homebridge-edomoticz Plugin
markk
Re: eDomoticz Homebridge-Plugin
Post by markk »
I followed the instructions. it now seems I've got homebridge running but when I tried to check the status it shows as Inacive (dead) :(
pi@raspberrypi:~$ sudo /etc/init.d/homebridge start
Starting homebridge
pi@raspberrypi:~$ systemctl status homebridge
● homebridge.service - LSB: Start daemon at boot time
   Loaded: loaded (/etc/init.d/homebridge)
   Active: inactive (dead)
pi@raspberrypi:~$
Marci
Domoticz version: 3.8153
Post by Marci »
Have you run it from the commandline by typing homebridge [enter] to see if any errors are thrown?
markk
Post by markk »
Back to the old "Illegal instruction" massages.
pi@raspberrypi:~$ homebridge
Illegal instruction
pi@raspberrypi:~$
Marci
Post by Marci »
Got a spare SD card?
markk
Post by markk »
Yeah
Do you think I should start from scratch then?
Shouldn't be too much bother. I only move domoticz from Windows to a Pi a couple of weeks ago.
Marci
Post by Marci »
Summat certainly seems b0rked on your current install. Do a clean install of Jessie from raspberry Pi site, then see text file attachment at end of first post. That's my own standard 'get up n running' setup.
MPaul
Post by MPaul »
Hi Marci.
Could I ask your help - I created water counters in Domoticz with type General and subtype Counter Incremental.
That counters got updated by ESP8266 and located at Utility tab in Domoticz.
I could see both total and instant values there.
But in Eve application, I see that counters as of Contact type - so no values, just 'NO' status.
Could you please tell what is wrong ?
I registered an issue for that in eDomoticz github and attached JSON output for that counters.
Thanks in advance.
markk
Post by markk »
Marci wrote:Got a spare SD card?
hi
I think i've made a bit of progress (if you can call different errors progress!)
I started from a fresh install and it now looks like I have forever and homebridge installed
pi@raspberrypi:~$ sudo find / -name forever
/root/.npm/registry.npmjs.org/forever
/root/.npm/forever
/usr/local/bin/forever
/usr/local/lib/node_modules/forever
/usr/local/lib/node_modules/forever/bin/forever
/usr/local/lib/node_modules/forever/lib/forever
pi@raspberrypi:~$ sudo find / -name homebridge
/root/.npm/homebridge
/home/pi/homebridge
/home/pi/homebridge/bin/homebridge
/usr/local/lib/node_modules/homebridge
/usr/local/lib/node_modules/homebridge/bin/homebridge
/usr/bin/homebridge
/usr/lib/node_modules/homebridge
/usr/lib/node_modules/homebridge/bin/homebridge
pi@raspberrypi:~$
Then type forever start /usr/local/lib/node_modules/homebridge/bin/homebridge
pi@raspberrypi:~$ forever start /usr/local/lib/node_modules/homebridge/bin/homebridge
warn:    --minUptime not set. Defaulting to: 1000ms
warn:    --spinSleepTime not set. Your script will exit if it does not stay up for at least 1000ms
info:    Forever processing file: /usr/local/lib/node_modules/homebridge/bin/homebridge
pi@raspberrypi:~$
Then running tail -f `ls -t ~/.forever/*.log | grep -v '^d' | head -n1`
pi@raspberrypi:~$ tail -f `ls -t ~/.forever/*.log | grep -v '^d' | head -n1`
    at Module.require (module.js:366:17)
    at require (module.js:385:17)
    at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/mdns/lib/dns_sd.js:32:22)
    at Module._compile (module.js:435:26)
    at Object.Module._extensions..js (module.js:442:10)
    at Module.load (module.js:356:32)
    at Function.Module._load (module.js:311:12)
error: Forever detected script exited with code: 1
error: Script restart attempt #7
module.js:339
    throw err;
Error: Cannot find module '../build/Release/dns_sd_bindings'
    at Function.Module._resolveFilename (module.js:337:15)
    at Function.Module._load (module.js:287:25)
error: Script restart attempt #8
module.js:339
    throw err;
This is my config.json
    "bridge": {
        "name": "Homebridge",
        "username": "CC:21:3E:E4:DE:33",
        "port": 51826,
        "pin": "031-45-154"
    "description": "Configuration file for Domoticz platform.",
    "platforms": [
            "platform": "eDomoticz",
            "name": "eDomoticz",
            "server": "xxxxx:[email protected]",
            "port": "8082",
            "ssl": 0,
            "roomid": 0
    "accessories": [
I'd be so grateful if someone could let me know how to fix this
Marci
Post by Marci »
sudo apt-get install libavahi-compat-libdnssd-dev
sudo npm install -g homebridge --unsafe-perm
(Installs libdns then reinstalls homebridge)
markk
Post by markk »
Thanks for you reply.
