Pass2PHP
ropske
- Domoticz version: V3_8394
Re: LUA Pass2php
You know other valves that should be better?
I also found some of Honeywell
ropske
Re: LUA Pass2php
script is running only for living room now (just want to test)
but what i see is, when temperature is almost there, the script is switching off/on the brander
is this normal that this happens?
or am i doing something wrong?
(btw i added some debug lines to see what is happening
2017-01-23 23:05:48.762 => Executing device: Living with status: 20.9
2017-01-23 23:05:48.831 => difLiving: -0.1 and bigdif: -0.1
2017-01-23 23:05:48.840 => test: 1
2017-01-23 23:05:48.848 => setting radiator RSetliving with :28.0
2017-01-23 23:05:48.855 => Thermostaat_Living1: 28
2017-01-23 23:05:48.863 => RSetliving: 28.0
2017-01-23 23:05:48.870 => brander: Off timebrander: 197832
2017-01-23 23:05:48.876 => false
2017-01-23 23:05:48.891 => SWITCH 211 On brander6 dif = -0.1, was off for 7:57:12
2017-01-23 23:05:48.900 User: Admin initiated a switch command (211/Brander_Q2/On)
2017-01-23 23:06:24.645 => Executing device: Verbruik vaatwas with status: 0.0
2017-01-23 23:06:24.752 => difLiving: -0.1 and bigdif: -0.1
2017-01-23 23:06:24.759 => test: 1
2017-01-23 23:06:24.785 => setting radiator RSetliving with :28.0
2017-01-23 23:06:24.793 => Thermostaat_Living1: 28
2017-01-23 23:06:24.805 => RSetliving: 28.0
2017-01-23 23:06:24.817 => brander: On timebrander: 197868
2017-01-23 23:06:24.825 => false
2017-01-23 23:06:24.851 => SWITCH 211 Off brander10 dif = -0.1, was on for 7:57:48
2017-01-23 23:06:24.873 User: Admin initiated a switch command (211/Brander_Q2/Off)
- Egregius
- Domoticz version: v2024.7
Re: LUA Pass2php
Yes, that's by design to avoid overheating.
Could be that you need to change the timings to suit your heating system/home.
ropske
Re: LUA Pass2php
okay, thanks for quick feedback
i just thought it was me doing something wrong lol :p
will play a little bit with the timers, because i'm affraid by swichting off/on so quickly i will harm my heater
because when i switch my heater manually on, he starts running, but the actual heating only begins after a good 30seconds
- Egregius
Re: LUA Pass2php
You find that quick?
if($bigdif<=-0.6&&$brander=="Off"&&$timebrander>20)sw('brander','On', 'brander1 dif = '.$bigdif.', was off for '.convertToHours($timebrander));
elseif($bigdif<=-0.5&&$brander=="Off"&&$timebrander>60)sw('brander','On', 'brander2 dif = '.$bigdif.', was off for '.convertToHours($timebrander));
elseif($bigdif<=-0.4&&$brander=="Off"&&$timebrander>120)sw('brander','On', 'brander3 dif = '.$bigdif.', was off for '.convertToHours($timebrander));
elseif($bigdif<=-0.3&&$brander=="Off"&&$timebrander>180)sw('brander','On', 'brander4 dif = '.$bigdif.', was off for '.convertToHours($timebrander));
elseif($bigdif<=-0.2&&$brander=="Off"&&$timebrander>240)sw('brander','On', 'brander5 dif = '.$bigdif.', was off for '.convertToHours($timebrander));
elseif($bigdif<=-0.1&&$brander=="Off"&&$timebrander>300)sw('brander','On', 'brander6 dif = '.$bigdif.', was off for '.convertToHours($timebrander));
elseif($bigdif<=0 &&$brander=="Off"&&$timebrander>1800)sw('brander','On', 'brander7 dif = '.$bigdif.', was off for '.convertToHours($timebrander));
elseif($bigdif>0 &&$brander=="On" &&$timebrander>30)sw('brander','Off','brander8 dif = '.$bigdif.', was on for '.convertToHours($timebrander));
elseif($bigdif>=0 &&$brander=="On"&&$timebrander>180)sw('brander','Off','brander9 dif = '.$bigdif.', was on for '.convertToHours($timebrander));
elseif($bigdif>=-0.1&&$brander=="On"&&$timebrander>300)sw('brander','Off','brander10 dif = '.$bigdif.', was on for '.convertToHours($timebrander));
elseif($bigdif>=-0.2&&$brander=="On"&&$timebrander>420)sw('brander','Off','brander11 dif = '.$bigdif.', was on for '.convertToHours($timebrander));
elseif($bigdif>=-0.3&&$brander=="On"&&$timebrander>540)sw('brander','Off','brander12 dif = '.$bigdif.', was on for '.convertToHours($timebrander));
