The plugin isn't modified, just the test scripts... So the plugin still uses 3.1 and is probably also not correctly parsing the responses...tete wrote: Monday 23 September 2019 15:12
I've made these changes and now I can get the plugin working.
Plug State Information:
{'devId': '60417563840d8e68fe98', 'dps': {'22': 626, '19': 1334, '23': 34433, '9': 0, '20': 2358, '18': 634, '1': True, '24': 19774, '21': 1, '25': 1045}}
Plug DPS List:
1
However, when I add the device to domoticz, the values are 0 and neither does work the on / off function.
But it works the on / off by command line (turnON.py, turnOFF.py).
What could be wrong?
[REQUEST] Plugin for Tuya
- FearNaBoinne
- Domoticz version: 2021.1
Re: [REQUEST] Plugin for Tuya
RasPi, Raspbian , Domoticz v2021.1, Z-Wave Stick, RFLink, RFXtrx433e, Hue, Tuya (Tasmota/Mosquitto with Discovery), ESP(easy), MySensors.org, OTGW
xavierlp
- Domoticz version: 2020.2
Ok got itFearNaBoinne wrote: Monday 23 September 2019 16:00 It's not key and devID, it's devID and gwID... They key is different, but not shown in the debug info...
In __init__.py
# This is intended to match requests.json payload at https://github.com/codetheweb/tuyapi
payload_dict = {
"device": {
"status": {
"hexByte": "0a",
"command": {"gwId": "", "devId": ""}
"set": {
"hexByte": "07",
"command": {"devId": "", "uid": "", "t": ""}
"prefix": "000055aa00000000000000", # Next byte is command byte ("hexByte") some zero padding, then length of remaining payload, i.e. command + suffix (unclear if multiple bytes used for length, zero padding implies could be more than one byte)
"suffix": "000000000000aa55"
xavierlp
If I run
sudo python3.5 get_dps.py 192.168.1.23 "55142707bcddc295" "c6e4fd6a1f14fe20"
INFO:pytuya:pytuya version 7.0.4
INFO:pytuya:Python 3.5.7 (default, Aug 17 2019, 22:31:31)
[GCC 4.9.2] on linux
INFO:pytuya:Using PyCrypto (2, 6, 1, 'final', 0)
INFO:pytuya:Using PyCrypto from '/usr/local/lib/python3.5/site-packages/Crypto/__init__.py'
test
DEBUG:pytuya:status() entry
DEBUG:pytuya:json_payload=b'{"gwId":"55142707bcddc295","devId":"55142707bcddc295"}'
A problem occur please retry...
gwId is BEFORE devId
If I run
sudo python3.5 get_dps.py 192.168.1.23 55142707bcddc295f96a c6e4fd6a1f14fe20
DEBUG:pytuya:json_payload=b'{"devId":"55142707bcddc295f96a","gwId":"55142707bcddc295f96a"}'
gwId is AFTER devId
test
If I run
gwId is AFTER devId
xavierlp
I removed then add the device to check the key value.
And Now I've got an second value !!!
But always the same message
- Xenomes
- Domoticz version: 2026.4
I have two Tuya devices LEDBulb and an LEDStrip with the new modifications the LEDStrip reacts on TurnON and TurnOff scripts the LEDBulb give a error : DEBUG:pytuya:decrypted result='json obj data unvalid'
I had the "A problem occur please retry..." error too when I closed the app on my phone the error gone.
I change the one of the scripts to run commands on one dps value. colour/white or 1 to 1000
turnCommand.py
When I do for example "./turnCcommand.py 192.168.1.34 361636752cf43206c777 3ab976c45h0275ce 21 colour" the LEDstrip is changing to colour mode
turnCommand.py
#!/usr/bin/python3
# Domoticz Tuya Smart Plug Python Plugin #
# MIT License #
# Copyright (c) 2018 tixi #
# Permission is hereby granted, free of charge, to any person obtaining a copy #
# of this software and associated documentation files (the "Software"), to deal #
# in the Software without restriction, including without limitation the rights #
# to use, copy, modify, merge, publish, distribute, sublicense, and/or sell #
# copies of the Software, and to permit persons to whom the Software is #
# furnished to do so, subject to the following conditions: #
# The above copyright notice and this permission notice shall be included in all #
# copies or substantial portions of the Software. #
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR #
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, #
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE #
# AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER #
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, #
# OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE #
# SOFTWARE. #
import sys
import pytuya
import socket #needed for socket.timeout exception
if(len(sys.argv)!=6):
print("usage: " + sys.argv[0] + " <IP> <DevID> <Local key> <DPS value> <DPS command>")
exit(1)
ip = sys.argv[1]
devid = sys.argv[2]
localkey = sys.argv[3]
dps_value = sys.argv[4]
dps_command = sys.argv[5]
device = pytuya.OutletDevice(devid,ip,localkey)
device.set_version(3.3)
try:
payload = device.generate_payload('set', {str(dps_value):(dps_command)})
device._send_receive(payload)
except (ConnectionResetError, socket.timeout, OSError) as e:
print("A problem occur please retry...")
