Page 15 of 18
Re: Python Plugin: Zigbee2Mqtt
Posted: Monday 25 October 2021 12:08
by manjh
EddyG wrote: Monday 25 October 2021 11:57
If you go into the zigbee2mqtt GUI you can go to Settings -> About
There you will find the version, in my case from yesterday.
Zigbee2MQTT version 1.21.2-dev commit: 3f0a2fed
So if you update now from the dev branch you are good.
I see:
I removed and re-installed the whole package. Should I do something special to get the dev version?
Posted: Monday 25 October 2021 13:26
by EddyG
If you use googled 'git change branch' then you would have found
or switch back and forth
And a lot of useful information about git.
Posted: Monday 25 October 2021 15:23
by manjh
EddyG wrote: Monday 25 October 2021 13:26
thanks
I think a lot is due to the fact that I've not really used Git, beside the pre-cooked statements that I find in installation procedures. Even the terminology needs a learning curve, e.g. the "branch".
OK, so taking the risk of asking stupid questions.
I submitted:
which gave me a list of modules, preceded with "M".
Also:
Then what? I can't tell if that brought the dev version down to my Pi...
I tried
sudo git pull
There is no tracking information for the current branch.
Please specify which branch you want to merge with.
Posted: Monday 25 October 2021 16:30
by EddyG
I use these commands all the time when I update, just to be sure that that I am on the right branch.
git checkout HEAD -- npm-shrinkwrap.json
git fetch
git checkout dev
git pull
And if you want to be 100% sure that you are on the right branch:
Sorry for the -b
Posted: Monday 25 October 2021 17:40
by manjh
I did as you suggested, with this result:
pi@Utrecht:/opt/zigbee2mqtt $ git branch
* dev
master
pi@Utrecht:/opt/zigbee2mqtt $ git fetch
remote: Enumerating objects: 5, done.
remote: Counting objects: 100% (5/5), done.
remote: Total 5 (delta 4), reused 4 (delta 4), pack-reused 0
Unpacking objects: 100% (5/5), done.
From https://github.com/Koenkk/zigbee2mqtt
56812e78..b08ce534 dev -> origin/dev
pi@Utrecht:/opt/zigbee2mqtt $ git checkout dev
M data/configuration.yaml
Already on 'dev'
pi@Utrecht:/opt/zigbee2mqtt $ git pull
See git-pull(1) for details.
git pull <remote> <branch>
If you wish to set tracking information for this branch you can do so with:
git branch --set-upstream-to=origin/<branch> dev
* dev
master
Did "npm instsall", and restarted zigbee2mqtt service. Still see this version:
Posted: Monday 25 October 2021 19:48
by EddyG
Try:
1. Stop zigbee2mqtt
2. Move the whole /opt/zigbee2mqtt to a save place.
3. Clone the zigbee2mqtt
4. git checkout dev
5. git pull
6. copy the original /opt/zigbee2mqtt/data back to the original place
7. start zigbee2mqtt
B.t.w. seen by the line " 56812e78..b08ce534 dev -> origin/dev" you are on the version of yesterday. So everything went fine.
Did you refresh your browser cache?
Posted: Monday 25 October 2021 21:53
by manjh
OK, followed the steps.
