Pass2PHP
Egregius
Domoticz version: v2024.7
Re: LUA Pass2php
Post by Egregius »
I don't know what to say. My lua starts 3msecs after the line of a pir (for ex).
The whole thing is done in 19/20 msecs.
sincze
Domoticz version: 2024.4
Re: RE: Re: LUA Pass2php
Post by sincze »
Egregius wrote:I don't know what to say. My lua starts 3msecs after the line of a pir (for ex).
I Cleared up all unused devices. Idx currently at 1030. Hopefully the database is okay :).
Maybe delete disabled events as well. Really don't know
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
sincze
Re: LUA Pass2php
Post by sincze »
I did the following: copy db to spare machine and removed all disabled db events.
2017-01-09 18:57:39.456 User: Admin initiated a switch command (621/ZonweringAuto/On)
2017-01-09 18:57:39.483 LUA: 1. Encoding started at time: 4.21
2017-01-09 18:57:39.486 LUA: 2. Encoding finished at time: 4.21
2017-01-09 18:57:39.497 LUA: 3. Curl finished at time: 4.21
Now.... i disabled several hardware devices in domoticz:
2017-01-09 19:10:24.503 User: Admin initiated a switch command (621/ZonweringAuto/On)
2017-01-09 19:10:24.510 LUA: 1. Encoding started at time: 2.30
2017-01-09 19:10:24.512 LUA: 2. Encoding finished at time: 2.30
2017-01-09 19:10:24.517 LUA: 3. Curl finished at time: 2.30
And I have a speed advantage.... :D
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
sincze
Re: LUA Pass2php
Post by sincze »
mmm something wrong?? opcache should be running however this says.. it's not I think.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Egregius
Re: LUA Pass2php
Post by Egregius »
37msecs with disabled events and 27msecs without events? Strange, you would expect no such difference.
Same goes for disabled hardware. I only have dummy, rfxcom and zwave.
I think your opcode isn't enabled in one of the php.ini files, you should search in wich it's set.
sincze
Re: LUA Pass2php
Post by sincze »
Egregius wrote:37msecs with disabled events and 27msecs without events? Strange, you would expect no such difference.
You would guess it is configured okay ? Right.? my .opcache directory is populated. :D
2. Opcache.JPG (28.12 KiB) Viewed 2786 times
Strange strange strange. If we could just get the first 30ms off ;-) from switching the switch to calling the php.
That would be amazing. However don't have a clue on how to achieve this.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Egregius
Re: LUA Pass2php
Post by Egregius »
If "LUA: 1. Encoding started" is the first line of your lua script you wont get that time off, that's in Domoticz.
If that's after the loading of the cb-json thing you could benefit from my concatenate stuff as that doesn't need to load anything external.
If you then have the system so that you only require the devicechanged table the encoding should be finished in less than 1 msec after the script is triggered.
I do see a difference in your opcode settings:
Seems that your's is set to use file cache instead of memory.
These are my settings:
; configuration for php opcache module
; priority=10
zend_extension=opcache.so
[opcache]
opcache.enable = 1
opcache.enable_cli = 1
opcache.memory_consumption = 32
opcache.interned_strings_buffer = 4
opcache.max_accelerated_files = 20000
opcache.max_wasted_percentage = 5
opcache.use_cwd = 1
opcache.validate_timestamps = 0
opcache.revalidate_freq = 2
opcache.revalidate_path = 0
opcache.save_comments = 1
opcache.load_comments = 1
opcache.fast_shutdown = 0
opcache.enable_file_override = 0
opcache.optimization_level = "0xffffffff"
opcache.inherited_hack = 1
opcache.dups_fix = 0
opcache.blacklist_filename = /dontcache.txt
opcache.max_file_size = 0
opcache.consistency_checks = 0
opcache.force_restart_timeout = 180
opcache.error_log =
opcache.log_verbosity_level = 1
opcache.preferred_memory_model =
opcache.protect_memory = 0
opcache.mmap_base =
opcache.restrict_api =
sincze
Re: LUA Pass2php
Post by sincze »
3. opcache.JPG (59.04 KiB) Viewed 2774 times
Damn.... missed that one..
; Enables or disables opcode caching in shared memory.
opcache.file_cache_only=0
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Egregius
Re: LUA Pass2php
Post by Egregius »
And still there's something wrong I think. You're at 0 misses and memory is at 0 bytes.