exit(1)
HP T630 (256GB SSD/8GB Mem) - Ubuntu 24.04.4 LTS (64Bit) - Domoticz 2026.4 (Docker)
Tinytuya
Tinytuya
- FearNaBoinne
Yes, the app seems to sometimes grab the socket and not let go...Xenomes wrote: Monday 23 September 2019 19:59 I had the "A problem occur please retry..." error too when I closed the app on my phone the error gone.
- FearNaBoinne
There's also a smartbulb plugin, perhaps that'd work better with the color strip?...Xenomes wrote: Monday 23 September 2019 19:59 I have two Tuya devices LEDBulb and an LEDStrip with the new modifications the LEDStrip reacts on TurnON and TurnOff scripts the LEDBulb give a error : DEBUG:pytuya:decrypted result='json obj data unvalid'
xavierlp
So Ican't find to run the get_dps but the plugin is working.FearNaBoinne wrote: Monday 23 September 2019 15:04 My output shows the devID and gwID in reversed order compared to yours:
Not sure whether that is the 'data format error' referenced in your output...Code: Select all
INFO:pytuya:pytuya version 7.0.4 INFO:pytuya:Python 3.7.3 (default, Apr 3 2019, 05:39:12) [GCC 8.2.0] on linux INFO:pytuya:Using PyCrypto (2, 6, 1, 'final', 0) INFO:pytuya:Using PyCrypto from '/usr/lib/python3/dist-packages/Crypto/__init__.py' DEBUG:pytuya:status() entry DEBUG:pytuya:json_payload=b'{"gwId":"70116356840d8e5c3382","devId":"70116356840d8e5c3382"}' DEBUG:pytuya:status received data=b'\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\n\x00\x00\x00L\x00\x00\x00\x00#H7\x00\x03\xe9\xb5p\x18\xdf`?\xa5+\x9f \x7f#\xf4\xe14)\x0f_5\xa1\x93\xb92f\xf1\xecp(\xff\xda\x9dT\xbeZ\xc4\xca\xbaSi@\x892\x14\xc3\x89\xbb2\xe6\x82\x02\xabI\xe0\x9c\xf9\x18\x7fQ`\x02\xba-\x00\x00\xaaU' DEBUG:pytuya:result=b'#H7\x00\x03\xe9\xb5p\x18\xdf`?\xa5+\x9f \x7f#\xf4\xe14)\x0f_5\xa1\x93\xb92f\xf1\xecp(\xff\xda\x9dT\xbeZ\xc4\xca\xbaSi@\x892\x14\xc3\x89\xbb2\xe6\x82\x02\xabI\xe0\x9c\xf9\x18\x7fQ' DEBUG:pytuya:decrypted result='{"devId":"70116356840d8e5c3382","dps":{"1":false,"9":0}}' Plug State Information: {'devId': '70116356840d8e5c3382', 'dps': {'1': False, '9': 0}} Plug DPS List: 1
The only issu is that my device is a doucle plug and I can only manage the fist one !
As I can't find the list of dps I'm reading the log of the plugin and I can find that :
2019-09-23 23:17:12.086 (Tuya) onMessage called: 192.168.1.23:6668 b'\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\n\x00\x00\x00\x9c\x00\x00\x00\x00{"devId":"55142707bcddc295f96a","dps":{"1":true,"2":false,"9":0,"10":0,"18":0,"19":0,"20":2278,"21":1,"22":609,"23":27297,"24":15519,"25":1340}}1\xb3Yx\x00\x00\xaaU'
2019-09-23 23:17:12.086 (Tuya - Tuya SmartPlug (Switch)) Updating device from 0:'' to have values 1:'On'.