elseif($bigdif>=-0.4&&$brander=="On"&&$timebrander>660)sw('brander','Off','brander13 dif = '.$bigdif.', was on for '.convertToHours($timebrander));
elseif($bigdif>=-0.5&&$brander=="On"&&$timebrander>780)sw('brander','Off','brander14 dif = '.$bigdif.', was on for '.convertToHours($timebrander));
elseif($bigdif>=-0.6&&$brander=="On"&&$timebrander>900)sw('brander','Off','brander15 dif = '.$bigdif.', was on for '.convertToHours($timebrander)); -
ropske
Re: LUA Pass2php
yeah, there was something wrong with saving the lastupdate time for every device
now it's updating normally, so i will test again tonight, i think it will be much better and normal like your script should work
thanks!
thanks!
ropske
Re: LUA Pass2php
all working ok, thank you
still, got a question:
if i understand this, i think that ''setpointliving'' is a kind of a manual override?
is this some kind of a button or is this a selector switch where you have manual/automatic?
$Setliving=14;
$setpointliving=apcu_fetch('setpointliving');
if($setpointliving!=0&&apcu_fetch('tliving_set')<time-10795){apcu_store('setpointliving',0);$setpointliving=0;}
if($setpointliving!=2){is this some kind of a button or is this a selector switch where you have manual/automatic?
ropske
Re: LUA Pass2php
if setpointliving = 2 => means probably manual override?
and when manual override is activated for around 3hours, then reset this?
am i correct?
you are using a selector switch for manual override?
am i correct?
- Egregius
Re: LUA Pass2php
Totally correct.
Variable is set when choosed on my floorplan.
ropske
Re: LUA Pass2php
Thank you.
One 'strange ' thing:
my __verwarming.php is also running on a 10sec cron
but i added a debug line in it, it shows up sometimes after 20-30 seconds
before it was every 10seconds
i have added some more code in it than before
i will probably need to buy the new raspberry pi3 :p
now running at the b+ model
- Egregius
Re: LUA Pass2php
Depends on how you trigger Domoticz to launch the event system.
If you 'update' a switch every 10 seconds it'll run every 10 sec.
But it shouldn't be an issue if it's sometimes executed after a longer time. Each temperature update will cause the event system to launch so it'll be executed.
If you really want it every 10 second you could do something with a bash script and cron.
I'm using this to be sure it's executed at maximum every two minutes:
#!/bin/bash
LASTCRON=`curl -s --connect-timeout 2 --max-time 5 "http://127.0.0.1/secure/lastcron.php"`
TIME=$(date +"%s")
TIME=$((TIME - 30))
if [ "$LASTCRON" -gt "$TIME" ] ; then
exit
DOMOTICZ=`curl -s --connect-timeout 2 --max-time 5 "http://127.0.0.1:8084/json.htm?type=command¶m=udevice&idx=203&nvalue=0&svalue=Off"`
STATUS=`echo $DOMOTICZ | jq -r '.status'`
if [ "$STATUS" == "OK" ] ; then
exit
sleep 5
STATUS2=`echo $DOMOTICZ | jq -r '.status'`
if [ "$STATUS2" == "OK" ] ; then
exit
sleep 5
STATUS3=`echo $DOMOTICZ | jq -r '.status'`
if [ "$STATUS3" == "OK" ] ; then
exit
curl -s --connect-timeout 2 --max-time 5 --data-urlencode "text=Domoticz Bad - Restarting" --data "silent=false" http://127.0.0.1/secure/telegram.php
NOW=$(date +"%Y-%m-%d_%H%M%S")
cp /volume1/appstore/domoticz/var/domoticz.log /volume1/files/temp/domoticz-$NOW.txt
sudo /var/packages/domoticz/scripts/start-stop-status stop
sleep 8
sudo kill $(sudo netstat -anp | awk '/ LISTEN / {if($4 ~ ":8084$") { gsub("/.*","",$7); print $7; exit } }')
sleep 8
sudo /var/packages/domoticz/scripts/start-stop-status start
fi
fi
fi
fi
<?php
echo apcu_fetch('cron10');-
dutchdevil83
- Domoticz version: latest
Re: LUA Pass2php
Hi i`m trying to get your script working but i am a newbie on php. I will run this on a raspberry pi can someone tell me which packages i need to install? Because i see you`re also using acpu? I don`t think this is standard installed on a pi? I have follow version running of php:
next question is there somewhere a "empty scratch file" so i can only have to fill mine own setup and don`t need to clear out egregius devices which are already filled in?