Should be like this:
On my system it was an improvement of approx 40 msec.
Or do you already see a speed improvement now?
sincze
Re: LUA Pass2php
Post by sincze »
Ah, I had to invalidate the entries... then they showed up like so.
Let me check the speed advantages ;-)
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
sincze
Re: LUA Pass2php
Post by sincze »
And the speedtest
Pretty stable at around 140-142.
We indeed loose 40ms during start :x
..	2017-01-10 20:20:12.366 User: Admin initiated a switch command (621/ZonweringAuto/On)
..	2017-01-10 20:20:12.368 (Virtual Device) Light/Switch (ZonweringAuto)
40	2017-01-10 20:20:12.406 LUA: 1. Encoding started at time: -39.29
 3	2017-01-10 20:20:12.409 LUA: 2. Encoding finished at time: -39.29
12	2017-01-10 20:20:12.421 LUA: 3. Curl finished at time: -39.28
	2017-01-10 20:20:12.486 --->> SETLEVEL 100
	2017-01-10 20:20:12.490 User: Admin initiated a switch command (531/Lamp (CV Ruimte) (RF)/Set Level)
71	2017-01-10 20:20:12.492 RFLink Sending: 10;NewKaku;ba1e09;a;15
2017-01-10 20:23:35.326 User: Admin initiated a switch command (621/ZonweringAuto/Off)
	2017-01-10 20:23:35.327 (Virtual Device) Light/Switch (ZonweringAuto)
42	2017-01-10 20:23:35.368 LUA: 1. Encoding started at time: -21.46
 3	2017-01-10 20:23:35.371 LUA: 2. Encoding finished at time: -21.45
12	2017-01-10 20:23:35.383 LUA: 3. Curl finished at time: -21.45
	2017-01-10 20:23:35.449 --->> SWITCH Off
	2017-01-10 20:23:35.452 User: Admin initiated a switch command (531/Lamp (CV Ruimte) (RF)/Off)
71	2017-01-10 20:23:35.454 RFLink Sending: 10;NewKaku;ba1e09;a;OFF
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Egregius
Re: LUA Pass2php
Post by Egregius »
Encoding started is the first line of the lua script? Before the include/require thing?
sincze
Re: LUA Pass2php
Post by sincze »
I added step 0 to show it more clearly ;-0
2017-01-10 21:52:28.134 User: Admin initiated a switch command (621/ZonweringAuto/On)
2017-01-10 21:52:28.135 (Virtual Device) Light/Switch (ZonweringAuto)
2017-01-10 21:52:28.181 LUA: 0. just before cb64json
2017-01-10 21:52:28.184 LUA: 1. encoding started
2017-01-10 21:52:28.187 LUA: 2. encoding finished
2017-01-10 21:52:28.205 LUA: 3. curl finished
2017-01-10 21:52:28.302 --->> SETLEVEL 100
2017-01-10 21:52:28.305 User: Admin initiated a switch command (531/Lamp (CV Ruimte) (RF)/Set Level)
2017-01-10 21:52:28.306 RFLink Sending: 10;NewKaku;ba1e09;a;15
And off.. just to give an overview of the log filling up
2017-01-10 21:55:20.935 User: Admin initiated a switch command (621/ZonweringAuto/Off)
2017-01-10 21:55:20.936 LUA: 1. encoding started
2017-01-10 21:55:20.949 LUA: 2. encoding finished
2017-01-10 21:55:21.009 LUA: 3. curl finished
2017-01-10 21:55:21.158 LUA: 0. just before cb64json
2017-01-10 21:55:21.187 LUA: 1. encoding started
2017-01-10 21:55:21.225 LUA: 2. encoding finished
2017-01-10 21:55:21.256 LUA: 3. curl finished
2017-01-10 21:55:21.307 LUA: 0. just before cb64json
2017-01-10 21:55:21.309 LUA: 1. encoding started
2017-01-10 21:55:21.319 LUA: 2. encoding finished
2017-01-10 21:55:21.343 LUA: 3. curl finished
2017-01-10 21:55:21.260 (Virtual Device) Light/Switch (ZonweringAuto)
2017-01-10 21:55:21.438 LUA: 0. just before cb64json
2017-01-10 21:55:21.446 LUA: 1. encoding started
2017-01-10 21:55:21.451 LUA: 2. encoding finished
2017-01-10 21:55:21.495 LUA: 3. curl finished
2017-01-10 21:55:21.591 --->> SWITCH Off
2017-01-10 21:55:21.598 User: Admin initiated a switch command (531/Lamp (CV Ruimte) (RF)/Off)
2017-01-10 21:55:21.602 RFLink Sending: 10;NewKaku;ba1e09;a;OFF
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Egregius
Re: LUA Pass2php
Post by Egregius »
Of course, only use that for debug/analyze. Otherwise disable as much as possible.
