Tesla hardware module
Doler
Re: Tesla hardware module
Post by Doler »
@JanJaap
I recently bought a Tesla Model Y and thought I should try the integration with Domoticz. All did go well until the start of the new hardware were I met the following error:
2024-07-16 10:13:47.938 Status: Tesla: Started.
2024-07-16 10:13:48.387 Status: Tesla: Initialized version 0.8.1, author 'Jan-Jaap Kostelijk'
2024-07-16 10:13:48.389 Tesla: Plugin starting
2024-07-16 10:13:48.392 Tesla: Starting version: 0.8.1
2024-07-16 10:13:49.018 Error: Tesla: Call to function 'onStart' failed, exception details:
2024-07-16 10:13:49.020 Error: Tesla: Traceback (most recent call last):
2024-07-16 10:13:49.020 Error: Tesla: File "/home/pi/domoticz/plugins/TeslaDomoticz/plugin.py", line 380, in onStart
2024-07-16 10:13:49.020 Error: Tesla: _plugin.onStart()
2024-07-16 10:13:49.020 Error: Tesla: File "/home/pi/domoticz/plugins/TeslaDomoticz/plugin.py", line 172, in onStart
2024-07-16 10:13:49.020 Error: Tesla: self.updateDevices(self.vehicle_dict[vehicle['vin']])
2024-07-16 10:13:49.020 Error: Tesla: File "/home/pi/domoticz/plugins/TeslaDomoticz/plugin.py", line 305, in updateDevices
2024-07-16 10:13:49.020 Error: Tesla: UpdateDeviceEx(deviceId, 2, vehicle.battery_range, "{:.1f}".format(vehicle.battery_range)) # range
2024-07-16 10:13:49.020 Error: Tesla: ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2024-07-16 10:13:49.020 Error: Tesla: File "/home/pi/domoticz/plugins/TeslaDomoticz/plugin.py", line 451, in UpdateDeviceEx
2024-07-16 10:13:49.020 Error: Tesla: Devices[Device].Units[Unit].nValue = nValue
2024-07-16 10:13:49.020 Error: Tesla: TypeError: 'float' object cannot be interpreted as an integer
With my limited knowledge of Python I succeeded in bringing it a step further by typecasting a float to integer in line 451 of plugin.py like:
Devices[Device].Units[Unit].nValue = int(nValue)
I don't understand why the error occurs since the percentage device should be able to accept float values.
Can you explain this and help me further?
Thanks, Mark
Mark: Domoticz Beta on Raspberry Pi 4 running Debian Bookworm - Z-Stick 7 - RFXCom - P1 - MySensors - SolarEdge - Dahua - Philips Hue - Docker - Zigbee2mqtt (plugin) - Zwave-js-ui - dzVents - Nodered
JanJaap
Domoticz version: Dev
Post by JanJaap »
Odd indeed. But nvalue should be an int, if I remember correctly. I'm on holiday now, will have a look early August when back home
JPSke
Domoticz version: 2022.1
Post by JPSke »
Hi JanJaap. Do you think it is possible to add a switch to control charging of the car?
JanJaap
Post by JanJaap »
Yes sorry. Got a bit distracted in another app and other hobbies..... But with winter around more time to spend. Hope before christmas to have something in