I did this but it looks like libdns was already installed
pi@raspberrypi:~$ sudo apt-get install libavahi-compat-libdnssd-dev
Reading package lists... Done
Building dependency tree
Reading state information... Done
libavahi-compat-libdnssd-dev is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 6 not upgraded
followed on with the next part and reinstalled homebridge anyway. now getting:
*** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** Please fix your application to use the native API of Avahi!
*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node>
*** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node&f=DNSServiceRegister>
[Wed Jun 01 2016 21:02:08 GMT+0100 (BST)] Warning: skipping plugin found at '/usr/local/lib/node_modules/homebridge-edomoticz' since we already loaded the same plugin from '/usr/lib/node_modules/homebridge-edomoticz'.
[Wed Jun 01 2016 21:02:16 GMT+0100 (BST)] Loaded plugin: homebridge-edomoticz
[Wed Jun 01 2016 21:02:16 GMT+0100 (BST)] Registering accessory 'homebridge-edomoticz.eDomoticz'
[Wed Jun 01 2016 21:02:16 GMT+0100 (BST)] Registering platform 'homebridge-edomoticz.eDomoticz'
[Wed Jun 01 2016 21:02:16 GMT+0100 (BST)] ---
[Wed Jun 01 2016 21:02:16 GMT+0100 (BST)] Loaded config.json with 0 accessories and 1 platforms.
[Wed Jun 01 2016 21:02:17 GMT+0100 (BST)] Loading 1 platforms...
[Wed Jun 01 2016 21:02:17 GMT+0100 (BST)] [Domoticz] Initializing eDomoticz platform...
[Wed Jun 01 2016 21:02:17 GMT+0100 (BST)] [Domoticz] Fetching Domoticz lights and switches...
[Wed Jun 01 2016 21:02:17 GMT+0100 (BST)] Loading 0 accessories...
[Wed Jun 01 2016 21:02:18 GMT+0100 (BST)] [Domoticz] There was a problem connecting to Domoticz.
error: Forever detected script exited with code: 0
error: Script restart attempt #14
Marci
Post by Marci »
The warnings are normal re: bonjour & avahi - just ignore those...
Somehow you've ended up with 2 copies of the plugin installed, fix with:
sudo rm -rf /usr/lib/node_modules/homebridge-edomoticz
And it should then detect and use the copy from /usr/local/lib/node_modules/homebridge-edomoticz
Finally, what's causing homebridge to actually fail and exit, as it says, is because it can't connect to Domoticz... check ~/.homebridge/config.json: ipaddress and port. Port is usually 8080. IP will usually work as 127.0.0.1
markk
Post by markk »
Thanks so much for your help. I've been messing around with config.json and finally mannaged to get it so it looks like a load of my switches etc are loading but now I get this error at the end:
[Wed Jun 01 2016 23:50:48 GMT+0100 (BST)] [Domoticz] Fetching Domoticz lights an        d switches...
[Wed Jun 01 2016 23:50:48 GMT+0100 (BST)] Loading 0 accessories...