2019-09-23 23:17:12.089 (Tuya) Update Tuya - Tuya SmartPlug (Switch): 1 - 'On'
2019-09-23 23:17:12.089 (Tuya - Tuya SmartPlug (A)) Updating device from 0:'' to have values 0:'27.297'.
2019-09-23 23:17:12.090 (Tuya - Tuya SmartPlug (kWh)) Updating device from 0:'0; 0.0' to have values 0:'1551.9;0'.
2019-09-23 23:17:12.092 (Tuya - Tuya SmartPlug (V)) Updating device from 0:'' to have values 0:'134.0'.
2019-09-23 23:17:12.093 (Tuya - Tuya SmartPlug (W)) Updating device from 0:'' to have values 0:'1551.9'.
xavierlp
I can't find a way to run the get_dps but the plugin is working.
The only issue is that my device is a double plug and I can only manage the fist one !
As I can't find the list of dps I'm reading the log of the plugin and I can read that :
<code>
2019-09-23 23:17:43.090 (Tuya) onMessage called: 192.168.1.23:6668 b'\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\n\x00\x00\x00\x9d\x00\x00\x00\x00{"devId":"55142707bcddc295f96a","dps":{"1":false,"2":false,"9":0,"10":0,"18":0,"19":0,"20":2278,"21":1,"22":609,"23":27297,"24":15519,"25":1340}}\xc5_\xed\xaa\x00\x00\xaaU'
2019-09-23 23:17:43.090 (Tuya - Tuya SmartPlug (A)) Updating device from 0:'27.297' to have values 0:'27.297'.
2019-09-23 23:17:43.092 (Tuya - Tuya SmartPlug (kWh)) Updating device from 0:'1551.9;0' to have values 0:'1551.9;0'.
2019-09-23 23:17:43.094 (Tuya - Tuya SmartPlug (V)) Updating device from 0:'134.0' to have values 0:'134.0'.
2019-09-23 23:17:43.096 (Tuya - Tuya SmartPlug (W)) Updating device from 0:'1551.9' to have values 0:'1551.9'.
2019-09-23 23:17:43.098 (Tuya) Updated: 27.297 Ampere Key is:2
2019-09-23 23:17:43.098 (Tuya) Updated: 1551.9 Watt Key is:13
2019-09-23 23:17:43.098 (Tuya) Updated: 134.0 Voltage Key is:14
2019-09-23 23:17:43.113 (Tuya) Pushing 'ReadEvent' on to queue
</code>
So I need some help to enter values in
DPS
DPS GROUP
ID AMP WATT VOLT
For AMP,WATT, VOLT I think is 2,13,14 I'm right ?
<code>
</code>
DPS
DPS GROUP
ID AMP WATT VOLT
- FearNaBoinne
Create a second copy of the device, same IP, ID and Key (those all rhyme!) and change the DPS field from 1 to 2...xavierlp wrote: Monday 23 September 2019 23:27 I can't find a way to run the get_dps but the plugin is working.
xavierlp
Thanks for your feedbackFearNaBoinne wrote: Monday 23 September 2019 23:32Create a second copy of the device, same IP, ID and Key (those all rhyme!) and change the DPS field from 1 to 2...xavierlp wrote: Monday 23 September 2019 23:27 I can't find a way to run the get_dps but the plugin is working.
I've got this error
2019-09-23 23:38:02.104 Error: (Tuya 2): Async Read Exception (192.168.1.23:6668): 104, Connection reset by peer
- FearNaBoinne
Well, it was worth a try...
- FearNaBoinne
Just checking, did you initially try DPS 1;2? (Because that is the official way it should work...)
xavierlp
I found the solution
DPS 1;2
DPS Group 1:2
All is OK now
DPS 1;2
DPS Group 1:2
All is OK now
- Xenomes
Yes I am aware of the SmartBulb plugin, but is not working with it and uses the same pytuya. so by updating pytuya to version 3.3 and learning how it work (with the test scrips) the SmartBulb can maybe modified.FearNaBoinne wrote: Monday 23 September 2019 22:57 There's also a smartbulb plugin, perhaps that'd work better with the color strip?...