root@raspberrypi:/home/pi# php -v
PHP 7.0.14-1~bpo8+1 (cli) ( NTS )
Copyright (c) 1997-2016 The PHP Group
Zend Engine v3.0.0, Copyright (c) 1998-2016 Zend Technologies
with Zend OPcache v7.0.14-1~bpo8+1, Copyright (c) 1999-2016, by Zend Technologies
Hardware
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
1x GoodWe Solarpanels
2x FGSD-002 Smoke Detector
1x FGBS-001 Binaire Sensor (RFID lezer)
7x FGMS-001 Motion Sensor
3x ZW089 Verzonken Deursensor
7x NC Wallplug
&lots of KaKu stuff
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
7x NC Wallplug
&lots of KaKu stuff
- Egregius
Re: LUA Pass2php
you also need php7-apcu and php7-cli or apache2/nginx. I find a curl to a webserver is faster than running in php-cli.
No, there's no 'empty' version of the latest online. Latest stuff is on github, or as a base the minimal script on my site.
dutchdevil83
Re: LUA Pass2php
I really have no clue where to start.... I have php installed and running. Have looked at your examples over and over and follow the wiki on your github but nothing is happening when i pull a switch.... Here is the code i have edited so far:
script_device_passphp.lua:
Pass2php.php:
a file TEST.php in the pass2php folder (switch is a dummy switch in domoticz named "TEST", other is a lamp named "Verlichting Dressoir":
In your wiki you describe the functions but in the examples your are using "ACPU_fetch"
What to use?
c = ''
s = ''
i = ''
t = ''
for k,v in pairs(devicechanged) do c = c..k.."|"..v.."#" end
for k,v in pairs(otherdevices) do s = s..k.."|"..v.."#" end
for k,v in pairs(otherdevices_idx) do i = i..k.."|"..v.."#" end
for k,v in pairs(otherdevices_lastupdate) do t = t..k.."|"..v.."#" end
--os.execute('/home/pi/domoticz/scripts/lua/pass2php/pass2php.php "'..c..'" "'..s..'" "'..i..'" "'..t..'" &')
os.execute('curl -s --data "c='..c..'&s='..s..'&i='..i..'&t='..t..'" http://127.0.0.1/secure/pass2php.php &')
commandArray={}
return commandArrayCode: Select all
<?php error_reporting(E_ALL);ini_set("display_errors","on");date_default_timezone_set('Europe/Amsterdam');
define('time',$_SERVER['REQUEST_TIME']);$actions=0;
$c=ex($_REQUEST['c']);
foreach($c as $device=>$status){
if(@include 'http://127.0.0.1/secure/pass2php/'.$device.'.php'){
//Filter the 'set level' stuff away for dimmers
if(in_array($device,array('Verlichting Slaapkamer'))){
if($status=='Off')apcu_store('s'.$device,'Off');
else apcu_store('s'.$device,filter_var($status,FILTER_SANITIZE_NUMBER_INT));
}else apcu_store('s'.$device,$status);
apcu_store('t'.$device,time);
$dev=$device;
if(!isset($dev))die();
include 'http://127.0.0.1/secure/__CRON.php';
function sw($idx,$action='',$info=''){
lg('SWITCH '.$idx.' '.$action.' '.$info);
if(empty($action))file_get_contents('http://127.0.0.1:8080/json.htm?type=command¶m=switchlight&idx='.$idx.'&switchcmd=Toggle');
else file_get_contents('http://127.0.0.1:8080/json.htm?type=command¶m=switchlight&idx='.$idx.'&switchcmd='.$action);
global $actions;$actions=$actions+1;
}Code: Select all
<?php
if($s['TEST']=='On')sw($i['Verlichting Dressoir'],'On');Hardware
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
7x NC Wallplug
&lots of KaKu stuff
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
7x NC Wallplug
&lots of KaKu stuff
- sincze
- Domoticz version: 2024.4
Re: LUA Pass2php
Do you have the LG function as well in the pass2php?
