dtgbot - Domoticz TeleGram BOT
jvdz
Domoticz version: 4.107
Re: dtgbot - Domoticz TeleGram BOT
Post by jvdz »
woody4165 wrote: Saturday 27 January 2018 8:52 Hi all
-snip-
This mean that everytime there is any kind of connection closing I have to restart the service?
Isn't that what I already said a few post up?
That is why I have added the extra log file to be able to check the age in monit and restart dtgbot when it is over 2 minutes old.
Jos
woody4165
Post by woody4165 »
Hi Jos
Even if I have it in monitrc, it doesn't restart the service..
jvdz
Post by jvdz »
What does the monit webfrontend & log tell you for this item when this situation occurs?
Does it run the bash script to restart dtgbot?
I know for sure it does work for me when my internet has a glitch.
Jos
woody4165
Post by woody4165 »
I'm sure too that there is some issue in my config.
This is my situation:
linaro@cubietruck:~/dtgbot$ ls -l *.sh
-rwxr-xr-x 1 root   root    963 Jan 24 12:22 restartbot.sh
-rwxr-xr-x 1 root   root    442 Jan 24 12:22 stopbot.sh
linaro@cubietruck:~/dtgbot$ ls /var/tmp -l
-rw-r--r-- 1 root root   5384 Jan 27 20:31 dtb.log
-rw-r--r-- 1 root root 738547 Jan 27 20:31 dtgloop.txt
when I run from terminal "/home/linaro/dtgbot/restartbot.sh"
I get
linaro@cubietruck:~/dtgbot$ /home/linaro/dtgbot/restartbot.sh
/home/linaro/dtgbot/restartbot.sh: line 11: /var/tmp/dtgloop.txt: Permission denied
/home/linaro/dtgbot/restartbot.sh: line 13: /var/tmp/dtgloop.txt: Permission denied
/home/linaro/dtgbot/restartbot.sh: line 15: /var/tmp/dtgloop.txt: Permission denied
/home/linaro/dtgbot/restartbot.sh: line 19: /var/tmp/dtgloop.txt: Permission denied
/home/linaro/dtgbot/restartbot.sh: line 22: /var/tmp/dtgloop.txt: Permission denied
/home/linaro/dtgbot/restartbot.sh: line 23: /var/tmp/dtgloop.txt: Permission denied
So I have added "sudo" in monitrc to the calls to the .sh
Now I get in webfronted of monit
It seems that the monitoring service of dtgloop is not started.
After I click to Start Service I get an error
Is it a owner issue?
I'm driving crazy.
jvdz
Post by jvdz »
Try to validate the config file as described in the manual to see if there are syntax errors:
Before Monit is started the first time, you can test the control file for syntax errors:
 $ monit -t
 $ Control file syntax OK
EDIT: Scratch that... that status is looking good and looks the same as what I see.
Curious what it states when the DTGBOT locked status occurs.
It also looks like you don't have the access to the dtgloop.txt file so you could try running it with sudo or add sudo infront of the echo statements in the restartbot.sh script.
Jos
woody4165
Post by woody4165 »
Thanks Jos for your support.
monit -t returns ok
I've added sudo into restartbot.sh in fromt of all echo command, but if I run restartbot.sh without sudo does not work anyway.
I've tried to add sudo into monitrc like
  start program = "sudo /home/linaro/dtgbot/restartbot.sh" timeout 20 seconds
but it seems that monit does not work properly, I get errors
Jan 27 21:56:28 cubietruck monit[741]: Starting daemon monitor: monit/etc/monit/monitrc:156: Program does...sudo'
Jan 27 21:56:28 cubietruck monit[741]: /etc/monit/monitrc:157: Program does not exist: 'sudo'
Jan 27 21:56:28 cubietruck monit[741]: /etc/monit/monitrc:163: Program does not exist: 'sudo'
and if I run monit -t I get
linaro@cubietruck:~$ sudo monit -t
/etc/monit/monitrc:156: Program does not exist: 'sudo'
What is the owner of you dtgloop.txt and of the restartbot.sh ? Maybe this can help...
simonrg
Domoticz version: 3.8807
Post by simonrg »
woody4165 wrote: Saturday 27 January 2018 22:01What is the owner of you dtgloop.txt and of the restartbot.sh ? Maybe this can help...
Looking at your outputs you are running on a Cubietruck (its helpful to include this in your forum signature) not a Raspberry Pi, and you don't appear to have sudo installed, which would explain why nothing happens when you add sudo into monitrc.
