Page 139 of 184
Screensaver
Posted: Saturday 02 September 2017 21:40
by PieterS
Try to configure a screensaver in Dashticz on my tablet at the wall.
syntax in the wiki:
var columns_standby = {}
columns_standby[1] = {}
columns_standby[1]['blocks'] = ['clock','currentweather_big','weather']
This syntax gives results! After a while there is a screensaver. I don't understand the other syntax in my config.js:
config['standby_after'] = 3;
config['auto_swipe_back_to'] = 1;
config['auto_swipe_back_after'] = '15';
config['auto_slide_pages'] = 0;
Can you explain these commands to me? Thnx in advance.
Posted: Sunday 03 September 2017 8:54
by lukbe
Hello, is possible change a position in the buienradar to Czech Republic?
Odesláno z mého MI 4W pomocí Tapatalk
Posted: Sunday 03 September 2017 10:38
by EdwinK
I don't think so. Buienradar is aimed at the Netherlands.
Posted: Sunday 03 September 2017 21:20
by Phantom
lukbe wrote: Sunday 03 September 2017 8:54 Hello, is possible change a position in the buienradar to Czech Republic?
The website is in dutch but maybe this link will help you a bit: https://www.buienradar.nl/wereldwijd/eu ... d/tsjechie
At the bottom you can insert a city.
Re: Screensaver
Posted: Monday 04 September 2017 9:09
by htilburgs
Al these syntaxes are explained in the Wiki: http://www.domoticz.com/wiki/Dashticz_V ... figuration ;)
Standby option:
config['standby_after'] - [MINUTES] - Enter the amount of minutes before entering stand-by mode
These are not standby options. You can let Dashticz automatic swipe between your screens, if you've multiple screens
config['auto_swipe_back_to'] - [SCREEN NR]- When no activity, swipe back to the selected screen
config['auto_swipe_back_after'] - [SECONDS] - Define the seconds after swiping back to the selected screen
config['auto_slide_pages'] - false / [SECONDS] - Loop all pages and change page every x (min. 5) seconds, set config['auto_swipe_back_after'] = 0
Re: Screensaver
Posted: Monday 04 September 2017 9:19
by htilburgs
PieterS wrote: Saturday 02 September 2017 21:40 Try to configure a screensaver in Dashticz on my tablet at the wall.
syntax in the wiki:
Standby option:
Posted: Monday 04 September 2017 21:59
by PieterS
Sorry for my omission! I missed that paragraph. :?
Thanks a lot for your hint.
Posted: Tuesday 05 September 2017 8:59
by htilburgs
PieterS wrote: Monday 04 September 2017 21:59
I hope you succeed! Otherwise we see you back soon and we will try to help you :D
Posted: Tuesday 05 September 2017 15:34
by godomogo
I just got Dashticz beta up and running and changed some settings via the "gear" configuration button in the upper right corner. I hid the title bar and now it and the the configuration button are gone.
I've tried this in CONFIG.js, but the top bar and config button are still missing.
config['hide_topbar'] = '0';
How can I get these back?
Posted: Tuesday 05 September 2017 20:56
by Douwe63
godomogo wrote: Tuesday 05 September 2017 15:34 I just got Dashticz beta up and running and changed some settings via the "gear" configuration button in the upper right corner. I hid the title bar and now it and the the configuration button are gone.
I just started with Dashticz and noticed that, by default, all settings in the CONFIG.js are 'commented out' by the /* and */ character codes. If these appear at the top and bottom of your CONFIG.js file then remove these and try again...
Posted: Wednesday 06 September 2017 17:43
by godomogo
robgeerts wrote: Thursday 24 August 2017 23:03 Ok, do you mean you just want to see the floorplan like you see in domoticz?
Yeah, I think this would be awesome to be able to put existing floorplans in screens[x]. Another option people might like is a button.floorpan setup to pop up a window/frame.