Tinytuya
Tinytuya
xavierlp
Hello all
the plugin is working good with my OXAOXE devices WiFi Smart Plug 2 in 1 for EU
https://oxaoxe.com/product/wifi-smart-p ... or-eu.html
I can easily switch on and switch off each.
I've got a question regarding options for consumption.
In the log I can read that
(Tuya) Calling message handler 'onMessage'.
2019-09-24 13:09:57.944 (Tuya) onMessage called: 192.168.1.23:6668
{"devId":"55142707bcddc295f96a","dps":{"1":false,"2":false,"9":0,"10":0,"18":0,"19":0,"20":2274,"21":1,"22":609,"23":27297,"24":15519,"25":1340}}
\xbc\x04\xac\xb9\x00\x00\xaaU'
2019-09-24 13:09:57.945 (Tuya - Gauche) Updating device from 0:'Off' to have values 0:'27.297'.
2019-09-24 13:09:57.950 (Tuya - Tuya SmartPlug (A)) Updating device from 0:'27.297' to have values 0:'1551.9;0'.
2019-09-24 13:09:57.953 (Tuya - Tuya SmartPlug (kWh)) Updating device from 0:'1551.9;0' to have values 0:'134.0'.
2019-09-24 13:09:57.955 (Tuya - Tuya SmartPlug (V)) Updating device from 0:'134.0' to have values 0:'1551.9'.
2019-09-24 13:09:57.957 (Tuya) Updated: 27.297 Ampere Key is:2
2019-09-24 13:09:57.957 (Tuya) Updated: 1551.9 Watt Key is:13
2019-09-24 13:09:57.958 (Tuya) Updated: 134.0 Voltage Key is:14
2019-09-24 13:09:57.958 (Tuya - Gauche) Updating device from 0:'27.297' to have values 0:'Off'.
2019-09-24 13:09:57.963 (Tuya) Update Tuya - Gauche: 0 - 'Off'
2019-09-24 13:09:57.963 (Tuya - Tuya SmartPlug (A)) Updating device from 0:'1551.9;0' to have values 0:'27.297'.
2019-09-24 13:09:57.966 (Tuya - Tuya SmartPlug (kWh)) Updating device from 0:'134.0' to have values 0:'1551.9;0'.
2019-09-24 13:09:57.969 (Tuya - Tuya SmartPlug (V)) Updating device from 0:'1551.9' to have values 0:'134.0'.
2019-09-24 13:09:57.972 (Tuya - Tuya SmartPlug (W)) Updating device from 0:'1551.9' to have values 0:'1551.9'.
2019-09-24 13:09:57.974 (Tuya) Updated: 27.297 Ampere Key is:3
2019-09-24 13:09:57.975 (Tuya) Updated: 1551.9 Watt Key is:14
2019-09-24 13:09:57.975 (Tuya) Updated: 134.0 Voltage Key is:15
When I receive the log the 2 plugs are OFF (1:False and 2: False)
I'd like to know which values I had to enter in the option ID Amp;Watt;Volt:
Currently I entered 23;24;25.
what is mean in the log theses lines
And Last point as the plus are OFF the consumption could be 0 ?
I can't understand how to read theses information.
xavierlp
I finally set up 18;19;20 . It's seem okxavierlp wrote: Tuesday 24 September 2019 13:21 Hello all
deennoo
You Can get it on Update Checkxavierlp wrote:Hello @deennoo
I am using OxaOxe
https://www.amazon.fr/gp/product/B07G2J ... le_o02_s00
I could red your post on github. For my side I don't know how to check the version of tuya.
thanks
According to some issue on Tuya-CLI GitHub
FW using >1.1.x use tuya 3.3
Envoyé de mon MI 9 en utilisant Tapatalk
http://domo-attitude.fr
tobydeteckel
- Domoticz version: V12461
I got the "Action" Tuya switches with 3.3 HTTPS working with node-red. 2 way MQTT communication.
I wil post the FLOW tonight here, including the used software.
Friendly greetings,
Thijs
Friendly greetings,
Thijs
tobydeteckel
Cant wait
It is for the single socket switches without power readings
The Node-red flow:
Made use of the "node-red-contrib-tuya-local" package/node
Hopefully somebody can use it, feel free to ask questions or improve the code.