[Wed Jun 01 2016 23:51:11 GMT+0100 (BST)] [Domoticz] Initializing platform accessory '/hdd/0/load/0 Used Space'...
[Wed Jun 01 2016 23:51:12 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'AIRCON HEAT ON'...
[Wed Jun 01 2016 23:51:12 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Aimee lamp'...
[Wed Jun 01 2016 23:51:12 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Aimee phone'...
[Wed Jun 01 2016 23:51:12 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Aimee socket'...
[Wed Jun 01 2016 23:51:12 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Aimeeslight'...
[Wed Jun 01 2016 23:51:12 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Alarm beep'...
[Wed Jun 01 2016 23:51:12 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Back Garden Sensor'...
[Wed Jun 01 2016 23:51:12 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Back door contact'...
[Wed Jun 01 2016 23:51:12 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Bathroom UFH'...
[Wed Jun 01 2016 23:51:12 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Bedroom blind'...
[Wed Jun 01 2016 23:51:12 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Bell 1'...
[Wed Jun 01 2016 23:51:12 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Big dog'...
[Wed Jun 01 2016 23:51:12 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Bonz bed light'...
[Wed Jun 01 2016 23:51:12 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Bonz home'...
[Wed Jun 01 2016 23:51:12 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Bunny house power'...
[Wed Jun 01 2016 23:51:13 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Bunnys house light'...
[Wed Jun 01 2016 23:51:13 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'CO Detector'...
[Wed Jun 01 2016 23:51:13 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'CPU Core 1'...
[Wed Jun 01 2016 23:51:13 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Dining room blind'...
[Wed Jun 01 2016 23:51:13 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Dining room socket 1'...
[Wed Jun 01 2016 23:51:13 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Dining room socket 2'...
[Wed Jun 01 2016 23:51:13 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Diningroomlight'...
[Wed Jun 01 2016 23:51:13 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Dog Switch'...
[Wed Jun 01 2016 23:51:13 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Dog barking'...
[Wed Jun 01 2016 23:51:13 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Domo Pi'...
[Wed Jun 01 2016 23:51:13 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Door Sensor'...
[Wed Jun 01 2016 23:51:13 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Door contact 2'...
[Wed Jun 01 2016 23:51:13 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Door sensor 2'...
[Wed Jun 01 2016 23:51:14 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Doorsensor'...
[Wed Jun 01 2016 23:51:14 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Dummy Doorbel'...
[Wed Jun 01 2016 23:51:14 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Dummy-Aimeeslight'...
[Wed Jun 01 2016 23:51:14 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Dummy-Diningroomlight'...
[Wed Jun 01 2016 23:51:14 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Dummy-Hallwaylight'...
[Wed Jun 01 2016 23:51:14 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Dummy-Landinglight'...
[Wed Jun 01 2016 23:51:14 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Dummy-Loungelights'...
[Wed Jun 01 2016 23:51:14 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Dummy-Ourbedroomlight'...
[Wed Jun 01 2016 23:51:14 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Dummy-Sparebedroomlight'...
[Wed Jun 01 2016 23:51:14 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Free'...
[Wed Jun 01 2016 23:51:14 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Freezer Temp'...
[Wed Jun 01 2016 23:51:14 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Fridge Temp'...
[Wed Jun 01 2016 23:51:15 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Front Door Bell'...
[Wed Jun 01 2016 23:51:15 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Front door contact'...
[Wed Jun 01 2016 23:51:15 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Frontcamswitch'...
[Wed Jun 01 2016 23:51:15 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Garden switch 1'...
[Wed Jun 01 2016 23:51:15 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Garden switch 2'...
[Wed Jun 01 2016 23:51:15 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Gardencamswitch'...
[Wed Jun 01 2016 23:51:15 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Gardenlights'...
[Wed Jun 01 2016 23:51:15 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Hallway socket'...
[Wed Jun 01 2016 23:51:15 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Hallwaylight'...
