Page 140 of 184
Re: Dashticz - Two Questions
Posted: Friday 08 September 2017 9:49
by Cletus
Bingo! Bedankt Hansie!!! :)
I changed those two to 0 and now i get my scenes and other buttons!
Much appreciated!
Posted: Saturday 09 September 2017 11:28
by PieterS
Nice interface! But There are different fontsizes between modules garbage, public transport and the newsblocks. So I like to change the size of text and format.
I looked in the Wiki and edited/saved custom.css in /volume1/@appstore/domoticz/www/dashticz/custom on my Syno.
// Change font size of public transport module
.publictransport div {
    font-size: 20px;
// Fontsize Trashcan Module
.trash .state div.trashrow {
    font-size: 20px;         // default 12px
.trash .state div.trashtoday {
    font-size: 26px;           // default 16px
.trash .state div.trashtomorrow {
    font-size: 24px;           // default 14px
I don't see any effect. Even after refreshing cache of browser. Is there need for changing any item in CONFIG.js or so? Any suggestions to solve my problem?
Posted: Sunday 10 September 2017 16:31
by PieterS
Problem solved: Syntax error because of the annotation...
// should be /* text */ :(
Posted: Sunday 17 September 2017 1:18
by Slinkos
My CONFIG.js file doesn't seem to work. When I open the Dashticz page on any device, none of the config settings are working, when I config it in the browser it does work. But only on that device off course. First time I copied the dashboard manually to my Raspberry PI, second time I did a GIT pull, but with the same results.
UPDATE: I noticed that the whole config file is made a comment by the /* and */ , removing that solved it.
Posted: Sunday 17 September 2017 10:27
by DomotRikz
Some devices have many values and produce many blocks, such as smart meters. I would like to give those blocks different titles to clarify the values. I tried that by declaring the blocks multiple times:
var blocks = {}
blocks['97_2'] = {}
blocks['97_2']['title'] = 'Verbruik vandaag';
blocks['97_2']['width'] = 6;
blocks['97_5'] = {}
blocks['97_5']['title'] = 'Teruglevering vandaag';
blocks['97_5']['width'] = 6;
var columns = {}
columns[3] = {}
columns[3]['width'] = 4;
columns[3]['blocks'] = ['97_2','97_5']
Now the correct values and titles are shown, but for some reason the block widths seem to be ignored. Is this a bug or is there another way to achieve this?
Posted: Sunday 17 September 2017 10:41
by florisi
I'm running Domoticz on Synology, latest version.
Downloaded the Dashticz master from Github.
Copied all the stuff to /volume1/web/dashticz.
Edited the CONFIG.js file with the right IP-address.
The only thing I get is a black screen.
It looks like it doesn't accept the 'var config = {}' etc.
Anyone an idea how to solve this?
I'm very very new to Domotics and Dashticz.
Posted: Sunday 17 September 2017 11:13
by EdwinK
Can you post the content of your CONFIG.js (remove personal information like API-keys)
Posted: Sunday 17 September 2017 11:20
by florisi
It is the DEFAULT_CONFIG, just changed the IP address and removed the first line (/*)
Here is my CONFIG.js:
var config = {}
config['domoticz_ip'] = 'http://xxx.xxx.x.xxx:8084';
var _DOMOTICZ_IP = 'http://192.168.1.112:8084'
var trashnames = {}
trashnames['Gft'] = 'GFT';
trashnames['Pmd'] = 'Plastic';
trashnames['Rest'] = ''; //LEAVE EMPTY IF YOU WANT TO HIDE IT
var publictransport = {}
publictransport.ovinfobus = { show_via: false, station: 'son-en-breugel/bushalte-penseelkever', provider: '9292-bus', icon: 'bus', width:5, results: 6 }
var tvguide = {}
tvguide.dutch = { key:'dutch', icon: 'fa-television', width:7, channels: [1,3,4,31,46,92], maxitems: 5 }
var _STREAMPLAYER_TRACKS = [
{"track":1,"name":"Q-music","file":"http://icecast-qmusic.cdp.triple-it.nl/ ... ive_96.mp3"},
{"track":2,"name":"538 Hitzone","file":"http://vip-icecast.538.lw.triple-it.nl/WEB11_MP3"},
{"track":3,"name":"Slam! NonStop","file":"http://stream.radiocorp.nl/web10_mp3"},
{"track":4,"name":"100%NL","file":"http://stream.100p.nl/100pctnl.mp3"},
var buttons = {}
buttons.nunl = {key: 'nunl', width:12, icon: 'fa-newspaper-o', title: 'Nu.nl', newwindow:true, url: 'http://www.nu.nl'}
buttons.nos = {key: 'nos', width:12, icon: 'fa-newspaper-o', title: 'Nos', url: 'http://www.nos.nl'}
var blocks = {}
blocks['blocktitle_1'] = {}
blocks['blocktitle_1']['key'] = 'blocktitle_1';
blocks['blocktitle_1']['title'] = 'Example';
var columns = {}
columns['bar'] = {}
columns[1] = {}
columns[1]['blocks'] = ['currentweather_big','weather','garbage']
columns[1]['width'] = 5;
columns[2] = {}
columns[2]['blocks'] = ['blocktitle_1',tvguide.dutch,publictransport.ovinfobus]
columns[2]['width'] = 5;
columns[3] = {}
columns[3]['blocks'] = ['sunrise','streamplayer',buttons.nunl,buttons.nos]
columns[3]['width'] = 2;
var columns_standby = {}
columns_standby[1] = {}
columns_standby[1]['blocks'] = ['clock','weather']
var screens = {}
screens[1] = {}
screens[1]['background'] = 'bg2.jpg';
Posted: Sunday 17 September 2017 11:42
by EdwinK
I think you also should remove the last */
Ps. Next time please use the [ code ] and [ /code ] tags (remove spaces). It makes it a bit more easy to read.
