robgeerts
Domoticz version: 3.7067
Re: connection problem
Post by robgeerts »
What type of login did you enter in Domoticz (Settings), shoudl be Basic Authentication...
aiolos
Domoticz version: stable
Post by aiolos »
evandenboom wrote: Tuesday 14 November 2017 16:21 Thanks for the quick response. But unfortunately still no icon.
Use
blocks['64_2']['icon'] = 'fa fa-sun-o';
(Note the extra fa)
Looks like there is a small bug in this. I might look into it later, right now I have quite some changes in the whole graphs stuff. I noted some missing units (so displaying '?') and some more small issues.
Contributor to Dashticz
More on my Github profile
FrankDutch
Post by FrankDutch »
then i get the popup on the tablet but there is no connection with Domoticz. No buttons
robgeerts
Post by robgeerts »
Maybe I can assist you tomorrow via Teamviewer?
FrankDutch
that is alright
we kan talk Dutch then lol
tommorow evening i have to work tomorrow
evandenboom
Post by evandenboom »
@aiolos Thank you. That was the tip I needed. Seems to work fine.
EdwinK
Re: Dashticz on tablet in fullscreen
Post by EdwinK »
Screen Shot 2017-11-15 at 14.05.33.png (10.61 KiB) Viewed 2522 times
Isn't this button not doing the same?
EdwinK
Post by EdwinK »
I just have 'fa-sun-o' without the need of an extra 'fa' tag.
aiolos
Post by aiolos »
Exactly, I just implemented that a few days ago :)
It indeed needs user interaction, luckily I would say, since otherwise websites could just go fullscreen by themselves.
aiolos
Post by aiolos »
EdwinK wrote: Wednesday 15 November 2017 14:13 I just have 'fa-sun-o' without the need of an extra 'fa' tag.
Is that in a block without an underscore?
EdwinK
Post by EdwinK »
It is indeed in one without an underscore.
aiolos
Post by aiolos »
EdwinK wrote: Wednesday 15 November 2017 17:02 It is indeed in one without an underscore.
A fix for this is available in the pull request I just made.
EdwinK
Post by EdwinK »
I'll wait till Rob has included it in his beta
robgeerts
Post by robgeerts »
Check latest beta :)
woody4165
Post by woody4165 »
Thanks @robgeerts
Now the graph work and shows temp and hum.
But not for all sensors... :? :roll:
I have these two sensors, first is an ESP8266 with ESPEasy with a DHT11
  "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 255,
         "CustomImage" : 0,
         "Data" : "12.0 C, 25 %",
         "Description" : "",
         "DewPoint" : "-7.45",
         "Favorite" : 1,
         "HardwareID" : 14,
         "HardwareName" : "various",
         "HardwareType" : "Dummy (Does nothing, use for virtual switches only)",
         "HardwareTypeVal" : 15,
         "HaveTimeout" : false,
         "Humidity" : 25,
         "HumidityStatus" : "Normal",
         "ID" : "140CD",
         "LastUpdate" : "2017-11-15 20:51:11",
         "Name" : "TempPatio",
         "Notifications" : "false",
         "PlanID" : "2",
         "PlanIDs" : [ 2 ],
         "Protected" : false,
         "ShowNotifications" : true,
         "SignalLevel" : "-",
         "SubType" : "THGN122/123, THGN132, THGR122/228/238/268",
         "Temp" : 12.0,
         "Timers" : "false",
         "Type" : "Temp + Humidity",
         "TypeImg" : "temperature",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "xxx"
and the second is the Netatmo Temp
    "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 96,
         "CustomImage" : 0,
         "Data" : "20.4 C",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 6,
         "HardwareName" : "Netatmo",
         "HardwareType" : "Netatmo",
         "HardwareTypeVal" : 54,
         "ID" : "1AC7",
         "LastUpdate" : "2017-11-15 20:42:38",
         "Name" : "NetatmoTemperatura",
         "PlanID" : "2",
         "PlanIDs" : [ 2, 8 ],
         "SignalLevel" : 10,
         "SubType" : "LaCrosse TX3",
         "Temp" : 20.399999999999999,
         "Timers" : "false",
         "Type" : "Temp",
         "Unit" : 199,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "xxx"
In both case I see this kind of window:
Sorry to bother you!!! :)
aiolos
Post by aiolos »
Good to hear it works, partly ;)
I also have a device with sort of that issue, that one has no data for the selected period, however, it looks like you have selected the last month, so that should have some data I can imagine.
Does one of the buttons give a result? And what does the same sensor look like in Domoticz itself? I'll investigate also my own device, see if I can find out more.
woody4165
Post by woody4165 »
Ops, another thing.
I don't see anymore the OWL graph, electricity stuff.
Before last beta update was working fine.
This is the device
       "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CounterToday" : "9.395 kWh",
         "CustomImage" : 0,
         "Data" : "35.410 kWh",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 15,
         "HardwareName" : "RFxxx",
         "HardwareType" : "RFLink Gateway USB",
         "HardwareTypeVal" : 46,
         "ID" : "00000009",
         "LastUpdate" : "2017-11-15 21:12:55",
         "Name" : "Owl",
         "Options" : "",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "SubType" : "kWh",
         "SwitchTypeVal" : 0,
         "Timers" : "false",
         "Type" : "General",
         "TypeImg" : "current",
         "Unit" : 1,
         "Usage" : "2350.0 Watt",
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "xxx"
aiolos
Post by aiolos »
Ok, looks like the output of domoticz is not very consistent with the various kWh subtypes :(
Can you still see the values in the blocks? Can you check the console output if you open the developer tools? (Press F12, and click the button/tab with 'console'.
aiolos
Post by aiolos »
I created a new PR for Rob, this might solve some problems with graphs for various device types. I cannot reproduce the above problems with devices with the same type and subtype, so there might still be missing something.
If you experience problems, please give as much info as possible:
- The device information from domoticz (as already given most of the time)
- How do you add the device in the config, with or without the underscore to select only one block
- Is the block clickable or not?
- Which of the graphs are not showing, all, of just one or 2 of them?
- Does the console in the developer tools of your browser show any error (hit F12, or right click on the element en select 'inspect', the way this works depends a bit on the browser)
- Is there any data in the graphs in domoticz? If it's a flat line there (so only an old value or someting) no graph shows up in dashticz
- Does a previous version of dashticz show the graph in the right way (or maybe even no graph at all)? I saw some graphs that were not showing the right information, since lines were stacked. Also, for some types blocks were not clickable.
I did quite some changes in the whole graph stuff to make it work for the device types I had issue with. However, I maybe don't have all the device types other have and domoticz can give different structures back for the different device types.
Stepdes
Domoticz version: 2022.1
Post by Stepdes »
Hi all, i gave a question about the hover effect on the buttons.
like you see on the image below, after activating the button, the hover effect maintain, just until you touch another button or empty space on the screen.
Is it possible to avoid that with some css code?
I'm running the latest Beta.
I would really appreciate any help on this.
Locked