The owner of restartbot.sh shouldn't matter as long as it is executable by all users, you can find the owner of dtgloop.txt by ls -l on the temporary directory, mine is owned by root.
pi@domoticz:~/dtgbot$ ls -l /var/tmp
-rw-r--r-- 1 root      root        2691 Jan 27 22:40 dtb.log
-rw-r--r-- 1 root      root           0 Jan 15 14:14 dtb.log.errors
-rw-r--r-- 1 root      root       97580 Jan 27 23:00 dtgloop.txt
-rw-r----- 1 root      root        2763 Jan 27 22:41 monit.log
I assume that monit is running as root on your system as it is on mine, so you don't need the sudo as the scripts will be run as root:
pi@domoticz:~/dtgbot$ ps -ef | grep -i monit
root       617     1  0 Jan15 ?        00:09:14 /usr/bin/monit -c /etc/monit/monitrc
restartbot.sh and stopbot.sh are both designed to run as root by monit.
As you are trying to do it is good idea to check restartbot.sh and stopbot.sh work, it looks like you need to install the sudo package or log on as root to test on your system.
I have tested both restartbot.sh and stopbot.sh on my system and they work effectively:
# dtgbot running normally
pi@domoticz:~/dtgbot$ ps -ef | grep -i bot
root      8884     1  0 Jan25 ?        00:00:00 /bin/sh /home/pi/dtgbot/dtgbot /var/run/dtgbot.pid
root      8885  8884  0 Jan25 ?        00:02:31 /usr/bin/lua5.2 /home/pi/dtgbot/dtgbot.lua
pi       21259 20106  0 22:38 pts/1    00:00:00 grep -i bot
# dtgbot stopped by stopbot
pi@domoticz:~/dtgbot$ sudo ./stopbot.sh
pi       21477 20106  0 22:39 pts/1    00:00:00 grep -i bot
# monit launches restartbot.sh
root     21526   617  2 22:39 ?        00:00:00 /bin/bash /home/pi/dtgbot/restartbot.sh
pi       21570 20106  0 22:39 pts/1    00:00:00 grep -i bot
# restartbot.sh starts the dtgbot service
root     21526   617  0 22:39 ?        00:00:00 /bin/bash /home/pi/dtgbot/restartbot.sh
root     21592 21526  0 22:39 ?        00:00:00 sudo service dtgbot start
root     21596 21592  0 22:39 ?        00:00:00 /bin/sh /usr/sbin/service dtgbot start
pi       21603 20106  0 22:39 pts/1    00:00:00 grep -i bot
# monit has now restarted dtgbot successfully
root     21621     1  0 22:39 ?        00:00:00 /bin/sh /home/pi/dtgbot/dtgbot /var/run/dtgbot.pid
root     21623 21621 49 22:39 ?        00:00:02 /usr/bin/lua5.2 /home/pi/dtgbot/dtgbot.lua
pi       21631 20106  0 22:40 pts/1    00:00:00 grep -i bot
/var/tmp/monit.log shows the processes happening:
[GMT Jan 27 22:39:41] error    : 'dtgbot' process is not running
[GMT Jan 27 22:39:41] info     : 'dtgbot' trying to restart
[GMT Jan 27 22:39:41] info     : 'dtgbot' start: /home/pi/dtgbot/restartbot.sh
[GMT Jan 27 22:41:55] info     : 'dtgbot' process is running with pid 21621
woody4165
Post by woody4165 »
simonrg wrote: Sunday 28 January 2018 0:05
Sudo is surely installed, it's workin, but it seems that adding just sudo to monit rc does not work.
So based on some search, I've added this to the monitrc config file:
  start program = "/home/linaro/dtgbot/restartbot.sh" as uid root and gid root timeout 20 seconds
  stop  program = "/home/linaro/dtgbot/stopbot.sh" as uid root and gid root timeout 20 seconds
adding as uid root and gid root to the start and stop program
simonrg wrote: Sunday 28 January 2018 0:05 The owner of restartbot.sh shouldn't matter as long as it is executable by all users, you can find the owner of dtgloop.txt by ls -l on the temporary directory, mine is owned by root.
All the files (logs) in the /var/tmp are owned by root:root too in my case.
simonrg wrote: Sunday 28 January 2018 0:05 I assume that monit is running as root on your system as it is on mine, so you don't need the sudo as the scripts will be run as root:
I get same result with ps command.
What I get in the monit.log when I close the xDSL connection is this:
[CET Jan 28 08:03:47] info     : 'dtgloop' trying to restart
[CET Jan 28 08:03:47] info     : 'dtgloop' start: /home/linaro/dtgbot/restartbot.sh
[CET Jan 28 08:04:07] error    : 'dtgloop' failed to start (exit status -1) -- /home/linaro/dtgbot/restartbot.sh: Program timed out -- 01/28/2018 08:03:47 AM restartbot.sh started  (2)
So I tried to run an
echo "test" >> /var/tmp/dtgloop.txt
and I get Permission denied, but also running it with sudo has same result. :shock:
Could it be still locked from don't know whom?
