Introducing dzVents - Domoticz Lua file based event scripting made e-z!
dannybloe
Re: Introducing dzVents - Domoticz Lua file based event scripting made e-z!
Post by dannybloe »
Wroopy wrote:
dannybloe wrote:
dannybloe wrote:
Every time the script is executed it reads the persistent data and stores it when the script is finished. So each time the switch changes.
I just tested it here and it works with this script:
	active = true,
		'mySensor'
	data = {
		history = {history = true, maxItems = 10}
	execute = function(domoticz, sensor)
		local reading = sensor.temperature
		domoticz.data.history.add(reading)
		local avg = domoticz.data.history.avg()
		local size = domoticz.data.history.size
		print(sensor.name .. ": last=" .. reading .. ", avg=" .. avg .. ", size= " .. size)
and the data file is like this:
-- Persistent Data
local multiRefObjects = {
} -- multiRefObjects
local obj1 = {
	["history"] = {
		[1] = {
			["time"] = "2016-10-19 09:45:59";
			["data"] = 16.799999237061;
		[2] = {
			["time"] = "2016-10-19 09:45:58";
		[3] = {
			["time"] = "2016-10-19 09:45:30";
		[4] = {
			["time"] = "2016-10-19 09:45:29";
		[5] = {
			["time"] = "2016-10-19 09:44:59";
		[6] = {
			["time"] = "2016-10-19 09:44:58";
		[7] = {
			["time"] = "2016-10-19 09:44:29";
		[8] = {
			["time"] = "2016-10-19 09:44:28";
		[9] = {
			["time"] = "2016-10-19 09:43:59";
		[10] = {
			["time"] = "2016-10-19 09:43:58";
			["data"] = 16.89999961853;
return obj1
Are you sure that the script is called multiple times?
Yes I'm sure it is calles several times. I can see it both in Domoticz log and the timestamp of the item is changed in the storage-file.
I've tested to increase the logging, i.e. change ['Log level'] = 3 in dzVents_settings.lua too see if I would get som extra useful information. Got some very confusing result
1. The size of the history variable where increasing. So finally I got 10 items as expected.
2. Changed back to ['Log level'] = 2 and now I get only one hisory item.
3. Switch to level 3 again and it worked as expected.
4. Changed back to 2 and got only one history item.
Does that give any hint on what the problem could be?
Wow, that is certainly weird. I'd have to debug that. Can you PM me your entire script code?
dannybloe
Post by dannybloe »
dannybloe wrote:
Wroopy wrote:
I cannot reproduce this. In my test the loglevel has no influence. :roll:
Wroopy
Domoticz version: v3.5745
Post by Wroopy »
dannybloe wrote:
Wroopy wrote:
	active = true,
		'mySensor'
	data = {
To make sure I don't have ant race conditions, I've removed all other scripts and have only the script that you've tested with.
Still the same problem.
Tested with different loglevels and it is only when having log level 2 it doesn't work. :?
Glatzi
Post by Glatzi »
dannybloe wrote:Yea you can set it to true if you start the stuff in th evening for the first time. That's an easy one ;)
Hi dannybloe,
just came back from vacation & quickly implemented your script. It works fine!
Thanks for your input!!!
What I'm still generally searching for is some kind of logic to distinguish if a switch was triggered by a PIR or manually trough the light button which triggers a Fibaro relay.
An example is that someone manually triggers a light switch in our hall. There also is a PIR. So although the switch is triggered manually the PIR detects the motion & the state in the dzVents table changes. So how can I differentiate this case for a proper handling?
Any input is really appreciated :-)
RPi3+UZB1,FIBARO FGMS001(9x),FIBARO FGD212,FIBARO FGRM222(6x),FIBARO FGSD002(1x),FIBARO FGWPE (3x),Neo CoolCam Power plug(5x),NodOn CRC-3-1 Remote(2x),Qubino ZMNHADx(1x),Qubino ZMNHDD1(2x),Z-Wave Weather Sensor(1x),Z-Wave ZME_WALLC-S,FIBARO System FGK10x
Glatzi
Post by Glatzi »
Hi dannybloe,
can you please take a look at the latest beta of Domoticz? Something is going wrong with the scenes & dzEvents there. I'm getting the following error with all of my scenes:
LUA: Cannot find the device. Skipping: KuecheLichtSchrank 1
I've deleted all scenes & recreated just the one above but the error remains. No more errors even in debug level 3.
I've also stopped Domoticz & deleted the devices.lua file so it can be build up from scratch but no luck at all :-(
Best rergards
Stephan
dannybloe
Post by dannybloe »
Glatzi wrote:Hi dannybloe,
Best rergards
Stephan
Upgrade to the latest dzvents release.
