Page 15 of 32
Re: Testers wanted!
Posted: Thursday 28 July 2016 13:09
by Varazir
I getting this in the log
2016-07-28 13:00:05.903 PROXY: Authenticate result: Maxinstances reached.
Re: Testers wanted!
Posted: Thursday 28 July 2016 19:04
by chimit
ilpol984 wrote:I've freshly installed domoticz but mydomoticz disconnects on regular bases and fails to reconnect (it requires a restart).
Also it's not accessible troughth domoticz mobile.
Is there a fix for this two issues?
Regards,
Failing to reconnect is a known issue. We're working on it, but we don't have a target date yet.
What do you mean by domoticz mobile?
Re: Testers wanted!
Posted: Friday 29 July 2016 13:00
by Nautilus
Hmm, all of a sudden I'm only getting "Invalid login". No 2FA enabled. Has something changed, and is it just me?
Re: Testers wanted!
Posted: Friday 29 July 2016 15:16
by juankar
I'm using a reverse tunnel to my own server. Perfect.
Re: Testers wanted!
Posted: Saturday 30 July 2016 16:11
by BarryT
juankar wrote:I'm using a reverse tunnel to my own server. Perfect.
Same here
5 raspberry's (till so far) works with reverse tunnel trough 5 subdomains...
Using my domain (with subdomains to the raspberry), a VPS with Ubuntu, some wildcard dns, ssh tunnels and some virtual hosts in Apache2.
Made my own raspberry "image" card, with the setup of all stuff needed.
Just install the image to a card, powering up the rpi, and expand my own script, and everything works as it should do.
The only thing i need to change later on, are the passwords (of the ssh) and the ports, otherwise it will connect trough the same (ssh) port.
Autossh is take care of the the reverse tunnel, wich is also re-connecting when the network has changed or had failures...
Just perfect
Re: Testers wanted!
Posted: Tuesday 02 August 2016 12:29
by ilpol984
I mean thought domoticz android app.
Inviato dal mio ONE A2003 utilizzando Tapatalk
Re: Testers wanted!
Posted: Tuesday 09 August 2016 10:29
by Nautilus
Nautilus wrote:Hmm, all of a sudden I'm only getting "Invalid login". No 2FA enabled. Has something changed, and is it just me?
Just did a password reset, which seemed to function without anything surprising happening during the process. But still getting the same "invalid login". For some reason Domoticz is very unresponsive with direct access from external networks (and has always been), so currently only Pilot app works for remote connections...
Re: Testers wanted!
Posted: Friday 12 August 2016 5:19
by NCa78
I have registered on MyDomoticz, everything went fine.
Added info in Domoticz settings, where the Instance ID is not updating, I just have the following lines in the code :
2016-08-12 09:55:44.814 Proxymanager started.
2016-08-12 09:55:44.874 Active notification subsystems: (0/11)
Now when I try to connect to MyDomoticz, it takes forever to establish the secure connexion and times out, are you doing some maintenance on the server ?
Re: Testers wanted!
Posted: Monday 15 August 2016 20:22
by dtwitkowski
Hi Rene. I've been working with Domoticz for about a week, just registered for the Forums, and have activated MyDomoticz with some success. I would PM you but the phpBB system won't let me until I post more.
...dtw
Re: Testers wanted!
Posted: Monday 15 August 2016 20:29
by chimit
Hi folks,
Over the past few weeks we've done some bug hunting. This meant that MyDomoticz was offline every now and then.
Right today, we've done a major OS update on the host machine. Which meant more downtime today.
Hopefully we get things sorted out shortly. Like I said, I have little time to be working on it.
Re: Testers wanted!
Posted: Thursday 18 August 2016 20:36
by commentator
Have a lot of this my log today:
Error: PROXY: Connect failed, reconnecting: Network is unreachable
Re: Testers wanted!
Posted: Saturday 03 September 2016 7:48
by Varazir
commentator wrote:Hi,
If you go to my.domoticz.com you will find out why...
I have turned it off on my domoticz for the time being.
Re: Testers wanted!
Posted: Thursday 15 September 2016 12:12
by MattLittle
Hiya.
Seems the server is up and running again, cant seem to access my domoticz though, just getting this screen...
- dom (Medium).jpg (49.99 KiB) Viewed 2826 times
Ie no green OR red man.
Have reset p/w, unique API checks out...
Thanks and hope Im not being a nagging pain in the backside...
Matt
Re: Testers wanted!
Posted: Thursday 15 September 2016 22:05
by chimit
MaxLittle> No worries. You might need to upgrade to the latest domoticz master code.
Maybe gizmocuz can shed a light if the latest changes are already in the Domoticz beta or not. Not sure.
Re: Testers wanted!
Posted: Friday 16 September 2016 0:27
by MattLittle
Chimit - Hah! Should have thought of that sorry. Just upgraded to 3.5641, my.domoticz now works well.
Thanks heaps,
Matt
Re: Testers wanted!
Posted: Saturday 17 September 2016 9:57
by thecosmicgate
In reconnect to my domo and delete the instance end reinstalled the instance .
The icon is green and the domo log tells me that authentication is okay :
Active notification subsystems: email, kodi, lms, pushbullet (4/11)
2016-09-17 09:50:56.606 (Slimme meter) P1 Smart Meter (Energie verbruik)
PROXY: We were assigned an instance id: F(my instance ID).
PROXY: Authenticate result: success
. But when I push on the green "men" my domo won't display. What could be wrong?
The domo log tell's me
Error: [web:8080] Failed authentication attempt, ignoring client request (remote address: 127.0.0.1)
Re: Testers wanted!
Posted: Sunday 18 September 2016 11:49
by MattLittle
thecosmicgate -> Dunno man, mine is working fine, if not a bit slow to load the dashboard after I click on the green man. Stating the obvious but run the latest version of domoticz, then maybe try rebooting your router?
Re: Testers wanted!
Posted: Monday 19 September 2016 16:12
by BuderKjell
So, update may solve my problem, same as yours. Did: wget
http://releases.domoticz.com/releases/r ... armv7l.tgz
But About displays: 3.4834
Is there another way to download update?
Re: Testers wanted!
Posted: Monday 19 September 2016 21:41
by deejc
i think the stable release can be updated by running
in the domoticz directory, may have to run it as
on some systems
my system is connected now after updating
Re: Testers wanted!
Posted: Tuesday 20 September 2016 20:47
by BuderKjell
Thank you for the help deejc. "sudo" did it. Version now 3.5641.