After npm start, it ends with:
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! [email protected] start: `node index.js`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the [email protected] start script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR! /root/.npm/_logs/2021-10-25T19_51_58_334Z-debug.log
Content of the log file:
0 info it worked if it ends with ok
1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
2 info using [email protected]
3 info using [email protected]
4 verbose run-script [ 'prestart', 'start', 'poststart' ]
5 info lifecycle [email protected]~prestart: [email protected]
6 info lifecycle [email protected]~start: [email protected]
7 verbose lifecycle [email protected]~start: unsafe-perm in lifecycle true
8 verbose lifecycle [email protected]~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/opt/zigbee2mqtt/node_modules/.bin:/usr/local/sbin:/usr/local/bin:$
9 verbose lifecycle [email protected]~start: CWD: /opt/zigbee2mqtt
10 silly lifecycle [email protected]~start: Args: [ '-c', 'node index.js' ]
11 silly lifecycle [email protected]~start: Returned: code: 1 signal: null
12 info lifecycle [email protected]~start: Failed to exec start script
13 verbose stack Error: [email protected] start: `node index.js`
13 verbose stack Exit status 1
13 verbose stack at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
13 verbose stack at EventEmitter.emit (events.js:314:20)
13 verbose stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
13 verbose stack at ChildProcess.emit (events.js:314:20)
13 verbose stack at maybeClose (internal/child_process.js:1022:16)
13 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:287:5)
14 verbose pkgid [email protected]
15 verbose cwd /opt/zigbee2mqtt
16 verbose Linux 5.10.63-v7l+
17 verbose argv "/usr/bin/node" "/usr/bin/npm" "start"
18 verbose node v12.22.7
19 verbose npm v6.14.15
20 error code ELIFECYCLE
21 error errno 1
22 error [email protected] start: `node index.js`
22 error Exit status 1
23 error Failed at the [email protected] start script.
23 error This is probably not a problem with npm. There is likely additional logging output above.
24 verbose exit [ 1, true ]
I don't feel very lucky today... I've gone back to the main version, with the external adapter for the bulb. Will see how it runs. For now it is OK.
Posted: Tuesday 26 October 2021 17:07
by manjh
I think I'll stick to the current setup, with the external converter file to support the lamp. I assume that with the next stable version the support will be built in.
here is one thing that puzzles me. The Ikea lamp is working OK, until the moment that I restart Zigbee2MQTT. After that the bulb shows up as "unsupported". I discovered that when I switch the power to the lamp off, and then on again, it re-connects to Z2M and show up as "supported" again.
Although this is not a big deal, I wonder if this is normal? At the moment I only have one single bulb, but when I add more bulbs in the future, it will become a hassle to go around the house and switch power everywhere.
So my question is: is this normal behaviour?
I also have five smoke detectors, and they drop connection as well. But at some point in time they connect back, probably because they report the status periodically.
A light bulb doesn't do this on its own, unless the power is switched...
Posted: Tuesday 26 October 2021 17:10
by manjh
manjh wrote: Tuesday 26 October 2021 17:07
But there is one thing that puzzles me. The Ikea lamp is working OK, until the moment that I restart Zigbee2MQTT. After that the bulb shows up as "unsupported". I discovered that when I switch the lamp-power off, and then on again, it re-connects to Z2M and shows up as "supported" again.
Posted: Tuesday 26 October 2021 17:17
by heggink
I haven't read your entire thread but allow me to provide some comments:
1) I strongly suggest to run zigbee2mqtt with the official docker container. It comes in a stable and a dev version
2) zigbee devices should not just drop off. There can be a couple of reasons: a) the usb adapter (memory, range) and b) network interference: this was a big issue for me until I figured out which wifi 2,4ghz overlap with zigbee. I then switched zigbee to a different channel and everything was smooth.
I hardly ever restart zigbee2mqtt. It just runs.
Posted: Tuesday 26 October 2021 17:38
by manjh
heggink wrote: Tuesday 26 October 2021 17:17
I have no experience using docker, will look into it.
Dropping devices: this happens when ZIgbee2MQTT has been restarted for whatever reason. This afternoon I restarted after making a few changes to the configuration.yaml file (debug setting, and allow-join). But it could also happen when I restart the Pi. So the device doesn't drop by itself, it is simply thrown off and then doesn't re-connect automatically.
Posted: Monday 08 November 2021 15:54
by fvdp80
Any idea where these errors come from?
2021-11-08 13:40:02.755 Error: SQL Query("INSERT INTO Temperature (DeviceRowID, Temperature, Chill, Humidity, Barometer, DewPoint, SetPoint) VALUES ('80', '11.90', '0.00', '69', '10231', '6.39', '0.00')") : no more rows available
Same errors are also mentioned in
this topic, but no solution is mentioned.