The Node-red flow:
[{"id":"72059e25.d0bc8","type":"tab","label":"Powerplug Monitor","disabled":false,"info":""},{"id":"40e9230e.47f2bc","type":"tuya-local","z":"72059e25.d0bc8","devName":"socket1","devIp":"192.168.0.13","devId":"70116356840d8e5c","devKey":"d89c9a46c82c","protocolVer":"3.3","renameSchema":"","filterCB":"","x":540,"y":380,"wires":[["c2f44da8.5bff1","c1117431.dc1ee8","17a73342.cca49d"]]},{"id":"65260fd2.0df5b","type":"mqtt out","z":"72059e25.d0bc8","name":"","topic":"domoticz/in","qos":"2","retain":"","broker":"45e510fc.ec136","x":1330,"y":380,"wires":[]},{"id":"8cd37074.96bd5","type":"template","z":"72059e25.d0bc8","name":"Switch on","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{\"command\": \"switchlight\", \"idx\": 272, \"switchcmd\": \"On\" }","output":"str","x":1140,"y":300,"wires":[["65260fd2.0df5b"]]},{"id":"bb387b2c.3fa1b8","type":"template","z":"72059e25.d0bc8","name":"Switch Off","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{\"command\": \"switchlight\", \"idx\": 272, \"switchcmd\": \"Off\" }","output":"str","x":1130,"y":460,"wires":[["65260fd2.0df5b"]]},{"id":"37ddec6.91e9314","type":"mqtt in","z":"72059e25.d0bc8","name":"","topic":"domoticz/out","qos":"2","datatype":"auto","broker":"45e510fc.ec136","x":90,"y":380,"wires":[["2564e2dc.ae170e","3f31cc83.02a464"]]},{"id":"2564e2dc.ae170e","type":"switch","z":"72059e25.d0bc8","name":"IDX","property":"payload","propertyType":"msg","rules":[{"t":"cont","v":"\"idx\" : 272,","vt":"str"}],"checkall":"true","repair":true,"outputs":1,"x":250,"y":300,"wires":[["33fa47de.f8f908"]]},{"id":"ed5e5819.23c408","type":"change","z":"72059e25.d0bc8","name":"On","rules":[{"t":"set","p":"payload","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":490,"y":300,"wires":[["40e9230e.47f2bc"]]},{"id":"3f31cc83.02a464","type":"switch","z":"72059e25.d0bc8","name":"IDX","property":"payload","propertyType":"msg","rules":[{"t":"cont","v":"\"idx\" : 272,","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":250,"y":460,"wires":[["f3b3f4a1.206778"]]},{"id":"65e72386.bddc1c","type":"change","z":"72059e25.d0bc8","name":"Off","rules":[{"t":"set","p":"payload","pt":"msg","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":490,"y":460,"wires":[["40e9230e.47f2bc"]]},{"id":"17a73342.cca49d","type":"switch","z":"72059e25.d0bc8","name":"false","property":"payload.dps[\"1\"]","propertyType":"msg","rules":[{"t":"cont","v":"false","vt":"str"}],"checkall":"true","repair":true,"outputs":1,"x":690,"y":380,"wires":[["f9573301.de463"]]},{"id":"33fa47de.f8f908","type":"switch","z":"72059e25.d0bc8","name":"state","property":"payload","propertyType":"msg","rules":[{"t":"cont","v":"\"nvalue\" : 1,","vt":"str"}],"checkall":"true","repair":true,"outputs":1,"x":370,"y":300,"wires":[["ed5e5819.23c408"]]},{"id":"f3b3f4a1.206778","type":"switch","z":"72059e25.d0bc8","name":"state","property":"payload","propertyType":"msg","rules":[{"t":"cont","v":"\"nvalue\" : 0,","vt":"str"}],"checkall":"true","repair":true,"outputs":1,"x":370,"y":460,"wires":[["65e72386.bddc1c"]]},{"id":"56a59c77.4a3e94","type":"http