What the hell...
simonrg
Post by simonrg »
woody4165 wrote: Sunday 28 January 2018 8:25
Sorry I thought in one of the post away back I had seen "sudo" not a recognised command, sudo is a package so it needn't be loaded but normally it is, I like the detailed signature :D .
I suggest that you first need to check that stopbot.sh and restartbot.sh are working correctly, outside of monit. Also restartbot.sh as supplied assumes /var/tmp for temporary files and dtgbot/dtgbot.lua as the end of the path for the bot lua file.
So remove the dtgbot / dtgloop lines from monitrc, restart monit then:
cd ~/dtgbot
sudo ./stopbot.sh
Assuming this works then:
sudo ./restartbot.sh
If you get a timeout as happened with monit, then have a look inside restart.sh, and execute the individual commnads:
sudo service dtgbot stop
sudo pkill -f dtgbot/dtgbot.lua
What output do you get from these?
woody4165
Post by woody4165 »
Hi Simon
linaro@cubietruck:~/dtgbot$ sudo ./stopbot.sh
linaro@cubietruck:~/dtgbot$ sudo ./restartbot.sh
Just did the stop and restart and everything is fine.
Removed first the check lines from monitrc and rebooted just to be sure.
Some strange message in dtgloop.txt ?
2018-01-28 09:28:16
01/28/2018 09:29:00 AM  Stopping
2018-01-28 09:29:07
01/28/2018 09:29:12 AM  Stopped
01/28/2018 09:29:18 AM restartbot.sh started but is already running so stopping this one. (3)
linaro@cubietruck:/var/tmp$
Just run one time stopbot.sh and restartbot.sh
woody4165
Post by woody4165 »
It seems that the issue was the permission of the dtgloop.txt file .
previously was -rw-r--r-- now I changed in -rw-rw-rw- and it seems to work now, from cmd line as well as from monit
So now I have all "echo" commands in the .sh files without sudo and in monitrc changed back to original
Monitor the DTGBOT Service
check process dtgbot with pidfile /var/run/dtgbot.pid
  start program = "/home/linaro/dtgbot/restartbot.sh" timeout 20 seconds
  stop  program = "/home/linaro/dtgbot/stopbot.sh" timeout 20 seconds
  if 5 restarts within 5 cycles then timeout
# Monitor the DTGBOT loop file which should be updated each minute.
# Restart DTGBOT when not updated in 2 minutes
 check file dtgloop with path /var/tmp/dtgloop.txt
  if timestamp > 2 minutes then restart
I'll keep an eye to it, but still don't understand why was working to all of you and not to me!!!
woody4165
Post by woody4165 »
I'm really sorry to say that I'm still having problems.
This time with the restartbot.sh that seems to be already running but "defunct".
This is what i find if I run a ps command
30010 ?        Zs     0:00 [restartbot.sh] <defunct>
and if I try to manually kill with "kill 30010" nothing happens
In the script there is a check if the restartbot.sh is already running, but I don't understand what it does if it found it running.
chk=`sudo ps x | grep "restartbot.sh" | grep -cv grep`
if  [ $chk -gt 2 ] ; then
        echo "`date +"%x %X"` restartbot.sh started but is already running so s$
        exit
fi
The message in dtgloop.txt is
01/29/2018 07:02:18 AM restartbot.sh started but is already running so stopping this one. (3)
but it seems it doesn't stop....
The saga continues :shock: :oops:
jvdz
Post by jvdz »
I am not a linux buff, but a quick google turned up this thread: https://askubuntu.com/questions/201303/ ... led#201308
It states you can't kill a defunc task and need to kill its parent.
I indeed build in a safeguard to avoid starting restartbot.sh multiple times, so any subsequent instance of restartbot.sh will stop after it detects an already running version. So in your case you have a defunct restartbot and no other one will be started.
A reboot should also clean things as a last resort measure.
Jos
woody4165
Post by woody4165 »
Thanks Jos.
This sounds really weird to me, it seems that I have some issue on my system or some mis.configuration.
I will continue to keep an eye on it because I like very much dtgbot and its functionality...
woody4165
Post by woody4165 »
Hi Jos.
I found a workaround for me and seems to work.
In restartbot.sh I have added sudo service monit restart when it checks if restartbot.sh is found active (or defunct in my case)
        echo "`date +"%x %X"` restartbot.sh started but is already running so stopping this one. ($chk)" >> /var/tmp/dtgloop.txt
        exit
fi
It seems that just restarting the monit service, that is the "father" of restartbot.sh, will clear this situation.
