raymond
Domoticz version: V4.10232
Post by raymond »
Is your IP correct and are you using Favorites in Domoticz?
I would still try to add a switch in your columns like I suggested above, just to check if it shows up
madpatrick
Domoticz version: 2026.1
Post by madpatrick »
raymond wrote: Friday 11 August 2017 11:23 Is your IP correct and are you using Favorites in Domoticz?
IP is correct. This is the same as in de popup. When i change this, the sensors and favorites dissapear.
Favorites are working in Domoticz and visable when i use popup configuration
IDX added, but just an empty line.
raymond
Post by raymond »
Clear your browser cache? Just trying to think out loud what it could be.
I had some troubles at start but in the end when you copy over the settings from the browser popup into CONFIG.js it works flawless over here.
madpatrick
When it press F12, isee the following error:
main.js?v=1502444821409:801 Domoticz error!
Please, double check the path to Domoticz in Settings!
This not is appearing when i use the popup setting
raymond
Post by raymond »
Did you set local IP adresses to acces Domoticz without login/password?
Go to Settings in Domoticz and check this in the System tab:
Local Networks (no username/password):
In here you can define your local network not needing a password to access
madpatrick
raymond wrote: Friday 11 August 2017 11:51 Did you set local IP adresses to acces Domoticz without login/password?
No password set in Domoticz.
But i put in other IDX numbers, and now i see the sensors ;) ;)
We are getting there.....
madpatrick
Groups are not working with the IDX.
Is this an other setting ?
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
For groups you have to put an s in front, like:
columns[1]['blocks'] = ['s1','s2']
raymond
Post by raymond »
Great !
I might be off here.. but typically your settings in the browser popup are used when the values are not found in your CONFIG.js file.
When something significant changes in de settings pop-up in the browser, I copy over these settings in my CONFIG.js file every now and then.
madpatrick
robgeerts wrote: Friday 11 August 2017 12:10 For groups you have to put an s in front, like:
Great !!
This is also working now !!
raymond
Post by raymond »
Yes! In addition you can use 'graph_x'
Sometimes a block is presenting 2 values (kWh devices for example) which you can define to single out by using 'x_1' or 'x_2'
where x is the IDX number of your switch in Domoticz. And don't forget to put this in ' ' :)
EDIT:
It might be an idea of keeping track of these things somewhere, in additon how to declare the default blocks.
I have the same thing going on understanding how to define the screens for different devices etc.
The Wiki can't keep up with the speed of changes in the beta !!! :D
femuruy
Help Needed
Post by femuruy »
Hi guys in first place plz apologize but i am very very new to domoticz and even newer to dashticz!
i have just installed Dashticz and connected it to my domoticz but i have 50 working switches and i can only see 25 of them on dashticz? also looks like my screen is divided into 3 columns (and only the leftmost one is populated with my switches) so how do i delete the columns i do not want and how do i get all my switches to show?
thank you in advance for your help!
Femur
robgeerts
Post by robgeerts »
By default, all your switches are placed in column 1, if you want to move some of the switches to column 2 or 3 you have to define it like this example. de numbers are de IDX of the device in Domoticz (you can find it on the Hardware-tab in Domoticz). The ones with the 's' in front are scenes/groups.
var columns = {}
columns['bar'] = {};
columns['bar']['blocks'] = ['logo', 'miniclock', 'settings'];
columns[1] = {};
columns[1]['blocks'] = [233, 62, 117, 110, 's1', 's2', '144_2', 295, 204];
columns[1]['width'] = 5;
columns[2] = {};
columns[2]['blocks'] = ['currentweather_big', 'weather', 324,174, 145, 284, 286, 287, '150_1', '150_2', '151_1', 5, 97, 301, 302];
columns[2]['width'] = 5;
columns[3] = {};
columns[3]['blocks'] = ['sunrise', 'streamplayer'];
columns[3]['width'] = 2;
femuruy
Post by femuruy »
hi thanks for the reply, is it possible to have just one column, full screen width and all my switches in there without having to write 50 different IDXs?
robgeerts
Post by robgeerts »
Download latest beta and add to config.js:
config['default_columns'] = 1;
femuruy
Post by femuruy »
thanks mate!
femuruy
Post by femuruy »
Rob... i hid the new config button and top bar... how do i unhide it?
robgeerts
Post by robgeerts »
In config.js, find:
config['hide_topbar'] = 1;
and change it to:
config['hide_topbar'] = 0;
MsbS
Post by MsbS »
My news (rss) block seems to have disappeared after the upgrade - anyone with similar issues? Can any of you share a link to any working RSS, so I could check if this is just my misconfigured CONFIG.js?
robgeerts
Post by robgeerts »
whats your current config.js?
Locked
