Page 15 of 25
Re: Android app
Posted: Thursday 16 October 2014 12:40
by tommysharp
Hey guys, is it just me or does this app still not work with the latest version of Domoticz?
UPDATE : Okay weird.... I had to fill in the "External" domoticz settings in the app even though I'm accessing from in my own network... It works now...
Re: Android app
Posted: Sunday 19 October 2014 22:08
by Blueone
It seems like the external connetions isn't working anymore with dromotica, maybe because an update of domoticz?
Re: Android app
Posted: Monday 20 October 2014 23:11
by Scoobydoo
Blueone wrote:It seems like the external connetions isn't working anymore with dromotica, maybe because an update of domoticz?
Working fine here with the latest 'stable' release of domoticz
Re: Android app
Posted: Tuesday 21 October 2014 10:03
by Blueone
I am using the latest Beta release (version 2066).
Re: Android app
Posted: Tuesday 21 October 2014 11:57
by Derik
I do have the same problem with the beta...
And when i try to lgin with my ip and port from a browser from a other Ip adres.
I do not have a problem.....
I try other login etc etc.
No wan login from the app is possible...
Re: Android app
Posted: Tuesday 21 October 2014 13:38
by Blueone
I can also still login with the webinterface from an external location, I think it happened around version 2055.
Re: Android app
Posted: Tuesday 21 October 2014 22:04
by Electrocut
No problem for me (but I'm accessing Domoticz services in HTTPS through nginx ... don't know if this helps)
In Domoticz settings, is "Security > Authentication > Basic-Auth" checked?
Re: Android app
Posted: Thursday 23 October 2014 21:54
by jjnj
Dear Sebas,
Could you add the option to control a RGBW controller? In domoticz you will get a colour frame on which to select the desired colour. In the app it is only possible to put the RGBW on or off.
It also would be nice to get a floorplan.
Br,
Joost
Re: Android app
Posted: Friday 24 October 2014 16:36
by ulysserevient
Hi I'm using v2.2074 of DomoticZ and Dromotica can't connect thru remote connection !
On local network, it doesn't work unless I filled out the field LANs.
Could you help me ?
Re: Android app
Posted: Friday 24 October 2014 21:08
by Electrocut
Same question:
Electrocut wrote:In Domoticz settings, is "Security > Authentication > Basic-Auth" checked?
Re: Android app
Posted: Saturday 25 October 2014 10:40
by ThinkPad
Derik wrote:feature request.
The protected switches in the app see / treat as protected
Please
This is also something i would like to see. I have some virtual switches, which are meant not to be activated by hand. In the webinterface of Domoticz this works fine, it asks nicely for a password to prevent accidental clicking on the switch. However, in your app i can just turn on/off the virtual switches. This is unhandy, because this way my girlfriend can click the virtual switches by accident, and mess up the working of the events.
However i am not sure if you can fix this in your app, because if you look at the JSON commands (
http://www.domoticz.com/wiki/Domoticz_API/JSON_URL's) and for example take the command which lists all the switches, the output doesn't mention anything about if the switch is protected or not.
Re: Android app
Posted: Sunday 26 October 2014 14:51
by pwhooftman
Marius wrote:Hi.
I am using danffos live connect with domoticz. On web interface I can control temperature with our any problem.
But in dromotica when I go to utilities I can see the thermostat with the current temperature but I can not change it. There is a field to choose the new temperature but it does nothing. Further more on the bottom of the screen there is a notification showing up every 5 sec
"thermostat set to 4.578\u00B0"
Lucky for me it does not set this value.
Can you please look in to this problem?
Exactly the same problem for me (iSense Thermostat), any progress?. Changing the thermostat setpoint from the Domiticz interface works OK.
Re: Android app
Posted: Monday 27 October 2014 10:04
by ThinkPad
As i hate forwarding ports for every application i want to access from outside my network, i use a VPN connection.
However, i noticed that the Dromotica app won't work with VPN. It either says: " Server url not set.", or it just hangs at the blue background logo.
I verified the URL in the settings, and this is correct. And when i am connected to my VPN, and enter that URL in my browser, i can succesfully acces Domoticz. So the VPN is working like it should.
Re: Android app
Posted: Thursday 30 October 2014 18:48
by vmb
@thinkpad Same situation here. When I connect through vpn (synology) I filled in Dromotica at field external and internal adress the internal adress of my Pi. Is works like a charm...
Re: Android app
Posted: Friday 31 October 2014 13:54
by Mart
Since the last Domoticz update to 2.025 the android app on my phone cannot establish a connection with the Domoticz on my Raspberry Pi. Somebody has an idea what to do?
Re: Android app
Posted: Friday 31 October 2014 14:13
by Brutus
Mart wrote:Since the last Domoticz update to 2.025 the android app on my phone cannot establish a connection with the Domoticz on my Raspberry Pi. Somebody has an idea what to do?
You need to set the Website Authentication to "Basic-Auth" in the Domoticz Application Settings.
Greetings Brutus.
Re: Android app
Posted: Sunday 02 November 2014 1:28
by Brutus
There is a update for this app available in the app store. The authentication supports again the login page.
I have downloaded en tested the update after I changed the settings in domoticz.
Thnx for this update
Re: Android app
Posted: Sunday 02 November 2014 10:57
by sebas
Brutus wrote:There is a update for this app available in the app store. The authentication supports again the login page.
Yes, I've released the update yesterday evening. It's available for download in the store and automatic updates should come in now or just download it manually from the store. I still need to put some finishing touches on it but I wanted to release it now as you guys have been waiting for it.
In the settings for Domoticz you'll need to indicate if you're using the basic-auth of login form method. That setting needs to match with what you've set in Domoticz itself.
I've read the requests and emails I got for new features, bugs and devices to support. Thanks all for your feedback and I'll work on them soon. I first want to focus on cleaning up the code of this app as it has grown out a lot and has become unmaintainable. It's what you get when you start to code without any real coding knowledge
Edit 1:
ThinkPad wrote:Derik wrote:feature request.
Please
The protected flag is included in the JSON for switches and scenes, the Wiki isn't very up-to-date. It was simple to include in the refactoring so I already implemented it. It will be in the next update that I just uploaded to the store.
Edit 2:
I've run into a bug causing errors when you use a SSL certificate that's not issued by a trusted CA like many of us do. I've fixed that and uploaded the new version to the store. The update should be coming your way soon.
Re: Android app
Posted: Sunday 02 November 2014 20:15
by Derik
Really great!!!
And thanks for your app and nice update...
Feedback:
Other icon or collor for open close of a contact / pir
Smoke sensor icon
Roomplan options
Love you...
xxxx
Re: Android app
Posted: Sunday 02 November 2014 21:23
by sebas
Google send me something to play with
This is Dromotica running on my TV with the Android TV developer unit. Fun stuff but needs lots of work to get it really working nicely.
Other stuff first