request","z":"72059e25.d0bc8","name":"","method":"GET","ret":"txt","paytoqs":false,"url":"http://192.168.0.101:8080/json.htm?type=devices&rid=272","tls":"","proxy":"","authType":"","x":830,"y":300,"wires":[["742a43b9.a5cf0c"]]},{"id":"742a43b9.a5cf0c","type":"switch","z":"72059e25.d0bc8","name":"","property":"payload","propertyType":"msg","rules":[{"t":"cont","v":"\"Status\" : \"Off\",","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":970,"y":300,"wires":[["8cd37074.96bd5"]]},{"id":"c1117431.dc1ee8","type":"switch","z":"72059e25.d0bc8","name":"true","property":"payload.dps[\"1\"]","propertyType":"msg","rules":[{"t":"cont","v":"true","vt":"str"}],"checkall":"true","repair":true,"outputs":1,"x":690,"y":300,"wires":[["56a59c77.4a3e94"]]},{"id":"f9573301.de463","type":"http request","z":"72059e25.d0bc8","name":"","method":"GET","ret":"txt","paytoqs":false,"url":"http://192.168.0.101:8080/json.htm?type=devices&rid=272","tls":"","proxy":"","authType":"","x":830,"y":380,"wires":[["587097d0.84f748"]]},{"id":"587097d0.84f748","type":"switch","z":"72059e25.d0bc8","name":"","property":"payload","propertyType":"msg","rules":[{"t":"cont","v":"\"Status\" : \"On\",","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":970,"y":380,"wires":[["bb387b2c.3fa1b8"]]},{"id":"c2f44da8.5bff1","type":"switch","z":"72059e25.d0bc8","name":"If offline switch off","property":"payload","propertyType":"msg","rules":[{"t":"cont","v":"undefined","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":730,"y":460,"wires":[["bb387b2c.3fa1b8"]]},{"id":"deca8f10.6b47","type":"comment","z":"72059e25.d0bc8","name":"If plug =On and switch =Off","info":"","x":828,"y":268,"wires":[]},{"id":"98791087.6a4a7","type":"comment","z":"72059e25.d0bc8","name":"If plug =Off and switch =On","info":"","x":830,"y":412,"wires":[]},{"id":"9bdccb66.88a618","type":"comment","z":"72059e25.d0bc8","name":"EDIT IDX SWITCH","info":"Edit the value to the IDX of the vitual dummy switch","x":290,"y":428,"wires":[]},{"id":"e4ec1f53.602ea","type":"comment","z":"72059e25.d0bc8","name":"EDIT IDX SWITCH","info":"Edit the value to the IDX of the vitual dummy switch","x":850,"y":326,"wires":[]},{"id":"f1951bec.707e48","type":"comment","z":"72059e25.d0bc8","name":"Search state switch and turn Off Plug","info":"","x":390,"y":491,"wires":[]},{"id":"14ce4ac6.bcbda5","type":"comment","z":"72059e25.d0bc8","name":"EDIT IDX SWITCH","info":"Edit the value to the IDX of the vitual dummy switch","x":290,"y":331,"wires":[]},{"id":"a8f6899a.73f3d8","type":"comment","z":"72059e25.d0bc8","name":"EDIT IDX SWITCH","info":"Edit the value to the IDX of the vitual dummy switch","x":850,"y":354,"wires":[]},{"id":"195c6fa4.207bc","type":"comment","z":"72059e25.d0bc8","name":"Search state switch and turn On Plug","info":"","x":392.6666564941406,"y":268.6666564941406,"wires":[]},{"id":"27d701e7.d6333e","type":"comment","z":"72059e25.d0bc8","name":"EDIT IDX SWITCH","info":"Edit the value to the IDX of the vitual dummy switch","x":1170,"y":270,"wires":[]},{"id":"f387f745.07cc48","type":"comment","z":"72059e25.d0bc8","name":"EDIT IDX SWITCH","info":"Edit the value to the IDX of the vitual dummy switch","x":1152,"y":491,"wires":[]},{"id":"b09785c8.055198","type":"inject","z":"72059e25.d0bc8","name":"connect","topic":"connect","payload":"connect","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":330,"y":365,"wires":[["40e9230e.47f2bc"]]},{"id":"c5aea957.053908","type":"inject","z":"72059e25.d0bc8","name":"disconnect","topic":"disconnect","payload":"disconnect","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":320,"y":394,"wires":[["40e9230e.47f2bc"]]},{"id":"45e510fc.ec136","type":"mqtt-broker","z":"","name":"","broker":"","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""}]Hopefully somebody can use it, feel free to ask questions or improve the code.
