Page 15 of 37
Re: ELV Max! Heating control system
Posted: Saturday 29 October 2016 12:32
by blackdog65
Yay! It worked!
Many thanks for your enormous help.
It worked fine, but I woke to over 700 e-mails telling me that the stats were missing
because the set-points have not changed in over an hour the system thinks they are lost
For anyone else thinking of using this script, I have a multi-switch with Off|Heating|Hot Water|Holiday with timers. This also serves as a manual over-ride.
Then a dummy switch called "Heating" which the script uses to determine if I want heat before it allows any other condition to turn on the "CH_Switch" for the boiler.
If the multi-switch is set to "Hot Water", the "Heating" dummy is turned off and "HW_Switch" is turned on.
The "MissingDevicesTime" is useful as I ignored it over summer and a wall stat battery died... leaked... killed the stat
However, if a set-point hasn't been updated within "MissingDevicesTime" ie 3600s it sees it as not updating and will e-mail you.
My initial cure for this is to a) double the time to 2hrs (7200s) and b) introduce some kind of "jitter" into the set-points. I believe there is a script for this that pops the setting up/down 1/2 deg every 30mins or so. I'll probably start by dropping and raising my temps every hour until the correct solution presents itself.
If anyone is interested, I'm thinking of putting a wiki page together so that the hard work of Westcott
, l0gic
and mvzut
is in one place with a working solution.
Thanks to all that have helped
Sean
Posted: Saturday 29 October 2016 12:52
by Skippiemanz
Great news! Please make a wiki.. Ive read through most of this thread but got a bit lost and want to implement you're solutions! Great work from both of you!
Posted: Sunday 30 October 2016 0:52
by mvzut
blackdog65 wrote:Yay! It worked!
You're welcome!
Isn't it a little strange to solve your problem with timeout notifications by periodically changing your setpoint, for no other reason than to trick the timeout detection script? Why not simply set the timeout period to e.g. 24 hours? In that time frame, your setpoint has probably changed anyway (assuming you have some kind of daily timer program on them). And having your valves out of control for one day, or not detecting an empty battery until the next day, doesn't seem like a disaster to me.
By the way, if you're interested, I could also adapt the script so that it updates a battery status device in Domoticz (in the form of another % device per MAX! device).
Martijn
Posted: Sunday 30 October 2016 1:01
by Westcott
Isn't the battery status simply reported as OK or not?
Does a low battery make the Cube's battery LED flash?
Posted: Sunday 30 October 2016 7:40
by hasan
Guys, thanks for great work. It would be nice to create Wiki for all others. I`m looking forward to finally integrate MAX! into Domoticz.
Posted: Sunday 30 October 2016 8:06
by mvzut
Westcott wrote:Isn't the battery status simply reported as OK or not?
Hmmm, I think you're right. I only knew battery status was extracted from the datagrams but now I see it can indeed only have two states. And it's on system level, not per device. We could still add a "MAX! battery low" status switch in Domoticz.
I haven't had empty batteries myself yet, don't know if the light will flash but I assume so (why else would they have added the LED?).
Posted: Sunday 30 October 2016 8:26
by mvzut
hasan wrote:Guys, thanks for great work. It would be nice to create Wiki for all others. I`m looking forward to finally integrate MAX! into Domoticz.
I agree that integration of MAX! in Domoticz is great, and probably interesting for a lot of others. Sean, if you start a Wiki page I'll see if I can add to it where possible.
Even greater would be if this was all converted into a real plugin, at least the part that reads out the Cube and updates the devices in Domoticz. You would then only have to fill in your Cube's IP address and port in the plugin settings, plus maybe the desired polling frequency, and it would automatically create and update all devices for you. I know this is possible, but I'm mainly a script coder (and only by self education) and plugins are written in C, plus they require you to follow certain templates. So I'm afraid this is way over my head. I feel tempted to dive into it though, starting by looking at comparable plugins such as the Hue plugin... Or is there anybody else here that has more experience and wants to help?
