Page 15 of 32
Re: Domoboard a New Dashboard using Domoticz as backend
Posted: Thursday 12 January 2017 21:37
by blackdog65
dutchdevil83 wrote:@blackdog65
Can you try following link in your browser if jou get Json result back? (Fill in your API key)
http://api.wunderground.com/api/api_key ... sbech.json
Yes that works...I must either have the syntax wrong or a broken plugin
Posted: Thursday 12 January 2017 21:39
by dutchdevil83
wez3 wrote:
dutchdevil83 wrote:
felix63 wrote:
I think my icons have disappeared from the top tiles. are you running development or master? It might be a bug?
i`m on develop. Trying to debug in chrome inspector but can`t get it to fix.
This one should be fixed:
https://github.com/wez3/domoboard/issues/71
Thnx for quick fix, iT is working now
Posted: Thursday 12 January 2017 21:42
by dutchdevil83
You can try Chrome inspection tool if you can discover which part does not load
Posted: Thursday 12 January 2017 21:59
by Awst6000
In which directory do I have to unzip the plugins?
I can't remember ever having seen entries in Settings - Plugins.
Posted: Thursday 12 January 2017 22:12
by bsmeding
I don't get the 'afvalwijzer' form working
When I add this to the config :
 [[afvalwijzer]]
  zipcode = Thuis, 1234AA, 1
I get error : Error: Zipcode not found and see this URL is hitting in the log:
192.168.111.141 - - [12/Jan/2017 22:08:25] "POST /api?custom=afvalwijzer&zipcode=1234AA&housenr=1 HTTP/1.1" 200 -
That looks correct, but give me an error
If i remove the word 'Thuis' is see the log that the house number is parsed as zipcode and housenr is empty
Posted: Thursday 12 January 2017 22:17
by Awst6000
bsmeding wrote:I don't get the 'afvalwijzer' form working
Same issue here.
Please check if the info is available at www.afvalwijzer.nl
(In my case nothing returns)
Posted: Thursday 12 January 2017 22:25
by squandor
dutchdevil83 wrote:
Sateetje wrote:
dutchdevil83 wrote:
Do you have a adblocker installed or something? Can you look into your page with multiple devices/browsers ?
No, no adblocker installed and on different browsers almost the same result (on IOS i've an icon at Plastic verpakkingen).
Mmm strange... you can check with Chrome Inspector tool for errors when loading the page. In Chrome press (CTRL+SHIFT+J) and check preserve log to follow loading trail. Also could be that you are missing some files in the afvalwijzer plug-in folder. You can try to copy the folder from github...
It could if afvalwijzer uses different classes on different zipcodes... i created the script that it will copy the category class from afvalwijzer so it will now which icon it must use. But if it uses different html and css tags on different zipcodes it is almost impossible to create an front which will work on all zipcodes.. :(
Posted: Thursday 12 January 2017 22:52
by Awst6000
dutchdevil83 wrote: If you update domoboard to latest version it now looks at the order you`re items are listed in the config file. It will take that order. Also you can make your top_tiles ordered with titles :
components = top_tiles[1], top_tiles[2], top_tiles[3]
[[top_tiles]]
[[[1]]]
example = 1
[[[2]]]
example = 2
[[[3]]]
example = 3
Coding this way does give three subsections in the top_titles.
But in my case the items do not appear in the way they are listed in the configfile.
(Full fresh install of Domoboard)
Although it looks like I keep on complaining? Almost everything works now and it looks great.
Many thanks! Have a beer on me ;)
Posted: Thursday 12 January 2017 23:28
by jhenrikb
after installing Traffic and afvalwijzer plugin, when relaunching domoboard i get first error:
"Error occured during loading imports for the plugin "X": No module named BeautifulSoup
then I delete afval.. same error message pop up for "anwb" : No module name natsort.
It tried git pull in both main and plugins folder without succcess, so I just have to delete them to start domoboard.
Posted: Friday 13 January 2017 5:42
by dutchdevil83
jhenrikb wrote:after installing Traffic and afvalwijzer plugin, when relaunching domoboard i get first error:
Then you need to install BeautifulSoup and Natsort. Try this:
pip install naturalsort
pip install beautifulsoup4
Posted: Friday 13 January 2017 10:06
by squandor
dutchdevil83 wrote:Still work in progress but i`m getting there :D
Showoff 2/3
Hi Dutchdevil83,
I saw in you're images that you have an dimmer/slider for volume, is that an virtual switch? :) i am searching for a way to control my mpd server's volume. I can do it with my python scripts but an slider is obviously more easy to use for my wife ;)
Posted: Friday 13 January 2017 10:12
by dutchdevil83
squandor wrote:
Hi Dutchdevil83,
Yep, made a dummy switch which controls my denon receiver over ip. Also pulls out data out of my denon (json) and update the volume slider when it differs, which happens if the volume has been changed manually. All put in a LUA script.
