MyDomoticz - Testers wanted!
Varazir
Re: Testers wanted!
Post by Varazir »
I getting this in the log
2016-07-28 13:00:05.903 PROXY: Authenticate result: Maxinstances reached.
chimit
Domoticz version: master
Re: Testers wanted!
Post by chimit »
ilpol984 wrote:I've freshly installed domoticz but mydomoticz disconnects on regular bases and fails to reconnect (it requires a restart).
Also it's not accessible troughth domoticz mobile.
Is there a fix for this two issues?
Regards,
Failing to reconnect is a known issue. We're working on it, but we don't have a target date yet.
What do you mean by domoticz mobile?
Nautilus
Re: Testers wanted!
Post by Nautilus »
Hmm, all of a sudden I'm only getting "Invalid login". No 2FA enabled. Has something changed, and is it just me?
juankar
Domoticz version: 4.
Re: Testers wanted!
Post by juankar »
I'm using a reverse tunnel to my own server. Perfect.
BarryT
Domoticz version: 2024.3
Re: Testers wanted!
Post by BarryT »
juankar wrote:I'm using a reverse tunnel to my own server. Perfect.
Same here :-)
5 raspberry's (till so far) works with reverse tunnel trough 5 subdomains...
Using my domain (with subdomains to the raspberry), a VPS with Ubuntu, some wildcard dns, ssh tunnels and some virtual hosts in Apache2.
Made my own raspberry "image" card, with the setup of all stuff needed.
Just install the image to a card, powering up the rpi, and expand my own script, and everything works as it should do.
The only thing i need to change later on, are the passwords (of the ssh) and the ports, otherwise it will connect trough the same (ssh) port.
Autossh is take care of the the reverse tunnel, wich is also re-connecting when the network has changed or had failures...
Just perfect
ilpol984
Re: Testers wanted!
Post by ilpol984 »
I mean thought domoticz android app.
Inviato dal mio ONE A2003 utilizzando Tapatalk
Nautilus
Re: Testers wanted!
Post by Nautilus »
Nautilus wrote:Hmm, all of a sudden I'm only getting "Invalid login". No 2FA enabled. Has something changed, and is it just me?
Just did a password reset, which seemed to function without anything surprising happening during the process. But still getting the same "invalid login". For some reason Domoticz is very unresponsive with direct access from external networks (and has always been), so currently only Pilot app works for remote connections... :roll:
NCa78
Domoticz version: 3.6460
Re: Testers wanted!
Post by NCa78 »
I have registered on MyDomoticz, everything went fine.
Added info in Domoticz settings, where the Instance ID is not updating, I just have the following lines in the code :
2016-08-12 09:55:44.814 Proxymanager started.
 2016-08-12 09:55:44.874 Active notification subsystems: (0/11)
Now when I try to connect to MyDomoticz, it takes forever to establish the secure connexion and times out, are you doing some maintenance on the server ?
dtwitkowski
Re: Testers wanted!
Post by dtwitkowski »
Hi Rene. I've been working with Domoticz for about a week, just registered for the Forums, and have activated MyDomoticz with some success. I would PM you but the phpBB system won't let me until I post more. ;)
...dtw
chimit
Re: Testers wanted!
Post by chimit »
Hi folks,
Over the past few weeks we've done some bug hunting. This meant that MyDomoticz was offline every now and then.
Right today, we've done a major OS update on the host machine. Which meant more downtime today.
Hopefully we get things sorted out shortly. Like I said, I have little time to be working on it.
commentator
Re: Testers wanted!
Post by commentator »
Have a lot of this my log today:
Error: PROXY: Connect failed, reconnecting: Network is unreachable
Varazir
Re: Testers wanted!
Post by Varazir »
commentator wrote:Hi,
If you go to my.domoticz.com you will find out why...
I have turned it off on my domoticz for the time being.
MattLittle
Re: Testers wanted!
Post by MattLittle »
Hiya.
Seems the server is up and running again, cant seem to access my domoticz though, just getting this screen...
dom (Medium).jpg (49.99 KiB) Viewed 2817 times
Ie no green OR red man.
Have reset p/w, unique API checks out...
Thanks and hope Im not being a nagging pain in the backside...
Matt
chimit
Re: Testers wanted!
Post by chimit »
MaxLittle> No worries. You might need to upgrade to the latest domoticz master code.
Maybe gizmocuz can shed a light if the latest changes are already in the Domoticz beta or not. Not sure.
MattLittle
Re: Testers wanted!
Chimit - Hah! Should have thought of that sorry. Just upgraded to 3.5641, my.domoticz now works well.
Thanks heaps,
Matt
thecosmicgate
Domoticz version: newest
Re: Testers wanted!
Post by thecosmicgate »
In reconnect to my domo and delete the instance end reinstalled the instance .
The icon is green and the domo log tells me that authentication is okay :
Active notification subsystems: email, kodi, lms, pushbullet (4/11)
2016-09-17 09:50:56.606 (Slimme meter) P1 Smart Meter (Energie verbruik)
PROXY: We were assigned an instance id: F(my instance ID).
PROXY: Authenticate result: success
. But when I push on the green "men" my domo won't display. What could be wrong?
The domo log tell's me
Error: [web:8080] Failed authentication attempt, ignoring client request (remote address: 127.0.0.1)
It's nice to be important, but it's more important to be nice
Scooter ;)
MattLittle
Re: Testers wanted!
thecosmicgate -> Dunno man, mine is working fine, if not a bit slow to load the dashboard after I click on the green man. Stating the obvious but run the latest version of domoticz, then maybe try rebooting your router?
BuderKjell
Domoticz version: 2023.1
Re: Testers wanted!
Post by BuderKjell »
So, update may solve my problem, same as yours. Did: wget http://releases.domoticz.com/releases/r ... armv7l.tgz
But About displays: 3.4834
Is there another way to download update?
deejc
Domoticz version: 3.5641
Re: Testers wanted!
Post by deejc »
i think the stable release can be updated by running
./updaterelease
in the domoticz directory, may have to run it as
sudo ./updaterelease
on some systems
my system is connected now after updating
Domoticz 3.5641 on RPI (Raspbian GNU/Linux 8)
BuderKjell
Re: Testers wanted!
Thank you for the help deejc. "sudo" did it. Version now 3.5641.