Posted: Wednesday 06 September 2017 20:08
by godomogo
Douwe63 wrote: Tuesday 05 September 2017 20:56
Turns out I had some syntax errors elsewhere in CONFIG.js. That's all fixed and this is looking GREAT!
Posted: Wednesday 06 September 2017 21:23
by robgeerts
Added the floorplan to github...
Unfortunately, I'm on vacation until 23th of september so wont be working on this before this date.
(And I have first some other things to fix)
Posted: Wednesday 06 September 2017 21:36
by Phantom
robgeerts wrote: Wednesday 06 September 2017 21:23 Added the floorplan to github...
Enjoy your holiday :D
Dashticz - Two Questions
Posted: Thursday 07 September 2017 13:38
by Cletus
Got two questions for Dashticz.
First, i can't seem to figure out how to add scene's to Dashticz. It just don't sees them. Checked the IDXes and everything. This is the block i use:
Am i doing something wrong?
blocks['blocktitle_1'] = {}
blocks['blocktitle_1']['title'] = 'Scenes';
blocks['s1'] = {}
blocks['s1']['width'] = 2; //1 to 12, remove this line if you want to use the default (4)
blocks['s1']['title'] = 'Living room' //if you want change the name of switch different then domoticz
blocks['s6'] = {}
blocks['s6']['width'] = 2;
blocks['s4'] = {}
blocks['s4']['width'] = 2;
blocks['s3'] = {}
blocks['s3']['width'] = 2;
blocks['s2'] = {}
blocks['s2']['width'] = 2;
var columns = {}
columns[1] = {}
columns[1]['blocks'] = ['blocktitle_1','s1','s2','s3','s4']
columns[1]['width'] = 2;
Second, i want to add two push-on buttons, the normal IDX buttons are added but as soon as i add these two it won't work. Do you have any idea why?
For example this is the JSON data:
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 255,
         "CustomImage" : 0,
         "Data" : "On",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 8,
         "HardwareName" : "Dummy Switches",
         "HardwareType" : "Dummy (Does nothing, use for virtual switches only)",
         "HardwareTypeVal" : 15,
         "HaveDimmer" : true,
         "HaveGroupCmd" : true,
         "HaveTimeout" : false,
         "ID" : "0001408B",
         "Image" : "Light",
         "IsSubDevice" : false,
         "LastUpdate" : "2017-07-01 21:56:25",
         "Level" : 0,
         "LevelInt" : 0,
         "MaxDimLevel" : 100,
         "Name" : "Thuis",
         "Notifications" : "false",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Protected" : false,
         "ShowNotifications" : true,
         "SignalLevel" : "-",
         "Status" : "On",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "Switch",
         "SwitchType" : "On/Off",
         "SwitchTypeVal" : 0,
         "Timers" : "false",
         "Type" : "Light/Switch",
         "TypeImg" : "lightbulb",
         "Unit" : 1,
         "Used" : 1,
         "UsedByCamera" : false,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "59"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "Off",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 8,
         "ID" : "0001408C",
         "Image" : "Light",
         "LastUpdate" : "2017-05-20 16:45:49",
         "Level" : 0,
         "LevelInt" : 0,
         "Name" : "Weg",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Status" : "Off",
         "StrParam1" : "",
         "StrParam2" : "",
         "Timers" : "false",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "60"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "Off",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 8,
         "ID" : "0001408D",
         "Image" : "Light",
         "LastUpdate" : "2017-05-16 14:10:59",
         "Level" : 100,
         "LevelInt" : 100,
         "Name" : "Nacht",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Status" : "Off",
         "StrParam1" : "",
         "StrParam2" : "",
         "Timers" : "false",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "61"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "On",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 8,
         "ID" : "0001408E",
         "Image" : "Light",
         "LastUpdate" : "2017-06-27 22:01:54",
         "Level" : 0,
         "LevelInt" : 0,
         "Name" : "Manual",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Status" : "On",
         "StrParam1" : "",
         "StrParam2" : "",
         "Timers" : "false",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "62"
Regards, Paul
Re: Dashticz - Two Questions
Posted: Thursday 07 September 2017 17:49
by HansieNL
Do you have var blocks = {} ?