Posted: Friday 13 January 2017 10:26
by squandor
dutchdevil83 wrote:
squandor wrote:
Hi Dutchdevil83,
How did you manage that there will be fired an program when the dimmer slide changes?
the switches has an on off action but with an dimmer i can't figure out how to do that
Posted: Friday 13 January 2017 10:33
by dutchdevil83
squandor wrote: How did you manage that there will be fired an program when the dimmer slide changes?
Here the piece of code out of my lua script that controls my receiver
if devicechanged[RECEIVER_VOLUME] then -- MUTE and VOLUME
    if (otherdevices[RECEIVER_VOLUME] == "Off") then
        os.execute ("curl http://" .. (DENON_IP) .. "/MainZone/index.put.asp?cmd0=PutVolumeMute%2Fon");
        print ("Device:" .. RECEIVER_VOLUME .. " send command Mute = On");
        NewLevel = otherdevices_svalues[RECEIVER_VOLUME] - 80 ; -- Apply offset from absolute to relative
        NewLevel = math.min(NewLevel, 9.5); -- Top Domoticz Scale
        os.execute ("curl http://" .. (DENON_IP) .. "/MainZone/index.put.asp?cmd0=PutVolumeMute%2Foff");
        os.execute ("curl http://" .. (DENON_IP) .. "/MainZone/index.put.asp?cmd0=PutMasterVolumeSet/" .. (NewLevel));
        print ("Device:" .. RECEIVER_VOLUME .. " send command Mute = Off; Set Volume = " .. NewLevel);
Basically the script gets triggered when the switch is used in domoticz " if devicechanged['Name of Dimmer'] then " if it turns to "Off" then its muting my receiver. Otherwise it gets the value from the dimmer " otherdevices_svalues['Name of Dimmer'] " and set that level to the receiver. (after doing some mathematical things to get the value correct for my receiver)
Posted: Friday 13 January 2017 10:38
by squandor
Great thank you i will try to put it into action with my mpd server :)
Posted: Friday 13 January 2017 10:42
by fergalom
Showoff 2/3
Hi Dutchdevil83,
Similar to you, also use MPD with airplay speakers, heres an extract from my script for volume using a dummy dimmer
-----Volume
if (devicechanged['Radio Volume']) then
        v = otherdevices_svalues['Radio Volume']
        os.execute('mpc volume ' ..v)
        print("radio volume " ..v)
Posted: Friday 13 January 2017 11:33
by squandor
fergalom wrote:
Showoff 2/3
Hi Dutchdevil83,
-----Volume
Jep fixed it to. but my mpd server is on an other raspberry.
this is my final lua code and it works like a charm thank you guys :)
Volume = 'Volume';
if devicechanged[Volume] then -- MUTE and VOLUME
    if (otherdevices[Volume] == "Off") then
        os.execute ("python /home/pi/domoticz/scripts/SetVolumeMPD.py 0");
        print ("Device:" .. Volume .. " send command Mute = On");
        NewLevel = otherdevices_svalues[Volume] ; -- Apply offset from absolute to relative
        os.execute ("python /home/pi/domoticz/scripts/SetVolumeMPD.py " .. (NewLevel));
        print ("Device:" .. Volume .. " send command Mute = Off; Set Volume = " .. NewLevel);
Posted: Friday 13 January 2017 11:36
by squandor
fergalom wrote:
Showoff 2/3
Hi Dutchdevil83,
-----Volume
i also managed with an python script to check if there are new airplay speakers in the mpd server it will add them to domoticz with an on/off action already filled in to activate them :) so if you're interested :)
Posted: Friday 13 January 2017 11:45
by fergalom
@squandor Definitely interested in seeing that. :-)
Posted: Friday 13 January 2017 13:16
by Snowtiger
I am on Development branche trying to get Wunderground to work.
In conf
[weer]
[[display_components]]
components = wunderground[condition], wunderground[forecast]
[[wunderground]]
[[[condition]]]
location = Lelystad
[[[forecast]]]
location = Lelystad
Results in no weather displayed - in log :
"POST /api?custom=wunderground&loc=condition&country=&action=Lelystad HTTP/1.1" 200 -
"POST /api?custom=wunderground&loc=forecast&country=&action=Lelystad HTTP/1.1" 200 -
Mismatch of arguments into api call??