What happens if you add some debug lines ??
example just below: $c=ex($_REQUEST['c']);
add:
does a line show up in domoticz log?? to indicate the pass2php was called ??
Add some debug lines to your lua as well:
Does the 1,2,3 show up in your domoticz log?
add:
lg('4. Egregius Start of Pass2PHP');Add some debug lines to your lua as well:
print('1. script started')
c = ''
s = ''
i = ''
t = ''
print('2. os execute started')
print('3. os execute ended')
commandArray={}
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
- Egregius
Re: LUA Pass2php
If you send all 4 lua tables you don't need apcu because all information is in the arrays created in the pass2php file
I store all information in apcu cache, with that pass2php is down to 19 msecs and my floorplan went from 30 to less than 1 millisecond.
dutchdevil83
Re: LUA Pass2php
Hi, thanks for your reply. When adding the debug lines this shows up in the log:sincze wrote:Do you have the LG function as well in the pass2php?
add:does a line show up in domoticz log?? to indicate the pass2php was called ??Code: Select all
Does the 1,2,3 show up in your domoticz log?Code: Select all
print('1. script started') c = '' s = '' i = '' t = '' for k,v in pairs(devicechanged) do c = c..k.."|"..v.."#" end for k,v in pairs(otherdevices) do s = s..k.."|"..v.."#" end for k,v in pairs(otherdevices_idx) do i = i..k.."|"..v.."#" end for k,v in pairs(otherdevices_lastupdate) do t = t..k.."|"..v.."#" end --os.execute('/home/pi/domoticz/scripts/lua/pass2php/pass2php.php "'..c..'" "'..s..'" "'..i..'" "'..t..'" &') print('2. os execute started') os.execute('curl -s --data "c='..c..'&s='..s..'&i='..i..'&t='..t..'" http://127.0.0.1/secure/pass2php.php &') print('3. os execute ended') commandArray={} return commandArray
2017-01-30 08:56:43.574 LUA: 1. script started
2017-01-30 08:56:43.582 LUA: 2. os execute started
2017-01-30 08:56:43.595 LUA: 3. os execute ended
2017-01-30 08:56:43.683 => 4. Egregius Start of Pass2PHPHardware
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
7x NC Wallplug
&lots of KaKu stuff
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
7x NC Wallplug
&lots of KaKu stuff
- Egregius
Re: LUA Pass2php
Look's good, the php script is called.
You can remove those print and lg commands, but we'll add others now:
replace:
with:
Then you should see a line for each deviceupdate like
2017-01-30 08:56:43.683 => TEST = On
TEST should then be the name of the file in the pass2php folder: TEST.php (case sensitive!)
replace:
foreach($c as $device=>$status){Code: Select all
lg($device.' = '.$status);2017-01-30 08:56:43.683 => TEST = On
dutchdevil83
Re: LUA Pass2php
OK now is see a lot of devices and there information. When i press the switch "TEST" is see this:Egregius wrote:Look's good, the php script is called.
replace:with:Code: Select all
foreach($c as $device=>$status){Then you should see a line for each deviceupdate likeCode: Select all
foreach($c as $device=>$status){ lg($device.' = '.$status);
2017-01-30 09:19:28.925 => 4. Egregius Start of Pass2PHP
2017-01-30 09:19:28.927 => TEST = On
2017-01-30 09:19:28.929 => =Hardware
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
7x NC Wallplug
&lots of KaKu stuff
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
7x NC Wallplug
&lots of KaKu stuff
- Egregius
Re: LUA Pass2php
OK that's good. Remove the lg line again, or place // before it to place it as a comment, could be usefull later.
Then in pass2php/TEST.php add this:
Then we know that the path and filename is good.
<?php