Posted: Sunday 30 October 2016 12:30
by Skippiemanz
+1 for the plugin! It already exists for openhab
Posted: Monday 31 October 2016 21:23
by blackdog65
Ok guys,
I've just written my first wiki
https://www.domoticz.com/wiki/EQ3_MAX!
Please check it out and pull it apart and find the typos etc.
Be gentle though... this is my first time
Sean
Posted: Monday 31 October 2016 21:55
by Westcott
Great work, BD!
Posted: Tuesday 01 November 2016 0:14
by Skippiemanz
Ok, Here we go.. I read your wiki and followed the steps youve described.
bu the pain starts at installing the luasec
sudo luarocks install luasec
Installing https://rocks.moonscript.org/luasec-0.6-1.rockspec...
Using https://rocks.moonscript.org/luasec-0.6-1.rockspec... switching to 'build' mode
Error: Could not find expected file libssl.a, or libssl.so, or libssl.so.* for OPENSSL -- you may have to install OPENSSL in your system and/or pass OPENSSL_DIR or OPENSSL_LIBDIR to the luarocks command. Example: luarocks install luasec OPENSSL_DIR=/usr/local
Im using the default Domoticz SD Card image on my Raspberry pi 3
Any pointing in the right directions?
P.S. the problem showed up in the log when running the script_time_max.lua. Running maxtest.lua had the derired outcome.
Although im not sure how my Window sensors will b treated with this scripts.
Posted: Tuesday 01 November 2016 8:50
by blackdog65
Hi Skippiemanz,
Skippiemanz wrote:
but the pain starts at installing the luasec
Take a look at this post
viewtopic.php?f=34&t=841&start=160#p86836 and the following 2 or 3 posts.
It looks like you've run into a similar problem to me. I'm sure I used mvzut's solution.
I hope some others can jump in here too
Sean
Posted: Tuesday 01 November 2016 20:26
by Skippiemanz
Ok,
Did som more digging...
The steps in the posts didn't get me further and are all in the wiki..
So i did a little google..
First i did a
then i download the lua 5.2 files from
http://www.domoticz.com/forum/viewtopic ... 638#p22638
and placed them in /home/pi/
Next steps where:
mv usrlocalliblua5p2.tar.gz /usr/local/lib/lua/5.2/
cd /usr/local/lib/lua/5.2/
sudo tar -xvf usrlocalsharelua5p2.tar.gz
sudo rm usrlocalsharelua5p2.tar.gz
sudo tar -xvf usrlocalliblua5p2.tar.gz
rm usrlocalliblua5p2.tar.gz
After that no more socket errors in the log.
But this line shows up:
2016-11-01 20:24:00.675 Error: EventSystem: in Max: [string "--..."]:155: attempt to concatenate field '?' (a nil value)
Line 155 states:
table.insert(commandArray, { ['UpdateDevice'] = otherdevices_idx[name.." (Valve)"]..'|0|'..temp..';'..valve_pos..';0'})
Could it has something to do with me not having wall thermostats?
package.loadlib("core.so", "*")
local Socket = require "socket"
local Basexx = require "basexx"
local Rooms = {}
local Devices = {}
local Room_nums = {}
local MaxIP = "192.168.2.123"
local MaxPort = 62910
local useWMT = false --# Set to true if there is a wall mounted thermostat in every room, then this one will be used for setpoint getting/setting
Debug = "YES" --# Turn debugging on ("YES") or off ("NO")
Or the fact that i have a windows sensor?
pi@raspberrypi:~/domoticz/scripts/lua$ lua maxtest.lua
Rooms
Kantoor Room
0CABDC
Zolder Room
0CACFA
Badkamer Room 095207
Devices
Kantoor Room-Rad 0CABDC
Zolder Links-Rad 0CACFA
Zolder Raam-Sens 0CBD92
Badkamer Room-Rad 095207
Device status
Valve Kantoor Room-Rad Setpoint=20 Temp=21.5 Valve pos=55 Battery=OK Mode=Manual
Valve Badkamer Room-Rad Setpoint=15 Temp=0 Valve pos=0 Battery=OK Mode=Manual
Valve Zolder Links-Rad Setpoint=20 Temp=0 Valve pos=44 Battery=OK Mode=Manual
Valve Zolder Raam-Sens Setpoint=20 Temp=0 Valve pos=44 Battery=OK Mode=Auto
Posted: Tuesday 01 November 2016 20:48
by blackdog65
Hi Skippiemanz,
1st. thanks for the lua installation info, I'll slip it into the wiki.