Since this happens to me once a day, unless other xDSL disconnections happens for other reasons, it's ok for me.
Thanks all for your support.
solidum90
Domoticz version: Debian
Post by solidum90 »
Great Work!!
Very very compliment!
satanasinc
Domoticz version: 4.9700
Post by satanasinc »
Hi!
First of all excuse my bad english. I do my best.
Ive got a RPi working with the telegram bot and domoticz control but my instalation is very old running ver rapsbian wheezy. So i do a fresh install in a new SD with raspbian stretch and the domoticz telegram bot control dont works.
I cant find where is the problem because dont recive answer from domoticz but the notification works perfect.
The /var/tmp/dtb.log apears to be correct...
2018-03-13 14:52:01 - DomoticzIP: 127.0.0.1
2018-03-13 14:52:01 - DomoticzPort: 8080
2018-03-13 14:52:01 - BotHomePath: /home/pi/dtgbot/
2018-03-13 14:52:01 - TempFileDir: /var/tmp/
2018-03-13 14:52:01 - BotLuaScriptPath: /home/pi/dtgbot/lua/
2018-03-13 14:52:01 - BotBashScriptPath: /home/pi/dtgbot/bash/
2018-03-13 14:52:01 - TelegramBotToken: 524####64:AAFZUOtHs_tvJ_F6c06GYpkt6$$$$$$$$$$$$
2018-03-13 14:52:01 - TelegramBotOffset: TelegramBotOffset
2018-03-13 14:52:01 - -----------------------------------------
2018-03-13 14:52:01 - Starting Telegram api Bot message handler
In /var/tmp/dtb.log.error i got this...
Illegal instruction
My /etc/profile.d/DomoticzData.sh#I can't get the next line to work during start-up so have gone to 127 instead
#export DomoticzIP=$(hostname -I|sed 's/[ ]*$//')
export DomoticzIP="127.0.0.1"
export DomoticzPort="8080"
export TempFileDir="/var/tmp/"
export BotHomePath="/home/pi/dtgbot/"
export BotBashScriptPath=$BotHomePath"bash/"
export BotLuaScriptPath=$BotHomePath"lua/"
export BotLuaLog=$TempFileDir"dtb.log"
export TelegramChatId='34####63#
export TelegramBotToken="524####64:AAFZUOtHs_tvJ_F6c06GYpkt6$$$$$$$$$$$$"
export TelegramBotOffset="TelegramBotOffset"
export EmailTo="alt$$$$$[email protected]"
I have started the installation a couple of times wthout luck following the domoticz wiki.
Any idea? What can i do to make it work?
Thanx in advance for your help.
jvdz
Post by jvdz »
The issue seems to lie in these lines so guess the best bet will be an issue with the require files:
-- Load necessary Lua libraries
http = require "socket.http";
socket = require "socket";
https = require "ssl.https";
JSON = require "JSON";
function file_exists(name)
   local f=io.open(name,"r")
   if f~=nil then io.close(f) return true else return false end
-- Load the configuration file this file contains the list of commands
-- used to define the external files with the command function to load.
local config=""
if (file_exists(BotHomePath.."dtgbot-user.cfg")) then
  config = assert(loadfile(BotHomePath.."dtgbot-user.cfg"))();
  print_to_log ("Using DTGBOT config file:"..BotHomePath.."dtgbot-user.cfg")
  config = assert(loadfile(BotHomePath.."dtgbot.cfg"))();
  print_to_log ("Using DTGBOT config file:"..BotHomePath.."dtgbot.cfg")
Could the issue be similar to issues reported like this one?: http://www.domoticz.com/forum/viewtopic ... on#p171940
Jos
satanasinc
jvdz wrote: Tuesday 13 March 2018 18:36 The issue seems to lie in these lines so guess the best bet will be an issue with the require files:
local config=""
Jos
Hi!
That is the soution!!!
Working at first attempt.
Like i tell you in october of 2015 youre the Jedi Master.
Thank you very much Jos.
Regards an thanx again
hansies
Domoticz version: stable
Post by hansies »
G3rard wrote: Saturday 13 May 2017 10:49
maomanna wrote:How did you compile the lua libraries?
In the OP is a 32bit version supplied.
I did the following steps to make dtgbot working on my Ubuntu server 14.04 x64.
I can confirm this is working on Ubuntu 16.04 64bit on my NUC with VirtualBox!
Domoticz stable | Intel NUC | VirtualBox | Ubuntu 16.04
RPI2B | RFLink
Yeelight | Sonoff Tasmota
