Page 135 of 184
Posted: Wednesday 09 August 2017 19:27
by robgeerts
Sorry dont know how to password protect a directory on a pi..maybe Google or another user knows the answer?
Posted: Wednesday 09 August 2017 21:13
by HansieNL
rednas wrote: Wednesday 09 August 2017 9:53 Is it right that it doesn't show a login screen when opening Dashticz?
That means that it is open to everyone and I don't want that.
How can I add this?
Maybe you can create a link from a password protected page to the Dashticz page.
Posted: Wednesday 09 August 2017 21:32
by rednas
Yes, is ofcourse possible but this still means that the page is accessible without a password if you go directly to it!
Re: Help, no data in dashticz!
Posted: Wednesday 09 August 2017 22:42
by klaasnicolaas
Nice that it has been solved ;) :lol:
Posted: Wednesday 09 August 2017 23:25
by avdw72
Please add the next lines to the nl_NL.json.
"energy_delivered": "Totaal geleverd",
"energy_deliveredtoday": "Vandaag geleverd",
"gas_usage": "Gasverbruik",
Dimmer as a simple switch
Posted: Thursday 10 August 2017 11:57
by edwin
So, I have 3 dimmers setup in dashticz that I would like to operate as a normal switch.
I can easily remove the slider in custom/custom.css:
.slider16 {display: none;}
The problem is, however, if I change the width to the default 4 for simple switches, the icon-data ratio is still set to the standard 2-10 that is used for dimmers. The width of 2 for the icon is too small for a decent icon size, resulting in the text being wrapped underneath the icon.
For now, I circumvented this by creating a group with just one lamp set to a specific brightness. This works, but obviously doesn't show the brightness setting, which I do like (so I can see if it has been tempered with using the physical switch :) )
Any suggestions?
Posted: Thursday 10 August 2017 14:48
by ztorm
I have a question about scenes/groups in my dashboard. I have made some scenes/groups that set multiple lamps to different levels or just switch them on/off. The scenes/groups are implemented in my dashboard as a switch (on/off different colors). The problem is now that all the scenes/groups are switched on (status on in the dashboard) when I turn on a lamp with the switch of the lamp, even when the lamp isn't represented as 'on' in the scene/group. Is it possible that the switches of the scenes/groups are only on when I switch them on?
Posted: Friday 11 August 2017 9:17
by edwin
I have a question about scenes/groups in my dashboard [...]
Hi ztorm. I think this may not be so much be a dashticz thing, but a general domoticz issue, as dashticz is simply showing the status that domoticz passes on. What does it look like in Domoticz?
What you could try is changing scenes to groups, and play around a bit with that (groups can be turned off, scenes cannot...)
Posted: Friday 11 August 2017 9:41
by madpatrick
I've installed Dashticz and it is running, only the configuration with config.js is not working.
Changing the settings in Dashticz configuration screen is working per station. When i make the changes config.js it makes no difference.
Posted: Friday 11 August 2017 9:47
by robgeerts
What does your current config.js look like?
Posted: Friday 11 August 2017 9:58
by madpatrick
robgeerts wrote: Friday 11 August 2017 9:47 What does your current config.js look like?
