Aurora theme
olinek2
Re: Aurora theme
Post by olinek2 »
Do you have any idea why Utility sections and Switches looks like this?
blauwebuis
Domoticz version: current
Re: Aurora theme
Post by blauwebuis »
@Xztraz: thanks!
@Olinek2: I have no idea. Have you cleared your application cache? tried different browsers? What device are you on?
UPDATE
BUGFIX
I've added a fix for the RGBW popup, which was recently changed in Domoticz.
NEW FEATURE
If the value of a text item is a URL, then the theme will automatically turn it into an iframe. This allows you to incorporate external sources into your dashboard, like weather and news feeds.
To try it:
- Create a dummy text item.
- On the Utilities page, click on the text and input a URL.
- Go to the dashboard and enjoy your iFrame.
Xztraz
Re: Aurora theme
Post by Xztraz »
iframe. where do you enter the url? as the name of the device, description or as the data?
remb0
Re: Aurora theme
Post by remb0 »
blauwebuis great work! I gonna test the iframes!
blauwebuis
Re: Aurora theme
@Xztraz: click on the text. Just try it, you'll find it.
bdormael
Aurora theme
Post by bdormael »
Just a suggestion:
Would it be possible to have the highlighted items to be independent from the columns?
For example I want my cameras to show in the most right columns, now this is not possible because it is only showing utilities.
Verzonden vanaf mijn iPad met Tapatalk
Xztraz
Re: Aurora theme
Post by Xztraz »
blauwebuis wrote: Saturday 24 February 2018 9:03 @Xztraz: click on the text. Just try it, you'll find it.
i guess its the hello world text? do you have an example of some site that should work in iframe? tried all different fields but only get an icon :D
bdormael
Re: Aurora theme
Post by bdormael »
Xztraz wrote: Saturday 24 February 2018 11:04
https://w.bookcdn.com/weather/picture/1 ... c_id=14924
Xztraz
Re: Aurora theme
Post by Xztraz »
This works: (adress in data field)
Awesome!
blauwebuis
Re: Aurora theme
@bdormael: the items position and and order is linked to their containers/type. Technically it would be possible to 'fish out' some items and store their ID in a user variable. And then always load these items into the special "highlighted" container when the page is built. Not a bad idea. But in a way you're then creating a system where you can make favourites inside your favourites :-)
hsvt
Re: Aurora theme
Post by hsvt »
First, thank for the beautiful project.
After some time domoticz picked up again and then his change. :D
My IP webcam (old phone) also works in the Iframe way.
Now only find out how I can adjust the resolution of this with the url.
rhendriks
Domoticz version: Newest
Re: Aurora theme
Post by rhendriks »
@ blauwe buis compliments for this theme.
Is it possible to make an update button in the menu for an update from the aurora-theme ,
instead of the git pull rule in putty.
Xztraz
Re: Aurora theme
Post by Xztraz »
workaround for update if you are that lazy :)
make a shell script under scripts/update_aurora.sh
fill it with(this is for rpi):
#!/bin/sh
cd /home/pi/domoticz/www/styles/aurora
git pull
chmod +x
call script from dummy button.
script://update_aurora.sh
Eoreh
Re: Aurora theme
Post by Eoreh »
Domoticz Version: 3.8946
I update today to this version beta domoticz, and we lost button "Theme" in settings.
I also check in new version Aurora the same problem.
Of course i clear all cache.
EDIT: becouse jquery in domoticz upgrade to ->jquery-3.3.1.min.js
and from version jquery 3.0 .andSelf() removed, and we have to use .addBack() in line 1951 in custom.js
Xztraz
Re: Aurora theme
Post by Xztraz »
tested replacing what you said. seem to work. and made a pull request
Xztraz
Re: Aurora theme
Post by Xztraz »
Should be fixed now. please test
Also added more viz for more sensors(even more coming)
Xztraz
Re: Aurora theme
Post by Xztraz »
fixed viz for negative temps (on pull request now)
blauwebuis
Re: Aurora theme
Merged. Thanks for the great contribution!
UPDATE
- Theme settings button is back.
- More devices and sensor types now support data visualization on the dashboard.
- Negative temperatures are now also shown in these visualizations.
Last edited by blauwebuis on Monday 26 February 2018 9:22, edited 1 time in total.
Xztraz
Re: Aurora theme
Post by Xztraz »
I do what i can :) thanks for a great theme!
Added the last of viz sensors. phu. takes 6 datapoints before any viz shows. can be good to know
olinek2
Re: Aurora theme
Post by olinek2 »
Update of Domoticz and plugin has solved issue :)
