
SwordFish
Post by SwordFish »
Looks nice.
Is it possible to move the weather witch now is located bij status to vooruitzichten?
robgeerts
Post by robgeerts »
You can move it to a place where ever you want :)
HansieNL
Post by HansieNL »
@robgeerts: You're almost faster than light :D ;)
Is it possible to have the selector switch show to the right selection instead of always "select"?
Blah blah blah
robgeerts
Post by robgeerts »
HansieNL wrote:@robgeerts: You're almost faster than light :D ;)
Well, it does at my dashboard...
In this case, I can hide the left block...
HansieNL
Post by HansieNL »
The Toon Setpoint is working great now!!! But I also have a selector switch to quickly select a presetted temperature.
Tried an other selector switch and it just shows "select" and not the selection already made. I hope it's more clear now.
Blah blah blah
robgeerts
Post by robgeerts »
HansieNL wrote:The Toon Setpoint is working great now!!! But I also have a selector switch to quickly select a presetted temperature.
What's the output of that selector?
HansieNL
Post by HansieNL »
I don't know if you can make it work default for every selector switch?
This is for my Thermostaat selector switch:
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 255,
         "CustomImage" : 15,
         "Data" : "On",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 2,
         "HardwareName" : "Dummy",
         "HardwareType" : "Dummy (Does nothing, use for virtual switches only)",
         "HardwareTypeVal" : 15,
         "HaveDimmer" : true,
         "HaveGroupCmd" : true,
         "HaveTimeout" : false,
         "ID" : "0001407F",
         "Image" : "Heating",
         "IsSubDevice" : false,
         "LastUpdate" : "2017-04-05 15:08:06",
         "Level" : 40,
         "LevelActions" : "|http%3A//192.168.2.14%3A8080/json.htm%3Ftype%3Dcommand%26param%3Dthermostatstate%26idx%3D35%26state%3D0|http%3A//192.168.2.14%3A8080/json.htm%3Ftype%3Dcommand%26param%3Dthermostatstate%26idx%3D35%26state%3D1|http%3A//192.168.2.14%3A8080/json.htm%3Ftype%3Dcommand%26param%3Dthermostatstate%26idx%3D35%26state%3D2|http%3A//192.168.2.14%3A8080/json.htm%3Ftype%3Dcommand%26param%3Dthermostatstate%26idx%3D35%26state%3D3|",
         "LevelInt" : 40,
         "LevelNames" : "Off|Comfort|Thuis|Slapen|Weg|Hand",
         "LevelOffHidden" : true,
         "MaxDimLevel" : 100,
         "Name" : "Thermostaat",
         "Notifications" : "false",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Protected" : false,
         "SelectorStyle" : 0,
         "ShowNotifications" : true,
         "SignalLevel" : "-",
         "Status" : "On",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "Selector Switch",
         "SwitchType" : "Selector",
         "SwitchTypeVal" : 18,
         "Timers" : "false",
         "Type" : "Light/Switch",
         "TypeImg" : "Light",
         "Unit" : 1,
         "Used" : 1,
         "UsedByCamera" : false,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "48"
Blah blah blah
robgeerts
Post by robgeerts »
I think the problem is that not of these levels (Off|Comfort|Thuis|Slapen|Weg|Hand) is set als active in the output...
What was the active state at the time you copied the output?
HansieNL
Post by HansieNL »
robgeerts wrote:I think the problem is that not of these levels (Off|Comfort|Thuis|Slapen|Weg|Hand) is set als active in the output...
"Weg" was selected. It must be this one: "LevelInt" : 40, or this on "Level" : 40,
Blah blah blah
robgeerts
Post by robgeerts »
Ah, great!
I didn't see it ;)
It's fixed in the next version (not pushed to Gitlab yet but will be when I finished the arrange-function, hopefully tonight)
Locked