As I see it there's only 6 msecs left to gain, by replacing the json thing. Don't know what else I can say.
sincze
Post by sincze »
Egregius wrote:Of course, only use that for debug/analyze. Otherwise disable as much as possible.
So we are on our way :) nice. I will check is hardware device 'ping' maybe is causing some delay. Needs to be converted to pass2php Image
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
ropske
Domoticz version: V3_8394
Re: LUA Pass2php
Post by ropske »
Egregius: is it possible to give some information about your heating script: __verwarming.php please?
for example, what is heating and what is brander?
you are also switching for heating with a relay i believe? is this one 'heating' or 'brander' ?
like these devices below, are these real devices or are they variables?
$heating=apcu_fetch('sheating');
$weg=apcu_fetch('sweg');
$slapen=apcu_fetch('sslapen');
$brander=apcu_fetch('sbrander');
$buiten_temp=apcu_fetch('buiten_temp');
thank you!
ropske
Re: LUA Pass2php
Post by ropske »
btw, you also have some Thermostaatkraan Popp i believe? or LC13?
https://www.robbshop.nl/radiator-thermostaat-popp
how long you have them and you an idea how long the batteries are going?
I have 1 popp now (ordered for testing, and i'm feeling good with it), i'm planning to order now for all rooms.
just want some information about 'an expert' ;)
Egregius
Re: LUA Pass2php
Post by Egregius »
My heating script is quite complex :P
Also changed yesterday that all my dummy devices are now only in apcu cache. I figured why set a switch in Domoticz that just sets a cache variable? So now I only set the variable and removed my dummy hardware.
Anyway, functionnallity stays the same as they are threaded like 'normal' on/off switches.
heating=switch that defines if the whole heating system needs to be active. This is automatically on whenever we're at home. As soon as we leave the home it's set to off. 'Weg' is Dutch for 'Away', 'slapen' for 'sleeping', explains themself I guess.
The extra 'heating' switch provides the possibility to activate the heating while away, on our way home for example. Once activated it triggers the rest of the heating script. If activated for more than one hour and still not home it's switched back off.
'Brander' is the heater, the gas burner that is switched by a regular relay.
'buiten_temp' is external temperature, grabbed from wunderground.
About the Danfoss LC13: biggest disadventage is the lack of report of battery status. I use Eneloop rechargeable batteries so the battery low indicater on the valve is always on. Battery status isn't in Domoticz so I have no idea when they will be empty.
For that I created something that notifies me whenever one of the valves hasn't updated in the last hour. Unfortunally that doesn't work. Already had multiple times that the valve still connects and updates but doesn't have enough power to close the radiator, resulting in a hot radiator with a open window. I'm now thinking of placing 24V valves directly on the manifold, at least for the living room. I can't do that easy for the bedrooms as there are 2 radiotors on one pipe there. So, that's still something that needs improvement.
For now, I just replace the batteries every first weekend of the month. They are rechargeable and I have hundreds of them in the house.
I guess it's hard to say how long they'll last as that's very dependent on how you use them. I don't use them as a 'thermostatic' valve but rather as a open/close valve.
ropske
Re: LUA Pass2php
Post by ropske »
Thanks ;)
Im just thinking, instead of ordering more popp valves with batteries, i better order something like this?
http://www.popp.eu/products/actuators/flow-stop/
And place them between my pipes? Ive got pipes from every room going to my collecteur.
So livingZ and livingZZ are danfoss valves?
Im trying to understand your program so i 'convert' it to my house :D
Egregius
Re: LUA Pass2php
Post by Egregius »
Yes, everything ending with capital Z is a danfoss valve.
Don't know if those popps are good for heating pipes...
