EdwinK
Post by EdwinK »
I think option 2 would be best
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
Ok, will do!
HansieNL
Post by HansieNL »
EdKo66 wrote:I think option 2 would be best
I also prefer option 2.
Blah blah blah
Onrust
Domoticz version: 4.10717
Post by Onrust »
Regarding the selector switch: I've hidden the 0 level ("Off") in Domoticz, but Dashticz still shows it. Would be good to have it hidden in Dashticz as well.
sebasjuh
Post by sebasjuh »
I added the moonphases module to my dashticz v2 screen only I got nog everyday from weather underground a message that I exceeded the 500 calls in a day. And when I look at the log of domoticz I see that every minute the script_time_moon.lua is executed to collect the data from:
http://api.wunderground.com/api/XXXXXX/ ... Zwaag.json
I changed the local checktime in the script_time_moon.lua from 3600 to 7200 but after the change the script is still being executed every minute.
How can I change that so that the script will be executed every hour and not see that script being executed every minute in domoticz log ?
EdwinK
Post by EdwinK »
I have it run every 1800 seconds (30 min), and with the following settings and never got those emails.
Screen Shot 2017-07-23 at 14.29.54.png (41.65 KiB) Viewed 3620 times
The log will still show it runs every minute, but because of the setting of 1800 it will only connect to the server once the time has past.
sebasjuh
Post by sebasjuh »
Thanks EdKo66, i solved it with the following script:
http://domoticz.com/forum/viewtopic.php?f=38&t=8979
I now set it up that the script only runs every 60 minutes (in my opinion more than enough) and my WU api likes it also, no more messages anymore that I exceeded the limit.
TapNL
Post by TapNL »
I have created two on/off buttons.
One is an off button to turn all lights (hue) off in my house.
One is an on button to turn all lights (hue) on in my house.
They both work in the domoticz environment.
Downside is that the on button does not work in Dashticz.
Anyone a suggestion, clue or a solution?
Thx in advance.
Bigted
Domoticz version: 2020.1
Re: New Dashboard Design v2, custom positioning and multiple screens
Post by Bigted »
SuperMouse wrote:
But is it able to make the 'vandaag' default?
I also noticed that after a refresh of the screen this is also set to the first option.
I'v read most of the posts on this thread, is there a solution to this issue?
blacksn0w
Post by blacksn0w »
Just submitted a pull request for solving this, after merge and an update of your Dashticz you should see a new option in the settings menu under "Screen" Image
Bigted
Post by Bigted »
blacksn0w wrote: Just submitted a pull request for solving this, after merge and an update of your Dashticz you should see a new option in the settings menu under "Screen" Image
Perfect thanks for the fast response
robgeerts
Post by robgeerts »
I will merge this later today!
robgeerts
Post by robgeerts »
Merged ;)
EdwinK
Post by EdwinK »
Just did a git pull:
remote: Counting objects: 8, done.
remote: Compressing objects: 100% (2/2), done.
remote: Total 8 (delta 6), reused 8 (delta 6), pack-reused 0
Unpacking objects: 100% (8/8), done.
From https://github.com/robgeerts/dashticz_v2
b66d5e9..0d14407 Beta -> origin/Beta
Your configuration specifies to merge with the ref 'refs/heads/beta'
from the remote, but no such ref was fetched.
Did I do something wrong?
robgeerts
Post by robgeerts »
No, something went wrong on my side...
Branch is now called Beta, instead of beta
EdwinK
Post by EdwinK »
Ah... So just to ignore it ;)
robgeerts
Post by robgeerts »
Yeah but did it get the latest version??
You can recognize it by new files in lang-folder like: 'nl_NL.json'
EdwinK
Post by EdwinK »
Yes, got those nl.json files
raymond
Domoticz version: V4.10232
Post by raymond »
Same here, got the language files, but I keep getting this error (if it is an error at all?)
remote: Counting objects: 25, done.
remote: Compressing objects: 100% (12/12), done.
remote: Total 25 (delta 16), reused 22 (delta 13), pack-reused 0
Unpacking objects: 100% (25/25), done.
   172b844..1a881c1  Beta       -> origin/Beta
Your configuration specifies to merge with the ref 'beta'
I'm not sure if I need to do something to merge? Or just leave it alone?
Cheers,
Ray
robgeerts
Post by robgeerts »
Leave it alone if you have those files.
You can always do a clean install with the Beta
Locked