As to your error, I get that too. Not all the time but it comes and goes. I still don't know exactly what causes it
2016-11-01 19:42:00.906 LUA: Thermostat SittingRoom-Stat Setpoint=20 Temp=20.5 Valve pos=-1
2016-11-01 19:42:00.906 LUA: Thermostat V-Bed-Stat Setpoint=18 Temp=19.3 Valve pos=-1
2016-11-01 19:42:00.907 LUA: Valve SittingRoom-Rad Setpoint=20 Temp=0 Valve pos=0
2016-11-01 19:42:00.907 LUA: Valve Z-Bed-Rad Setpoint=17 Temp=0 Valve pos=0
2016-11-01 19:42:00.907 Error: EventSystem: in /home/linaro/domoticz/scripts/lua/script_time_max2.lua: /home/linaro/domoticz/scripts/lua/script_time_max2.lua:131: attempt to concatenate field '?' (a nil value)
2016-11-01 19:42:00.911 EventSystem: Script event triggered: /home/linaro/domoticz/scripts/lua/script_time_max.lua
So it reads 4 devices then for some reason throws up an error and doesn't get the next 4.
Is the script reading any of your devices and updating the dummies?
Sean
Posted: Tuesday 01 November 2016 20:55
by Skippiemanz
thanks for the prompt response...
No unfortunetly no updates at all. Stil at the date of creation.
- eeeeeeeeeeeeeeeeeeq.PNG (78.44 KiB) Viewed 2452 times
Posted: Tuesday 01 November 2016 21:24
by blackdog65
Hmmm,
I see you have one device set to auto. I had that and it wasn't read.
Does the log show any devices?
I'm hoping mvzut can get back to us on this. My problem isn't so bad as it's intermittent.
Sean
Posted: Tuesday 01 November 2016 21:30
by Skippiemanz
Thats the window sensor, i will delete that one and report back.
But it would be great if i can use them. because the sensor sets the valve to a fixed low temp to prevent loss of heat when the window is open.
*EDIT* Just deleted the window sensor and still the same error.
Could it be because 2 of the valves have 0 as temperature?
*EDIT 2* Did the maxtest.lua again and found out the window sensor wasn't removed. Then reset the cube and added 2 room/valves and voila!
2016-11-01 22:04:00.950 LUA: Valve Kantoor Room-Rad Setpoint=21 Temp=0 Valve pos=82
2016-11-01 22:04:00.950 LUA: 2016-10-31 23:19:02
2016-11-01 22:04:00.950 LUA: 81898
2016-11-01 22:04:00.950 LUA: Domoticz setpoint updated
2016-11-01 22:04:00.950 LUA: Valve Badkamer Room-Rad Setpoint=21 Temp=0 Valve pos=67
2016-11-01 22:04:00.950 LUA: 2016-10-31 23:19:13
2016-11-01 22:04:00.950 LUA: 81887
2016-11-01 22:04:00.953 EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_time_max.lua
Posted: Tuesday 01 November 2016 22:13
by Westcott
Thermostats in Auto mode should work OK.
A bit more coding is needed to get window sensors working.
The first step is to get its raw L data.
Also an extra test in the function maxCmd_L(data) to handle data_len other than 12 and 13, print the actual value, and not do the full device data print.
Posted: Tuesday 01 November 2016 22:30
by Skippiemanz
Hmmm... It read the data twice and now it stopped and gives the same error.
The window sensor including parts sounds good!
How can i give you the raw L data?
Posted: Tuesday 01 November 2016 23:48
by Westcott
Hi Skippiemanz,
Con you post the Lua file that You use, please?
I'll mod it for you.
