Page 15 of 49
Re: Dashticz - Module - Garbage collector
Posted: Monday 04 September 2017 19:48
by geertvercamer
here in Belgium we have an optional (= pay extra) service for the collection of waste from the garden (grass, leaves, ...). Would it be possible to define an extra 'garbage'? I could use a calendar, but a green 'klikko' would be nice.
Thanks.
Example: https://wedevise.nl/dashticz/ical/demo/ ... /basic.ics
Thanks.
Posted: Tuesday 05 September 2017 21:05
by robgeerts
Indeed, sorry, tried anotherway (it posts its data to a specific url) but they dont accept that...
Posted: Sunday 17 September 2017 11:59
by jjnj
I'm still having issues with the module saying "Loading''
My config:
config['garbage_company'] = 'afvalwijzer';
config['garbage_zipcode'] = '170Xxx';
config['garbage_street'] = 0;
config['garbage_housenumber'] = '1';
I'm now running the latest beta
Posted: Wednesday 20 September 2017 10:56
by marxkemp
Mozart wrote: Monday 31 July 2017 8:22 I found out how to get the JSON output from http://www.rova.nl. I use the following to get the info:
curl -v --cookie "RovaLc_inwoners={\"Id\":160266,\"ZipCode\":\"7731ZT\",\"HouseNumber\":\"84\",\"HouseAddition\":null,\"Municipality\":\"Ommen\",\"Province\":null,\"Firstname\":null,\"Lastname\":null,\"UserAgent\":\"\",\"School\":null,\"Street\":null,\"Country\":null,\"Portal\":null,\"AreaLevel\":5,\"City\":\"Ommen\",\"Ip\":null}" https://www.rova.nl/api/TrashCalendar/GetCalendarItems?portal=inwoners
The output looks like this:
*   Trying 141.138.194.225...
* Connected to www.rova.nl (141.138.194.225) port 443 (#0)
* found 173 certificates in /etc/ssl/certs/ca-certificates.crt
* found 696 certificates in /etc/ssl/certs
* ALPN, offering http/1.1
* SSL connection using TLS1.2 / ECDHE_RSA_AES_256_CBC_SHA384
*        server certificate verification OK
*        server certificate status verification SKIPPED
*        common name: www.rova.nl (matched)
*        server certificate expiration date OK
*        server certificate activation date OK
*        certificate public key: RSA
*        certificate version: #3
*        subject: CN=www.rova.nl
*        start date: Tue, 23 May 2017 06:01:00 GMT
*        expire date: Mon, 21 Aug 2017 06:01:00 GMT
*        issuer: C=US,O=Let's Encrypt,CN=Let's Encrypt Authority X3
*        compression: NULL
* ALPN, server did not agree to a protocol
> GET /api/TrashCalendar/GetCalendarItems?portal=inwoners HTTP/1.1
> Host: www.rova.nl
> User-Agent: curl/7.47.0
> Accept: */*
> Cookie: RovaLc_inwoners={"Id":160266,"ZipCode":"7731ZT","HouseNumber":"84","HouseAddition":null,"Municipality":"Ommen","Province":null,"Firstname":null,"Lastname":null,"UserAgent":"","School":null,"Street":null,"Country":null,"Portal":null,"AreaLevel":5,"City":"Ommen","Ip":null}
< HTTP/1.1 200 OK
< Cache-Control: no-cache
< Pragma: no-cache
< Content-Type: application/json; charset=utf-8
< Expires: -1
< Server: Microsoft-IIS/8.5
< X-AspNet-Version: 4.0.30319
< X-Powered-By: ASP.NET
< Date: Mon, 31 Jul 2017 06:20:40 GMT
< Content-Length: 279
* Connection #0 to host www.rova.nl left intact
[{"GarbageTypeCode":"GFT","GarbageType":"GFT","Date":"2017-08-04T00:00:00","Regular":true},{"GarbageTypeCode":"GFT","GarbageType":"GFT","Date":"2017-08-18T00:00:00","Regular":true},{"GarbageTypeCode":"PLASTICPLUS","GarbageType":"PMD","Date":"2017-08-25T00:00:00","Regular":true}]
Can you integrate this into the code?
Could this be added? Couldn't find a reply on this post.
Posted: Sunday 01 October 2017 12:52
by robgeerts
jjnj wrote: Sunday 17 September 2017 11:59 I'm still having issues with the module saying "Loading''
My config:
Whats your full zipcode?
Posted: Sunday 01 October 2017 12:53
by robgeerts
*        compression: NULL
> Host: www.rova.nl
> Accept: */*
< HTTP/1.1 200 OK
< Pragma: no-cache
< Expires: -1
Ok, but how did you get the id (160266) ?
Posted: Thursday 05 October 2017 18:52
by Derik
m,mm Did use for a long time no dashticz..
Now i give it a [ new ] try...
Grrrr connot get it to work...
I use:
config['garbage_company'] 		= 'Mijn Afval Wijzer';
config['garbage_icalurl'] 		= 0;
config['garbage_zipcode']		= '6466AW';
config['garbage_street'] 		= 'startweg';
config['garbage_housenumber'] 		= '12';
config['garbage_maxitems'] 		= '6';
config['garbage_width'] 		= '6';
config['garbage_hideicon'] 		= 0;
var trashnames = {}
trashnames['Restafval'] 		= 'Grijze';
trashnames['Grofvuil'] 			= 'Groot';
trashnames['Papier'] 			= 'Papier';
trashnames['Gft'] 			= 'GFT-Folie';
trashnames['Tuinafval'] 		= 'Takken';
var trashcolors = {}
trashcolors['Restafval'] 		= 'White';
trashcolors['Grofvuil'] 		= 'Grey'
trashcolors['Papier'] 			= 'Blue'
trashcolors['Gft'] 			= 'Red';
trashcolors['Tuinafval'] 		= 'Green';
Is this code correct?
