Page 134 of 184
Posted: Tuesday 08 August 2017 15:12
by homeserv
robgeerts wrote:Strange, it works when I use your config...
By the way, you can delete:
var _LANGUAGE = 'nl_NL'; //or: en_US, fr_FR, hu_HU, sw_SW
var _HOST_DOMOTICZ = 'http://192.168.250.202:8080';
var _DOMOTICZ_REFRESH = 5; //in seconds
var _DASHTICZ_REFRESH = 30; //in minutes
var _THEME = 'default'
Now I've moved the config from index.html to custom/CONFIG.js and it works on this device.
But when I move to another device (lets say my phone), I get the black screen again.
Maybe it is an initial (cache) problem?
As far as I can see the error starts at the js/main.js file#55
else if(typeof(config.language)!=='undefined'){ setLang = config.language}
Posted: Tuesday 08 August 2017 15:23
by robgeerts
That could be the problem indeed... if you refresh on your phone it works i guess?
Posted: Tuesday 08 August 2017 15:27
by homeserv
robgeerts wrote:That could be the problem indeed... if you refresh on your phone it works i guess?
No, still a black screen.
But if I move the config back to the index.html file it is working.
Posted: Tuesday 08 August 2017 16:04
by homeserv
@robgeerts, I've created an issue at github.
https://github.com/robgeerts/dashticz_v2/issues/141
If you need any assistance (testing) on this issue, please let me know (via PM, could be in Dutch)
Posted: Tuesday 08 August 2017 16:29
by avdw72
As requested my CONFIG.js. Worked fine before the update
Re: Help, no data in dashticz!
Posted: Tuesday 08 August 2017 17:28
by miesjel
EdKo66 wrote:Shouldn't the config-file start with
This isn't neccesary, the config I posted was the default one (except the IP ofcourse) and it didnt showed me the switches after i've added that line to the config.
But I did solve the problem a few minutes ago!
I had a typo.... I saved the config file as CONFIG.JS, the extension needs to be in small letters, CONFIG.js. So problem solved, thanks for the support!
Posted: Tuesday 08 August 2017 17:52
by sschouten
After i update it via git pull i get a black screen
- Spoiler: show
- var _LANGUAGE = 'nl_NL'; //or: en_US, fr_FR, hu_HU
var _HOST_DOMOTICZ = 'http://10.0.0.95:8080';
var _DOMOTICZ_REFRESH = 10; //in seconds
var _THEME = 'default'; // default = dashticz default theme
var _HOST_ZIGGO_HORIZON = ''; //e.g. http://192.168.1.3/domoticz/switch_horizon.php';
var _CLIENTID_SPOTIFY = '*********************';
var _APIKEY_WUNDERGROUND = '****************';
var _WEATHER_CITY = 'Hoofddorp';
var _WEATHER_CITYNAME = 'Hoofddorp'; //show a different city name, leave empty if same as _WEATHER_CITY
var _WEATHER_COUNTRY = 'NL';
var _USE_AUTO_POSITIONING = true; //don't want to configure positions, use auto positioning
var _USE_FAVORITES = true; //only used when using auto positioning
var _HIDE_SECONDS_IN_CLOCK = false; //do not show the seconds in the clock
var _NEWS_RSSFEED = 'http://www.nu.nl/rss/algemeen';
var _USE_FAHRENHEIT = false;
var _USE_BEAUFORT = false; //Bft instead of m/s
var _TRANSLATE_SPEED = false; //windspeed, north northwest instead of NNW
var _STANDBY_AFTER_MINUTES = false; //enter amount of minutes like: 5 (5 minutes)
var _SCROLL_NEWS_AFTER = 7000; //milliseconds, so 7000 is 7 seconds
var _SHOW_LASTUPDATE = true;
var _LASTUPDATE_FORMAT = 'DD-MM-YY HH:mm';
var _SCREENSLIDER_EFFECT = 'slide'; //'slide' or 'fade' or 'cube' or 'coverflow' or 'flip'
var _hide_topbar = true;
var _APIKEY_MAPS = 'AIzaSyB-9M_gqRF7OuoyikWgxfOr1if3A-PpXNQ';
var _MAPS_LATITUDE = '52.3026557';
var _MAPS_LONGITUDE = '4.6607214,17';
var _AUTO_SWIPEBACK_TO = 1; //when no activity, swipe back to main screen after x seconds
var _AUTO_SWIPEBACK_TIME = 10; //seconds
var buttons = {}
buttons.buienradar = {width:12, isimage:true, refreshimage:60000, image: 'http://api.buienradar.nl/image/1.0/Rada ... =285&h=256', url: 'http://www.weer.nl/verwachting/nederland/son/189656/'}
buttons.webcam = {width:12, isimage:true, refresh:2000, image: 'http://10.0.0.220/videostream.cgi?user=admin&pwd=************', url: '*********************************'}
buttons.log = {key:'log', width:12, icon:'fa-microchip', title: 'Domoticz Log', log:true, level: 2}
there is my config file.
before the update it was working
when i look at the config_default.js it is completly different from mine, do i need to change something more ?
and when a add to the index.html it is working.
Posted: Tuesday 08 August 2017 20:41
by robgeerts
Yes, some stuff has been changed...
First, get latest version (again).
If you still get a black screen, show me what your console (f12) is saying.
(FYI, the VARIABLES has been changed so I could create a settings-screen inside dashticz)
As an example, my CONFIG.js in the attachment...
Posted: Tuesday 08 August 2017 21:00
by EdwinK
Did you change the swipe thing? Swiping up/down in stead of left/right
Posted: Tuesday 08 August 2017 21:17
by robgeerts
No?
Is it still swiping, or are you just scrolling?
Posted: Tuesday 08 August 2017 21:34
by EdwinK
Nope, it's scrolling now. It's just one big page now.
Posted: Tuesday 08 August 2017 21:38
by robgeerts
And in latest version?
Posted: Tuesday 08 August 2017 21:45
by EdwinK
Just did a new pull, and now it's normal again
Posted: Tuesday 08 August 2017 22:13
by avdw72
Updated again & changed the variables. Works fine now. Thanks
Posted: Wednesday 09 August 2017 9:53
by rednas
Is it right that it doesn't show a login screen when opening Dashticz?
That means that it is open to everyone and I don't want that.
How can I add this?
Posted: Wednesday 09 August 2017 10:14
by robgeerts
Thats right, theres no login...
Since Dashticz is only build with Javascript its not really possible (well, it is, but its easy to crack
What you can do is add htaccess/htpasswd files to you dashticz directory, find more info about this at:
https://www.addedbytes.com/blog/code/pa ... -htaccess/
Posted: Wednesday 09 August 2017 11:23
by JuanUil
what small or big letters can do...
Posted: Wednesday 09 August 2017 18:33
by rednas
The link throws a 404 error, however I found some other sites.
I put the .htaccess in my www/dashboard/ folder, but no matter what I enter it doesn't do anything. It looks like it isn't able to find and/or read it.
How can I fix this?
Posted: Wednesday 09 August 2017 18:48
by robgeerts
On what device are you rumnning Dashticz?
Posted: Wednesday 09 August 2017 19:10
by rednas
A raspberry pi!