Posted: Thursday 07 September 2017 19:38
by Cletus
As far as i can see yes.
Posted: Thursday 07 September 2017 20:35
by HansieNL
Maybe you can post your config.js? Are you using stable or beta version of Dashticz?
Posted: Thursday 07 September 2017 22:18
by Cletus
Surething! Using the one from GIT Hub, downloaded it this week.
var _EDIT_MODE = false;
var config = {}
config['domoticz_ip'] = 'http://192.168.2.253:8080';
config['default_news_url'] = 'http://www.nu.nl/rss/algemeen';
config['news_scroll_after'] = '7';
config['standby_after'] = 0;
config['auto_swipe_back_after'] = '10';
config['slide_effect'] = 'slide';
config['standard_graph'] = 'hours';
config['language'] = 'en_US';
config['timeformat'] = 'DD-MM-YY HH:mm';
config['calendarformat'] = 'dd DD.MM HH:mm';
config['calendarlanguage'] = 'en_US';
config['calendarurl'] = '---masked---';
config['boss_stationclock'] = 'RedBoss';
config['gm_api'] = '---masked---';
config['gm_zoomlevel'] = '10';
config['gm_latitude'] = '52.497911';
config['gm_longitude'] = '4.959753';
config['wu_api'] = '---masked---';
config['wu_city'] = 'Purmerend';
config['wu_name'] = 'Weer Purmerend';
config['wu_country'] = 'NL';
config['idx_moonpicture'] = 1;
config['switch_horizon'] = 0;
config['host_nzbget'] = 0;
config['spot_clientid'] = 0;
config['garbage_company'] = 0;
config['garbage_icalurl'] = 0;
config['garbage_zipcode'] = 0;
config['garbage_street'] = 0;
config['garbage_housenumber'] = 0;
config['garbage_maxitems'] = 0;
config['garbage_width'] = 0;
config['selector_instead_of_buttons'] = 0;
config['auto_positioning'] = 1;
config['use_favorites'] = 1;
config['last_update'] = 1;
config['hide_topbar'] = 0;
config['hide_seconds'] = 0;
config['hide_seconds_stationclock'] = 0;
config['use_fahrenheit'] = 0;
config['use_beaufort'] = 0;
config['translate_windspeed'] = 1;
config['static_weathericons'] = 0;
config['hide_mediaplayer'] = 0;
var trashnames = {}
trashnames['Gft'] = 'GFT';
trashnames['Pmd'] = 'Plastic';
trashnames['Rest'] = ''; //LEAVE EMPTY IF YOU WANT TO HIDE IT
var calendars = {}
calendars.private = { key:'private', width:6, maxitems: 4, icalurl: '---masked---' }
var publictransport = {}
publictransport.ovinfobus = { show_via: false, station: 'purmerend/bushalte-bovenlandsestraat', provider: '9292-bus', icon: 'bus', width:5, results: 6 }
var tvguide = {}
tvguide.dutch = { key:'dutch', icon: 'fa-television', width:7, channels: [1,3,4,31,46,92], maxitems: 5 }
var maps = {}
maps.purmerend = { key:'purmerend', height: 300, link:'http://www.ovzoeker.nl', width:12, latitude: 52.497911, longitude: 4.959753, zoom:9 }
var _STREAMPLAYER_TRACKS  	= [
	{"track":1,"name":"Q-music","file":"http://icecast-qmusic.cdp.triple-it.nl/Qmusic_nl_live_96.mp3"},
	{"track":2,"name":"538 Hitzone","file":"http://vip-icecast.538.lw.triple-it.nl/WEB11_MP3"},
	{"track":3,"name":"Slam! NonStop","file":"http://stream.radiocorp.nl/web10_mp3"},