(edit: remove the last */ also, then it would work. Just tried with your CONFIG.js)
Posted: Sunday 17 September 2017 12:09
by florisi
thanks, it works
Posted: Sunday 17 September 2017 13:22
by frans1967
I have installed domoticz and dashticz on a RPI and a 5"lcd touchscreen. i open dashticz ik kiosk mode (Chromium). when i touch the dashticz screen it swipes a bit, so the viryual button not activating.
my question, is it possible to disable the swipe function at all. i want a static dashtic screen.
Frans
Posted: Sunday 17 September 2017 17:51
by EdwinK
I think if you just have one screen in CONFIG.js it wouldn't swipe.
Posted: Sunday 17 September 2017 18:12
by PieterS
ImageI would like to show the values of my solarpanels. They are logged to PVoutput. In Domoticz I got IDX 27 till 30.
IDX Omnik.PNG (13.08 KiB) Viewed 5082 times
But when i define blocks with this IDX and put them at the end of column 1
blocks[28] = {}
blocks[28]['title'] = 'Temp Omnik';
blocks[28]['width'] = 4;
blocks[29] = {}
blocks[29]['title'] = 'Voltage Omnik';
blocks[29]['width'] = 4;
blocks[30] = {}
blocks[30]['title'] = 'Opbrengst Omnik';
blocks[30]['width'] = 4;
columns[1] = {}
columns[1]['blocks'] = ['blocktitle_1',31,110,10,55,11,18,9,14,477,'blocktitle_2',377,93,512,3,28,29,30]
I get 2 empty bloks in Dashticz and only the block with Voltage shows oke.. :roll: In Domoticz no problems.. Anybody with an solution?
Posted: Sunday 17 September 2017 21:34
by Peacock
Can someone help here, I really do not know why I keep on getting a blank page. I have altered the CONFIG.js as per instructions, still no luck after a dozen retries or so... (even if I change my IP to a non existent one it keeps on getting an empty page, so I would reckon it cannot logon correctly on domoticz or something like that). Thanks for your time...
This is my CONFIG.js (I left username and password, there I fill in the ones I uses to logon to Domoticz)
var config = {}
config['domoticz_ip'] = 'http://username:[email protected]:8084';
var trashnames = {}
var tvguide = {}
	{"track":1,"name":"Q-music","file":"http://icecast-qmusic.cdp.triple-it.nl/Qmusic_nl_live_96.mp3"},
var buttons = {}
var blocks = {}
var columns = {}
columns['bar'] = {}
columns[1] = {}
columns[2] = {}
columns[3] = {}
var screens = {}
screens[1] = {}
Edit:
Even if I allow Domoticz to acces without password on local address (192.168.2.7) and I leave out the username:password bit in the CONFIG.js it only shows a blank page. Further I noticed some CONFIG files with a lot more (and different coding iso array var config = {} with var _LANGUAGE = nl_NL etc). What is the difference?
btw I use version 3.8153 Domoticz.
UPDATE: my mistake, something went wrong with copying dashticz to webfolder. Not all files had been copied.
Posted: Sunday 17 September 2017 21:36
by levynger
started to test dashticz, really liked it.
however i noticed that some dummyHW switch devices i have in my db, doesnt seems to show.
created new dummyHW, without anything - also failed to load in dashticz page.
i do have other dummyHW switch devices, mainly for mqtt messages - and they do work..
any idea?