Posted: Monday 08 November 2021 18:47
by EddyG
Are you sure there is a dev version on docker? I see only a regular stable (master) version.
Posted: Tuesday 09 November 2021 1:44
by waltervl
EddyG wrote: Monday 08 November 2021 18:47
https://hub.docker.com/r/koenkk/zigbee2mqtt/tags latest-dev
Posted: Tuesday 09 November 2021 8:55
by EddyG
Oeps.
I looked here because I have a raspberry armv7
https://hub.docker.com/r/zigbee2mqtt/zi ... armv7/tags
Strange that that is not synchronized.
Posted: Tuesday 30 November 2021 11:29
by purch
z2m plugin crashes domoticz. Only start status messages looping in Domoticz log window and in Windows (Win 11) event viewer shows following error with all tested versions. Crashing stops if I disable z2m plugin in hardware section.
Fault bucket 1290729138380626289, type 5
Event Name: BEX
Response: Not available
Cab Id: 0
Problem signature:
P1: domoticz.exe
P2: 2021.1.0.13875
P3: 61a3c354
P4: StackHash_2beb
P5: 0.0.0.0
P6: 00000000
P7: PCH_2B_FROM_ntdll+0x00074C6C
P8: c0000005
P9: 00000008
P10:
- z2m works - I can use frontend to trigger devices (tested 3 latest versions)
- MQTT Explorer can connect Mosquito and show info
- plugin z2m (tested 3 latest version)
- domoticz (tested beta and latest)
- zzh - CC2652R Stick (2 new ones tested with latest fw and after error red'ish' light blinks)
What to debug and test next or how to get this thing working?
Posted: Monday 27 December 2021 16:37
by samourai47
Hello
Some help please
I tried to use a MOES BHT-002-GCLZB with deconz and that dosen't work prefectly
I try with mqtt and zigbee2mqtt plugin
That work only in domoticz beta and the 3.1 plugins, but i have a little problem
My problem
The BHT seem's to ahave a little bug
Stop message flooding
This unit has a bug that makes it send multiple messages when updating. To stop this from flooding your MQTT Queues, please add the following to your configuration.yaml file:
devices: '0x12345678': friendly_name: thermostat debounce: 1
An when i modify the file configuration.yaml
sudo nano /opt/zigbee2mqtt/data/configuration.yaml
I restart the pi and no device works, i have no error message in domoticz. If a restore the file all the devices work
Original file:
evices:
'0x00158d00023d4a85':
friendly_name: '0x00158d00023d4a85'
'0x00158d000302f81f':
friendly_name: '0x00158d000302f81f'
'0x9035eafffe6ee770':
friendly_name: '0x9035eafffe6ee770'
Modify file
devices:
I try many solutions but only the original file work; HAve you some idea?
Thank's for your help
Posted: Monday 27 December 2021 17:10
by Nautilus
I would try specifying the device options with line breaks as shown here:
https://www.zigbee2mqtt.io/guide/config ... ce-options
Posted: Monday 27 December 2021 18:36
by samourai47
thank you that work like this
friendly_name: 'thermostat'
debounce: 1
Posted: Monday 27 December 2021 20:10
by samourai47
I don't arrive to pair the conbee2 and the smoke detector frient with the sigbee2mqtt plugin
When i press the button, the led flashes a few minutes then stop but nothing is in the mqttplugin
It seem to be possible in zigbee2mqtt
https://www.zigbee2mqtt.io/devices/SMSZB-120.html
I have this msg
2021-12-28 08:16:35.359 Error: Zigbee2mqtt: 0x0015bc003100c892: can not process binary item "alarm"
2021-12-28 08:16:35.359 Error: Zigbee2mqtt: 0x0015bc003100c892: can not process binary item "fault"
The Temperture dosen't work andd i have no siren device...
I don't understand