[Wed Jun 01 2016 23:51:15 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'HarmonyPowerOff'...
[Wed Jun 01 2016 23:51:15 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'IPCAMswitch'...
[Wed Jun 01 2016 23:51:15 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Kitchen Sensor'...
[Wed Jun 01 2016 23:51:15 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Kitchen socket 1'...
[Wed Jun 01 2016 23:51:16 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Kitchen socket 2'...
[Wed Jun 01 2016 23:51:16 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Kitchen socket 3'...
[Wed Jun 01 2016 23:51:16 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Kitchen socket 4'...
[Wed Jun 01 2016 23:51:16 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Kitchencamswitch'...
[Wed Jun 01 2016 23:51:16 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Kodi Lights'...
[Wed Jun 01 2016 23:51:16 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Kodi TV'...
[Wed Jun 01 2016 23:51:16 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Kodi kindle'...
[Wed Jun 01 2016 23:51:16 GMT+0100 (BST)] [Domoticz] Initializing platform accessory 'Landing'...
/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/Accessory.js:219
      throw new Error("Cannot add a bridged Accessory with the same UUID as another bridged Accessory: " + existing.UUID);
Error: Cannot add a bridged Accessory with the same UUID as another bridged Accessory: d157d998-ffc0-45a9-a7fc-f42455cfbc3a
    at Bridge.Accessory.addBridgedAccessory (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/Accessory.js:219:13)
    at Server.<anonymous> (/usr/local/lib/node_modules/homebridge/lib/server.js:346:24)
    at /usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/util/once.js:15:19
    at callbackLater (/usr/local/lib/node_modules/homebridge-edomoticz/index.js:366:37)
    at Object.<anonymous> (/usr/local/lib/node_modules/homebridge-edomoticz/index.js:392:17)
    at Request.self.callback (/usr/local/lib/node_modules/homebridge-edomoticz/node_modules/request/request.js:198:22)
    at emitTwo (events.js:87:13)
    at Request.emit (events.js:172:7)
    at Request.<anonymous> (/usr/local/lib/node_modules/homebridge-edomoticz/node_modules/request/request.js:1082:10)
    at emitOne (events.js:82:20)
error: Script restart attempt #12
markk
Post by markk »
Maybe I still have two copies of the plugin. This didn't seem to do anything:
pi@raspberrypi:~$ sudo rm -rf /usr/lib/node_modules/homebridge-edomoticz
pi@raspberrypi:~$
Marci
Post by Marci »
You have two switches/devices in Domoticz with the same name ('Landing'). Every device must have a unique name.
markk
Post by markk »
So I have :oops:
My smartwares radiator added two devices, both with the same name. Ok, it's running now. Now to connect to Eve :)
Thanks again very much for all your time, effort and patience in helping me to get this installed.
markk
Post by markk »
Oh dear. Fallen again on the home straight :(
Marci
Post by Marci »
How many devices do you have in total in Domoticz?
markk
Post by markk »
Loads :oops: I think that is the problem
I've now created a roomplan with just those I need and changed the config.json from 0 to reflect this plan but whever I reboot it loads all of them again. How can I get it to only load the roomplan items?
Marci
Post by Marci »
Post the content of your current config.json...
markk
Post by markk »
This is it. My Domoticz runs on port 8082
    "bridge": {
        "port": 51826,
        "pin": "031-45-154"
    "description": "Configuration file for (e)xtended Domoticz platform.",
    "platforms": [
            "name": "Domoticz",
            "server": "127.0.0.1",
            "port": "8082",
            "ssl": 0,
            "roomid": 13
    "accessories": []
EDIT: Ok, I managed to get it working. it seems that, no matter what editor I used, the config.json changes I made via Winscp weren't taking effect.
I stopped homebridge and did
sudo pico ~/.homebridge/config.json
changed the room id from 0 to 13, saved with "ctrl o" then "ctrl x" and it all worked.