	{"track":4,"name":"100%NL","file":"http://stream.100p.nl/100pctnl.mp3"},
var buttons = {}
buttons.buienradar = { key: 'buienradar', width:12, isimage:true, image: 'http://api.buienradar.nl/image/1.0/RadarMapNL?w=285&h=256', url: 'http://www.weeronline.nl/Europa/Nederland/Purmerend/4058348'}
buttons.tweakers = {key: 'tweakers',  width:12, icon: 'fa-newspaper-o', title: 'Tweakers', url: 'https://www.tweakers.net'}
buttons.nunl = {key: 'nunl',  width:12, icon: 'fa-newspaper-o', title: 'Nu.nl', newwindow:true, url: 'http://www.nu.nl'}
buttons.nos = {key: 'nos',  width:12, icon: 'fa-newspaper-o', title: 'Nos', url: 'http://www.nos.nl'}
buttons.domoticz = {key:'log', width:12, icon:'fa-microchip', title: 'Domoticz Log', log:true, level: 2}
//buttons.nunl = {key: 'nunl',  width:12, icon: 'fa-newspaper-o', title: 'Nu.nl', newwindow:true, url: 'http://www.nu.nl'}
//buttons.nos = {key: 'nos',  width:12, icon: 'fa-newspaper-o', title: 'Nos', url: 'http://www.nos.nl'}
var blocks = {}
blocks['s1'] = {}
blocks['s6'] = {}
blocks['s4'] = {}
blocks['s3'] = {}
blocks['s2'] = {}
blocks['news_1'] = {}
blocks['news_1']['feed'] = 'https://cors-anywhere.herokuapp.com/http://www.nu.nl/rss/Algemeen';
blocks['news_1']['maxheight'] = 113;
blocks['news_2'] = {}
blocks['news_2']['feed'] = 'https://cors-anywhere.herokuapp.com/http://feeds.feedburner.com/tweakers/nieuws';
blocks['news_2']['maxheight'] = 113;
var columns = {}
columns['bar'] = {}
columns[1] = {}
columns[2] = {}
columns[2]['blocks'] = ['currentweather_big','weather',publictransport.ovinfobus,calendars.private]
columns[2]['width'] = 5;
columns[3] = {}
columns[3]['blocks'] = [buttons.buienradar,'sunrise','stationclock',buttons.nunl,buttons.nos]
columns[3]['width'] = 2;
columns[8] = {}
columns[8]['blocks'] = [buttons.domoticz,'sunrise']
columns[8]['width'] = 2;
buttons.moon = {width:6, isimage:true, refreshimage:60000, image: 'moon'}
columns[5] = {}
columns[5]['blocks'] = [buttons.buienradar, buttons.nunl, buttons.radio, buttons.moon]
columns[5]['width'] = 4;
columns[6] = {}
columns[6]['blocks'] = ['traffic','train',maps.purmerend]
columns[6]['width'] = 5;
columns[7] = {}
columns[7]['blocks'] = ['log','news_1','news_2']
columns[7]['width'] = 5;
columns_standby[1]['blocks'] = ['clock','weather']
var screens = {}
screens[1] = {}
screens[1]['background'] = 'bg9.jpg';
//screens[1]['background_morning'] = 'bg_morning.jpg';
//screens[1]['background_noon'] = 'bg_noon.jpg';
//screens[1]['background_afternoon'] = 'bg_afternoon.jpg';
//screens[1]['background_night'] = 'bg_night.jpg';
screens[2] = {}
screens[2]['background'] = 'bg9.jpg';
screens[2]['columns'] = [5,6,7]
Posted: Thursday 07 September 2017 22:39
by HansieNL
I'm not sure, but Maybe you can change both to 0 and see if that solves your problem
config['auto_positioning'] = 0;
config['use_favorites'] = 0;
If you don't see your other switches you have to create these as blocks. You can find how to do that in the wiki.