Glatzi
Post by Glatzi »
Thx, that solved the error!
Glatzi
Post by Glatzi »
I've got a question regarding the switchOn().for_min(x) method.
If I'm using this with a power switch in conjunction with a PIR like this:
if ( PIRKeller.state == 'On' and Keller_Switch.state == 'Off' ) then
	Keller_Switch.switchOn().for_min(2)
 elseif ( PIRKeller.state == 'On' and Keller_Switch.state == 'On' ) then
What happens with the for_min(x) timer when the elsif section is executed:
Is the first timer just canceled & the second will be executed with 2 minutes or is the
time added to the first timer?
Glatzi
Post by Glatzi »
Hi dannybloe,
what is the reason for the __data. Dot files in the scripts/storage folder?
Wroopy
Post by Wroopy »
I got the same dot-file in the data directory. For me, the reason is that I'm using vi as editor and when you open a file in vi a backup file is created with a leading dot in the filename.
The backupfile is detected and evaluated as a ordinary script by dzVents/lua.
@dannybloe; A possible improvement to dzVents woul be to ignore script-files with a leading dot?
/Andreas
dannybloe
Post by dannybloe »
/Andreas
Aha.. that explains... we should certainly ignore those .dotted scripts completely. Right now they are executed as normal scripts!!
I'm very busy at home right now (renovation) which will take at least one or two weeks so I don't have time to fix that I think. I will try but no promises. On the other hand... pull requests are always welcome ;-)
Markvr
Post by Markvr »
Hi Danny,
I'm trying to read the CounterDelivToday from a P1 Smart Meter device. But I only get a nil value returned. The CounterToday value is working well!
Can you help me?
Glatzi
Post by Glatzi »
/Andreas
Hi Andreas,
when you edit files with vim the file is marked with a dot as a prefix & a suffix .swp
Anyway, this is no big deal.
Goold luck with your renovation project @dannybloe :-) This year we had do it in our whole house instead of taking a vacation :D
Wroopy
Post by Wroopy »
dannybloe wrote: Aha.. that explains... we should certainly ignore those .dotted scripts completely. Right now they are executed as normal scripts!!
Made a pull request (my first time, but hope it was done correct).
The current logic is to include all files that contains .lua
Changed to logic to make sure that the file ends with .lua and does not begin with a dot.
felix63
Domoticz version: 2020.1
Post by felix63 »
Hi Danny,
Nice piece of software. My compliments. I have ported a few scripts. Easier then I thought. Two small questions. I have one script controlling two devices. If one is changed the other one follows. This requires more lines then I expected because apparently I can't copy the state of one device to the other. Is that true or am I missing something?
	active = true,
	on = { 'Subwoofer',
			'Versterker' },
	execute = function(domoticz, mySwitch)
		if domoticz.devices['Versterker'].changed and domoticz.devices['Subwoofer'].state ~= domoticz.devices['Versterker'].state then
			if domoticz.devices['Versterker'].state == 'On' then
				domoticz.devices['Subwoofer'].switchOn()
				domoticz.devices['Subwoofer'].switchOff()
		elseif  domoticz.devices['Subwoofer'].changed and domoticz.devices['Versterker'].state ~= domoticz.devices['Subwoofer'].state then
			if domoticz.devices['Subwoofer'].state == 'On' then
				domoticz.devices['Versterker'].switchOn()
				domoticz.devices['Versterker'].switchOff()
Secondly can I use a (selector-type) switch in domoticz to dynamically set the log-level? If yes then how?
Cheers,
Lex
Doler
Post by Doler »
Something like
Domoticz.devices['Subwoofer'].setState(Domoticz.devices['Versterker'].state)
Mark: Domoticz latest Beta on Virtual machine (Proxmox) running Debian Trixie - Z-Stick 7 - RFXCom - P1 - SolarEdge - Dahua - Philips Hue - Docker - Zigbee2mqtt (latest, docker) via python plugin - Zwave-js-ui (latest, docker) - dzVents - Nodered
felix63
Post by felix63 »
Doler wrote:Something like
That works better, thanks!
Verzonden vanaf mijn iPad met Tapatalk
felix63
Post by felix63 »
Wouldn't it be possible to set/change the debug level using a (selector)switch?
gus
Post by gus »
Hi!
Trying to switch on groups with dzvents but don't get it to work...
Shouldn't this work:
domoticz.switchGroups('Innelampor Basement', 'On')
Please advice
/Rickard
Doler
Post by Doler »
gus wrote:Hi!
domoticz.groups['Innelampor Basement'].switchOn()
Please advice
/Rickard
You should use
 domoticz.switchGroup('Innelampor Basement', 'On')
(see Domoticz methods)
Locked