var config = {}
config['domoticz_ip'] = 'http://192.168.1.1:9200';
config['default_news_url'] = 'http://www.nu.nl/rss/algemeen';
config['news_scroll_after'] = '7';
config['standby_after'] = 0;
config['auto_swipe_back_to'] = 1;
config['auto_swipe_back_after'] = '10';
config['auto_slide_pages'] = 0;
config['slide_effect'] = 'slide';
config['standard_graph'] = 'hours';
config['language'] = 'nl_NL';
config['timeformat'] = 'DD-MM-YY HH:mm';
config['calendarformat'] = 'dd DD.MM HH:mm';
config['calendarlanguage'] = 'nl_NL';
config['calendarurl'] = 0;
config['boss_stationclock'] = 'RedBoss';
config['gm_api'] = 0;
config['gm_zoomlevel'] = 0;
config['gm_latitude'] = 0;
config['gm_longitude'] = 0;
config['wu_api'] = 0;
config['wu_city'] = 'Amsterdam';
config['wu_name'] = 0;
config['wu_country'] = 'NL';
config['idx_moonpicture'] = 0;
config['switch_horizon'] = 0;
config['host_nzbget'] = 0;
config['spot_clientid'] = 0;
config['garbage_company'] = 0;
config['garbage_icalurl'] = 0;
config['garbage_zipcode'] = 0;
config['garbage_street'] = 0;
config['garbage_housenumber'] = 0;
config['garbage_maxitems'] = 0;
config['garbage_width'] = 0;
config['selector_instead_of_buttons'] = 0;
config['auto_positioning'] = 1;
config['use_favorites'] = 1;
config['last_update'] = 1;
config['hide_topbar'] = 0;
config['hide_seconds'] = 0;
config['hide_seconds_stationclock'] = 0;
config['use_fahrenheit'] = 0;
config['use_beaufort'] = 0;
config['translate_windspeed'] = 1;
config['static_weathericons'] = 0;
config['hide_mediaplayer'] = 0;
var trashnames = {}
trashnames['Gft'] = 'GFT';
trashnames['Pmd'] = 'Plastic';
trashnames['Rest'] = ''; //LEAVE EMPTY IF YOU WANT TO HIDE IT
var publictransport = {}
publictransport.ovinfobus = { show_via: false, station: 'son-en-breugel/bushalte-penseelkever', provider: '9292-bus', icon: 'bus', width:5, results: 6 }
var tvguide = {}
tvguide.dutch = { key:'dutch', icon: 'fa-television', width:7, channels: [1,3,4,31,46,92], maxitems: 5 }
var _STREAMPLAYER_TRACKS  	= [
	{"track":1,"name":"Q-music","file":"http://icecast-qmusic.cdp.triple-it.nl/Qmusic_nl_live_96.mp3"},
	{"track":2,"name":"538 Hitzone","file":"http://vip-icecast.538.lw.triple-it.nl/WEB11_MP3"},
	{"track":3,"name":"Slam! NonStop","file":"http://stream.radiocorp.nl/web10_mp3"},
	{"track":4,"name":"100%NL","file":"http://stream.100p.nl/100pctnl.mp3"},
var buttons = {}
buttons.nunl = {key: 'nunl',  width:12, icon: 'fa-newspaper-o', title: 'Nu.nl', newwindow:true, url: 'http://www.nu.nl'}
buttons.nos = {key: 'nos',  width:12, icon: 'fa-newspaper-o', title: 'Nos', url: 'http://www.nos.nl'}
var blocks = {}
blocks['blocktitle_1'] = {}
blocks['blocktitle_1']['key'] = 'blocktitle_1';
blocks['blocktitle_1']['title'] = 'Example';
var columns = {}
columns['bar'] = {}
columns[1] = {}
columns[1]['blocks'] = ['currentweather_big','weather','garbage']
columns[1]['width'] = 5;
columns[2] = {}
columns[2]['blocks'] = ['blocktitle_1']
columns[2]['width'] = 5;
columns[3] = {}
columns[3]['blocks'] = ['sunrise']
columns[3]['width'] = 2;
var columns_standby = {}
columns_standby[1] = {}
columns_standby[1]['blocks'] = ['clock','weather']
var screens = {}
screens[1] = {}
screens[1]['background'] = 'bg6.jpg';
Posted: Friday 11 August 2017 10:05
by raymond
I had this too, you should remove the /* at the top and the */ at the bottom of the file, otherwise the whole settings are "commented out"
Posted: Friday 11 August 2017 10:06
by robgeerts
Remove the /* at the beginning and the */ at the end ;)
Posted: Friday 11 August 2017 10:23
by madpatrick
thanks !!
This worked, but now i don't see my sensors any more... :? :?