Posted: Tuesday 19 September 2017 10:31
by Peacock
I do not seem to get the Favorites loaded into Dashticz. Can anyone help, I do see one warning in the console, see below.
Schermafbeelding 2017-09-19 om 10.26.24.jpg (113.22 KiB) Viewed 4998 times
EDIT:
When I add custom blocks with a typical switchIDx into the Config, I do get the values.
Schermafbeelding 2017-09-19 om 11.40.43.png (391.85 KiB) Viewed 4977 times
My CONFIG.js
var config = {}
config['domoticz_ip'] = 'http://192.168.2.7:8084';
config['domoticz_refresh'] = '60';
config['default_news_url'] = 'http://www.nu.nl/rss/algemeen';
config['news_scroll_after'] = '7';
config['standby_after'] = 0;
config['auto_swipe_back_to'] = 1;
config['auto_swipe_back_after'] = '10';
config['auto_slide_pages'] = 0;
config['slide_effect'] = 'slide';
config['standard_graph'] = 'hours';
config['language'] = 'nl_NL';
config['timeformat'] = 'DD-MM-YY HH:mm';
config['calendarformat'] = 'dd DD.MM HH:mm';
config['calendarlanguage'] = 'en_US';
config['calendarurl'] = 0;
config['boss_stationclock'] = 'RedBoss';
config['gm_api'] = 0;
config['gm_zoomlevel'] = 0;
config['gm_latitude'] = 0;
config['gm_longitude'] = 0;
config['wu_api'] = '48fe526bc013203b';
config['wu_city'] = 'Luttelgeest';
config['wu_name'] = 'Weer';
config['wu_country'] = 'NL';
config['idx_moonpicture'] = 0;
config['switch_horizon'] = 0;
config['host_nzbget'] = 0;
config['spot_clientid'] = 0;
config['garbage_company'] = 'hvc';
config['garbage_icalurl'] = 0;
config['garbage_zipcode'] = '8315PL';
config['garbage_street'] = 'Uiterdijkenweg';
config['garbage_housenumber'] = '13';
config['garbage_maxitems'] = '4';
config['garbage_width'] = '5';
config['selector_instead_of_buttons'] = 0;
config['auto_positioning'] = 1;
config['use_favorites'] = 1;
config['last_update'] = 1;
config['hide_topbar'] = 0;
config['hide_seconds'] = 0;
config['hide_seconds_stationclock'] = 0;
config['use_fahrenheit'] = 0;
config['use_beaufort'] = 0;
config['translate_windspeed'] = 1;
config['static_weathericons'] = 0;
config['hide_mediaplayer'] = 0;
//var _LANGUAGE 				= 'nl_NL'; //or: en_US, fr_FR, hu_HU
//var _HOST_DOMOTICZ		  	= 'http://192.168.2.7:8084';
//var _USE_AUTO_POSITIONING 	= true; //don't want to configure positions, use auto positioning
//var _USE_FAVORITES			= true; //only used when using auto positioning
var trashnames = {}
trashnames['Rest'] = 'Rest'; //LEAVE EMPTY IF YOU WANT TO HIDE IT
var tvguide = {}
var buttons = {}
var blocks = {}
var columns = {}
columns['bar'] = {}
columns[1] = {}
columns[1]['blocks'] = [36,52,'currentweather_big','weather','garbage']
columns[2] = {}
columns[3] = {}
var screens = {}
screens[1] = {}
Posted: Tuesday 19 September 2017 20:31
by Ingmar
The favourites also didn't automatically add in my dashboard, don't know why. I just manually entered everything it's not that much work anyway.
Posted: Wednesday 20 September 2017 10:35
by levynger
levynger wrote: Sunday 17 September 2017 21:36 started to test dashticz, really liked it.
any idea?
seems that i have found the solution - event if working with manual blocks and positioning in CONFIG.js, the switch must be in the favorite page in domoticz.
Posted: Wednesday 20 September 2017 10:43
by woody4165
Try to use this in CONFIG.js
var config = {}
config['use_favorites'] = 0;
Posted: Thursday 21 September 2017 12:42
by hdpop38
Hi All,
I started to use Dashticz to see devices of Domoticz. Started it's easy but something not work ( perhaps some seting was fail )
I'm able to see temperature and log of domoticz.
But I not able to see switch devices IDX=123 with this code
blocks[123] = {}
blocks[123]['icon'] = 'fa-female';
blocks[123]['title'] = 'Annie';
And another thing, I not see my favorites devices declared in domoticz
If somebody can help me...
CONFIG.js
My Config.js
(4.87 KiB) Downloaded 194 times
Domotics devices
Domotics devices