Posted: Thursday 05 October 2017 19:01
by Derik
I use:
var trashnames = {}
Posted: Friday 06 October 2017 12:28
by robgeerts
You mis a lot of config[] ?
Or do you mean the trash isnt working but the rest is?
Posted: Friday 06 October 2017 12:30
by Derik
The rest is oké
This is my part of garbage.
Posted: Friday 06 October 2017 17:50
by Derik
mmm
Found it:
Must be:
config['garbage_company'] 		= 'mijnafvalwijzer';
Perhaps change this in the wiki?
Posted: Sunday 15 October 2017 21:42
by Musje
robgeerts wrote: Sunday 01 October 2017 12:53
*        compression: NULL
> Host: www.rova.nl
> Accept: */*
< HTTP/1.1 200 OK
< Pragma: no-cache
< Expires: -1
Hi Rob,
Don't know if it's helpfull ;)
I think the ID(160266) is a number from the ROVA-pas. This is a card that belongs to the adres/house and can be used for the underground containers.
i've got one myself too.
Posted: Wednesday 18 October 2017 19:48
by curious
Is it possible to add information from https://www.zuidhorn.nl/inwoners/afvalkalender_3712/
Like this module very much
Edit : found that the data can be retrieved from https://afvalkalender.zuidhorn.nl/nc/af ... 70824.html too
Posted: Sunday 22 October 2017 12:03
by curious
I was able to load an ics-file but when I try to use it, I still get the 'loading' message
I put the file in a public part of my google drive and I tried to use link to my own domain.
Does it have to be connected to a calendar-program ?
I use this ical _url : 'https://drive.google.com/drive/folders/ ... 04SC-4.ics'
Posted: Tuesday 24 October 2017 12:54
by htilburgs
@Rob, currently I'm testing with a Surface RT with Internet Explorer 11 and the latest (beta) version of Dashticz.
Everything works fine, except for the Garbage Module. In 99% of cases I get the messge "Loading...." and nothing else.
I don't think it has anything to do with Safari, Google or IE, because on other systems I've got the same issue.
How can I find out what is going on?
My settings:
config['garbage_company'] = 'cure';
 // Garbage - Advanced Settings
var _DO_NOT_USE_COLORED_TRASHCAN 	= true;
var trashcan = {}
var trashnames = {}
trashnames['Pmd bennekel blaarthem'] = 'PMD';
trashnames['Papier en karton'] = 'PAPIER';
trashnames['Gft'] = 'GFT'
columns[3] = {}
columns[3]['blocks'] = ['clock', buttons.moon, 211, 208, 'sunrise','currentweather_big','blocktitle_8',178, 'garbage']
columns[3]['width'] = 2;
I've tried to look for a way to test it manualy, but can't seem to find the correct url in garbage.js.
https://cors-anywhere.herokuapp.com/htt ... usenumber/ gives an application error (replace postalcode-housenumber with the correct information).
EDIT:
When I change garbage.js (line 170 and 171) from:
		$.getJSON('https://cors-anywhere.herokuapp.com/'+baseURL + '/rest/adressen/' + postcode + '-' + homenumber,function(data){
			$.getJSON('https://cors-anywhere.herokuapp.com/'+baseURL + '/rest/adressen/'+data[0].bagId+'/afvalstromen',function(data){
to:
		$.getJSON(baseURL + '/rest/adressen/' + postcode + '-' + homenumber,function(data){
			$.getJSON(baseURL + '/rest/adressen/'+data[0].bagId+'/afvalstromen',function(data){
everything works fine. So it lookes like the problem is in the https://cors-anywhere.herokuapp.com.
Can you do anything with this information?
Posted: Thursday 26 October 2017 15:53
by robgeerts
curious wrote: Wednesday 18 October 2017 19:48 Is it possible to add information from https://www.zuidhorn.nl/inwoners/afvalkalender_3712/
Gives me an error?
curious wrote: Sunday 22 October 2017 12:03 I was able to load an ics-file but when I try to use it, I still get the 'loading' message
You should put the ical on your own domain..
Posted: Thursday 26 October 2017 15:54
by robgeerts
htilburgs wrote: Tuesday 24 October 2017 12:54 @Rob, currently I'm testing with a Surface RT with Internet Explorer 11 and the latest (beta) version of Dashticz.
My settings:
var trashcan = {}
var trashnames = {}
columns[3] = {}
EDIT:
to:
Weird, If I remove the cors-anywhere, I get an error at my Dashticz, so for me, removing is not an option..
Posted: Thursday 26 October 2017 21:25
by curious
When I make the ics-file accessible form my own domain, and I use the url in a webbrowser it wants to download the file.
In dashticz the "loading"-message stays.
Posted: Thursday 26 October 2017 22:08
by robgeerts
Could you PM me the url to your ics-file?
(Dont worry, I dont care about the actual events ;)
Posted: Monday 30 October 2017 13:06
by Gerald
Musje wrote: Sunday 15 October 2017 21:42
*        compression: NULL
> Host: www.rova.nl
> Accept: */*
< HTTP/1.1 200 OK
< Pragma: no-cache
< Expires: -1
Hi Rob,
Hi Rob,
Can you please integrate this? Or let me know how to use the output of the JSON command in Dashticz?
As Rova is the company who collects our wast as well, and it will make my life much easier if I can use this on my home control tablet :)