Posted: Friday 11 August 2017 10:28
by robgeerts
When you change the settings via de popup, after saving you get a code you have to put into config.js...
Posted: Friday 11 August 2017 11:04
by madpatrick
robgeerts wrote: Friday 11 August 2017 10:28 When you change the settings via de popup, after saving you get a code you have to put into config.js...
I've done this.
The strange thing is that every change in config.js is visable, but the domoticz buttons are not displayed any more.
When is put back */ in the script and run with the popup settings, i can see the domoticz buttons.
Posted: Friday 11 August 2017 11:05
by robgeerts
Ip correct???
Posted: Friday 11 August 2017 11:10
by raymond
You don't have any buttons/devices defined in your columns, although you did specify to use Domoticz favorites. Are you using Favorites in Domoticz?
Can you try to add a switch replaceing this part <switchIDX> ?
columns[1] = {}
columns[1]['blocks'] = [<switchIDX>,'currentweather_big','weather','garbage']
So for eaxmple:
columns[1] = {}
columns[1]['blocks'] = [10,'currentweather_big','weather','garbage']
Posted: Friday 11 August 2017 11:15
by robgeerts
Using favorites only works if auto positioning is set to 1
Posted: Friday 11 August 2017 11:16
by madpatrick
This is my latest config:
var config = {}
config['app_title'] = 'Dashticz Control Panel';
config['standard_graph'] = 'month';
config['gm_api'] = 'key';
config['wu_api'] = '25cd31fb44aab3bd';
config['wu_city'] = 'pws:IHELLEVO2';
config['wu_name'] = 'Hellevoetsluis';
config['spot_clientid'] = 'key';
config['garbage_company'] = 'deafvalapp';
config['garbage_zipcode'] = '5692VG';
config['garbage_street'] = 'Hoogstraat';
config['garbage_housenumber'] = '3';
config['garbage_maxitems'] = '5';
config['garbage_width'] = '5';
config['static_weathericons'] = 1;
var trashnames = {}
publictransport.ovinfobus= { show_via: false, station: 'son-en-breugel/bushalte-penseelkever', provider: '9292-bus', icon: 'bus', width:5, results: 6 }
var tvguide = {}
var calendars = {}
calendars.private = { key:'private', width:6, maxitems: 4, icalurl: 'https://calendar.google.com/calendar/ical/bladiebla/basic.ics' }
var maps = {}
maps.sonenbreugel = { key:'sonenbreugel', height: 300, link:'http://www.ovzoeker.nl', width:12, latitude: 51.5322056, longitude: 5.4870054, zoom:10 }
var buttons = {}
buttons.buienradar = { key: 'buienradar', width:12, isimage:true, image: 'http://api.buienradar.nl/image/1.0/RadarMapNL?w=285&h=256', url: 'http://www.weeronline.nl/Europa/Nederland/Son/4058667'}
buttons.tweakers = {key: 'tweakers',  width:12, icon: 'fa-newspaper-o', title: 'Tweakers', url: 'https://www.tweakers.net'}
buttons.domoticz = {key:'log', width:12, icon:'fa-microchip', title: 'Domoticz Log', log:true, level: 2}
var blocks = {}
blocks['news_1'] = {}
blocks['news_1']['feed'] = 'https://cors-anywhere.herokuapp.com/http://www.nu.nl/rss/Algemeen';
blocks['news_1']['maxheight'] = 113;
blocks['blocktitle_1']['title'] = 'Weer';
var columns = {}
columns['bar'] = {}
columns[1] = {}
columns[1]['blocks'] = [buttons.domoticz]
columns[2] = {}
columns[2]['blocks'] = ['currentweather_big','weather','news_1']
columns[3] = {}
columns[3]['blocks'] = ['blocktitle_1',buttons.buienradar,'sunrise']
columns_standby[1]['blocks'] = ['clock','currentweather_big','weather']
var screens = {}
screens[1] = {}
screens[1]['background'] = 'bg3.jpg';
